realsy
Not sure if anyone else experienced this, but my DJI pilot app just suddenly showed "No Signal" (see picture 1). I pressed the RTH button immediately to ensure that the phantom is in RTH mode whenever the connection is re-established, although I do know that the phantom would normally switch to RTH model after losing signal for several seconds automatically.However, unfortunately the connection didn't get back after around 30 senconds, which was weird becuase the phantom was only about 800ft or 250 meters away from home launch point. Then I realized that it might experience some kind of failure, so I jumped into my car and drove to the last known location as shown on the DJI pilot app. Luckily, someone found it and was standing by his front door, where it was just two blocks away. The guy was kind of mad since the phantom almost crashed onto him when the phantom was droped straight from sky (the last height data was only 272ft or 83 meters).
We believe that it should be caused by a battery or motor failure, since I have upgraded the firmware for weeks and have had 94 flights and 9hr54min of flight time, the app software and firmware have been tested and seemed to be stable and reliable. When a motor fails in the air, the software or firmware can't really do anything to return home, but drop to the ground.
We hope DJI warrenty or customer support could mitigate this. I tried to get the logs from phantom, but it doesn't seem to boot anymore. A service center might have other ways to get the logs. I have flight logs from the DJI pilot app, all control surface has correct input before crash, and the distance was only 800ft; the height was only 272ft..
I remember seeing other posts on this forum regaring crashes caused by firmware or hardware failures, but couldn't find how they ended.
