How to extract high res jpegs from 4k video
44632 14 2015-6-21
Linolens
Flight distance : 501250 ft
Macao
Anyone with good experience on extracting high res stills from the I1 4k video?
Just to be clear....I'm not talking about screenshots here.
2015-6-21
jimhare
Flight distance : 239035 ft
Couple of options.    If you have Photoshop you can open the MOV and select which frame you want to edit.   Or QuickTime7 PRO can copy any frame into the buffer and paste the full res into an editor.
Or you could probably do it in your non-linear editor if you have one.
2015-6-21
GB44
Flight distance : 343848 ft
You can also do it in Final Cut Pro.
I was also put onto this webs site by an Apple tech which allows you to export multiple still images from FCP :
Its been a while since I used it though : fcpxImageExporter
http://adamteale.com/apps/fcpximageexporter/
2015-6-22
skyvideoct
Flight distance : 1136230 ft
I use GOM player which plays the files beautifully and has an extract frame button that simply works.
2015-6-22
Pgale
Flight distance : 275207 ft
If you have Premiere Pro, it's as easy as clicking a button when you have the CTI over the right spot.
2015-6-22
Flight 1
Pgale Posted at 2015-6-23 00:23
If you have Premiere Pro, it's as easy as clicking a button when you have the CTI over the right spo ...
In latest version of FCPX go to export. in the share clips menu select Save Current Frame. If Save Current Frame is not in the menu select add destination and add it to the menu.
2015-6-22
panox
Flight distance : 568819 ft
Flight 1 Posted at 2015-6-23 09:51
In latest version of FCPX go to export. in the share clips menu select Save Current Frame. If Save ...
I'm ending up with Wondershare-Player which extracts the images in full resolution into the folder C:\ProgramData\Wondershare Player\Snapshot  (Windows 7) . Each image gets its own name.
I have tried IrfanView, but here I only can get copies which must be opened in Photoshop.
A tutorial:
http://issuu.com/haraldbendschne ... ?e=7950524/13236222
2015-6-22
arunmehta
Flight distance : 120909757 ft
i always frame Grab with VLan player with SUPERB results ...very simple the picture is saved in your >documents> mypictures if you press camera icon on JLAN!!
i have printed 20X40 aerials with this method ...excellent resolution! i was shocked
2015-6-22
wes
Flight distance : 1338891 ft
Adobe Lightroom 5.6 works really good for me....
How to do it:
Open the video in Lightroom... next to the timer/counter on the play bar there is a little square... click on that and then click "capture frame" ... it will save the image to the same directory that the .mov file is in.
Each image was about 3mb from the 4k video.
2015-10-4
Mercury
There’s also a tool called Anyframe that lets you capture still frames from videos. They support Youtube videos and it looks like Vimeo support is coming, too. http://www.anyframe.net
2016-3-28
Mercury
jimhare Posted at 2015-6-22 03:41
Couple of options.    If you have Photoshop you can open the MOV and select which frame you want to  ...
Accidental post
2016-3-28
Mercury
GB44 Posted at 2015-6-22 04:12
I was also put onto this webs site by an Apple tech which allo ...
Accidental post
2016-3-28
Mercury
arunmehta Posted at 2015-6-23 03:52
i always frame Grab with J Lan player with SUPERB results ...very simple the picture is saved in you ...
Accidental post
2016-3-28
GeoSkier
Norway
Hi Guys, Reopening the post here: Do you know, if it's possible to extract the GPS position of the frame you take from the movie?
We're doing hi-res 3D modelling of cliffs and outcrops, so far we've been taking individual snaps, and it works ok, but filming the cliff, and exporting snaps from the movie goes way faster, but so far, I haven't been able to get the GPS position extracted as well.
cheers
Val
2017-4-12
Brandon Ernst
Flight distance : 59160 ft
Also wondering the same thing about location data...Would be a great feature.
2019-4-2
