phil-142
Flight distance : 149964 ft
DJI Stephen Posted at 6-12 21:18
Hello there phil-142. I am sorry for the trouble and thank you for reaching out. Just a friendly reminder that the DJI Mavic 3 Pro does not have a fan, so it uses the heat sink on the bottom of the DJI drone to dissipate heat. After the DJI Mini 3 Pro is powered on and kept on a flat surface ( such as ground or a desk ) for a while, the heat dissipation will be affected, as the surface is close to the heat sink. In this case, the DJI drone should be turned off and kept idle for a while to drop its temperature before using it again. Thank you.
thank you so much for your reply. appreciated.
thank you for explaining this. it all makes sense now and what the problem is.
your time and help is most welcome. thank you. |
