DIY Antenna Booster for Phantom 3
123Next >
98809 104 2015-7-9
FPV Booster
The beauty of this DIY booster is no antenna mods required. You can install or remove the booster within seconds on Phantom 3 remote controller. It is cheap (cost almost nothing) and easier than any antenna mod without the hassles and risks of adding/replacing 2.4G antenna, pigtail cable and drilling holes on RC. It's widely used in RC hobby and Wi-Fi router for years.
Video shows how it works improving both RC and HD video signal
A modified PDF template for Phantom 3 antenna available for download https://drive.google.com/file/d/0B6EvPgvmsFJlc1FXR2txV1hSeWs/view?usp=sharing
• Material required: card paper, aluminum foil
• Tools required: printer, scissors, utility knife, glue, double tape (I use double tape to stick aluminium foil onto card paper)
• DIY steps:
1. Print 2 copies of the PDF template from the above download link
2. Use common sense and follow the steps below
3. https://rchelimenace.wordpress.com/how-to-build-your-own-windsurfer-antenna/
4.
2015-7-9
ScottyT
Anyone tried these?
2015-7-9
Brandon00151
Flight distance : 119137 ft
hmm interesting if it really works.
2015-7-9
P4TRI0T
Flight distance : 53645 ft
Cool idea.
2015-7-9
Willie Wonka
What works better is stand in front of your car it will make a nice reflector if it's made out of metal no fiber.
2015-7-9
Mikey14
It's really hard to believe that something that simple would make the P3P almost double in flight length. Can someone verify that this actually works?
2015-7-9
pcmeid
South Africa
Mikey14 Posted at 2015-7-10 14:05
It's really hard to believe that something that simple would make the P3P almost double in flight le ...
Does it really work?
2015-7-9
brycerichert
I don't see why it would not .... You must pay particularly attentive to pointing  your antennas perpendicular to your  bird while it's farther  away  than usual as it isn't a dohnut shapped wave anymore. Not as much signal will be seeping to the sides or behind you with this DIY "adjustment"
2015-7-10
020667
Flight distance : 14495 ft
Denmark
hahaha - and then also make a tinfoil hat with the leftovers
2015-7-10
DaGunn
Flight distance : 203117 ft
This actually works for me!  I made a pair in an hour.  Increased my flight  distance from 2000 ft to over 5800 ft.  Easy to slip on/off.  Free.
2015-7-12
paulbio
Taiwan
it's work for me a lot, thanks for share
2015-7-14
jrlink
Some one with a plotter should make these from copper sheet and 3d printed frames and sell them. I would buy one!!!1
2015-7-14
jf_slaats
Flight distance : 3114462 ft
jrlink@msn.com Posted at 2015-7-15 01:50
Some one with a plotter should make these from copper sheet and 3d printed frames and sell them. I w ...
This works like hell! Flew at least double the range (5K) not losing or weak signal once.
2015-7-15
jf_slaats
2015-7-15
heveys4
Thanks for the idea. I took it and I made them taller. Because the P3 antenns are so tall I wanted something that reflected the entire antenna.
I have not tested them out yet. I will be doing that today
booster
booster
2015-8-5
giufini
Flight distance : 399039 ft
Hi guys, I have very good news for everyone who owns a 3D printer: now you can print by yourself your "DJI Phantom 3 / Inspire 1 Range Booster" since I have published on Thingiverse.com a "ready to be printed" 3D model of a very performant and accurate parabolic antenna for your DJI drone:
http://www.thingiverse.com/thing:946565
Anyway, for everyone who don't have a 3D printer, I can sell them a printed and well finished Range Booster ready to use with aluminum coating already applied (19,00 € + shipping fees).
If you are interested, contact me at giuseppe.finizia@gmail.com.
Happy flying!
2015-8-5
Gabe R
giufini Posted at 2015-8-6 01:34
Hi guys, I have very good news for everyone who owns a 3D printer: now you can print by yourself you ...
Just printed mine out.....thank you man. What do you recommend to apply to the inside, will aluminum foil work or someone said a sheet of copper??
2015-8-5
rayrokni
Flight distance : 8139875 ft
ScottyT Posted at 2015-7-10 06:58
Anyone tried these?
Yea I have and it works
2015-8-5
rayrokni
I have , I have a post called range!!!
Check it out.
It doesn't double the range but it does help
2015-8-5
rayrokni
Go to eBay, I bought one, not received yet.
It is in a vertical format instead of horizontal, so I ll let u guys know when I receive it. Search for windsurfer p3 range booster. It's 3d printed and looked nice and neat, how it will work? I will let u know
2015-8-5
rayrokni
Gabe R Posted at 2015-8-6 10:31
Just printed mine out.....thank you man. What do you recommend to apply to the inside, will alumin ...
Copper will work too but aluminum foil easier and cheaper.
2015-8-5
giufini
Hi Gabe, adhesive aluminum foil is a valid solution  ;-)
2015-8-7
Gabe R
Printed pretty well. glued some aluminum foil to it. will be testing it later this afternoon. Not sure how to add pictures, using a macbook pro
2015-8-7
k.kavelaars
Gonna try this aswell, i have a pretty good rance allreddy one time flow 3500 meters and still decent signal, battery 53 % and a warning to go back home, so if this works it must handle 5K ?
only problem than would be the limid of the battery, i,ll keep you informed !
2015-8-7
020667
Denmark
giufini Posted at 2015-8-8 01:11
Hi Gabe, adhesive aluminum foil is the best solution, trust me  ;-)
Not really.
With copper being twice as conductive as aluminum and 6 times more conductive than steel, it makes an excellent choice as an antenna material. The increased electrical efficiency means more of your RF energy will go up and out the antenna and not be trapped, creating heat energy.
On a pure energy efficiency standpoint, copper is the best material to choose for a base station or permanently mounted antenna. More of your signal will get into the air and less RF energy will be turned into heat by the internal resistance of the metal.Any energy you use to make heat is energy you aren't using to make electromagnetic waves.
Copper Foil Tape would be a pretty good solution for those who look for extended range.Something like this.
http://www.allfoils.com/single-product/copper-foil-tape/
Cheers´
2015-8-7
rayrokni
020667@gmail.co Posted at 2015-8-8 07:08
Not really.
With copper being twice as conductive as aluminum and 6 times more conductive than stee ...
i agree,but if you wanna build one NOW, make one with foil while u getyour sheet of copper.
2015-8-7
020667
Denmark
Cool I might order.
What printer and material are you using.
thx.
2015-8-7
Gabe R
I have the lulzbot mini and used abs
2015-8-7
mtnmaddman
Not really.
Here also http://www.ebay.com/itm/15169724 ... =STRK%3AMEBIDX%3AIT
2015-8-8
mtnmaddman
rayrokni Posted at 2015-8-8 07:24
use aluminum foil or aluminum tape for now.http://www.ebay.com/itm/15169724 ... =STRK%3AMEBIDX%3AIT
2015-8-8
jayhkr
Any new results on this?  Heck, I don't know what I'm more interested in now, the antenna maker, or a 3D printer now! LOL
2015-8-8
DMB2015
heveys4 Posted at 2015-8-5 21:40
Thanks for the idea. I took it and I made them taller. Because the P3 antenns are so tall I wanted s ...
excellent idea making them longer.  have you tested them out, for the difference with, and without?
2015-8-8
giufini
020667@gmail.co Posted at 2015-8-8 07:36
Cool I might order.
thx.
Hi, I use a ZORTRAX M200 3D Printer with high-quality Z-ABS filaments.
This 3D printer is one of the most accurate and uses special filaments that assure solid and durable prints. Moreover, every single 3D printed Range Booster is perfectly hand-finished assuring the best possible quality.
If you wish to order it, please let me know how many pieces you need and your postal address and I will calculate the shipment fees.
A single Range Booster costs 19,00 Euros but if you buy multiple items I could apply a special discount.
You can pay to my Paypal ID "giuseppe.finizia@gmail.com". Every Range Booster is usually ready for the shipment within 1 day from the payment.
Best regards.
2015-8-8
Noziroh
Flight distance : 279196 ft
Denmark
#33
Those look beautiful!
2015-8-8
todor
Flight distance : 2192221 ft
Bulgaria
Thanks for sharing this! I will give a try to the handmade FPV booster first.
2015-8-9
DanH
Flight distance : 315177 ft
Ordered one on Ebay, and did a first test yesterday.
I had to depress the RTH button once the bird reached 4.04km (more than 13250 feet, or 2.51mi) because the bird had to fly back upwind.
No a single signal drop, landed with 17% battery. Total flight distance 8471m - 27792 feet
I'm pretty sure it would have reached 5km without wind.
2015-8-9
bobasbury
Flight distance : 1140502 ft
As far as copper vs. aluminum... The shield is needed for reflectivity, not conductivity.  So I would think both would work equally well.
2015-8-9
k.kavelaars
People windsurfer antenna actually works! I saw him today, fabricated and tested , normally I can in good conditions when I'm high enough fly fetch about 3,500 meters, now I was at 4,200 meters without signal loss , the limiting factor is the battery now , at 55 % it indicates you have to go back , and that's true good, you need 50 % to achieve the maximum distance and another 50 % to come back safe with a safety margin of 5 %
So more can hardly , I flew with 7 meters per second, so maybe if you fly max speed you come up even further?
2015-8-9
rayrokni
bobasbury Posted at 2015-8-9 21:24
As far as copper vs. aluminum... The shield is needed for reflectivity, not conductivity.  So I woul ...
U hit it right on the NAIL!!
2015-8-9
spheasant1
Flight distance : 3014675 ft
For everyone's information...here is a link to ebay that looks just like Giuseppe's except you can either keep them vertical or you can separate them at a 45' angle like the actual windsurfer idea:
DJI Phantom 3/Inspire 1 Controller / Video Split Range Booster ~ Windsurfer
2015-8-9
123Next >
