Naza M Lite set up for F450
3785 7 2014-11-23
stan
Just built my F450 complete with a Naza M lite bound the Spektrum DX9 to the Spektrum AR8000 all OK.
When I try to connect the F450 to the computer to use the set up Assistant the Led Flashes  Red then turns to a dim Green and then goes out.
The lights ( Red & Blue ) on the bottom corner of the Naza M Lite Assistant do not light at all.
I have checked the Rx by pluging servos in and that is working OK.
Help required
Stan J
2014-11-23
Blade_Strike
Flight distance : 872694 ft
Stan make sure you have the pmu connected to the Naza correctly.
2014-11-23
stan
Blade_Strike Posted at 2014-11-24 01:55
Found the first problem I did not install the drivers for the Assistant program.
Next problem  set up as per the assistant program but when disconnected from the computer and sat as if to fly the led continues to flash red. No green at all.
Ideas please
2014-11-23
Blade_Strike
When in the assistant what flight modes are configured?
2014-11-23
stan
Blade_Strike Posted at 2014-11-24 07:18
All three flight modes can be set.
But I have Just tried again to set it up with the Naza M Assistant software but the voltage page is greyed out so I cannot change anything and the soft ware, when I use my laptop say I have low voltage hence the continuous flashing red light.
How can I get the voltage page to work
2014-11-24
Blade_Strike
Make sure your PMU is connected to x3 of the naza controller.
2014-11-24
stan
Blade_Strike Posted at 2014-11-25 03:00
Thank you that,s just cured my problems
2014-11-27
fansd5409fba
India
My drone is Not lifting up
I have 5200mah Battery and 2212 kV motors
2017-12-9
