ETDroneHome
It has been established both here and on RCG that the production mount will definitely be able to hold the iPad Air. It would probably be helpful if DJI stated the maximum width the mount is able to hold securely.
For reference, the dimensions of both the iPad Air and the Galaxy Tab 4:
iPad Air: 240 mm (9.4 in) (h); 169.5 mm (6.67 in) (w); 7.5 mm (0.30 in) (d)
GT4: 243.4 x 176.4 x 8 mm (9.58 x 6.94 x 0.31 in)
As you can see, the Tab 4 is slightly wider (you would be mounting it in landscape orientation) than the Air by 6.9mm. |
