knarfboy
Flight distance : 494508 ft
The HDMI Output Module for the Phantom 3 (Pro/Adv) can export 720P real-time images via an HDMI port.
It can be used in broadcasting or video monitoring.
It supports a double-screen display, and exports real-time images via the HDMI and USB ports.
Live data of flight controls, video feedback and the aircraft’s battery levels can be exported via the HDMI Output Module.
You can also choose to switch off the data display on your app.
This module can be mounted on the back of the Phantom 3‘s remote controller.
It includes a Mini-HDMI output port, Micro-USB port, USB port and a CAN expansion port.
Here to buy: http://goo.gl/jdGjKQ
Installation Guide / more Pictures -> http://www.rcgroups.com/forums/showthread.php?t=2422113
If one then looks at the new board, which as it says in 1435 this means
which the board was produced in the 35 calendar week in 2014.
So, the whole retrofitting a large cheat?
Take it out of the design, to sell it expencive?
For what, the CAN-Bus port will be using?
