What are included in M100 set? Craft body, remote controller, battery, battery charger,GPS, extension frame accessory pack, and propellers; You need to purchase the GUIDANCE,GUIDANCE install fittings, gimbal accessories, and gimbal CanI assemble H4-3d and H3-3d gimbal on M100? Not completely. M100 uses theInspire 1 gimbal camera. Since the communication protocols are different(Inspire 1 uses the USB link while H4-3D and H3-3D use CAN link), thus theH4-3D and H3-3D will be not perfectly supported. If the N1 Video Encoder is acted inconcert with Gopro, you can connect the CVBS(AV) ports of Gopro to the N1 Video Encoder, then the imagetransmission can be exported by the HDMI or DJI Pilot App. What flight controller is used in M100?M100 uses N1 flight controller. What’s the max communication distance of M100 remote controller and whatimage transmission device it uses?The remote controller integrates a HD image transmissioninside and its max transmission distance could reach 2000. The HD imagetransmission greatly improves the transmission quality and the reliability ofcommunication. Is the M100 gimbal similar to Inspire 1 gimbal? M100 uses DJI ZENMUSE X3 gimbal camera, same to the Inspire1 gimbal. What’s the M100 battery capacity and what’s the flight time? Can we use Inspire 1 battery on M100?The battery capacity is 4500mAh and the battery voltage is 22.2V.The hovering time can reach up to 25mins. The Inspire 1 battery is notcompatible with M100 battery because of the structure difference of batteryclamp. Can M100 supports double battery compartments? What’s the maxflight time? The doublebattery compartments of DJI M100 can hold a second TB48D battery (you muststart the battery connected to the MC communication first and then anotherbattery; otherwise error warning occurs. Also, make sure both XT60 power plugsare plugged in. If you don’t need double battery supply, make sure to unplugthe XT60 plug of the spare battery compartment in case short circuit happens). What propulsion system is used inM100? Can we assemble the E800 set on M100? Since M100 uses a new custom E800 propulsion system, thusthe retailed E800 set can be assembled on the M100 directly. Differences: 1. The power and signal ports are different and notcompatible. 2. The software and hardware are different. Is the M100 GPS the same as the A2 GPS?The GPS in M100 isGPS PRO PLUS, they are compatible. But we recommended to use the A2 GPS PROPLUS. GPS PRO PLUS greatly improves the performance of anti-interference,satellites acquisition and positioning accuracy. Can we assemble the battery compartment on the upper centre plate?Yes. Users have the option to assemble the batterycompartment on the lower centre plate or upper centre plate. While assembling,please make sure the battery terminal faces the aircraft tail direction and use4 M2.5X5 screws to mount it on the extension bar. Meanwhile, adjust themounting position of battery compartment on the extension bar accordingly sothat the center of gravity could be adjusted properly (Usersneed to be aware that there is a spare through-hole on the upper plate for thewiring, but be careful of the placement of the erection column, ESC, etc. of the centre frame in case damagingthe cables). How to connect the gimbal cables? 1. Insert one end of the 10-pin gimbal cable into the 10-pin port offlight controller, and the 8-pin gimbal cable into the 8-pin port, as shown inthe pic below: 2. Insert the other end of the 10-pin gimbal cableinto the 10-pin port of the gimbal clamp, and the other end of the 8-pin gimbalcable into the 8-pin port.
How to control the inclinedinward angle to 3 degree while assembling the M100 arm? Any special fixturesneeded? No any special fixture is needed. The 3 degree compress partis installed on the aircraft by default. As the left picture shows, thecompress part should be assembled on the mounting position A and make sure the tangentplane of the arm ring coincide with the tangent plane of the compress part withscrews tightened. The propeller plane and the horizontal plane will shape a 3degree tilt.
Sketch map of MC and battery compartment side centre plateconnection
The features of output electric current and voltage on XT30 portand XT60 port? EachXT60 port and XT30 port contain the following features: Output voltage range | 2-26.1V(the output voltage stays at 22.2V instead of in a range value) | Max constant output current | |
Note: the total current of all the reserved XT60 ports and XT30ports cannot exceed 10A. Can we connect other accessories to M100? There are 5 extension ports designed on the 2 sides of thecenter frame for users to connect their devices. The five ports are XT30/XT60/GPSCAN/CAN1/UART. DoesM100 have the function of damping? What’s the range of the impact it cansupport?The M100 landing gears have the function of damping. It cansupport the impact force to the extent that when an aircraft with a 3.0 KGtakeoff weight lands at a speed of 1m/s. What’s the definition of CAN port and UART port? Onthe 2 sides of center frame there is a reserved GPS CAN port, 2 CAN1 ports(5 pin)and 2 UART ports(6 pin)for the connection with otherdevices(whileconnecting devices to the following 2 power ports, users should pay attentionto the voltage in case damage of external devices happens. Meanwhile, do notconnect other charging devices to the power port in case short circuit occursinside the flight controller). Thedefinition of CAN1 port and UART port are as follows: Does M100 have no-fly zones? Can I cancel the no-fly zone?M100 has set the airport restriction and other special flight restrictionareas. You can refer to DJI official website for more details of global flightrestriction areas( http://flysafe.dji.com/cn/no-fly). Userscan’t cancel the no-fly zones. What’s the M100 one key takeoff height?1.5m. Can we use master and slave remote controllers on M100? Yes you can. Can I use App to achieve allInspire 1 functions without using SDK functions? Yes, except the functions related tothe intelligent landing gear. Is IMU calibration on Assistant Software the same as Appcalibration? Same. What’s the max altitude it canachieve when it’s under Ready to Fly mode? Max Altitude : 3000m. What’s the functional difference between Inspire 1 and M100? Basically the same.However, Compare to Inspire 1, M100 can provide more Expansibility. For Example: 1. M100 can equip the extra devices and 1kg load 2. M100 support the onboardSDK and has extra ports 3. M100 support dual batteries 4. Lighter craft body, longer flight time … Which parameter can you adjust through the assistant Software? Firmware upgrade, SDK setting, etc. How far will the visual orientation system keep the aircraftaway from the barrier? Can this parameter be changed? The obstacle avoidance distance could be divided intoperceptive obstacle distance and brake distance. The GUIDANCE has a formula to calculate the perceptiveobstacle distance according to the current flight speed of the drone. The max brake distance before hitting an object is 2m and you may adjustthe parameter in the Assistant Software. What difference (like flight speed) can the obstacle avoidancefunction make? Before the obstacle avoidance function is on, the flight performance ofM100 stays the same as that of Inspire 1; when this function is on, it canachieve a max flight speed of up to 7m/s and the velocity is adjustable. Can Guidance be used with otherDJI flight controllers, or a third party controller? Currently it only supports N1 flight controller. The dead zone of GuidanceBelow the shaded areas are the dead zones of Guidance.
