I just updated my DJI A2 and IOSD Mark II to the latest software today and now I have a problem with the OSD not showing the data form the IMU also the IMU flashes 9 times. I don't know if it was flashing before the update. Has anyone else had an issue with the OSD after updating and does their IMU flash?
I a glad everything went well for you. But can you tell me if your IMU flashes? Mine flashes 9 times is this normal? If you view your iOSD indoors does it show data or is it blank except for the main icons?
I thought so but wasn't sure there is no mention of the led flashing in the manual.
I have solved the update problem by switching the cable connecting the iOSD to the IMU from the cable with one locking end and the other just a slip in connection to the cable with both ends with the locking connection. Don't know why the last cable worked before update and then did not after update, maybe some safety feature added to the update. Sure would like to have known this before I tore everything apart.
HI,
Thanks fot your post...could you explain me a bit more how you did your connection ....I can't get my flight logs....only a line instead of parameters and when i export it it only generates O txt iles...some help?
