SaltyDog
Hate to say it, but it is NOT the card. Bummed, to say the least. Ran tests last night on the new UHS3 card and had no luck! Brand new card, formatted in camera.
@Nick Martin - your PNY card is actually slower according to quick research online, (not intentionally putting down or denouncing your intellect) then my Sandisk Extreme PLUS. Your card is a class 10, but only a UHS rating of 1. My Sandisk is rated at a UHS3 speed so read/write is the fastest available for 'conservative' money and recommended for handling 4K video.
Here is a link for anyone that is looking for more comprehension on SD cards. (literature applies to micro SD as well)
SD Card Tests & Data Info
SD Association
All video features functioned properly along with images settings (ISO, shutter)
So my final conclusion could be corrupt software (chances very slim) or firmware issue. Did not have this issue when the drone first arrived and tested. (original firmware)
Anyways, if anyone does have this problem this is my solution that worked for me:
Pull up your DNG files in a finder window FROM THE CARD.
Open Adobe DNG Converter, and run the process from the files ON THE CARD to a new folder designated where you like.
Locate new exported files from DNG Converter and proceed to open files in LR, PS, or your application of preference. New processed files will NOT have any pink lines and still have the 'info' as the original files just slightly smaller in terms on file size.
Hope this can help anyone out there that may have this issue. Will eventually try to reinstall PS and LR for eliminate the potential for corrupted software. Thanks for your help/feedback everyone!
