Gimbal Overload problem
2743 19 2015-7-16
stac57
Has anyone been ableto get this Gimbal Overload problem fixed on their P3P?
I'm using a Ipad2 mini and once I updated the APP my gimbal can'tkeep still.
Images look like I'm in an earth quake.
Can look at the images I'm getting
https://youtu.be/5h-w6glvOuM
DJI just keeps telling me to recalabrate everything and reenstall the APP but I have done it all 5 times and the same outcome.
Any help would be great.
2015-7-16
bastell
Flight distance : 1526929 ft
Your problem I believe is what it says it is Gimbal overloaded.Check the two clear white pins that go through the white rubber boots on the gimbal.There either too loose or to tight.They have a little clear washer type thing on the clear pins pull them off using your fingernails and re-clip them back on they should be just pushed on so the clear white pin can move up and down giving the gimbal plenty of movement.Anywho hope that helps.
2015-7-16
skylerlivingsto
I may have a fix for you.  Have you crashed your drone before this started happening?
2015-7-16
stac57
skylerlivingsto Posted at 2015-7-17 12:00
No crashes,
Everything was working great and then I updated the APP and then it started to give me the Warning.
2015-7-17
stac57
bastell Posted at 2015-7-17 07:34
Your problem I believe is what it says it is Gimbal overloaded.Check the two clear white pins that g ...
I put new 40% rubber in and the pins are not tight.
Would it be the Stoppers? doesn't like them maybe?
They are for the P3P, but Maybe I'll put the factory ones back in and see if that changes anything.
2015-7-17
bastell
stac57 Posted at 2015-7-17 23:08
Would it be the Stoppers? doesn't like them ma ...
Yep I think you have answered your own problem put them in and do a cold recalibration see what happens.
2015-7-17
rgerami222
Flight distance : 519219 ft
Why does my controller say Gimbal Overload?
2015-7-17
Dive-N-Dog
Flight distance : 1087028 ft
Its DJI's Pilot 1.2.0 app.  The latest release was made more sensitive than it should have been, at least that's what DJI is saying.  The below quote is from this thread http://forum.dji.com/thread-22152-1-1.html a while back.  A quick search of this forum results in atleast three threads about this topic.  I had this start the day I upgrade to Pilot 1.2.0 and nothing changed on Phantom 3 at all.
-Dog
DJI Posting
DJI Posting
2015-7-17
Daninho
Flight distance : 70203 ft
Dive-N-Dog Posted at 2015-7-18 06:11
Its DJI's Pilot 1.2.0 app.  The latest release was made more sensitive than it should have been, at  ...
yes its because of the new App BUT it is obviosly not a good sign when the app shows gimbal overload because that means something is not optimal with your gimbal. Mostly jello gimbals will show that and there are pahntom owners without that error message with this particular app version, so there are optimal working gimbals out there
2015-7-17
Droneless in AL
Daninho Posted at 2015-7-18 08:09
yes its because of the new App BUT it is obviosly not a good sign when the app shows gimbal overlo ...
Just received my new P3A today and went through the unboxing process. I was receiving a Gimbal Overload message right out of the box.
As I wait for an answer from DJI, should I keep this grounded until that is resolved? Or is it ok to fly but I'll have poor video/photo quality?
Thanks for your help
2015-7-17
Dive-N-Dog
Droneless in AL Posted at 2015-7-18 11:28
Just received my new P3A today and went through the unboxing process. I was receiving a Gimbal Ove ...
According to DJI it's okay to fly. As they have mentioned the tolerances were set too sensitive and they will correct it upon the next release of the pilot app.
-Dog
2015-7-17
Droneless in AL
Dive-N-Dog Posted at 2015-7-18 12:18
According to DJI it's okay to fly. As the have mentioned the tolerances were set too sensitive and ...
Appreciate the quick response Dog. Looking forward to firing this thing up in the morning!
2015-7-17
Dive-N-Dog
The jello that you mention, I found that if I have the camera full forward and was facing the sun I got jello from the two forward props. It was a reflection or light re-fraction . I was able to correct that with a lens hood that I fashioned.
-Dog
2015-7-17
Tahoe_Ed
Flight distance : 2605 ft
It is ok to fly.  The gimbal overload is being misreported by the App.  Unless your are seeing aberrations in your video you are good to go.
2015-7-17
Daninho
Dive-N-Dog Posted at 2015-7-18 12:23
The jello that you mention, I found that if I have the camera full forward and was facing the sun I ...
reflections are normal, can be solved with your sunhood or ND Filter. IF you dont have jello effect its ok, than your gimbal is good.
2015-7-18
Swiss Tony
Flight distance : 505459 ft
I had this today when I was taking off on grass that was long enough to contact the gimbal. It wasn't putting a lot of pressure on it but it must be real sensitive.
2015-7-18
bhstudios
Chile
Is there any solution for this problema at this point?
2015-7-20
alan.gvs
bhstudios Posted at 2015-7-20 19:31
After a successful flight this morning and only encountering the DJI App crashing twice, I can confirm that I had landed on slightly long grass and had message saying Gimble Overload! However, I picked up the P3 and immediately the message went back to normal operation!! Hope that helps?
2015-9-8
seahaze
skylerlivingsto Posted at 2015-7-17 00:00
Hi.  I have this Gimbal Overload problem too.  It started right after a minor crash. Can you please tell me what your potential fix is?  The gimbal goes crazy on start up.  My firmware is 1.2.6 Thank you.
2015-10-7
Italian Dronema
I had the same problem and I sent it back to DJI for repair and now it is ok I think it was the firmware they really didn't tell me what it was.
2015-11-27
