Cannot bind new DJI 2.4 Controller with Lightbridge
1895 2 2014-11-8
adrian
Has anyone successfully binded the new dji 2.4 controller with lightbridge on a phantom 2 with gopro ? If so can you please let me know your work flow.
My lightbridge works, I am getting image & IOS on my screen, BUT it says Controller = 0  . I have binded the controller with another phantom 2 so I know the controller works. I have upgraded the Controller, The phantom 2, Lightbridge ground & transmitter.
This is the odd part
> I push in the red LED to bind until it blinks > Turn on the controller
> the red blinking light will turn SOLID GREEN ( which means it has successfully binded )
>  BUT the yellow lights keep flashing instead of doing rapid green
* when i plug into P2 assistant it does not recognize any information from the 2.4 controller.
2014-11-8
Tahoe_Ed
Flight distance : 2605 ft
You do not bind the controller to the Lightbridge.  The controller is just a dumb ppm terminal.  You connect it to the Lightbridge via the trainer port.  If you are using the new controller with the trainer port in the back, then reverse the cable, black to the Tx and red to the ground unit.  That will work.  Map and calibrate your channels in LB Assistant and then do the same in your P2 Assistant.
2014-11-9
adrian
Thanks Tahoe, that worked!
2014-11-10
