dtburr
Hi -
I haven't managed to find the answers to these two Qs even though I am sure they are out there.
If signal is lost or the aircraft goes into failsafe and RTH mode is initiated, does the Phantom make a direct line from where it is to RTH altitude? I assume that thi is the case. If it is, it seems like a higher RTH than 20m mioght be a good idea if you are in an area with a lot of trees. Thoughts?
Also, although I'm operating mostly in open areas, in my neighborhood, a Ground Station flight is going to put this out of my view, with trees blocking, maybe a house, etc. How conservative should I be? Can I send this from my backyard, over my house, across the street where it's behind trees, etc and still have it come back in one piece as long as I stay within, say, a 200m range? All the Ground Station flights on YouTube are in wide-open scenarios. What are peoples' experiences?
