I took delivery on my backup sets of the Renaat ND filtersfor the I1 and wanted to do some comparisons on the different levels andquality of results between each filter. Let me first state that I am not aprofessional in any way and strictly a hobbyists so my methods of evaluatingmay be a bit odd vs that of a professional.
My tests include the following –
- Single setting daytime altitude test with all lenseswith same angle, time, altitude and physical position without change of any camera settings. Image optomized from stock ND4 filter.(Completed 5-26) (No postwork on images)
(Time of test 6:45pm, Sun was just out ofthe North West at about 10 o’clock from my position with an elevation of 24.24°with the I1 shooting to the south.Sunset on day of test at 8:15 at Azimuth 279.9° at an elevation of -.83°, Golden hour was estimated at 6:46 p.m. – 7:46p.m.,)
- Single setting daytime altitude test with all lenseswith same angle, time, altitude and physical position without change of anycamera settings. Image optomized at best possible on ND16 filter to allow noticable images on the higher level filters. (No post work on images)
- Variable setting test of each filters with samerespective physical position, altitude and image (snapshot) being shot howevermaking adjustments to shutter speed, exposure settings etc (all documented) toachieve the same settings on the histogram.
- Variable setting test of each filters with similar respectivephysical flight pattern, altitude, etc (video) being shot however makingadjustments to shutter speed, exposure settings etc (all documented) to achievethe same settings on the histogram. (Right before golden hour so that a shot inthe direction of the sun is accomplished in the flight loop.
I had originally thought I was going to have some more timeto get a full comparison done on the Renaat ND filters over the Memorial Day weekendthat I purchased but even with the long weekend I found myself with very littleflight time.
I will finish the tests this weekend over the next couple ofdays including. After all I will post my opinions and personal findings afterALL of the tests are done this week and post each of the test updates on thisoriginal post.
