Tahoe_Ed
Flight distance : 2605 ft
Formate the SD card. Then load the update bin file from the zip download to the card. Make sure the battery has 50% or more charge. Do not turn the Tx on. Insert the card and then power the craft. Listen to the beeps. It will beep 4 time continuously while updating. The battery will update as well. The leds will flash different colors. That is all normal. Do not turn the Inspire off until you hear da-da,da. You should then be able to turn the Inspire off, remove the SD card and view the txt file in the root directory. It should say success. Delete that file and you need to move to the Tx. You can use a USB stick formatted with the bin file or a USB SD card reader using the crafts SD card. The Tx will beep. When the beeping stops and the led turns green you are done. |
