PV2+ V3 S1 and S2 problems in Naza
1154 8 2014-11-29
max
South Africa
Hi Everyone, I would really appreciate some guidance here.
I bought a PV2+V3, and swithcehd the software to Naza-M, to enable IOC, and RTH on the S1 and S2 switches (Upgraded Controller)
When I verify the commands on the PC, it all worlks and corresponds, and all is checked on and seems perfect.
However
When I go out and fly, S1 and S2 is in Vision+ mode, no IOC or Failsafe
PLEASE, any guidance and or tips as to what I may be doing wrong?
Regards
C
2014-11-29
mixstreme
Do You know you have to press enter to accept anything you change in assistant software?
There is also a separate RC software.....
Any screenshots of on-going issues would be great/....
2014-11-29
max
South Africa
Thank you Mixstreme, I will take some screenshots in the morning.
Even if I cycle down the Quad, restart the software, and turn the Radio on and off, the result is still the same.
In the software it shows all enabled, even when I flip the switches on the radio, it changed to the correct actions on the software
Its just outside in the field that the Phantom does not execute the commands
2014-11-29
max
South Africa
Oh, and to answer your questions correctly, yes, I have both the PT2 and RC modules running, both reports correctly
2014-11-29
rod
New Zealand
mixstreme Posted at 2014-11-30 07:36
There is al ...
Mixtreme, that's a little gem of info, I never knew that. I have just changed over to NAZA mode but haven't flown it since, so I must go and hook up to check the  settings.  If "enter" wasn't hit are you saying the software will show NAZA but the quad will still be in phantom mode? thanks for the input.
Rod
2014-11-29
mixstreme
max@kingsley.co Posted at 2014-11-30 07:59
Oh, and to answer your questions correctly, yes, I have both the PT2 and RC modules running, both re ...
Do you use the app?  is Dynamic home point selected?
The s1 switch when switched to the bottom should initiate RTH Failsafe and display yellow flashing leds.....
IOC tickbox checked in the assistant software?
will await screenies.....
2014-11-29
mixstreme
rod@voxvideopro Posted at 2014-11-30 08:11
Mixtreme, that's a little gem of info, I never knew that. I have just changed over to NAZA mode bu ...
Its not all the settings I don't think, but I've taught myself to do it just to be safe.....
Gains etc..  need the enter button to be pressed to verify the change.
2014-11-29
DJI-Autumn;-)
China
Like what @mixstreme mentioned you need check the IOC tickbox in the ASS
And how is the GPS signal there? Seems you cant use these IOC or RTH when GPS signal is feeble....
2014-12-1
max
South Africa
mixstreme Posted at 2014-11-30 08:11
The s1 switch when switched to the bottom sho ...
Thanks everybody!  Happy to report its all sorted.
I just did it all again and made sure I press enter all the time till the green leds blink rapidly, all good!
2014-12-1
