f550 mixer type fail.
909 3 2015-7-10
schjeldaldk
Denmark
I bought a DJI F550 with a naza-m v2, it is very nice but i have a problem.
I have set the mixer type of the drone to HexaRotorV where the front of the drone is between m1 and m2. but it is flying like the mixer type is set to HexaRotorI. my Naza-m v2 is running 4.04 firmware and the problem was also there before i updated the firmware.
If you have suggestion to what i can do to solve the problem, please post them in this thread
2015-7-10
knarfboy
Flight distance : 494508 ft
Check the cable from the ESC's M1 to M6 , do you connect each motor to the correct port. Counter clock wise from M1 to M6 , double check with the user manual.
http://download.dji-innovations. ... _Manual_v1.9_en.pdf      Page 6
download.dji-innovations.com/downloads/flamewheel/en/F550_User_Manual_v1.9_en.pdf
2015-7-10
schjeldaldk
Denmark
I have checked that all ESC's are connected right , and they were. I have also checked it in the NAZAM Assistant.
2015-7-11
DJI-Dave
Strange problem. I would disconnect everything and start again from scratch. Also reset everything in Naza Assistant and start that from scratch.
2015-7-13
