gsp171
nope, but I glued: the transmitter has two outputs and cables attach at right angles, so with the RC sitting in front of you facing normal direction, the transmitter port on the right have the cable go left,,,,, transmitter port on left have cable go right, the cable will snap into the transmitter, glue the cables to the transmitter and glue where the two cable cross each other, provides a nice solid anchor, now the left cable will run along the right edge of the RC, I glued it at two spots along the way, same on left side but up the middle of the controller (because of cable length), you just don't want them flopping around in there. |
