When I first setup LB I made tests with both Zenmuse z-15 and GoPro and got great HDMI output to the small screen I use for my DSLR Video and TV + a monitor. Then for some time I used the IPhone and IPad mini that worked great. But now the HDMI want work on any HDMI output device.
I have upgraded and used the iOS menu to set HDMI and tried with other HDMI devices.
Any advice?
PS: I know only IOS/Android or HDMI work at one time and not both at once :-)
Thank you both. will test. The cable I use now is not the one I used when testing. I know the one I used to test is high-speed as its a original RED HDMI cable. Will try. Thank you again.
