david.p.mann
Flight distance : 18669501 ft
Point 1 - not every firmware update includes a battery firmware update. If a battery firmware update is included in the .bin file, the battery firmware will be updated at the same time as the Phantom aircraft firmware is updated.
Point 2 - In some cases, if you put a new battery in the Phantom and it is missing the latest firmware update, the Phantom may not operate and you may not be able to link to the RC.
Point 3 - YES - after you have updated the firmware in all your batteries, you can delete the .bin file from your SD card. If you buy a new battery at a later date, you should always put the latest firmware .bin file on the SD card and put it in the Phantom before starting up that battery the first time, in case it needs a firmware update.
Point 4 - Remember, when updating the Phantom aircraft firmware and/or the Phantom battery firmware, leave the Remote Control OFF and then turn on the aircraft battery. If after the gimbal dance finishes you hear only a single D-DD beep from the Phantom, no firmware update was required. However, if it starts a series of D-D-D-D beeps, then a firmware update is in progress. Wait until the beep pattern changes to D-DD, which means the update is finished and you can power off the Phantom battery. Battery firmware updates typically only take a couple minutes each. |
