Another firmware upgrade problem
12Next >
4851 42 2015-8-14
stan
Flight distance : 8834869 ft
I have upgraded my Inspire 1 few times previously without problem. It's my turn of failure this time!
Similar to other failed cases, it just sounded DDDD for about 35 minutes for upgrading AC, then a long weeeeeee.
so I didn't proceed to upgrade the RC. I checked the log txt file, it is obviously a failure. Anyway I checked the version on the Pilot App, it shows this is still v1.2.1.06.
Anyway, I format my SD card and download the firmware again, upgrade still failed, tried with other SD card, same failed, repeat many times, failed!
Once boot up, it can still connect to my RC (still v1.2.1.06 without upgrade), video is ok, control seems ok also, but it said it has gimbal calibration error everytime it boots up.
Now, what should I do?  Can't upgrade or downgrade! I have no confident to fly it, although the video link and control seem ok.
Please help!
The txt file is shown here
Result: Failed.
Reboot the aircraft and try to upgrade the firmware again.
========== 2014.01.01 00:00:03 remo-con disconnect======
Packet: WM610_FW_V01.03.00.00.bin
Result: Failed.
========== 2014.01.01 00:00:04 remo-con disconnect======
Result: Abort.
The firmware on the SD card is identical to or older than the current firmware on the aircraft.
Result: Failed.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Upgrading ...
Result: Success.
Result: Abort.
Upgrading ...
Result: Success.
Result: Abort.
Result: Abort.
Upgrading ...
Result: Success.
Packet: WM610_FW_V01.02.01.06.bin
Upgrading ...
Result: Success.
Upgrading ...
Result: Success.
Packet: WM610_FW_V01.02.01.07.bin
Result: Corrupted.
Firmware bin file is corrupted, download it again from the DJI offical website.
Result: Corrupted.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Failed.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
I also list the log txt file in the subdirectory here
[00004921][01 00] Firmware upgrade finished successfully.
[00005041]Done.
[00005070]Packet [C:\WM610_FW_V01.03.00.00.bin] resumed, card sn [0x00cea48f].
[00005103]Packet vlink 01.03.0000 <-> 01.02.0000.
[00005173]Version checking[2]...
[00005202][01 00][05] v1.19.3422 -> v1.19.3422
[00005229][01 01][00] v1.8.2729 -> v1.19.3422 need upgrade
[00005296][03 05][00] v34.1.0.5 -> v34.1.0.5
[00005375][03 06][00] v2.0.5.14 -> v2.2.6.33 need upgrade.
[00005410][04 00][00] v1.16.0.76 -> v1.26.0.3 need upgrade.
[00005475][05 00][00] v2.5.6.1 -> v3.0.6.1 need upgrade.
[00005520][08 00][00] v1.12.0.21 -> v1.14.0.25 need upgrade.
[00005567][09 00][00] v1.7.0.3 -> v1.8.0.0 need upgrade.
[00005638][11 00][00] v3.7.1.0 -> v3.7.15.9 need upgrade.
[00005738][12 00][00] v1.3.0.60 -> v1.8.0.0 need upgrade.
[00005838][12 01][00] v1.3.0.60 -> v1.8.0.0 need upgrade.
[00005895][12 02][00] v1.3.0.60 -> v1.8.0.0 need upgrade.
[00006039][12 03][00] v1.3.0.60 -> v1.8.0.0 need upgrade.
[00018584][15 00][00] device not detected.
[00018634][17 00][00] v1.1.0.1 -> v1.1.0.4 need upgrade.
[00018734][17 01][00] v2.0.0.1 -> v2.0.0.8 need upgrade.
[00018780][19 00][00] v1.0.8.96 -> v1.0.8.96
[00018808]Done.
[00018836]Firmware upgrading[2]...
[00018999][01 01] Firmware upgrade start...
[00049282][01 01] Firmware upgrade finished successfully.
[00050256][08 00] Firmware upgrade start...
[01178457][08 00] Firmware upgrade finished successfully.
[01178509][12 00] Firmware upgrade start...
[01234446][12 00] Firmware upgrade finished successfully.
[01234502][12 01] Firmware upgrade start...
[01289702][12 01] Firmware upgrade finished successfully.
[01289754][12 02] Firmware upgrade start...
[01345438][12 02] Firmware upgrade finished successfully.
[01345487][12 03] Firmware upgrade start...
[01401572][12 03] Firmware upgrade finished successfully.
[01401828][03 06] Firmware upgrade start...
[01626312][03 06] Firmware upgrade finished successfully.
[01626379][17 00] Firmware upgrade start...
[01687826][17 00] Firmware upgrade finished successfully.
[01687872][17 01] Firmware upgrade start...
[01741521][17 01] Firmware upgrade finished successfully.
[01741567][11 00] Firmware upgrade start...
[01819755][11 00] Firmware upgrade finished successfully.
[01819807][05 00] Firmware upgrade start...
[01863910][05 00] Firmware upgrade finished successfully.
[01863978][09 00] Firmware upgrade start...
[01919048][09 00] Firmware upgrade finished successfully.
[01919123][04 00] Firmware upgrade start...
[01981803][04 00] Firmware upgrade finished successfully.
[01981836]Done.
[01981865]Version checking[3]...
[01981901][01 00][05] v1.19.3422 -> v1.19.3422
[01981933][01 01][05] v1.19.3422 -> v1.19.3422
[01981997][03 05][00] v34.1.0.5 -> v34.1.0.5
[01982057][03 06][05] v2.2.6.33 -> v2.2.6.33
[01982092][04 00][05] v1.26.0.3 -> v1.26.0.3
[01982157][05 00][05] v3.0.6.1 -> v3.0.6.1
[01982199][08 00][05] v1.14.0.25 -> v1.14.0.25
[01982249][09 00][05] v1.8.0.0 -> v1.8.0.0
[01982298][11 00][05] v3.7.15.9 -> v3.7.15.9
[01982398][12 00][05] v1.8.0.0 -> v1.8.0.0
[01982498][12 01][05] v1.8.0.0 -> v1.8.0.0
[01982598][12 02][05] v1.8.0.0 -> v1.8.0.0
[01982658][12 03][05] v1.8.0.0 -> v1.8.0.0
[01987787][15 00][00] device not detected.
[01987837][17 00][05] v1.1.0.4 -> v1.1.0.4
[01987938][17 01][05] v2.0.0.8 -> v2.0.0.8
[01987977][19 00][00] v1.0.8.96 -> v1.0.8.96
[01988008]Packet upgrade failed at version checking.
[00004626]========== remo-con disconnect. boot(15) ============
[00004680]Packet [C:\WM610_FW_V01.03.00.00.bin] detected, card sn [0x00000019].
[00004725]Packet upgrade start...
[00004785]Packet checking...
[00004838]Packet vlink 01.03.0000 <-> 01.02.0000.
[00004914]Done.
[00004962]Version checking[1]...
[00005005][01 00][00] v1.19.3422 -> v1.19.3422
[00005068][01 01][00] v1.19.3422 -> v1.19.3422
[00005175][03 05][00] v34.1.0.5 -> v34.1.0.5
[00005275][03 06][00] v2.2.6.33 -> v2.2.6.33
[00005367][04 00][00] v1.26.0.3 -> v1.26.0.3
[00005539][05 00][00] v3.0.6.1 -> v3.0.6.1
[00005602][08 00][00] v1.14.0.25 -> v1.14.0.25
[00005664][09 00][00] v1.8.0.0 -> v1.8.0.0
[00005774][11 00][00] v3.7.15.9 -> v3.7.15.9
[00005894][12 00][00] v1.8.0.0 -> v1.8.0.0
[00005994][12 01][00] v1.8.0.0 -> v1.8.0.0
[00006094][12 02][00] v1.8.0.0 -> v1.8.0.0
[00006194][12 03][00] v1.8.0.0 -> v1.8.0.0
[00011048][15 00][00] device not detected.
[00011114][17 00][00] v1.1.0.4 -> v1.1.0.4
[00013739][17 01][00] v2.0.0.8 -> v2.0.0.8
[00013794][19 00][00] v1.0.8.96 -> v1.0.8.96
[00015845]Packet upgrade failed at version checking.
[00004570]========== remo-con disconnect. boot(15) ============
[00004616]Packet [C:\WM610_FW_V01.03.00.00.bin] detected, card sn [0x00000019].
[00004670]Packet upgrade start...
[00004723]Packet checking...
[00004776]Packet vlink 01.03.0000 <-> 01.02.0000.
[00004859]Done.
[00004919]Version checking[1]...
[00004987][01 00][00] v1.19.3422 -> v1.19.3422
[00005047][01 01][00] v1.19.3422 -> v1.19.3422
[00005130][03 05][00] v34.1.0.5 -> v34.1.0.5
[00005230][03 06][00] v2.2.6.33 -> v2.2.6.33
[00005303][04 00][00] v1.26.0.3 -> v1.26.0.3
[00005390][05 00][00] v3.0.6.1 -> v3.0.6.1
[00005458][08 00][00] v1.14.0.25 -> v1.14.0.25
[00005530][09 00][00] v1.8.0.0 -> v1.8.0.0
[00005610][11 00][00] v3.7.15.9 -> v3.7.15.9
[00005730][12 00][00] v1.8.0.0 -> v1.8.0.0
[00005849][12 01][00] v1.8.0.0 -> v1.8.0.0
[00005949][12 02][00] v1.8.0.0 -> v1.8.0.0
[00006049][12 03][00] v1.8.0.0 -> v1.8.0.0
[00014261][15 00][00] v1.1.2.0 -> v1.1.2.0
[00016829][17 00][00] v1.1.0.4 -> v1.1.0.4
[00016949][17 01][00] v2.0.0.8 -> v2.0.0.8
[00017003][19 00][00] v1.0.8.96 -> v1.0.8.96
[00019052]Packet upgrade cancelled at version checking.
[00004583]========== remo-con disconnect. boot(15) ============
[00004637]Packet [C:\WM610_FW_V01.03.00.00.bin] detected, card sn [0x00000019].
[00004684]Packet upgrade start...
[00004747]Packet checking...
[00004794]Packet vlink 01.03.0000 <-> 01.02.0000.
[00004946]Record vlink 01.03.0000 <-> 01.02.0000 (flow = 0).
[00005008]Done.
[00005070]Version checking[1]...
[00005139][01 00][00] v1.19.3422 -> v1.19.3422
[00005200][01 01][00] v1.19.3422 -> v1.19.3422
[00005305][03 05][00] v34.1.0.5 -> v34.1.0.5
[00005405][03 06][00] v2.2.6.33 -> v2.2.6.33
[00005467][04 00][00] v1.26.0.3 -> v1.26.0.3
[00005545][05 00][00] v3.0.6.1 -> v3.0.6.1
[00005610][08 00][00] v1.14.0.25 -> v1.14.0.25
[00005680][09 00][00] v1.8.0.0 -> v1.8.0.0
[00005767][11 00][00] v3.7.15.9 -> v3.7.15.9
[00005885][12 00][00] v1.8.0.0 -> v1.8.0.0
[00006005][12 01][00] v1.8.0.0 -> v1.8.0.0
[00006125][12 02][00] v1.8.0.0 -> v1.8.0.0
[00006237][12 03][00] v1.8.0.0 -> v1.8.0.0
[00018785][15 00][00] device not detected.
[00018885][17 00][00] v1.1.0.4 -> v1.1.0.4
[00019004][17 01][00] v2.0.0.8 -> v2.0.0.8
[00019064][19 00][00] v1.0.8.96 -> v1.0.8.96
[00021113]Packet upgrade failed at version checking.
[00004655]========== remo-con disconnect. boot(15) ============
[00004691]Packet [C:\WM610_FW_V01.03.00.00.bin] detected, card sn [0x27baf9de].
[00004727]Packet upgrade start...
[00004775]Packet checking...
[00004813]Packet vlink 01.03.0000 <-> 01.02.0000.
[00004851]Record vlink 01.03.0000 <-> 01.02.0000 (flow = 0).
[00004894]Done.
[00004949]Version checking[1]...
[00005002][01 00][00] v1.19.3422 -> v1.19.3422
[00005057][01 01][00] v1.19.3422 -> v1.19.3422
[00005139][03 05][00] v34.1.0.5 -> v34.1.0.5
[00005219][03 06][00] v2.2.6.33 -> v2.2.6.33
[00005301][04 00][00] v1.26.0.3 -> v1.26.0.3
[00005359][05 00][00] v3.0.6.1 -> v3.0.6.1
[00005413][08 00][00] v1.14.0.25 -> v1.14.0.25
[00005488][09 00][00] v1.8.0.0 -> v1.8.0.0
[00005558][11 00][00] v3.7.15.9 -> v3.7.15.9
[00005658][12 00][00] v1.8.0.0 -> v1.8.0.0
[00005758][12 01][00] v1.8.0.0 -> v1.8.0.0
[00005858][12 02][00] v1.8.0.0 -> v1.8.0.0
[00005958][12 03][00] v1.8.0.0 -> v1.8.0.0
[00006429][15 00][00] v1.1.2.0 -> v1.1.2.0
[00006501][17 00][00] v1.1.0.4 -> v1.1.0.4
[00006759][17 01][00] v2.0.0.8 -> v2.0.0.8
[00006822][19 00][00] v1.0.8.96 -> v1.0.8.96
[00008877]Packet upgrade cancelled at version checking.
[00004704]========== remo-con disconnect. boot(15) ============
[00004745]Packet [C:\WM610_FW_V01.03.00.00.bin] detected, card sn [0x27baf9de].
[00004780]Packet upgrade start...
[00004820]Packet checking...
[00004863]Packet vlink 01.03.0000 <-> 01.02.0000.
[00004910]Record vlink 01.03.0000 <-> 01.02.0000 (flow = 0).
[00004969]Done.
[00005018]Version checking[1]...
[00005076][01 00][00] v1.19.3422 -> v1.19.3422
[00005127][01 01][00] v1.19.3422 -> v1.19.3422
[00005203][03 05][00] v34.1.0.5 -> v34.1.0.5
[00005302][03 06][00] v2.2.6.33 -> v2.2.6.33
[00005347][04 00][00] v1.26.0.3 -> v1.26.0.3
[00005402][05 00][00] v3.0.6.1 -> v3.0.6.1
[00005471][08 00][00] v1.14.0.25 -> v1.14.0.25
[00005518][09 00][00] v1.8.0.0 -> v1.8.0.0
[00005602][11 00][00] v3.7.15.9 -> v3.7.15.9
[00005722][12 00][00] v1.8.0.0 -> v1.8.0.0
[00005842][12 01][00] v1.8.0.0 -> v1.8.0.0
[00005942][12 02][00] v1.8.0.0 -> v1.8.0.0
[00006022][12 03][00] v1.8.0.0 -> v1.8.0.0
[00009382][15 00][00] v1.1.2.0 -> v1.1.2.0
[00009443][17 00][00] v1.1.0.4 -> v1.1.0.4
[00009544][17 01][00] v2.0.0.8 -> v2.0.0.8
[00009592][19 00][00] v1.0.8.96 -> v1.0.8.96
[00011629]Packet upgrade cancelled at version checking.
[00004699]========== remo-con disconnect. boot(15) ============
[00004748]Packet [C:\WM610_FW_V01.03.00.00.bin] detected, card sn [0x27baf9de].
[00004783]Packet upgrade start...
[00004827]Packet checking...
[00004870]Packet vlink 01.03.0000 <-> 01.02.0000.
[00004919]Record vlink 01.03.0000 <-> 01.02.0000 (flow = 0).
[00004977]Done.
[00005027]Version checking[1]...
[00005082][01 00][00] v1.19.3422 -> v1.19.3422
[00005140][01 01][00] v1.19.3422 -> v1.19.3422
[00005214][03 05][00] v34.1.0.5 -> v34.1.0.5
[00005314][03 06][00] v2.2.6.33 -> v2.2.6.33
[00005357][04 00][00] v1.26.0.3 -> v1.26.0.3
[00005554][05 00][00] v3.0.6.1 -> v3.0.6.1
[00005601][08 00][00] v1.14.0.25 -> v1.14.0.25
[00005673][09 00][00] v1.8.0.0 -> v1.8.0.0
[00005754][11 00][00] v3.7.15.9 -> v3.7.15.9
[00005854][12 00][00] v1.8.0.0 -> v1.8.0.0
[00005953][12 01][00] v1.8.0.0 -> v1.8.0.0
[00006039][12 02][00] v1.8.0.0 -> v1.8.0.0
[00006113][12 03][00] v1.8.0.0 -> v1.8.0.0
[00007453][15 00][00] v1.1.2.0 -> v1.1.2.0
[00007554][17 00][00] v1.1.0.4 -> v1.1.0.4
[00007673][17 01][00] v2.0.0.8 -> v2.0.0.8
[00007748][19 00][00] v1.0.8.96 -> v1.0.8.96
[00009793]Packet upgrade cancelled at version checking.
[00004686]========== remo-con disconnect. boot(15) ============
[00004723]Packet [C:\WM610_FW_V01.03.00.00.bin] detected, card sn [0x00cea48f].
[00004768]Packet upgrade start...
[00004809]Packet checking...
[00004854]Packet vlink 01.03.0000 <-> 01.02.0000.
[00004891]Record vlink 01.03.0000 <-> 01.02.0000 (flow = 0).
[00004928]Done.
[00004970]Version checking[1]...
[00005007][01 00][00] v1.19.3422 -> v1.19.3422
[00005053][01 01][00] v1.19.3422 -> v1.19.3422
[00005218][03 06][00] v2.2.6.33 -> v2.2.6.33
[00005293][04 00][00] v1.26.0.3 -> v1.26.0.3
[00005378][05 00][00] v3.0.6.1 -> v3.0.6.1
[00005420][08 00][00] v1.14.0.25 -> v1.14.0.25
[00005493][09 00][00] v1.8.0.0 -> v1.8.0.0
[00005578][11 00][00] v3.7.15.9 -> v3.7.15.9
[00006068][15 00][00] v1.1.2.0 -> v1.1.2.0
[00006140][17 00][00] v1.1.0.4 -> v1.1.0.4
[00006240][17 01][00] v2.0.0.8 -> v2.0.0.8
[00006287][19 00][00] v1.0.8.96 -> v1.0.8.96
[00008326]Packet upgrade cancelled at version checking.
[00004499]========== remo-con disconnect. boot(15) ============
[00004541]Packet [C:\WM610_FW_V01.03.00.00.bin] detected, card sn [0x00cea48f].
[00004578]Packet upgrade start...
[00004616]Packet checking...
[00004756]Packet vlink 01.03.0000 <-> 01.02.0000.
[00004795]Record vlink 01.03.0000 <-> 01.02.0000 (flow = 0).
[00004837]Done.
[00004877]Version checking[1]...
[00004938][01 00][00] v1.19.3422 -> v1.19.3422
[00004987][01 01][00] v1.19.3422 -> v1.19.3422
[00005074][03 05][00] v34.1.0.5 -> v34.1.0.5
[00005174][03 06][00] v2.2.6.33 -> v2.2.6.33
[00005263][04 00][00] v1.26.0.3 -> v1.26.0.3
[00005338][05 00][00] v3.0.6.1 -> v3.0.6.1
[00005400][08 00][00] v1.14.0.25 -> v1.14.0.25
[00005467][09 00][00] v1.8.0.0 -> v1.8.0.0
[00005539][11 00][00] v3.7.15.9 -> v3.7.15.9
[00005639][12 00][00] v1.8.0.0 -> v1.8.0.0
[00005739][12 01][00] v1.8.0.0 -> v1.8.0.0
[00005839][12 02][00] v1.8.0.0 -> v1.8.0.0
[00005954][12 03][00] v1.8.0.0 -> v1.8.0.0
[00006048][15 00][00] v1.1.2.0 -> v1.1.2.0
[00006114][17 00][00] v1.1.0.4 -> v1.1.0.4
[00006214][17 01][00] v2.0.0.8 -> v2.0.0.8
[00006294][19 00][00] v1.0.8.96 -> v1.0.8.96
[00008336]Packet upgrade cancelled at version checking.
[00004509]========== remo-con disconnect. boot(15) ============
[00004551]Packet [C:\WM610_FW_V01.03.00.00.bin] detected, card sn [0x00cea48f].
[00004588]Packet upgrade start...
[00004629]Packet checking...
[00004676]Packet vlink 01.03.0000 <-> 01.02.0000.
[00004713]Record vlink 01.03.0000 <-> 01.02.0000 (flow = 0).
[00004751]Done.
[00004788]Version checking[1]...
[00004826][01 00][00] v1.19.3422 -> v1.19.3422
[00004868][01 01][00] v1.19.3422 -> v1.19.3422
[00004955][03 05][00] v34.1.0.5 -> v34.1.0.5
[00005049][03 06][00] v2.2.6.33 -> v2.2.6.33
[00005111][04 00][00] v1.26.0.3 -> v1.26.0.3
[00005189][05 00][00] v3.0.6.1 -> v3.0.6.1
[00005266][08 00][00] v1.14.0.25 -> v1.14.0.25
[00005318][09 00][00] v1.8.0.0 -> v1.8.0.0
[00005408][11 00][00] v3.7.1.0 -> v3.7.15.9 need upgrade.
[00005508][12 00][00] v1.8.0.0 -> v1.8.0.0
[00005608][12 01][00] v1.8.0.0 -> v1.8.0.0
[00005728][12 02][00] v1.8.0.0 -> v1.8.0.0
[00005828][12 03][00] v1.8.0.0 -> v1.8.0.0
[00005939][15 00][00] v1.1.2.0 -> v1.1.2.0
[00006108][17 00][00] v1.1.0.4 -> v1.1.0.4
[00006208][17 01][00] v2.0.0.8 -> v2.0.0.8
[00006293][19 00][00] v1.0.8.96 -> v1.0.8.96
[00006334]Done.
[00008381]Waiting for user confirm...
[00018419]Timeout, start upgrade automatically.
[00018494]Firmware upgrading[1]...
[00018550][11 00] Firmware upgrade start...
[00099760][11 00] Firmware upgrade finished successfully.
[00099805]Done.
[00099841]Version checking[2]...
[00099877][01 00][00] v1.19.3422 -> v1.19.3422
[00099919][01 01][00] v1.19.3422 -> v1.19.3422
[00099979][03 05][00] v34.1.0.5 -> v34.1.0.5
[00100040][03 06][00] v2.2.6.33 -> v2.2.6.33
[00100082][04 00][00] v1.26.0.3 -> v1.26.0.3
[00100161][05 00][00] v3.0.6.1 -> v3.0.6.1
[00100201][08 00][00] v1.14.0.25 -> v1.14.0.25
[00100290][09 00][00] v1.8.0.0 -> v1.8.0.0
[00100361][11 00][05] v3.7.15.9 -> v3.7.15.9
[00100440][12 00][00] v1.8.0.0 -> v1.8.0.0
[00100520][12 01][00] v1.8.0.0 -> v1.8.0.0
[00100600][12 02][00] v1.8.0.0 -> v1.8.0.0
[00100700][12 03][00] v1.8.0.0 -> v1.8.0.0
[00100799][15 00][00] v1.1.2.0 -> v1.1.2.0
[00100880][17 00][00] v1.1.0.4 -> v1.1.0.4
[00100980][17 01][00] v2.0.0.8 -> v2.0.0.8
[00101029][19 00][00] v1.0.8.96 -> v1.0.8.96
[00101067]Packet upgrade finish successfully.
[00004646]========== remo-con disconnect. boot(15) ============
[00004700]Packet [C:\WM610_FW_V01.03.00.00.bin] detected, card sn [0x00000019].
[00004756]Packet upgrade start...
[00004817]Packet checking...
[00004874]Packet vlink 01.03.0000 <-> 01.02.0000.
[00004945]Record vlink 01.03.0000 <-> 01.02.0000 (flow = 0).
[00005020]Done.
[00005096]Version checking[1]...
[00005171][01 00][00] v1.19.3422 -> v1.19.3422
[00005239][01 01][00] v1.19.3422 -> v1.19.3422
[00005348][03 05][00] v34.1.0.5 -> v34.1.0.5
[00005448][03 06][00] v2.2.6.33 -> v2.2.6.33
[00005506][04 00][00] v1.26.0.3 -> v1.26.0.3
[00005588][05 00][00] v3.0.6.1 -> v3.0.6.1
[00005668][08 00][00] v1.14.0.25 -> v1.14.0.25
[00005883][09 00][00] v1.8.0.0 -> v1.8.0.0
[00005989][11 00][00] v3.7.15.9 -> v3.7.15.9
[00006088][12 00][00] v1.8.0.0 -> v1.8.0.0
[00006188][12 01][00] v1.8.0.0 -> v1.8.0.0
[00006328][12 02][00] v1.8.0.0 -> v1.8.0.0
[00006428][12 03][00] v1.8.0.0 -> v1.8.0.0
[00006543][15 00][00] v1.1.2.0 -> v1.1.2.0
[00006629][17 00][00] v1.1.0.4 -> v1.1.0.4
[00006753][17 01][00] v2.0.0.8 -> v2.0.0.8
[00006818][19 00][00] v1.0.8.96 -> v1.0.8.96
[00008875]Packet upgrade cancelled at version checking.
[00004792]========== remo-con disconnect. boot(15) ============
[00004847]Packet [C:\WM610_FW_V01.03.00.00.bin] detected, card sn [0x00000019].
[00004903]Packet upgrade start...
[00004987]Packet checking...
[00005067]Packet vlink 01.03.0000 <-> 01.02.0000.
[00005139]Record vlink 01.03.0000 <-> 01.02.0000 (flow = 0).
[00005209]Done.
[00005296]Version checking[1]...
[00005371][01 00][00] v1.19.3422 -> v1.19.3422
[00005440][01 01][00] v1.19.3422 -> v1.19.3422
[00005539][03 05][00] v34.1.0.5 -> v34.1.0.5
[00005613][03 06][00] v2.2.6.33 -> v2.2.6.33
[00005696][04 00][00] v1.26.0.3 -> v1.26.0.3
[00005813][05 00][00] v3.0.6.1 -> v3.0.6.1
[00005904][08 00][00] v1.14.0.25 -> v1.14.0.25
[00005988][09 00][00] v1.8.0.0 -> v1.8.0.0
[00006114][11 00][00] v3.7.1.0 -> v3.7.15.9 need upgrade.
[00006213][12 00][00] v1.8.0.0 -> v1.8.0.0
[00006335][12 01][00] v1.8.0.0 -> v1.8.0.0
[00006436][12 02][00] v1.8.0.0 -> v1.8.0.0
[00006541][12 03][00] v1.8.0.0 -> v1.8.0.0
[00006648][15 00][00] v1.1.2.0 -> v1.1.2.0
[00006714][17 00][00] v1.1.0.4 -> v1.1.0.4
[00006836][17 01][00] v2.0.0.8 -> v2.0.0.8
[00006908][19 00][00] v1.0.8.96 -> v1.0.8.96
[00006962]Done.
[00009023]Waiting for user confirm...
[00019084]Timeout, start upgrade automatically.
[00019189]Firmware upgrading[1]...
[00019263][11 00] Firmware upgrade start...
[00100304][11 00] Firmware upgrade finished successfully.
[00100358]Done.
[00100407]Version checking[2]...
[00100457][01 00][00] v1.19.3422 -> v1.19.3422
[00100596][01 01][00] v1.19.3422 -> v1.19.3422
[00100765][03 05][00] v34.1.0.5 -> v34.1.0.5
[00100865][03 06][00] v2.2.6.33 -> v2.2.6.33
[00100923][04 00][00] v1.26.0.3 -> v1.26.0.3
[00101025][05 00][00] v3.0.6.1 -> v3.0.6.1
[00101084][08 00][00] v1.14.0.25 -> v1.14.0.25
[00101160][09 00][00] v1.8.0.0 -> v1.8.0.0
[00101265][11 00][05] v3.7.15.9 -> v3.7.15.9
[00101365][12 00][00] v1.8.0.0 -> v1.8.0.0
[00101484][12 01][00] v1.8.0.0 -> v1.8.0.0
[00101584][12 02][00] v1.8.0.0 -> v1.8.0.0
[00101704][12 03][00] v1.8.0.0 -> v1.8.0.0
[00101807][15 00][00] v1.1.2.0 -> v1.1.2.0
[00101884][17 00][00] v1.1.0.4 -> v1.1.0.4
[00102004][17 01][00] v2.0.0.8 -> v2.0.0.8
[00102069][19 00][00] v1.0.8.96 -> v1.0.8.96
[00102135]Packet upgrade finish successfully.
[00004726]========== remo-con disconnect. boot(15) ============
[00004785]Packet [C:\WM610_FW_V01.03.00.00.bin] detected, card sn [0x00000019].
[00004838]Packet upgrade start...
[00004902]Packet checking...
[00004976]Packet vlink 01.03.0000 <-> 01.02.0000.
[00005056]Record vlink 01.03.0000 <-> 01.02.0000 (flow = 0).
[00005130]Done.
[00005209]Version checking[1]...
[00005295][01 00][00] v1.19.3422 -> v1.19.3422
[00005371][01 01][00] v1.19.3422 -> v1.19.3422
[00005485][03 05][00] v34.1.0.5 -> v34.1.0.5
[00005568][03 06][00] v2.2.6.33 -> v2.2.6.33
[00005657][04 00][00] v1.26.0.3 -> v1.26.0.3
[00005745][05 00][00] v3.0.6.1 -> v3.0.6.1
[00005841][08 00][00] v1.14.0.25 -> v1.14.0.25
[00005920][09 00][00] v1.8.0.0 -> v1.8.0.0
[00006026][11 00][00] v3.7.15.9 -> v3.7.15.9
[00006145][12 00][00] v1.8.0.0 -> v1.8.0.0
[00006245][12 01][00] v1.8.0.0 -> v1.8.0.0
[00006345][12 02][00] v1.8.0.0 -> v1.8.0.0
[00006445][12 03][00] v1.8.0.0 -> v1.8.0.0
[00014034][15 00][00] v1.1.2.0 -> v1.1.2.0
[00014105][17 00][00] v1.1.0.4 -> v1.1.0.4
[00014232][17 01][00] v2.0.0.8 -> v2.0.0.8
[00014294][19 00][00] v1.0.8.96 -> v1.0.8.96
[00016349]Packet upgrade cancelled at version checking.
[00004724]========== remo-con disconnect. boot(15) ============
[00004845]Packet upgrade start...
[00004919]Packet checking...
[00005008]Packet vlink 01.03.0000 <-> 01.02.0000.
[00005089]Record vlink 01.03.0000 <-> 01.02.0000 (flow = 0).
[00005169]Done.
[00005246]Version checking[1]...
[00005322][01 00][00] v1.19.3422 -> v1.19.3422
[00005402][01 01][00] v1.19.3422 -> v1.19.3422
[00005500][03 05][00] v34.1.0.5 -> v34.1.0.5
[00005578][03 06][00] v2.2.6.33 -> v2.2.6.33
[00005664][04 00][00] v1.26.0.3 -> v1.26.0.3
[00005778][05 00][00] v3.0.6.1 -> v3.0.6.1
[00005901][08 00][00] v1.14.0.25 -> v1.14.0.25
[00005983][09 00][00] v1.8.0.0 -> v1.8.0.0
[00006078][11 00][00] v3.7.15.9 -> v3.7.15.9
[00006206][12 00][00] v1.8.0.0 -> v1.8.0.0
[00006358][12 01][00] v1.8.0.0 -> v1.8.0.0
[00006501][12 02][00] v1.8.0.0 -> v1.8.0.0
[00006618][12 03][00] v1.8.0.0 -> v1.8.0.0
[00006735][15 00][00] v1.1.2.0 -> v1.1.2.0
[00006819][17 00][00] v1.1.0.4 -> v1.1.0.4
[00006959][17 01][00] v2.0.0.8 -> v2.0.0.8
[00007040][19 00][00] v1.0.8.96 -> v1.0.8.96
[00009094]Packet upgrade cancelled at version checking.
[00004747]========== remo-con disconnect. boot(15) ============
[00004800]Packet [C:\WM610_FW_V01.03.00.00.bin] detected, card sn [0x00000019].
[00004859]Packet upgrade start...
[00004947]Packet checking...
[00005025]Packet vlink 01.03.0000 <-> 01.02.0000.
[00005104]Record vlink 01.03.0000 <-> 01.02.0000 (flow = 0).
[00005185]Done.
[00005268]Version checking[1]...
[00005339][01 00][00] v1.19.3422 -> v1.19.3422
[00005414][01 01][00] v1.19.3422 -> v1.19.3422
[00005520][03 05][00] v34.1.0.5 -> v34.1.0.5
[00005620][03 06][00] v2.2.6.33 -> v2.2.6.33
[00005690][04 00][00] v1.26.0.3 -> v1.26.0.3
[00005802][05 00][00] v3.0.6.1 -> v3.0.6.1
[00005887][08 00][00] v1.14.0.25 -> v1.14.0.25
[00005984][09 00][00] v1.8.0.0 -> v1.8.0.0
[00006079][11 00][00] v3.7.1.0 -> v3.7.15.9 need upgrade.
[00006319][12 00][00] v1.8.0.0 -> v1.8.0.0
[00006419][12 01][00] v1.8.0.0 -> v1.8.0.0
[00006519][12 02][00] v1.8.0.0 -> v1.8.0.0
[00006619][12 03][00] v1.8.0.0 -> v1.8.0.0
[00006743][15 00][00] v1.1.2.0 -> v1.1.2.0
[00006966][17 01][00] v2.0.0.8 -> v2.0.0.8
[00007054][19 00][00] v1.0.8.96 -> v1.0.8.96
[00007111]Done.
[00009186]Waiting for user confirm...
[00019426]Timeout, start upgrade automatically.
[00019534]Firmware upgrading[1]...
[00019617][11 00] Firmware upgrade start...
[00102310][11 00] Firmware upgrade finished successfully.
[00102367]Done.
[00102421]Version checking[2]...
[00102477][01 00][00] v1.19.3422 -> v1.19.3422
[00102531][01 01][00] v1.19.3422 -> v1.19.3422
[00102610][03 05][00] v34.1.0.5 -> v34.1.0.5
[00102690][03 06][00] v2.2.6.33 -> v2.2.6.33
[00102753][04 00][00] v1.26.0.3 -> v1.26.0.3
[00102831][05 00][00] v3.0.6.1 -> v3.0.6.1
[00102900][08 00][00] v1.14.0.25 -> v1.14.0.25
[00102969][09 00][00] v1.8.0.0 -> v1.8.0.0
[00103051][11 00][05] v3.7.15.9 -> v3.7.15.9
[00103151][12 00][00] v1.8.0.0 -> v1.8.0.0
[00103251][12 01][00] v1.8.0.0 -> v1.8.0.0
[00103351][12 02][00] v1.8.0.0 -> v1.8.0.0
[00103451][12 03][00] v1.8.0.0 -> v1.8.0.0
[00103571][15 00][00] v1.1.2.0 -> v1.1.2.0
[00103671][17 00][00] v1.1.0.4 -> v1.1.0.4
[00103811][17 01][00] v2.0.0.8 -> v2.0.0.8
[00103875][19 00][00] v1.0.8.96 -> v1.0.8.96
[00103927]Packet upgrade finish successfully.
[00004803]========== remo-con disconnect. boot(15) ============
[00005029]Packet [C:\WM610_FW_V01.02.01.06.bin] detected, card sn [0x00cea48f].
[00005193]Packet upgrade start...
[00005442]Packet checking...
[00005570]Packet vlink 01.02.0000 <-> 01.02.0000.
[00005716]Record vlink 01.03.0000 <-> 01.02.0000 (flow = 1).
[00005939]Done.
[00006096]Version checking[1]...
[00006246][01 00][00] v1.19.3422 -> v1.8.2729
[00006401][01 01][00] v1.19.3422 -> v1.8.2729
[00006570][03 05][00] v34.1.0.5 -> v34.1.0.5
[00007011][03 06][00] v2.2.6.33 -> v2.0.5.14
[00007166][04 00][00] v1.26.0.3 -> v1.16.0.76
[00007311][05 00][00] v3.0.6.1 -> v2.5.6.1
[00007365][08 00][00] v1.14.0.25 -> v1.12.0.21
[00007430][09 00][00] v1.8.0.0 -> v1.7.0.3
[00007491][11 00][00] v3.7.15.9 -> v3.7.1.0
[00007590][12 00][00] v1.8.0.0 -> v1.3.0.60
[00007690][12 01][00] v1.8.0.0 -> v1.3.0.60
[00007790][12 02][00] v1.8.0.0 -> v1.3.0.60
[00007910][12 03][00] v1.8.0.0 -> v1.3.0.60
[00008011][15 00][00] v1.1.2.0 -> v1.1.2.0
[00008090][17 00][00] v1.1.0.4 -> v1.1.0.1 need upgrade.
[00008210][17 01][00] v2.0.0.8 -> v2.0.0.1 need upgrade.
[00008319][19 00][00] v1.0.8.96 -> v1.0.8.96
[00008379]Done.
[00010420]Waiting for user confirm...
[00020582]Timeout, start upgrade automatically.
[00020665]Firmware upgrading[1]...
[00020740][17 00] Firmware upgrade start...
[00080863][17 00] Firmware upgrade finished successfully.
[00080918][17 01] Firmware upgrade start...
[00130779][17 01] Firmware upgrade finished successfully.
[00130829]Done.
[00130872]Version checking[2]...
[00130914][01 00][00] v1.19.3422 -> v1.8.2729
[00130960][01 01][00] v1.19.3422 -> v1.8.2729
[00131039][03 05][00] v34.1.0.5 -> v34.1.0.5
[00131119][03 06][00] v2.2.6.33 -> v2.0.5.14
[00131173][04 00][00] v1.26.0.3 -> v1.16.0.76
[00131239][05 00][00] v3.0.6.1 -> v2.5.6.1
[00131295][08 00][00] v1.14.0.25 -> v1.12.0.21
[00131354][09 00][00] v1.8.0.0 -> v1.7.0.3
[00131420][11 00][00] v3.7.15.9 -> v3.7.1.0
[00131520][12 00][00] v1.8.0.0 -> v1.3.0.60
[00131620][12 01][00] v1.8.0.0 -> v1.3.0.60
[00131720][12 02][00] v1.8.0.0 -> v1.3.0.60
[00131820][12 03][00] v1.8.0.0 -> v1.3.0.60
[00131933][15 00][00] v1.1.2.0 -> v1.1.2.0
[00131999][17 00][05] v1.1.0.1 -> v1.1.0.1
[00132120][17 01][05] v2.0.0.1 -> v2.0.0.1
[00132179][19 00][00] v1.0.8.96 -> v1.0.8.96
[00132221]Packet upgrade finish successfully.
[00004762]========== remo-con disconnect. boot(15) ============
[00004817]Packet [C:\WM610_FW_V01.03.00.00.bin] detected, card sn [0x00000019].
[00005017]Packet upgrade start...
[00005112]Packet checking...
[00005201]Packet vlink 01.03.0000 <-> 01.02.0000.
[00005280]Record vlink 01.03.0000 <-> 01.02.0000 (flow = 0).
[00005368]Done.
[00005440]Version checking[1]...
[00005502][01 00][00] v1.19.3422 -> v1.19.3422
[00005568][01 01][00] v1.19.3422 -> v1.19.3422
[00005672][03 05][00] v34.1.0.5 -> v34.1.0.5
[00005771][03 06][00] v2.2.6.33 -> v2.2.6.33
[00005870][04 00][00] v1.26.0.3 -> v1.26.0.3
[00005978][05 00][00] v3.0.6.1 -> v3.0.6.1
[00006070][08 00][00] v1.14.0.25 -> v1.14.0.25
[00006186][09 00][00] v1.8.0.0 -> v1.8.0.0
[00006311][11 00][00] v3.7.15.9 -> v3.7.15.9
[00006432][12 00][00] v1.8.0.0 -> v1.8.0.0
[00006551][12 01][00] v1.8.0.0 -> v1.8.0.0
[00006651][12 02][00] v1.8.0.0 -> v1.8.0.0
[00006772][12 03][00] v1.8.0.0 -> v1.8.0.0
[00006906][15 00][00] v1.1.2.0 -> v1.1.2.0
[00006992][17 00][00] v1.1.0.1 -> v1.1.0.4 need upgrade.
[00007132][17 01][00] v2.0.0.1 -> v2.0.0.8 need upgrade.
[00007226][19 00][00] v1.0.8.96 -> v1.0.8.96
[00007300]Done.
[00009381]Waiting for user confirm...
[00019628]Timeout, start upgrade automatically.
[00019740]Firmware upgrading[1]...
[00019838][17 00] Firmware upgrade start...
[00081223][17 00] Firmware upgrade finished successfully.
[00081302][17 01] Firmware upgrade start...
[00135060][17 01] Firmware upgrade finished successfully.
[00135118]Done.
[00135181]Version checking[2]...
[00135239][01 00][00] v1.19.3422 -> v1.19.3422
[00135293][01 01][00] v1.19.3422 -> v1.19.3422
[00135380][03 05][00] v34.1.0.5 -> v34.1.0.5
[00135480][03 06][00] v2.2.6.33 -> v2.2.6.33
[00135549][04 00][00] v1.26.0.3 -> v1.26.0.3
[00135620][05 00][00] v3.0.6.1 -> v3.0.6.1
[00135686][08 00][00] v1.14.0.25 -> v1.14.0.25
[00135754][09 00][00] v1.8.0.0 -> v1.8.0.0
[00135860][11 00][00] v3.7.15.9 -> v3.7.15.9
[00135960][12 00][00] v1.8.0.0 -> v1.8.0.0
[00136080][12 01][00] v1.8.0.0 -> v1.8.0.0
[00136200][12 02][00] v1.8.0.0 -> v1.8.0.0
[00136420][12 03][00] v1.8.0.0 -> v1.8.0.0
[00136557][15 00][00] v1.1.2.0 -> v1.1.2.0
[00136640][17 00][05] v1.1.0.4 -> v1.1.0.4
[00136760][17 01][05] v2.0.0.8 -> v2.0.0.8
[00136829][19 00][00] v1.0.8.96 -> v1.0.8.96
[00136888]Packet upgrade finish successfully.
[00005254]========== remo-con disconnect. boot(15) ============
[00005324]Packet [C:\WM610_FW_V01.02.01.07.bin] detected, card sn [0x00cea48f].
[00005400]Packet upgrade start...
[00005479]Packet checking...
[00005563]Packet upgrade failed at packet checking.
[00004625]========== remo-con disconnect. boot(15) ============
[00004678]Packet [C:\WM610_FW_V01.02.01.07.bin] detected, card sn [0x00cea48f].
[00004724]Packet upgrade start...
[00004780]Packet checking...
[00004829]Packet upgrade failed at packet checking.
[00004811]========== remo-con disconnect. boot(15) ============
[00004874]Packet [C:\WM610_FW_V01.03.00.00.bin] detected, card sn [0x00000019].
[00004963]Packet upgrade start...
[00005056]Packet checking...
[00005146]Packet vlink 01.03.0000 <-> 01.02.0000.
[00005239]Record vlink 01.03.0000 <-> 01.02.0000 (flow = 0).
[00005322]Done.
[00005409]Version checking[1]...
[00005475][01 00][00] v1.19.3422 -> v1.19.3422
[00005538][01 01][00] v1.19.3422 -> v1.19.3422
[00005641][03 05][00] v34.1.0.5 -> v34.1.0.5
[00005741][03 06][00] v2.2.6.33 -> v2.2.6.33
[00005827][04 00][00] v1.26.0.3 -> v1.26.0.3
[00005941][05 00][00] v3.0.6.1 -> v3.0.6.1
[00013515][08 00][00] v1.14.0.25 -> v1.14.0.25
[00013585][09 00][00] v1.8.0.0 -> v1.8.0.0
[00013680][11 00][00] v3.7.15.9 -> v3.7.15.9
[00013780][12 00][00] v1.8.0.0 -> v1.8.0.0
[00013900][12 01][00] v1.8.0.0 -> v1.8.0.0
[00014000][12 02][00] v1.8.0.0 -> v1.8.0.0
[00014100][12 03][00] v1.8.0.0 -> v1.8.0.0
[00014213][15 00][00] v1.1.2.0 -> v1.1.2.0
[00014321][17 00][00] v1.1.0.4 -> v1.1.0.4
[00014442][17 01][00] v2.0.0.8 -> v2.0.0.8
[00014510][19 00][00] v1.0.8.96 -> v1.0.8.96
[00016571]Packet upgrade cancelled at version checking.
[00004890]========== remo-con disconnect. boot(15) ============
[00004987]Packet [C:\WM610_FW_V01.03.00.00.bin] detected, card sn [0x00000019].
[00005075]Packet upgrade start...
[00005175]Packet checking...
[00005270]Packet vlink 01.03.0000 <-> 01.02.0000.
[00005359]Record vlink 01.03.0000 <-> 01.02.0000 (flow = 0).
[00005446]Done.
[00005530]Version checking[1]...
[00005596][01 00][00] v1.19.3422 -> v1.19.3422
[00005662][01 01][00] v1.19.3422 -> v1.19.3422
[00005772][03 05][00] v34.1.0.5 -> v34.1.0.5
[00005872][03 06][00] v2.2.6.33 -> v2.2.6.33
[00005967][04 00][00] v1.26.0.3 -> v1.26.0.3
[00006072][05 00][00] v3.0.6.1 -> v3.0.6.1
[00006158][08 00][00] v1.14.0.25 -> v1.14.0.25
[00006247][09 00][00] v1.8.0.0 -> v1.8.0.0
[00006392][11 00][00] v3.7.15.9 -> v3.7.15.9
[00006492][12 00][00] v1.8.0.0 -> v1.8.0.0
[00006592][12 01][00] v1.8.0.0 -> v1.8.0.0
[00006712][12 02][00] v1.8.0.0 -> v1.8.0.0
[00006812][12 03][00] v1.8.0.0 -> v1.8.0.0
[00006944][15 00][00] v1.1.2.0 -> v1.1.2.0
[00007035][17 00][00] v1.1.0.4 -> v1.1.0.4
[00007153][17 01][00] v2.0.0.8 -> v2.0.0.8
[00007221][19 00][00] v1.0.8.96 -> v1.0.8.96
[00009309]Packet upgrade cancelled at version checking.
[00004975]========== remo-con disconnect. boot(15) ============
[00005063]Packet [C:\WM610_FW_V01.03.00.00.bin] detected, card sn [0x00000019].
[00005145]Packet upgrade start...
[00005255]Packet checking...
[00005354]Packet vlink 01.03.0000 <-> 01.02.0000.
[00005439]Record vlink 01.03.0000 <-> 01.02.0000 (flow = 0).
[00005518]Done.
[00005596]Version checking[1]...
[00005658][01 00][00] v1.19.3422 -> v1.19.3422
[00005746][01 01][00] v1.19.3422 -> v1.19.3422
[00005840][03 05][00] v34.1.0.5 -> v34.1.0.5
[00005952][03 06][00] v2.2.6.33 -> v2.2.6.33
[00006049][04 00][00] v1.26.0.3 -> v1.26.0.3
[00006172][05 00][00] v3.0.6.1 -> v3.0.6.1
[00006253][08 00][00] v1.14.0.25 -> v1.14.0.25
[00006387][09 00][00] v1.8.0.0 -> v1.8.0.0
[00006592][11 00][00] v3.7.15.9 -> v3.7.15.9
[00006712][12 00][00] v1.8.0.0 -> v1.8.0.0
[00006835][12 01][00] v1.8.0.0 -> v1.8.0.0
[00006952][12 02][00] v1.8.0.0 -> v1.8.0.0
[00007052][12 03][00] v1.8.0.0 -> v1.8.0.0
[00007181][15 00][00] v1.1.2.0 -> v1.1.2.0
[00007273][17 00][00] v1.1.0.4 -> v1.1.0.4
[00007432][17 01][00] v2.0.0.8 -> v2.0.0.8
[00007512][19 00][00] v1.0.8.96 -> v1.0.8.96
[00009576]Packet upgrade cancelled at version checking.
[00004889]========== remo-con disconnect. boot(15) ============
[00004954]Packet [C:\WM610_FW_V01.03.00.00.bin] detected, card sn [0x00000019].
[00005038]Packet upgrade start...
[00005147]Packet checking...
[00005239]Packet vlink 01.03.0000 <-> 01.02.0000.
[00005326]Record vlink 01.03.0000 <-> 01.02.0000 (flow = 0).
[00005414]Done.
[00005505]Version checking[1]...
[00005580][01 00][00] v1.19.3422 -> v1.19.3422
[00005647][01 01][00] v1.19.3422 -> v1.19.3422
[00005782][03 05][00] v34.1.0.5 -> v34.1.0.5
[00005902][03 06][00] v2.2.6.33 -> v2.2.6.33
[00005997][04 00][00] v1.26.0.3 -> v1.26.0.3
[00006122][05 00][00] v3.0.6.1 -> v3.0.6.1
[00006307][08 00][00] v1.14.0.25 -> v1.14.0.25
[00006417][09 00][00] v1.8.0.0 -> v1.8.0.0
[00006522][11 00][00] v3.7.15.9 -> v3.7.15.9
[00006642][12 00][00] v1.8.0.0 -> v1.8.0.0
[00006742][12 01][00] v1.8.0.0 -> v1.8.0.0
[00006842][12 02][00] v1.8.0.0 -> v1.8.0.0
[00006963][12 03][00] v1.8.0.0 -> v1.8.0.0
[00007103][15 00][00] v1.1.2.0 -> v1.1.2.0
[00007203][17 00][00] v1.1.0.4 -> v1.1.0.4
[00007323][17 01][00] v2.0.0.8 -> v2.0.0.8
[00007411][19 00][00] v1.0.8.96 -> v1.0.8.96
[00009498]Packet upgrade cancelled at version checking.
[00004926]========== remo-con disconnect. boot(15) ============
[00004997]Packet [C:\WM610_FW_V01.03.00.00.bin] detected, card sn [0x00000019].
[00005091]Packet upgrade start...
[00005195]Packet checking...
[00005286]Packet vlink 01.03.0000 <-> 01.02.0000.
[00005381]Record vlink 01.03.0000 <-> 01.02.0000 (flow = 0).
[00005595]Done.
[00005671]Version checking[1]...
[00005764][01 00][00] v1.19.3422 -> v1.19.3422
[00005830][01 01][00] v1.19.3422 -> v1.19.3422
[00005946][03 05][00] v34.1.0.5 -> v34.1.0.5
[00006068][03 06][00] v2.2.6.33 -> v2.2.6.33
[00006154][04 00][00] v1.26.0.3 -> v1.26.0.3
[00006269][05 00][00] v3.0.6.1 -> v3.0.6.1
[00006385][08 00][00] v1.14.0.25 -> v1.14.0.25
[00006476][09 00][00] v1.8.0.0 -> v1.8.0.0
[00006569][11 00][00] v3.7.15.9 -> v3.7.15.9
[00006686][12 00][00] v1.8.0.0 -> v1.8.0.0
[00006808][12 01][00] v1.8.0.0 -> v1.8.0.0
[00006926][12 02][00] v1.8.0.0 -> v1.8.0.0
[00007046][12 03][00] v1.8.0.0 -> v1.8.0.0
[00007170][15 00][00] v1.1.2.0 -> v1.1.2.0
[00007270][17 00][00] v1.1.0.4 -> v1.1.0.4
[00007427][17 01][00] v2.0.0.8 -> v2.0.0.8
[00007511][19 00][00] v1.0.8.96 -> v1.0.8.96
[00009676]Packet upgrade cancelled at version checking.
[00004778]========== remo-con disconnect. boot(15) ============
[00004829]Packet [C:\WM610_FW_V01.03.00.00.bin] detected, card sn [0x27baf9de].
[00004884]Packet upgrade start...
[00004953]Packet checking...
[00005010]Packet vlink 01.03.0000 <-> 01.02.0000.
[00005094]Record vlink 01.03.0000 <-> 01.02.0000 (flow = 0).
[00005175]Done.
[00005258]Version checking[1]...
[00005341][01 00][00] v1.19.3422 -> v1.19.3422
[00005419][01 01][00] v1.19.3422 -> v1.19.3422
[00005693][04 00][00] v1.26.0.3 -> v1.26.0.3
[00005792][05 00][00] v3.0.6.1 -> v3.0.6.1
[00005883][08 00][00] v1.14.0.25 -> v1.14.0.25
[00005982][09 00][00] v1.8.0.0 -> v1.8.0.0
[00006092][11 00][00] v3.7.15.9 -> v3.7.15.9
[00006212][12 00][00] v1.8.0.0 -> v1.8.0.0
[00006312][12 01][00] v1.8.0.0 -> v1.8.0.0
[00006453][12 02][00] v1.8.0.0 -> v1.8.0.0
[00006552][12 03][00] v1.8.0.0 -> v1.8.0.0
[00006673][15 00][00] v1.1.2.0 -> v1.1.2.0
[00006772][17 00][00] v1.1.0.4 -> v1.1.0.4
[00006913][17 01][00] v2.0.0.8 -> v2.0.0.8
[00006993][19 00][00] v1.0.8.96 -> v1.0.8.96
[00009117]Packet upgrade cancelled at version checking.
[00004723]========== remo-con disconnect. boot(15) ============
[00004780]Packet [C:\WM610_FW_V01.03.00.00.bin] detected, card sn [0x27baf9de].
[00004829]Packet upgrade start...
[00004883]Packet checking...
[00004942]Packet vlink 01.03.0000 <-> 01.02.0000.
[00005014]Record vlink 01.03.0000 <-> 01.02.0000 (flow = 0).
[00005095]Done.
[00005174]Version checking[1]...
[00005256][01 00][00] v1.19.3422 -> v1.19.3422
[00005343][01 01][00] v1.19.3422 -> v1.19.3422
[00005452][03 05][00] v34.1.0.5 -> v34.1.0.5
[00005529][03 06][00] v2.2.6.33 -> v2.2.6.33
[00005612][04 00][00] v1.26.0.3 -> v1.26.0.3
[00005689][05 00][00] v3.0.6.1 -> v3.0.6.1
[00005790][08 00][00] v1.14.0.25 -> v1.14.0.25
[00005894][09 00][00] v1.8.0.0 -> v1.8.0.0
[00006109][12 00][00] v1.8.0.0 -> v1.8.0.0
[00006209][12 01][00] v1.8.0.0 -> v1.8.0.0
[00006309][12 02][00] v1.8.0.0 -> v1.8.0.0
[00006429][12 03][00] v1.8.0.0 -> v1.8.0.0
[00006553][15 00][00] v1.1.2.0 -> v1.1.2.0
[00006749][17 01][00] v2.0.0.8 -> v2.0.0.8
[00006809][19 00][00] v1.0.8.96 -> v1.0.8.96
[00008861]Packet upgrade cancelled at version checking.
[00004682]========== remo-con disconnect. boot(15) ============
[00004739]Packet [C:\WM610_FW_V01.03.00.00.bin] detected, card sn [0x27baf9de].
[00004784]Packet upgrade start...
[00004843]Packet checking...
[00004912]Packet vlink 01.03.0000 <-> 01.02.0000.
[00004995]Record vlink 01.03.0000 <-> 01.02.0000 (flow = 0).
[00005073]Done.
[00005155]Version checking[1]...
[00005240][01 00][00] v1.19.3422 -> v1.19.3422
[00005315][01 01][00] v1.19.3422 -> v1.19.3422
[00005401][03 05][00] v34.1.0.5 -> v34.1.0.5
[00005520][03 06][00] v2.2.6.33 -> v2.2.6.33
[00005589][04 00][00] v1.26.0.3 -> v1.26.0.3
[00005701][05 00][00] v3.0.6.1 -> v3.0.6.1
[00005801][08 00][00] v1.14.0.25 -> v1.14.0.25
[00006020][09 00][00] v1.8.0.0 -> v1.8.0.0
[00006120][11 00][00] v3.7.15.9 -> v3.7.15.9
[00006220][12 00][00] v1.8.0.0 -> v1.8.0.0
[00006360][12 01][00] v1.8.0.0 -> v1.8.0.0
[00006460][12 02][00] v1.8.0.0 -> v1.8.0.0
[00006560][12 03][00] v1.8.0.0 -> v1.8.0.0
[00006668][15 00][00] v1.1.2.0 -> v1.1.2.0
[00006761][17 00][00] v1.1.0.4 -> v1.1.0.4
[00006881][17 01][00] v2.0.0.8 -> v2.0.0.8
[00006965][19 00][00] v1.0.8.96 -> v1.0.8.96
[00009042]Packet upgrade cancelled at version checking.
[00004885]========== remo-con disconnect. boot(15) ============
[00004972]Packet [C:\WM610_FW_V01.03.00.00.bin] detected, card sn [0x00cea48f].
[00005055]Packet upgrade start...
[00005143]Packet checking...
[00005225]Packet vlink 01.03.0000 <-> 01.02.0000.
[00005312]Record vlink 01.03.0000 <-> 01.02.0000 (flow = 0).
[00005396]Done.
[00005454]Version checking[1]...
[00005514][01 00][00] v1.19.3422 -> v1.19.3422
[00005595][01 01][00] v1.19.3422 -> v1.19.3422
[00005680][03 05][00] v34.1.0.5 -> v34.1.0.5
[00005801][03 06][00] v2.2.6.33 -> v2.2.6.33
[00005901][04 00][00] v1.26.0.3 -> v1.26.0.3
[00006001][05 00][00] v3.0.6.1 -> v3.0.6.1
[00006092][08 00][00] v1.14.0.25 -> v1.14.0.25
[00006185][09 00][00] v1.8.0.0 -> v1.8.0.0
[00006301][11 00][00] v3.7.15.9 -> v3.7.15.9
[00006401][12 00][00] v1.8.0.0 -> v1.8.0.0
[00006502][12 01][00] v1.8.0.0 -> v1.8.0.0
[00006602][12 02][00] v1.8.0.0 -> v1.8.0.0
[00006720][12 03][00] v1.8.0.0 -> v1.8.0.0
[00006851][15 00][00] v1.1.2.0 -> v1.1.2.0
[00006941][17 00][00] v1.1.0.4 -> v1.1.0.4
[00007061][17 01][00] v2.0.0.8 -> v2.0.0.8
[00007155][19 00][00] v1.0.8.96 -> v1.0.8.96
[00009220]Packet upgrade cancelled at version checking.
[00004915]========== remo-con disconnect. boot(15) ============
[00004975]Packet [C:\WM610_FW_V01.03.00.00.bin] detected, card sn [0x00cea48f].
[00005026]Packet upgrade start...
[00005108]Packet checking...
[00005208]Packet vlink 01.03.0000 <-> 01.02.0000.
[00005293]Record vlink 01.03.0000 <-> 01.02.0000 (flow = 0).
[00005512]Done.
[00005577]Version checking[1]...
[00005630][01 00][00] v1.19.3422 -> v1.19.3422
[00005716][01 01][00] v1.19.3422 -> v1.19.3422
[00005823][03 05][00] v34.1.0.5 -> v34.1.0.5
[00005943][03 06][00] v2.2.6.33 -> v2.2.6.33
[00006023][04 00][00] v1.26.0.3 -> v1.26.0.3
[00006123][05 00][00] v3.0.6.1 -> v3.0.6.1
[00013700][08 00][00] v1.14.0.25 -> v1.14.0.25
[00013768][09 00][00] v1.8.0.0 -> v1.8.0.0
[00013843][11 00][00] v3.7.15.9 -> v3.7.15.9
[00013923][12 00][00] v1.8.0.0 -> v1.8.0.0
[00014023][12 01][00] v1.8.0.0 -> v1.8.0.0
[00014123][12 02][00] v1.8.0.0 -> v1.8.0.0
[00014223][12 03][00] v1.8.0.0 -> v1.8.0.0
[00014313][15 00][00] v1.1.2.0 -> v1.1.2.0
[00014383][17 00][00] v1.1.0.4 -> v1.1.0.4
[00014523][17 01][00] v2.0.0.8 -> v2.0.0.8
[00014593][19 00][00] v1.0.8.96 -> v1.0.8.96
[00016647]Packet upgrade cancelled at version checking.
[00004854]========== remo-con disconnect. boot(15) ============
[00004908]Packet [C:\WM610_FW_V01.03.00.00.bin] detected, card sn [0x00cea48f].
[00004961]Packet upgrade start...
[00005047]Packet checking...
[00005130]Packet vlink 01.03.0000 <-> 01.02.0000.
[00005219]Record vlink 01.03.0000 <-> 01.02.0000 (flow = 0).
[00005305]Done.
[00005392]Version checking[1]...
[00005461][01 00][00] v1.19.3422 -> v1.19.3422
[00005513][01 01][00] v1.19.3422 -> v1.19.3422
[00005617][03 05][00] v34.1.0.5 -> v34.1.0.5
[00005697][03 06][00] v2.2.6.33 -> v2.2.6.33
[00005797][04 00][00] v1.26.0.3 -> v1.26.0.3
[00005940][05 00][00] v3.0.6.1 -> v3.0.6.1
[00006014][08 00][00] v1.14.0.25 -> v1.14.0.25
[00006097][09 00][00] v1.8.0.0 -> v1.8.0.0
[00006217][11 00][00] v3.7.15.9 -> v3.7.15.9
[00006317][12 00][00] v1.8.0.0 -> v1.8.0.0
[00006457][12 01][00] v1.8.0.0 -> v1.8.0.0
[00006557][12 02][00] v1.8.0.0 -> v1.8.0.0
[00006657][12 03][00] v1.8.0.0 -> v1.8.0.0
[00019217][15 00][00] device not detected.
[00019297][17 00][00] v1.1.0.4 -> v1.1.0.4
[00019436][17 01][00] v2.0.0.8 -> v2.0.0.8
[00019601][19 00][00] v1.0.8.96 -> v1.0.8.96
[00021659]Packet upgrade failed at version checking.
[00004709]========== remo-con disconnect. boot(15) ============
[00004768]Packet [C:\WM610_FW_V01.03.00.00.bin] detected, card sn [0x27baf9de].
[00004819]Packet upgrade start...
[00004891]Packet checking...
[00004977]Packet vlink 01.03.0000 <-> 01.02.0000.
[00005068]Record vlink 01.03.0000 <-> 01.02.0000 (flow = 0).
[00005155]Done.
[00005243]Version checking[1]...
[00005318][01 00][00] v1.19.3422 -> v1.19.3422
[00005378][01 01][00] v1.19.3422 -> v1.19.3422
[00005510][03 05][00] v34.1.0.5 -> v34.1.0.5
[00005630][03 06][00] v2.2.6.33 -> v2.2.6.33
[00005724][04 00][00] v1.26.0.3 -> v1.26.0.3
[00005830][05 00][00] v3.0.6.1 -> v3.0.6.1
[00005990][09 00][00] v1.8.0.0 -> v1.8.0.0
[00006110][11 00][00] v3.7.15.9 -> v3.7.15.9
[00006210][12 00][00] v1.8.0.0 -> v1.8.0.0
[00006350][12 01][00] v1.8.0.0 -> v1.8.0.0
[00006450][12 02][00] v1.8.0.0 -> v1.8.0.0
[00006550][12 03][00] v1.8.0.0 -> v1.8.0.0
[00006663][15 00][00] v1.1.2.0 -> v1.1.2.0
[00009250][17 00][00] v1.1.0.4 -> v1.1.0.4
[00009376][17 01][00] v2.0.0.8 -> v2.0.0.8
[00009450][19 00][00] v1.0.8.96 -> v1.0.8.96
[00011501]Packet upgrade cancelled at version checking.
[00005647]========== remo-con disconnect. boot(15) ============
[00005740]Packet [C:\WM610_FW_V01.03.00.00.bin] detected, card sn [0x00000019].
[00005839]Packet upgrade start...
[00005944]Packet checking...
[00006040]Packet vlink 01.03.0000 <-> 01.02.0000.
[00006140]Record vlink 01.03.0000 <-> 01.02.0000 (flow = 0).
[00006313]Done.
[00006383]Version checking[1]...
[00006469][01 00][00] v1.19.3422 -> v1.19.3422
[00006563][01 01][00] v1.19.3422 -> v1.19.3422
[00006695][03 05][00] v34.1.0.5 -> v34.1.0.5
[00006841][03 06][00] v2.2.6.33 -> v2.2.6.33
[00006941][04 00][00] v1.26.0.3 -> v1.26.0.3
[00007096][05 00][00] v3.0.6.1 -> v3.0.6.1
[00014787][08 00][00] v1.14.0.25 -> v1.14.0.25
[00014870][09 00][00] v1.8.0.0 -> v1.8.0.0
[00014962][11 00][00] v3.7.15.9 -> v3.7.15.9
[00015095][12 00][00] v1.8.0.0 -> v1.8.0.0
[00015195][12 01][00] v1.8.0.0 -> v1.8.0.0
[00015315][12 02][00] v1.8.0.0 -> v1.8.0.0
[00015435][12 03][00] v1.8.0.0 -> v1.8.0.0
[00015705][15 00][00] v1.1.2.0 -> v1.1.2.0
[00015795][17 00][00] v1.1.0.4 -> v1.1.0.4
[00015935][17 01][00] v2.0.0.8 -> v2.0.0.8
[00016020][19 00][00] v1.0.8.96 -> v1.0.8.96
[00018086]Packet upgrade cancelled at version checking.
[00005780]========== remo-con disconnect. boot(15) ============
[00005885]Packet [C:\WM610_FW_V01.03.00.00.bin] detected, card sn [0x00000019].
[00005988]Packet upgrade start...
[00006101]Packet checking...
[00006206]Packet vlink 01.03.0000 <-> 01.02.0000.
[00006311]Record vlink 01.03.0000 <-> 01.02.0000 (flow = 0).
[00006388]Done.
[00006477]Version checking[1]...
[00006570][01 00][00] v1.19.3422 -> v1.19.3422
[00006649][01 01][00] v1.19.3422 -> v1.19.3422
[00006880][03 05][00] v34.1.0.5 -> v34.1.0.5
[00007020][03 06][00] v2.2.6.33 -> v2.2.6.33
[00007122][04 00][00] v1.26.0.3 -> v1.26.0.3
[00007241][05 00][00] v3.0.6.1 -> v3.0.6.1
[00007320][08 00][00] v1.14.0.25 -> v1.14.0.25
[00007406][09 00][00] v1.8.0.0 -> v1.8.0.0
[00007500][11 00][00] v3.7.15.9 -> v3.7.15.9
[00007620][12 00][00] v1.8.0.0 -> v1.8.0.0
[00007741][12 01][00] v1.8.0.0 -> v1.8.0.0
[00007860][12 02][00] v1.8.0.0 -> v1.8.0.0
[00008003][12 03][00] v1.8.0.0 -> v1.8.0.0
[00008142][15 00][00] v1.1.2.0 -> v1.1.2.0
[00008260][17 00][00] v1.1.0.4 -> v1.1.0.4
[00008420][17 01][00] v2.0.0.8 -> v2.0.0.8
[00008542][19 00][00] v1.0.8.96 -> v1.0.8.96
[00010641]Packet upgrade cancelled at version checking.
[00004972]========== remo-con disconnect. boot(15) ============
[00005067]Packet [C:\WM610_FW_V01.03.00.00.bin] detected, card sn [0x00000019].
[00005163]Packet upgrade start...
[00005275]Packet checking...
[00005374]Packet vlink 01.03.0000 <-> 01.02.0000.
[00005551]Record vlink 01.03.0000 <-> 01.02.0000 (flow = 0).
[00005638]Done.
[00005717]Version checking[1]...
[00005813][01 00][00] v1.19.3422 -> v1.19.3422
[00005913][01 01][00] v1.19.3422 -> v1.19.3422
[00006040][03 05][00] v34.1.0.5 -> v34.1.0.5
[00006157][03 06][00] v2.2.6.33 -> v2.2.6.33
[00006280][04 00][00] v1.26.0.3 -> v1.26.0.3
[00006376][05 00][00] v3.0.6.1 -> v3.0.6.1
[00006468][08 00][00] v1.14.0.25 -> v1.14.0.25
[00006552][09 00][00] v1.8.0.0 -> v1.8.0.0
[00006640][11 00][00] v3.7.15.9 -> v3.7.15.9
[00006741][12 00][00] v1.8.0.0 -> v1.8.0.0
[00006840][12 01][00] v1.8.0.0 -> v1.8.0.0
[00006976][12 02][00] v1.8.0.0 -> v1.8.0.0
[00007097][12 03][00] v1.8.0.0 -> v1.8.0.0
[00007231][15 00][00] v1.1.2.0 -> v1.1.2.0
[00007341][17 00][00] v1.1.0.4 -> v1.1.0.4
[00007477][17 01][00] v2.0.0.8 -> v2.0.0.8
[00007586][19 00][00] v1.0.8.96 -> v1.0.8.96
[00009683]Packet upgrade cancelled at version checking.
[00005239]========== remo-con disconnect. boot(15) ============
[00005339]Packet [C:\WM610_FW_V01.03.00.00.bin] detected, card sn [0x00000019].
[00005439]Packet upgrade start...
[00005554]Packet checking...
[00005658]Packet vlink 01.03.0000 <-> 01.02.0000.
[00005721]Record vlink 01.03.0000 <-> 01.02.0000 (flow = 0).
[00005807]Done.
[00005896]Version checking[1]...
[00005975][01 00][00] v1.19.3422 -> v1.19.3422
[00006073][01 01][00] v1.19.3422 -> v1.19.3422
[00006198][03 05][00] v34.1.0.5 -> v34.1.0.5
[00006318][03 06][00] v2.2.6.33 -> v2.2.6.33
[00006408][04 00][00] v1.26.0.3 -> v1.26.0.3
[00006558][05 00][00] v3.0.6.1 -> v3.0.6.1
[00006641][08 00][00] v1.14.0.25 -> v1.14.0.25
[00006712][09 00][00] v1.8.0.0 -> v1.8.0.0
[00006818][11 00][00] v3.7.15.9 -> v3.7.15.9
[00006938][12 00][00] v1.8.0.0 -> v1.8.0.0
[00007038][12 01][00] v1.8.0.0 -> v1.8.0.0
[00007158][12 02][00] v1.8.0.0 -> v1.8.0.0
[00007278][12 03][00] v1.8.0.0 -> v1.8.0.0
[00007421][15 00][00] v1.1.2.0 -> v1.1.2.0
[00007538][17 00][00] v1.1.0.4 -> v1.1.0.4
[00007798][17 01][00] v2.0.0.8 -> v2.0.0.8
[00007918][19 00][00] v1.0.8.96 -> v1.0.8.96
[00010009]Packet upgrade cancelled at version checking.
[00005072]========== remo-con disconnect. boot(15) ============
[00005172]Packet [C:\WM610_FW_V01.03.00.00.bin] detected, card sn [0x00000019].
[00005272]Packet upgrade start...
[00005413]Packet checking...
[00005497]Packet vlink 01.03.0000 <-> 01.02.0000.
[00005570]Record vlink 01.03.0000 <-> 01.02.0000 (flow = 0).
[00005668]Done.
[00005731]Version checking[1]...
[00005826][01 00][00] v1.19.3422 -> v1.19.3422
[00005927][01 01][00] v1.19.3422 -> v1.19.3422
[00006080][03 05][00] v34.1.0.5 -> v34.1.0.5
[00006220][03 06][00] v2.2.6.33 -> v2.2.6.33
[00006298][04 00][00] v1.26.0.3 -> v1.26.0.3
[00006420][05 00][00] v3.0.6.1 -> v3.0.6.1
[00006505][08 00][00] v1.14.0.25 -> v1.14.0.25
[00006585][09 00][00] v1.8.0.0 -> v1.8.0.0
[00006681][11 00][00] v3.7.15.9 -> v3.7.15.9
[00006803][12 00][00] v1.8.0.0 -> v1.8.0.0
[00006919][12 01][00] v1.8.0.0 -> v1.8.0.0
[00007060][12 02][00] v1.8.0.0 -> v1.8.0.0
[00007180][12 03][00] v1.8.0.0 -> v1.8.0.0
[00007326][15 00][00] v1.1.2.0 -> v1.1.2.0
[00007442][17 00][00] v1.1.0.4 -> v1.1.0.4
[00007600][17 01][00] v2.0.0.8 -> v2.0.0.8
[00007709][19 00][00] v1.0.8.96 -> v1.0.8.96
[00009805]Packet upgrade cancelled at version checking.
[00005196]========== remo-con disconnect. boot(15) ============
[00005295]Packet [C:\WM610_FW_V01.03.00.00.bin] detected, card sn [0x00000019].
[00005396]Packet upgrade start...
[00005509]Packet checking...
[00005603]Packet vlink 01.03.0000 <-> 01.02.0000.
[00005669]Record vlink 01.03.0000 <-> 01.02.0000 (flow = 0).
[00005768]Done.
[00005845]Version checking[1]...
[00005939][01 00][00] v1.19.3422 -> v1.19.3422
[00006040][01 01][00] v1.19.3422 -> v1.19.3422
[00006187][03 05][00] v34.1.0.5 -> v34.1.0.5
[00006307][03 06][00] v2.2.6.33 -> v2.2.6.33
[00006391][04 00][00] v1.26.0.3 -> v1.26.0.3
[00006627][05 00][00] v3.0.6.1 -> v3.0.6.1
[00006707][08 00][00] v1.14.0.25 -> v1.14.0.25
[00006793][09 00][00] v1.8.0.0 -> v1.8.0.0
[00006907][11 00][00] v3.7.15.9 -> v3.7.15.9
[00007027][12 00][00] v1.8.0.0 -> v1.8.0.0
[00007170][12 01][00] v1.8.0.0 -> v1.8.0.0
[00007288][12 02][00] v1.8.0.0 -> v1.8.0.0
[00007428][12 03][00] v1.8.0.0 -> v1.8.0.0
[00007567][15 00][00] v1.1.2.0 -> v1.1.2.0
[00007687][17 00][00] v1.1.0.4 -> v1.1.0.4
[00007847][17 01][00] v2.0.0.8 -> v2.0.0.8
[00007967][19 00][00] v1.0.8.96 -> v1.0.8.96
[00010072]Packet upgrade cancelled at version checking.
[00005002]========== remo-con disconnect. boot(15) ============
[00005106]Packet [C:\WM610_FW_V01.03.00.00.bin] detected, card sn [0x00000019].
[00005208]Packet upgrade start...
[00005328]Packet checking...
[00005473]Packet vlink 01.03.0000 <-> 01.02.0000.
[00005559]Record vlink 01.03.0000 <-> 01.02.0000 (flow = 0).
[00005897]Done.
[00005989]Version checking[1]...
[00006070][01 00][00] v1.19.3422 -> v1.19.3422
[00006145][01 01][00] v1.19.3422 -> v1.19.3422
[00006256][03 05][00] v34.1.0.5 -> v34.1.0.5
[00006356][03 06][00] v2.2.6.33 -> v2.2.6.33
[00006428][04 00][00] v1.26.0.3 -> v1.26.0.3
[00006517][05 00][00] v3.0.6.1 -> v3.0.6.1
[00006602][08 00][00] v1.14.0.25 -> v1.14.0.25
[00006686][09 00][00] v1.8.0.0 -> v1.8.0.0
[00006797][11 00][00] v3.7.15.9 -> v3.7.15.9
[00006916][12 00][00] v1.8.0.0 -> v1.8.0.0
[00007056][12 01][00] v1.8.0.0 -> v1.8.0.0
[00007197][12 02][00] v1.8.0.0 -> v1.8.0.0
[00007342][12 03][00] v1.8.0.0 -> v1.8.0.0
[00007517][15 00][00] v1.1.2.0 -> v1.1.2.0
[00007642][17 00][00] v1.1.0.4 -> v1.1.0.4
[00010336][17 01][00] v2.0.0.8 -> v2.0.0.8
[00010415][19 00][00] v1.0.8.96 -> v1.0.8.96
[00012483]Packet upgrade cancelled at version checking.
2015-8-14
w1der
Sweden
Maybe you should adress this with DJI support team ...
2015-8-14
retret66
I have exactly the same issue..What I think is that the firmware cannot write completely, leaving it halfway done..If you leave it like that, you will get no signal or video feed but everthing works fine..I fix mine doing it 5x until the firmware loaded successfully.. I prepare two microSD card, one with older firmware and the other is with new firmware..With full battery charge, update the firmware to the latest, then check the txt file latest entry if it was successful, if not, load the older firmware, then update it again with the latest.I did this like 5 to 6x until I get a perfect firmware push..The reason for this is that, if you have the latest firmware in there and it is not completely loaded, you cannot reload it with same version..the firmware check will stop it and it will say that you have the latest..By downgrading it and reloading to the latest always works..
2015-8-14
stan
retret66 Posted at 2015-8-15 04:09
I have exactly the same issue..What I think is that the firmware cannot write completely, leaving it ...
I did exactly as you said, one SD card with new firmware and one with old firmware, swapping them one by one. The upgrading/downgrading each takes about 2 minutes, then stop with D-DD sound instead of 25 minutes in normal situation. The result is still fail. I noticed that there are two conrupted bin messages on the .txt file no mater which version it is.
Sending DJI support message with no answer yet, just an automatic response saying they will check on it.
I am just so fustrated that how come such a good engineered product could come with such a stupid unreliable firmware upgrade method!
I understand most product do not need upgrade, but in the case of this complex flying machine, the software will never be fully debugged or developed, and upgrading is a must. But DJI please use high quality flash boot chips if you foresee upgrading is a must!
2015-8-15
retret66
try to reformat the SD via the pilot app, then download a good copy of the binfiles
2015-8-15
stan
retret66 Posted at 2015-8-16 01:10
Did try with formating on Pilot Apps, tried many sd cards with various speed class, tried downloading the bin file with different PC, shut off all virus scan, unfortunately results are the same!
After repeat upgrade and downgrade, I think I am now got stuck somewhere between v1.2.1.06 and v1.3.0, Pilot Apps shows it is v1.2.1.06 always.
The video link and control seem normal, except that everytime I power up the machine, "gimbal calibration error" message always pops up.
No response from DJI still.
Should I just ignore the firmware version and fly the bird with care?
I guess, if a newer firmware coming out later, I should be able to upgrade it and leave this funny hybird version
2015-8-16
retret66
Pls post the contents of the hidden file on MISC/LOG...Pilot App should show 1.30
2015-8-16
stan
retret66 Posted at 2015-8-17 09:27
After several repeat attempts of upgrade/downgrade, look like that I cleared all error messages in the .txt file. Now the messages are either abort or success. But still Pilot App shows v.1.2.1.06. Anyway, I proceeded to upgrade the RC without problem, then install the DJI GO. I checked on the DJI Go, the firmware version now shown is N/A, really funny!  Anyway, here is the .txt file under the MSIC/LOG directory
[00004902]Delete history success.
[00005379]========== remo-con disconnect. boot(15) ============
[00005495]Packet [C:\WM610_FW_V01.03.00.00.bin] detected, card sn [0x00000019].
[00005605]Packet upgrade start...
[00005749]Packet checking...
[00005893]Packet vlink 01.03.0000 <-> 01.02.0000.
[00006019]Record vlink 01.03.0000 <-> 01.02.0000 (flow = 0).
[00006157]Done.
[00006266]Version checking[1]...
[00006365][01 00][00] v1.19.3422 -> v1.19.3422
[00006465][01 01][00] v1.19.3422 -> v1.19.3422
[00006589][03 05][00] v34.1.0.5 -> v34.1.0.5
[00006733][03 06][00] v2.2.6.33 -> v2.2.6.33
[00006851][04 00][00] v1.26.0.3 -> v1.26.0.3
[00006988][05 00][00] v3.0.6.1 -> v3.0.6.1
[00007093][08 00][00] v1.14.0.25 -> v1.14.0.25
[00007204][09 00][00] v1.8.0.0 -> v1.8.0.0
[00007369][11 00][00] v3.7.15.9 -> v3.7.15.9
[00007528][12 00][00] v1.8.0.0 -> v1.8.0.0
[00007708][12 01][00] v1.8.0.0 -> v1.8.0.0
[00007908][12 02][00] v1.8.0.0 -> v1.8.0.0
[00008087][12 03][00] v1.8.0.0 -> v1.8.0.0
[00008358][15 00][00] v1.1.2.0 -> v1.1.2.0
[00008527][17 00][00] v1.1.0.4 -> v1.1.0.4
[00008708][17 01][00] v2.0.0.8 -> v2.0.0.8
[00008818][19 00][00] v1.0.8.96 -> v1.0.8.96
[00010931]Packet upgrade cancelled at version checking.
[00004719]========== remo-con disconnect. boot(15) ============
[00004813]Packet [C:\WM610_FW_V01.03.00.00.bin] detected, card sn [0x00000019].
[00004922]Packet upgrade start...
[00005082]Packet checking...
[00005240]Packet vlink 01.03.0000 <-> 01.02.0000.
[00005385]Record vlink 01.03.0000 <-> 01.02.0000 (flow = 0).
[00005482]Done.
[00005623]Version checking[1]...
[00005763][01 00][00] v1.19.3422 -> v1.19.3422
[00005905][01 01][00] v1.19.3422 -> v1.19.3422
[00006086][03 05][00] v34.1.0.5 -> v34.1.0.5
[00006246][03 06][00] v2.2.6.33 -> v2.2.6.33
[00006352][04 00][00] v1.26.0.3 -> v1.26.0.3
[00006469][05 00][00] v3.0.6.1 -> v3.0.6.1
[00006582][08 00][00] v1.14.0.25 -> v1.14.0.25
[00006706][09 00][00] v1.8.0.0 -> v1.8.0.0
[00006827][11 00][00] v3.7.15.9 -> v3.7.15.9
[00007106][12 00][00] v1.8.0.0 -> v1.8.0.0
[00007306][12 01][00] v1.8.0.0 -> v1.8.0.0
[00007446][12 02][00] v1.8.0.0 -> v1.8.0.0
[00007626][12 03][00] v1.8.0.0 -> v1.8.0.0
[00007832][15 00][00] v1.1.2.0 -> v1.1.2.0
[00008006][17 00][00] v1.1.0.4 -> v1.1.0.4
[00008246][17 01][00] v2.0.0.8 -> v2.0.0.8
[00008404][19 00][00] v1.0.8.96 -> v1.0.8.96
[00010534]Packet upgrade cancelled at version checking.
[00004716]========== remo-con disconnect. boot(15) ============
[00004812]Packet [C:\WM610_FW_V01.03.00.00.bin] detected, card sn [0x00000019].
[00004938]Packet upgrade start...
[00005093]Packet checking...
[00005247]Packet vlink 01.03.0000 <-> 01.02.0000.
[00005380]Record vlink 01.03.0000 <-> 01.02.0000 (flow = 0).
[00005492]Done.
[00005618]Version checking[1]...
[00005758][01 00][00] v1.19.3422 -> v1.19.3422
[00005901][01 01][00] v1.19.3422 -> v1.19.3422
[00006087][03 05][00] v34.1.0.5 -> v34.1.0.5
[00006241][03 06][00] v2.2.6.33 -> v2.2.6.33
[00006347][04 00][00] v1.26.0.3 -> v1.26.0.3
[00006462][05 00][00] v3.0.6.1 -> v3.0.6.1
[00014064][08 00][00] v1.14.0.25 -> v1.14.0.25
[00014166][09 00][00] v1.8.0.0 -> v1.8.0.0
[00014320][11 00][00] v3.7.15.9 -> v3.7.15.9
[00014460][12 00][00] v1.8.0.0 -> v1.8.0.0
[00014601][12 01][00] v1.8.0.0 -> v1.8.0.0
[00014742][12 02][00] v1.8.0.0 -> v1.8.0.0
[00014880][12 03][00] v1.8.0.0 -> v1.8.0.0
[00015000][15 00][00] v1.1.2.0 -> v1.1.2.0
[00015120][17 00][00] v1.1.0.4 -> v1.1.0.4
[00015280][17 01][00] v2.0.0.8 -> v2.0.0.8
[00015386][19 00][00] v1.0.8.96 -> v1.0.8.96
[00017483]Packet upgrade cancelled at version checking.
[00004619]========== remo-con disconnect. boot(15) ============
[00004702]Packet [C:\WM610_FW_V01.02.01.06.bin] detected, card sn [0x27baf9de].
[00004878]Packet checking...
[00005012]Packet vlink 01.02.0000 <-> 01.02.0000.
[00005151]Record vlink 01.03.0000 <-> 01.02.0000 (flow = 1).
[00005284]Done.
[00005526]Version checking[1]...
[00005652][01 00][00] v1.19.3422 -> v1.8.2729
[00005783][01 01][00] v1.19.3422 -> v1.8.2729
[00005949][03 05][00] v34.1.0.5 -> v34.1.0.5
[00006089][03 06][00] v2.2.6.33 -> v2.0.5.14
[00006182][04 00][00] v1.26.0.3 -> v1.16.0.76
[00006329][05 00][00] v3.0.6.1 -> v2.5.6.1
[00006424][08 00][00] v1.14.0.25 -> v1.12.0.21
[00006530][09 00][00] v1.8.0.0 -> v1.7.0.3
[00006649][11 00][00] v3.7.15.9 -> v3.7.1.0
[00006809][12 00][00] v1.8.0.0 -> v1.3.0.60
[00006930][12 01][00] v1.8.0.0 -> v1.3.0.60
[00007110][12 02][00] v1.8.0.0 -> v1.3.0.60
[00007270][12 03][00] v1.8.0.0 -> v1.3.0.60
[00007448][15 00][00] v1.1.2.0 -> v1.1.2.0
[00007610][17 00][00] v1.1.0.4 -> v1.1.0.1 need upgrade.
[00007830][17 01][00] v2.0.0.8 -> v2.0.0.1 need upgrade.
[00007976][19 00][00] v1.0.8.96 -> v1.0.8.96
[00008111]Done.
[00010244]Waiting for user confirm...
[00020323]Timeout, start upgrade automatically.
[00020478]Firmware upgrading[1]...
[00020575][17 00] Firmware upgrade start...
[00080662][17 00] Firmware upgrade finished successfully.
[00080749][17 01] Firmware upgrade start...
[00106558][17 01] Firmware upgrade finish without reboot.
[00136640][17 01] Firmware upgrade finished successfully.
[00136715]Done.
[00136794]Version checking[2]...
[00136874][01 00][00] v1.19.3422 -> v1.8.2729
[00136966][01 01][00] v1.19.3422 -> v1.8.2729
[00137079][03 05][00] v34.1.0.5 -> v34.1.0.5
[00137199][03 06][00] v2.2.6.33 -> v2.0.5.14
[00137313][04 00][00] v1.26.0.3 -> v1.16.0.76
[00137438][05 00][00] v3.0.6.1 -> v2.5.6.1
[00137523][08 00][00] v1.14.0.25 -> v1.12.0.21
[00137613][09 00][00] v1.8.0.0 -> v1.7.0.3
[00137742][11 00][00] v3.7.15.9 -> v3.7.1.0
[00137878][12 00][00] v1.8.0.0 -> v1.3.0.60
[00138018][12 01][00] v1.8.0.0 -> v1.3.0.60
[00138158][12 02][00] v1.8.0.0 -> v1.3.0.60
[00138338][12 03][00] v1.8.0.0 -> v1.3.0.60
[00138473][15 00][00] v1.1.2.0 -> v1.1.2.0
[00138579][17 00][05] v1.1.0.1 -> v1.1.0.1
[00138719][17 01][05] v2.0.0.1 -> v2.0.0.1
[00138934][19 00][00] v1.0.8.96 -> v1.0.8.96
[00139009]Packet upgrade finish successfully.
[00004591]========== remo-con disconnect. boot(15) ============
[00004671]Packet [C:\WM610_FW_V01.03.00.00.bin] detected, card sn [0x00306dc9].
[00004751]Packet upgrade start...
[00004829]Packet checking...
[00004952]Packet vlink 01.03.0000 <-> 01.02.0000.
[00005084]Record vlink 01.03.0000 <-> 01.02.0000 (flow = 0).
[00005216]Done.
[00005326]Version checking[1]...
[00005417][01 00][00] v1.19.3422 -> v1.19.3422
[00005541][01 01][00] v1.19.3422 -> v1.19.3422
[00005686][03 05][00] v34.1.0.5 -> v34.1.0.5
[00005868][03 06][00] v2.2.6.33 -> v2.2.6.33
[00005981][04 00][00] v1.26.0.3 -> v1.26.0.3
[00006105][05 00][00] v3.0.6.1 -> v3.0.6.1
[00006192][08 00][00] v1.14.0.25 -> v1.14.0.25
[00006321][09 00][00] v1.8.0.0 -> v1.8.0.0
[00006425][11 00][00] v3.7.15.9 -> v3.7.15.9
[00006585][12 00][00] v1.8.0.0 -> v1.8.0.0
[00006725][12 01][00] v1.8.0.0 -> v1.8.0.0
[00006845][12 02][00] v1.8.0.0 -> v1.8.0.0
[00007005][12 03][00] v1.8.0.0 -> v1.8.0.0
[00007169][15 00][00] v1.1.2.0 -> v1.1.2.0
[00007326][17 00][00] v1.1.0.1 -> v1.1.0.4 need upgrade.
[00007546][17 01][00] v2.0.0.1 -> v2.0.0.8 need upgrade.
[00007702][19 00][00] v1.0.8.96 -> v1.0.8.96
[00007860]Done.
[00009983]Waiting for user confirm...
[00020064]Timeout, start upgrade automatically.
[00020218]Firmware upgrading[1]...
[00020324][17 00] Firmware upgrade start...
[00081518][17 00] Firmware upgrade finished successfully.
[00081602][17 01] Firmware upgrade start...
[00135314][17 01] Firmware upgrade finished successfully.
[00135396]Done.
[00135470]Version checking[2]...
[00135549][01 00][00] v1.19.3422 -> v1.19.3422
[00135622][01 01][00] v1.19.3422 -> v1.19.3422
[00135755][03 05][00] v34.1.0.5 -> v34.1.0.5
[00135874][03 06][00] v2.2.6.33 -> v2.2.6.33
[00135964][04 00][00] v1.26.0.3 -> v1.26.0.3
[00136097][05 00][00] v3.0.6.1 -> v3.0.6.1
[00136182][08 00][00] v1.14.0.25 -> v1.14.0.25
[00136385][09 00][00] v1.8.0.0 -> v1.8.0.0
[00136501][11 00][00] v3.7.15.9 -> v3.7.15.9
[00136635][12 00][00] v1.8.0.0 -> v1.8.0.0
[00136755][12 01][00] v1.8.0.0 -> v1.8.0.0
[00136895][12 02][00] v1.8.0.0 -> v1.8.0.0
[00137015][12 03][00] v1.8.0.0 -> v1.8.0.0
[00137158][15 00][00] v1.1.2.0 -> v1.1.2.0
[00137295][17 00][05] v1.1.0.4 -> v1.1.0.4
[00137434][17 01][05] v2.0.0.8 -> v2.0.0.8
[00137524][19 00][00] v1.0.8.96 -> v1.0.8.96
[00137595]Packet upgrade finish successfully.
[00004590]========== remo-con disconnect. boot(15) ============
[00004672]Packet [C:\WM610_FW_V01.03.00.00.bin] detected, card sn [0x00306dc9].
[00004753]Packet upgrade start...
[00004838]Packet checking...
[00004950]Packet vlink 01.03.0000 <-> 01.02.0000.
[00005083]Record vlink 01.03.0000 <-> 01.02.0000 (flow = 0).
[00005216]Done.
[00005327]Version checking[1]...
[00005521][01 01][00] v1.19.3422 -> v1.19.3422
[00005698][03 05][00] v34.1.0.5 -> v34.1.0.5
[00005858][03 06][00] v2.2.6.33 -> v2.2.6.33
[00005972][04 00][00] v1.26.0.3 -> v1.26.0.3
[00006118][05 00][00] v3.0.6.1 -> v3.0.6.1
[00006206][08 00][00] v1.14.0.25 -> v1.14.0.25
[00006340][09 00][00] v1.8.0.0 -> v1.8.0.0
[00006478][11 00][00] v3.7.15.9 -> v3.7.15.9
[00006617][12 00][00] v1.8.0.0 -> v1.8.0.0
[00006757][12 01][00] v1.8.0.0 -> v1.8.0.0
[00006898][12 02][00] v1.8.0.0 -> v1.8.0.0
[00007058][12 03][00] v1.8.0.0 -> v1.8.0.0
[00007213][15 00][00] v1.1.2.0 -> v1.1.2.0
[00007379][17 00][00] v1.1.0.4 -> v1.1.0.4
[00007579][17 01][00] v2.0.0.8 -> v2.0.0.8
[00007718][19 00][00] v1.0.8.96 -> v1.0.8.96
[00009872]Packet upgrade cancelled at version checking.
[00004600]========== remo-con disconnect. boot(15) ============
[00004680]Packet [C:\WM610_FW_V01.03.00.00.bin] detected, card sn [0x00306dc9].
[00004759]Packet upgrade start...
[00004840]Packet checking...
[00004956]Packet vlink 01.03.0000 <-> 01.02.0000.
[00005359]Done.
[00005483]Version checking[1]...
[00005586][01 00][00] v1.19.3422 -> v1.19.3422
[00005901][03 05][00] v34.1.0.5 -> v34.1.0.5
[00006059][03 06][00] v2.2.6.33 -> v2.2.6.33
[00006153][04 00][00] v1.26.0.3 -> v1.26.0.3
[00006302][05 00][00] v3.0.6.1 -> v3.0.6.1
[00006388][08 00][00] v1.14.0.25 -> v1.14.0.25
[00006502][09 00][00] v1.8.0.0 -> v1.8.0.0
[00006619][11 00][00] v3.7.15.9 -> v3.7.15.9
[00006778][12 00][00] v1.8.0.0 -> v1.8.0.0
[00006940][12 01][00] v1.8.0.0 -> v1.8.0.0
[00007118][12 02][00] v1.8.0.0 -> v1.8.0.0
[00007259][12 03][00] v1.8.0.0 -> v1.8.0.0
[00007441][15 00][00] v1.1.2.0 -> v1.1.2.0
[00007599][17 00][00] v1.1.0.4 -> v1.1.0.4
[00007841][17 01][00] v2.0.0.8 -> v2.0.0.8
[00007994][19 00][00] v1.0.8.96 -> v1.0.8.96
[00010112]Packet upgrade cancelled at version checking.
[00004651]========== remo-con disconnect. boot(15) ============
[00004729]Packet [C:\WM610_FW_V01.02.01.06.bin] detected, card sn [0x27baf9de].
[00004813]Packet upgrade start...
[00004924]Packet checking...
[00005063]Packet vlink 01.02.0000 <-> 01.02.0000.
[00005196]Record vlink 01.03.0000 <-> 01.02.0000 (flow = 1).
[00005312]Done.
[00005404]Version checking[1]...
[00005521][01 00][00] v1.19.3422 -> v1.8.2729
[00005640][01 01][00] v1.19.3422 -> v1.8.2729
[00005802][03 05][00] v34.1.0.5 -> v34.1.0.5
[00005942][03 06][00] v2.2.6.33 -> v2.0.5.14
[00006055][04 00][00] v1.26.0.3 -> v1.16.0.76
[00006162][05 00][00] v3.0.6.1 -> v2.5.6.1
[00013758][08 00][00] v1.14.0.25 -> v1.12.0.21
[00013856][09 00][00] v1.8.0.0 -> v1.7.0.3
[00013962][11 00][00] v3.7.15.9 -> v3.7.1.0
[00014101][12 00][00] v1.8.0.0 -> v1.3.0.60
[00014221][12 01][00] v1.8.0.0 -> v1.3.0.60
[00014381][12 02][00] v1.8.0.0 -> v1.3.0.60
[00014521][12 03][00] v1.8.0.0 -> v1.3.0.60
[00014632][15 00][00] v1.1.2.0 -> v1.1.2.0
[00014746][17 00][00] v1.1.0.4 -> v1.1.0.1 need upgrade.
[00014961][17 01][00] v2.0.0.8 -> v2.0.0.1 need upgrade.
[00015061][19 00][00] v1.0.8.96 -> v1.0.8.96
[00015136]Done.
[00017214]Waiting for user confirm...
[00027294]Timeout, start upgrade automatically.
[00027445]Firmware upgrading[1]...
[00027546][17 00] Firmware upgrade start...
[00087474][17 00] Firmware upgrade finished successfully.
[00087563][17 01] Firmware upgrade start...
[00137370][17 01] Firmware upgrade finished successfully.
[00137451]Done.
[00137526]Version checking[2]...
[00137603][01 00][00] v1.19.3422 -> v1.8.2729
[00137678][01 01][00] v1.19.3422 -> v1.8.2729
[00137790][03 05][00] v34.1.0.5 -> v34.1.0.5
[00137910][03 06][00] v2.2.6.33 -> v2.0.5.14
[00137999][04 00][00] v1.26.0.3 -> v1.16.0.76
[00138110][05 00][00] v3.0.6.1 -> v2.5.6.1
[00138193][08 00][00] v1.14.0.25 -> v1.12.0.21
[00138319][09 00][00] v1.8.0.0 -> v1.7.0.3
[00138411][11 00][00] v3.7.15.9 -> v3.7.1.0
[00138551][12 00][00] v1.8.0.0 -> v1.3.0.60
[00138691][12 01][00] v1.8.0.0 -> v1.3.0.60
[00138833][12 02][00] v1.8.0.0 -> v1.3.0.60
[00138950][12 03][00] v1.8.0.0 -> v1.3.0.60
[00139090][15 00][00] v1.1.2.0 -> v1.1.2.0
[00139190][17 00][05] v1.1.0.1 -> v1.1.0.1
[00139350][17 01][05] v2.0.0.1 -> v2.0.0.1
[00139455][19 00][00] v1.0.8.96 -> v1.0.8.96
[00139533]Packet upgrade finish successfully.
[00004622]========== remo-con disconnect. boot(15) ============
[00004705]Packet [C:\WM610_FW_V01.03.00.00.bin] detected, card sn [0x00306dc9].
[00004786]Packet upgrade start...
[00004880]Packet checking...
[00005012]Packet vlink 01.03.0000 <-> 01.02.0000.
[00005151]Record vlink 01.03.0000 <-> 01.02.0000 (flow = 0).
[00005284]Done.
[00005369]Version checking[1]...
[00005483][01 00][00] v1.19.3422 -> v1.19.3422
[00005576][01 01][00] v1.19.3422 -> v1.19.3422
[00005751][03 05][00] v34.1.0.5 -> v34.1.0.5
[00005910][03 06][00] v2.2.6.33 -> v2.2.6.33
[00006027][04 00][00] v1.26.0.3 -> v1.26.0.3
[00006130][05 00][00] v3.0.6.1 -> v3.0.6.1
[00006387][08 00][00] v1.14.0.25 -> v1.14.0.25
[00006610][11 00][00] v3.7.15.9 -> v3.7.15.9
[00006749][12 00][00] v1.8.0.0 -> v1.8.0.0
[00006909][12 01][00] v1.8.0.0 -> v1.8.0.0
[00007090][12 02][00] v1.8.0.0 -> v1.8.0.0
[00007230][12 03][00] v1.8.0.0 -> v1.8.0.0
[00007510][15 00][00] v1.1.2.0 -> v1.1.2.0
[00007670][17 00][00] v1.1.0.1 -> v1.1.0.4 need upgrade.
[00007910][17 01][00] v2.0.0.1 -> v2.0.0.8 need upgrade.
[00008065][19 00][00] v1.0.8.96 -> v1.0.8.96
[00008173]Done.
[00010266]Waiting for user confirm...
[00020343]Timeout, start upgrade automatically.
[00020493]Firmware upgrading[1]...
[00020592][17 00] Firmware upgrade start...
[00081822][17 00] Firmware upgrade finished successfully.
[00081905][17 01] Firmware upgrade start...
[00135558][17 01] Firmware upgrade finished successfully.
[00135635]Done.
[00135708]Version checking[2]...
[00135783][01 00][00] v1.19.3422 -> v1.19.3422
[00135861][01 01][00] v1.19.3422 -> v1.19.3422
[00135978][03 05][00] v34.1.0.5 -> v34.1.0.5
[00136101][03 06][00] v2.2.6.33 -> v2.2.6.33
[00136183][04 00][00] v1.26.0.3 -> v1.26.0.3
[00136339][05 00][00] v3.0.6.1 -> v3.0.6.1
[00136416][08 00][00] v1.14.0.25 -> v1.14.0.25
[00136519][09 00][00] v1.8.0.0 -> v1.8.0.0
[00136619][11 00][00] v3.7.15.9 -> v3.7.15.9
[00136739][12 00][00] v1.8.0.0 -> v1.8.0.0
[00136879][12 01][00] v1.8.0.0 -> v1.8.0.0
[00136999][12 02][00] v1.8.0.0 -> v1.8.0.0
[00137119][12 03][00] v1.8.0.0 -> v1.8.0.0
[00137255][15 00][00] v1.1.2.0 -> v1.1.2.0
[00137359][17 00][05] v1.1.0.4 -> v1.1.0.4
[00137503][17 01][05] v2.0.0.8 -> v2.0.0.8
[00137588][19 00][00] v1.0.8.96 -> v1.0.8.96
[00137669]Packet upgrade finish successfully.
[00004705]========== 2015.08.17 22:57:08. boot(15) ============
[00004787]Packet [C:\WM610_FW_V01.03.00.00.bin] detected, card sn [0x27baf9de].
[00004871]Packet upgrade start...
[00004988]Packet checking...
[00005125]Packet vlink 01.03.0000 <-> 01.02.0000.
[00005373]Record vlink 01.03.0000 <-> 01.02.0000 (flow = 0).
[00005464]Done.
[00005578]Version checking[1]...
[00005689][01 00][00] v1.19.3422 -> v1.19.3422
[00005819][01 01][00] v1.19.3422 -> v1.19.3422
[00005987][03 05][00] v34.1.0.5 -> v34.1.0.5
[00006146][03 06][00] v2.2.6.33 -> v2.2.6.33
[00006279][04 00][00] v1.26.0.3 -> v1.26.0.3
[00006387][05 00][00] v3.0.6.1 -> v3.0.6.1
[00006489][08 00][00] v1.14.0.25 -> v1.14.0.25
[00006593][09 00][00] v1.8.0.0 -> v1.8.0.0
[00006707][11 00][00] v3.7.15.9 -> v3.7.15.9
[00006846][12 00][00] v1.8.0.0 -> v1.8.0.0
[00006986][12 01][00] v1.8.0.0 -> v1.8.0.0
[00007167][12 02][00] v1.8.0.0 -> v1.8.0.0
[00007347][12 03][00] v1.8.0.0 -> v1.8.0.0
[00007544][15 00][00] v1.1.2.0 -> v1.1.2.0
[00007707][17 00][00] v1.1.0.4 -> v1.1.0.4
[00007947][17 01][00] v2.0.0.8 -> v2.0.0.8
[00008097][19 00][00] v1.0.8.96 -> v1.0.8.96
[00010210]Packet upgrade cancelled at version checking.
[00006733]========== 2015.08.17 22:58:25. boot(15) ============
[00006828]Packet [C:\WM610_FW_V01.03.00.00.bin] detected, card sn [0x27baf9de].
[00006942]Packet upgrade start...
[00007066]Packet checking...
[00007196]Packet vlink 01.03.0000 <-> 01.02.0000.
[00007327]Record vlink 01.03.0000 <-> 01.02.0000 (flow = 0).
[00007463]Done.
[00007612]Version checking[1]...
[00007747][01 00][00] v1.19.3422 -> v1.19.3422
[00007875][01 01][00] v1.19.3422 -> v1.19.3422
[00008030][03 05][00] v34.1.0.5 -> v34.1.0.5
[00008170][03 06][00] v2.2.6.33 -> v2.2.6.33
[00008297][04 00][00] v1.26.0.3 -> v1.26.0.3
[00008410][05 00][00] v3.0.6.1 -> v3.0.6.1
[00008634][08 00][00] v1.14.0.25 -> v1.14.0.25
[00008725][09 00][00] v1.8.0.0 -> v1.8.0.0
[00008830][11 00][00] v3.7.15.9 -> v3.7.15.9
[00008949][12 00][00] v1.8.0.0 -> v1.8.0.0
[00009071][12 01][00] v1.8.0.0 -> v1.8.0.0
[00009209][12 02][00] v1.8.0.0 -> v1.8.0.0
[00009349][12 03][00] v1.8.0.0 -> v1.8.0.0
[00009553][15 00][00] v1.1.2.0 -> v1.1.2.0
[00009930][17 00][00] v1.1.0.4 -> v1.1.0.4
[00010210][17 01][00] v2.0.0.8 -> v2.0.0.8
[00010335][19 00][00] v1.0.8.96 -> v1.0.8.96
[00012418]Packet upgrade cancelled at version checking.
2015-8-17
retret66
that seems like a normal output
2015-8-17
retret66
check your camera FAN if its turning or missing a blade maybe..My problem came back...so we both having the same issue and requested to have an exchange from DJI..Mine is a long story, after the update the no signal is chronic..But remote signal is full..I can fly the aircraft no problem, it can take a video or pic, but there is no feed going to android or IOS..So I am flying blind..
[00032253]Packet checking...
[00032330]Packet vlink 01.02.0000 <-> 01.02.0000.
[00032404]Record vlink 01.03.0000 <-> 01.02.0000 (flow = 1).
[00032478]Done.
[00032555]Version checking[1]...
[00032630][01 00][00] v1.19.3422 -> v1.8.2729
[00032704][01 01][00] v1.19.3422 -> v1.8.2729
[00032829][03 05][00] v34.1.0.5 -> v34.1.0.5
[00032956][03 06][00] v2.2.6.33 -> v2.0.5.14
[00033036][04 00][00] v1.26.0.3 -> v1.16.0.76
[00033151][05 00][00] v3.0.6.1 -> v2.5.6.1
[00045725][08 00][00] device not detected.
[00045818][09 00][00] v1.8.0.0 -> v1.7.0.3
[00045929][11 00][00] v3.7.15.9 -> v3.7.1.0
[00046049][12 00][00] v1.8.0.0 -> v1.3.0.60
[00046170][12 01][00] v1.8.0.0 -> v1.3.0.60
[00046289][12 02][00] v1.8.0.0 -> v1.3.0.60
[00046409][12 03][00] v1.8.0.0 -> v1.3.0.60
[00058983][15 00][00] device not detected.
[00059088][17 00][00] v1.1.0.1 -> v1.1.0.1
[00059248][17 01][00] v2.0.0.1 -> v2.0.0.1
[00059331][19 00][00] v1.0.8.96 -> v1.0.8.96
[00061405]Packet upgrade failed at version checking.
2015-8-17
CrabHawk
Flight distance : 7782 ft
This is INSANE.
2015-8-17
stan
Flight distance : 8834869 ft
I think my upgrade is now clean and success, despite the GO APP still shows the firmware version is N/A.
Now, I think I have figured out what went wrong.
I used a 4G SD card for upgrade, one that comes with my P2V+, my previous two upgrades on Inspire 1 have no problem, but this time there are some corrupted bin file messages after parity checking. I thought this standard 4G SD card is not fast enough, so I used an Extreme class 32G SD card to try again, this times, the number of corrupted messages is reduced, but still can not achieve a clean upgrade, so I repeated the downgrade and upgrade progress several times, but the corrupted messages still hang around.
Finally, I noticed that there is always a gimbal calibration error when power up and the camera is shaking a bit before it stabilized, despite that the video link and control seems normal, I began to suspect there may be some hardware issues, so I thoughtfully checked the cable underneath the gimbal connecting the camera to the main unit. After carefully unplugged, cleaned and plugged it back, bingo! the upgrade now has fully success or abort status without the corrupted bin file message.
To summarize my experience;
Slower SD card that works in previous upgrade does not necessarily work in this newer firmware upgrade, possibly they have re-tuned the software reading speed of flash memory card to only cater for higher speed SD cards
Despite having normal video pump, check the cable connecting the camera to main unit, there may some timing jitters for loosy connected cable
hope that helps!
I will test fly my Inspire 1 with extreme care this weekend (my GO APPS still shows firmware version N/A) , cheers!
2015-8-18
teamnest1
Flight distance : 18484 ft
retret66 Posted at 2015-8-18 02:29
check your camera FAN if its turning or missing a blade maybe..My problem came back...so we both hav ...
I am having the same exact issue as you. I can turn motors on, I can move the gimbal, but my aircraft will NOT take the update. It simply beeps 3 times then goes to the long DDDDDDDDDDDDD noise and the logs say that the update failed.
I really do not want to have to ship it all the way back to California and wait 2+ months for it to come back.
Stan, I will check my camera connectors, I hope I will be as lucky as you!
2015-8-21
Tahoe_Ed
Flight distance : 2605 ft
Stan, your upgrade was completed long ago from the MISC/Log/xxxx.txt.  It will stop at version checking if all the files are on the current version.  @Teamnest1, please post the MISC/Log/xxxx.txt file here so we can take a look at it.
2015-8-24
teamnest1
Tahoe_Ed Posted at 2015-8-25 11:15
Stan, your upgrade was completed long ago from the MISC/Log/xxxx.txt.  It will stop at version check ...
I apologize for the late reply!I just tried again. I reformatted the card both on the computer and then on the DJI GO App. (SD card that came with inspire)
I then tried to upgrade the aircraft and received an error.
(I apologize for the long log)
[00006227][01 00] Firmware upgrade finished successfully.
[00006332]Done.
[00006370]Packet [C:\WM610_FW_V01.03.00.00.bin] resumed, card sn [0x60ce191d].
[00006405]Packet vlink 01.03.0000 <-> 01.02.0000.
[00006467]Version checking[2]...
[00006498][01 00][05] v1.19.3422 -> v1.19.3422
[00006533][01 01][00] v1.8.2729 -> v1.19.3422 need upgrade
[00006596][03 05][00] v34.1.0.5 -> v34.1.0.5
[00006676][03 06][00] v2.0.5.14 -> v2.2.6.33 need upgrade.
[00006712][04 00][00] v1.16.0.76 -> v1.26.0.3 need upgrade.
[00006796][05 00][00] v2.5.6.1 -> v3.0.6.1 need upgrade.
[00011836][08 00][00] v1.12.0.21 -> v1.14.0.25 need upgrade.
[00011876][09 00][00] v1.7.0.3 -> v1.8.0.0 need upgrade.
[00011935][11 00][00] v3.7.1.0 -> v3.7.15.9 need upgrade.
[00012015][12 00][00] v1.3.0.60 -> v1.8.0.0 need upgrade.
[00012096][12 01][00] v1.3.0.60 -> v1.8.0.0 need upgrade.
[00012176][12 02][00] v1.3.0.60 -> v1.8.0.0 need upgrade.
[00012255][12 03][00] v1.3.0.60 -> v1.8.0.0 need upgrade.
[00015031][15 00][00] device not detected.
[00015075][17 00][00] v1.1.0.1 -> v1.1.0.4 need upgrade.
[00015175][17 01][00] v2.0.0.1 -> v2.0.0.8 need upgrade.
[00015215][19 00][00] v1.0.8.96 -> v1.0.8.96
[00015246]Done.
[00015274]Firmware upgrading[2]...
[00015412][01 01] Firmware upgrade start...
[00045669][01 01] Firmware upgrade finished successfully.
[00046537][08 00] Firmware upgrade start...
[00371015][08 00] Firmware upgrade finished successfully.
[00371061][12 00] Firmware upgrade start...
[00425738][12 00] Firmware upgrade finished successfully.
[00425784][12 01] Firmware upgrade start...
[00480794][12 01] Firmware upgrade finished successfully.
[00480838][12 02] Firmware upgrade start...
[00536129][12 02] Firmware upgrade finished successfully.
[00536173][12 03] Firmware upgrade start...
[00590604][12 03] Firmware upgrade finished successfully.
[00590823][03 06] Firmware upgrade start...
[00814384][03 06] Firmware upgrade finished successfully.
[00814438][17 00] Firmware upgrade start...
[00876099][17 00] Firmware upgrade finished successfully.
[00876143][17 01] Firmware upgrade start...
[00004522]========== remo-con disconnect. boot(15) ============
[00004563]Packet [C:\WM610_FW_V01.03.00.00.bin] detected, card sn [0x60ce191d].
[00004595]Packet upgrade start...
[00004632]Packet checking...
[00004670]Packet vlink 01.03.0000 <-> 01.02.0000.
[00004734]Done.
[00004769]Version checking[1]...
[00004803][01 00][00] v1.19.3422 -> v1.19.3422
[00004835][01 01][00] v1.19.3422 -> v1.19.3422
[00004918][03 05][00] v34.1.0.5 -> v34.1.0.5
[00004998][03 06][00] v2.2.6.33 -> v2.2.6.33
[00005055][04 00][00] v1.16.0.76 -> v1.26.0.3 need upgrade.
[00005118][05 00][00] v2.5.6.1 -> v3.0.6.1 need upgrade.
[00005175][08 00][00] v1.14.0.25 -> v1.14.0.25
[00005243][09 00][00] v1.7.0.3 -> v1.8.0.0 need upgrade.
[00005318][11 00][00] v3.7.1.0 -> v3.7.15.9 need upgrade.
[00005398][12 00][00] v1.8.0.0 -> v1.8.0.0
[00005477][12 01][00] v1.8.0.0 -> v1.8.0.0
[00005564][12 02][00] v1.8.0.0 -> v1.8.0.0
[00005664][12 03][00] v1.8.0.0 -> v1.8.0.0
[00014279][15 00][00] device not detected.
[00014339][17 00][00] v1.1.0.4 -> v1.1.0.4
[00014437][17 01][00] v2.0.0.8 -> v2.0.0.8
[00014477][19 00][00] v1.0.8.96 -> v1.0.8.96
[00014510]Done.
[00016542]Waiting for user confirm...
[00026574]Timeout, start upgrade automatically.
[00026638]Firmware upgrading[1]...
[00026684][11 00] Firmware upgrade start...
[00107448][11 00] Firmware upgrade finished successfully.
[00107494][05 00] Firmware upgrade start...
[00151445][05 00] Firmware upgrade finished successfully.
[00151500][09 00] Firmware upgrade start...
[00198256][09 00] Firmware upgrade finished successfully.
[00198321][04 00] Firmware upgrade start...
[00260413][04 00] Firmware upgrade finished successfully.
[00260445]Done.
[00260475]Version checking[2]...
[00260507][01 00][00] v1.19.3422 -> v1.19.3422
[00260540][01 01][00] v1.19.3422 -> v1.19.3422
[00260607][03 05][00] v34.1.0.5 -> v34.1.0.5
[00260767][03 06][00] v2.2.6.33 -> v2.2.6.33
[00260806][04 00][05] v1.26.0.3 -> v1.26.0.3
[00260887][05 00][05] v3.0.6.1 -> v3.0.6.1
[00268433][08 00][00] v1.14.0.25 -> v1.14.0.25
[00268476][09 00][05] v1.8.0.0 -> v1.8.0.0
[00268546][11 00][05] v3.7.15.9 -> v3.7.15.9
[00268626][12 00][00] v1.8.0.0 -> v1.8.0.0
[00268726][12 01][00] v1.8.0.0 -> v1.8.0.0
[00268806][12 02][00] v1.8.0.0 -> v1.8.0.0
[00268907][12 03][00] v1.8.0.0 -> v1.8.0.0
[00273652][15 00][00] device not detected.
[00273711][17 00][00] v1.1.0.4 -> v1.1.0.4
[00273806][17 01][00] v2.0.0.8 -> v2.0.0.8
[00273856][19 00][00] v1.0.8.96 -> v1.0.8.96
[00273888]Packet upgrade failed at version checking.
[00004560]========== remo-con disconnect. boot(15) ============
[00004594]Packet [C:\WM610_FW_V01.03.00.00.bin] detected, card sn [0x60ce191d].
[00004633]Packet upgrade start...
[00004673]Packet checking...
[00004714]Packet vlink 01.03.0000 <-> 01.02.0000.
[00004779]Done.
[00004819]Version checking[1]...
[00004852][01 00][00] v1.19.3422 -> v1.19.3422
[00004888][01 01][00] v1.19.3422 -> v1.19.3422
[00004969][03 05][00] v34.1.0.5 -> v34.1.0.5
[00005041][03 06][00] v2.2.6.33 -> v2.2.6.33
[00005079][04 00][00] v1.26.0.3 -> v1.26.0.3
[00005161][05 00][00] v3.0.6.1 -> v3.0.6.1
[00005219][08 00][00] v1.14.0.25 -> v1.14.0.25
[00005276][09 00][00] v1.8.0.0 -> v1.8.0.0
[00005362][11 00][00] v3.7.15.9 -> v3.7.15.9
[00005461][12 00][00] v1.8.0.0 -> v1.8.0.0
[00005541][12 01][00] v1.8.0.0 -> v1.8.0.0
[00005641][12 02][00] v1.8.0.0 -> v1.8.0.0
[00005741][12 03][00] v1.8.0.0 -> v1.8.0.0
[00014517][15 00][00] device not detected.
[00014581][17 00][00] v1.1.0.4 -> v1.1.0.4
[00014681][17 01][00] v2.0.0.8 -> v2.0.0.8
[00014724][19 00][00] v1.0.8.96 -> v1.0.8.96
[00016757]Packet upgrade failed at version checking.
[00004556]========== remo-con disconnect. boot(15) ============
[00004595]Packet [C:\WM610_FW_V01.03.00.00.bin] detected, card sn [0x60ce191d].
[00004630]Packet upgrade start...
[00004764]Packet checking...
[00004798]Packet vlink 01.03.0000 <-> 01.02.0000.
[00004864]Done.
[00004898]Version checking[1]...
[00004933][01 00][00] v1.19.3422 -> v1.19.3422
[00004972][01 01][00] v1.19.3422 -> v1.19.3422
[00005035][03 05][00] v34.1.0.5 -> v34.1.0.5
[00005115][03 06][00] v2.2.6.33 -> v2.2.6.33
[00005182][04 00][00] v1.26.0.3 -> v1.26.0.3
[00005256][05 00][00] v3.0.6.1 -> v3.0.6.1
[00005321][08 00][00] v1.14.0.25 -> v1.14.0.25
[00005386][09 00][00] v1.8.0.0 -> v1.8.0.0
[00005455][11 00][00] v3.7.15.9 -> v3.7.15.9
[00005555][12 00][00] v1.8.0.0 -> v1.8.0.0
[00005655][12 01][00] v1.8.0.0 -> v1.8.0.0
[00005755][12 02][00] v1.8.0.0 -> v1.8.0.0
[00005855][12 03][00] v1.8.0.0 -> v1.8.0.0
[00014470][15 00][00] device not detected.
[00014535][17 00][00] v1.1.0.4 -> v1.1.0.4
[00014635][17 01][00] v2.0.0.8 -> v2.0.0.8
[00014679][19 00][00] v1.0.8.96 -> v1.0.8.96
[00016711]Packet upgrade failed at version checking.
[00004569]========== remo-con disconnect. boot(15) ============
[00004603]Packet [C:\WM610_FW_V01.03.00.00.bin] detected, card sn [0x60ce191d].
[00004639]Packet upgrade start...
[00004680]Packet checking...
[00004716]Packet vlink 01.03.0000 <-> 01.02.0000.
[00004784]Done.
[00004853][01 00][00] v1.19.3422 -> v1.19.3422
[00004892][01 01][00] v1.19.3422 -> v1.19.3422
[00004981][03 05][00] v34.1.0.5 -> v34.1.0.5
[00005063][03 06][00] v2.2.6.33 -> v2.2.6.33
[00005118][04 00][00] v1.26.0.3 -> v1.26.0.3
[00005220][05 00][00] v3.0.6.1 -> v3.0.6.1
[00005277][08 00][00] v1.14.0.25 -> v1.14.0.25
[00005351][09 00][00] v1.8.0.0 -> v1.8.0.0
[00005420][11 00][00] v3.7.1.0 -> v3.7.15.9 need upgrade.
[00005500][12 00][00] v1.8.0.0 -> v1.8.0.0
[00005580][12 01][00] v1.8.0.0 -> v1.8.0.0
[00005680][12 02][00] v1.8.0.0 -> v1.8.0.0
[00005780][12 03][00] v1.8.0.0 -> v1.8.0.0
[00014536][15 00][00] device not detected.
[00014600][17 00][00] v1.1.0.4 -> v1.1.0.4
[00014700][17 01][00] v2.0.0.8 -> v2.0.0.8
[00014840][19 00][00] v1.0.8.96 -> v1.0.8.96
[00014875]Done.
[00016913]Waiting for user confirm...
[00026948]Timeout, start upgrade automatically.
[00027014]Firmware upgrading[1]...
[00027059][11 00] Firmware upgrade start...
[00107736][11 00] Firmware upgrade finished successfully.
[00107771]Done.
[00107805]Version checking[2]...
[00107839][01 00][00] v1.19.3422 -> v1.19.3422
[00107873][01 01][00] v1.19.3422 -> v1.19.3422
[00107958][03 05][00] v34.1.0.5 -> v34.1.0.5
[00108032][03 06][00] v2.2.6.33 -> v2.2.6.33
[00108071][04 00][00] v1.26.0.3 -> v1.26.0.3
[00108132][05 00][00] v3.0.6.1 -> v3.0.6.1
[00113189][08 00][00] v1.14.0.25 -> v1.14.0.25
[00113231][09 00][00] v1.8.0.0 -> v1.8.0.0
[00113291][11 00][05] v3.7.15.9 -> v3.7.15.9
[00113391][12 00][00] v1.8.0.0 -> v1.8.0.0
[00113472][12 01][00] v1.8.0.0 -> v1.8.0.0
[00113570][12 02][00] v1.8.0.0 -> v1.8.0.0
[00113670][12 03][00] v1.8.0.0 -> v1.8.0.0
[00124236][15 00][00] device not detected.
[00124291][17 00][00] v1.1.0.4 -> v1.1.0.4
[00124430][17 01][00] v2.0.0.8 -> v2.0.0.8
[00124476][19 00][00] v1.0.8.96 -> v1.0.8.96
[00124511]Packet upgrade failed at version checking.
[00004576]========== 2015.08.08 17:45:54. boot(15) ============
[00004610]Packet [C:\WM610_FW_V01.03.00.00.bin] detected, card sn [0x60ce191d].
[00004646]Packet upgrade start...
[00004690]Packet checking...
[00004728]Packet vlink 01.03.0000 <-> 01.02.0000.
[00004797]Done.
[00004833]Version checking[1]...
[00004870][01 00][00] v1.19.3422 -> v1.19.3422
[00004906][01 01][00] v1.19.3422 -> v1.19.3422
[00004990][03 05][00] v34.1.0.5 -> v34.1.0.5
[00005070][03 06][00] v2.2.6.33 -> v2.2.6.33
[00005129][04 00][00] v1.26.0.3 -> v1.26.0.3
[00005211][05 00][00] v3.0.6.1 -> v3.0.6.1
[00005275][08 00][00] v1.14.0.25 -> v1.14.0.25
[00005358][09 00][00] v1.8.0.0 -> v1.8.0.0
[00005431][11 00][00] v3.7.15.9 -> v3.7.15.9
[00005511][12 00][00] v1.8.0.0 -> v1.8.0.0
[00005591][12 01][00] v1.8.0.0 -> v1.8.0.0
[00005791][12 02][00] v1.8.0.0 -> v1.8.0.0
[00005871][12 03][00] v1.8.0.0 -> v1.8.0.0
[00014488][15 00][00] device not detected.
[00014550][17 00][00] v1.1.0.4 -> v1.1.0.4
[00014651][17 01][00] v2.0.0.8 -> v2.0.0.8
[00014699][19 00][00] v1.0.8.96 -> v1.0.8.96
[00016736]Packet upgrade failed at version checking.
[00005170]========== remo-con disconnect. boot(15) ============
[00005215]Packet [C:\WM610_FW_V01.03.00.00.bin] detected, card sn [0xa0ce31e0].
[00005256]Packet upgrade start...
[00005303]Packet checking...
[00005349]Packet vlink 01.03.0000 <-> 01.02.0000.
[00005415]Done.
[00005451]Version checking[1]...
[00005489][01 00][00] v1.19.3422 -> v1.19.3422
[00005528][01 01][00] v1.19.3422 -> v1.19.3422
[00005599][03 05][00] v34.1.0.5 -> v34.1.0.5
[00005679][03 06][00] v2.2.6.33 -> v2.2.6.33
[00005731][04 00][00] v1.26.0.3 -> v1.26.0.3
[00005820][05 00][00] v3.0.6.1 -> v3.0.6.1
[00005884][08 00][00] v1.14.0.25 -> v1.14.0.25
[00005965][09 00][00] v1.8.0.0 -> v1.8.0.0
[00006039][11 00][00] v3.7.15.9 -> v3.7.15.9
[00006140][12 00][00] v1.8.0.0 -> v1.8.0.0
[00006221][12 01][00] v1.8.0.0 -> v1.8.0.0
[00006321][12 02][00] v1.8.0.0 -> v1.8.0.0
[00006421][12 03][00] v1.8.0.0 -> v1.8.0.0
[00015040][15 00][00] device not detected.
[00015099][17 00][00] v1.1.0.4 -> v1.1.0.4
[00015198][17 01][00] v2.0.0.8 -> v2.0.0.8
[00015248][19 00][00] v1.0.8.96 -> v1.0.8.96
[00017285]Packet upgrade failed at version checking.
[00004542]========== remo-con disconnect. boot(15) ============
[00004587]Packet [C:\WM610_FW_V01.02.01.07.bin] detected, card sn [0xa0ce31e0].
[00004681]Packet checking...
[00004720]Packet upgrade failed at packet checking.
[00005028]========== remo-con disconnect. boot(15) ============
[00005069]Packet [C:\WM610_FW_V01.02.01.07.bin] detected, card sn [0xa0ce31e0].
[00005108]Packet upgrade start...
[00005187]Packet upgrade failed at packet checking.
[00004597]========== remo-con disconnect. boot(15) ============
[00004634]Packet [C:\WM610_FW_V01.02.01.07.bin] detected, card sn [0x60ce191d].
[00004677]Packet upgrade start...
[00004720]Packet checking...
[00004763]Packet upgrade failed at packet checking.
[00004580]========== remo-con disconnect. boot(15) ============
[00004618]Packet [C:\WM610_FW_V01.02.01.07.bin] detected, card sn [0x60ce191d].
[00004654]Packet upgrade start...
[00004696]Packet checking...
[00004737]Packet upgrade failed at packet checking.
[00004519]========== remo-con disconnect. boot(15) ============
[00004556]Packet [C:\WM610_FW_V01.02.01.07.bin] detected, card sn [0x60ce191d].
[00004598]Packet upgrade start...
[00004639]Packet checking...
[00004678]Packet upgrade failed at packet checking.
[00004905]========== remo-con disconnect. boot(15) ============
[00004946]Packet [C:\WM610_FW_V01.02.01.06.bin] detected, card sn [0x60ce191d].
[00004992]Packet upgrade start...
[00005037]Packet checking...
[00005102]Packet vlink 01.02.0000 <-> 01.02.0000.
[00005193]Done.
[00005249]Version checking[1]...
[00005312][01 00][00] v1.19.3422 -> v1.8.2729
[00005377][01 01][00] v1.19.3422 -> v1.8.2729
[00005485][03 05][00] v34.1.0.5 -> v34.1.0.5
[00005564][03 06][00] v2.2.6.33 -> v2.0.5.14
[00005627][04 00][00] v1.26.0.3 -> v1.16.0.76
[00005704][05 00][00] v3.0.6.1 -> v2.5.6.1
[00005777][08 00][00] v1.14.0.25 -> v1.12.0.21
[00005843][09 00][00] v1.8.0.0 -> v1.7.0.3
[00005923][11 00][00] v3.7.15.9 -> v3.7.1.0
[00006023][12 00][00] v1.8.0.0 -> v1.3.0.60
[00006123][12 01][00] v1.8.0.0 -> v1.3.0.60
[00006224][12 02][00] v1.8.0.0 -> v1.3.0.60
[00006304][12 03][00] v1.8.0.0 -> v1.3.0.60
[00014918][15 00][00] device not detected.
[00014984][17 00][00] v1.1.0.4 -> v1.1.0.1
[00015083][17 01][00] v2.0.0.8 -> v2.0.0.1
[00015143][19 00][00] v1.0.8.96 -> v1.0.8.96
[00017184]Packet upgrade failed at version checking.
[00004529]========== remo-con disconnect. boot(15) ============
[00004574]Packet [C:\WM610_FW_V01.02.01.06.bin] detected, card sn [0x60ce191d].
[00004617]Packet upgrade start...
[00004667]Packet checking...
[00004710]Packet vlink 01.02.0000 <-> 01.02.0000.
[00004782]Done.
[00004824]Version checking[1]...
[00004871][01 00][00] v1.19.3422 -> v1.8.2729
[00004911][01 01][00] v1.19.3422 -> v1.8.2729
[00005019][03 05][00] v34.1.0.5 -> v34.1.0.5
[00005119][03 06][00] v2.2.6.33 -> v2.0.5.14
[00005189][04 00][00] v1.26.0.3 -> v1.16.0.76
[00005278][05 00][00] v3.0.6.1 -> v2.5.6.1
[00005334][08 00][00] v1.14.0.25 -> v1.12.0.21
[00005398][09 00][00] v1.8.0.0 -> v1.7.0.3
[00005499][11 00][00] v3.7.15.9 -> v3.7.1.0
[00005639][12 00][00] v1.8.0.0 -> v1.3.0.60
[00005738][12 01][00] v1.8.0.0 -> v1.3.0.60
[00005839][12 02][00] v1.8.0.0 -> v1.3.0.60
[00005938][12 03][00] v1.8.0.0 -> v1.3.0.60
[00014567][15 00][00] device not detected.
[00014638][17 00][00] v1.1.0.4 -> v1.1.0.1
[00014742][17 01][00] v2.0.0.8 -> v2.0.0.1
[00014793][19 00][00] v1.0.8.96 -> v1.0.8.96
[00016834]Packet upgrade failed at version checking.
[00004538]========== remo-con disconnect. boot(15) ============
[00004580]Packet [C:\WM610_FW_V01.02.01.06.bin] detected, card sn [0x60ce191d].
[00004625]Packet upgrade start...
[00004674]Packet checking...
[00004718]Packet vlink 01.02.0000 <-> 01.02.0000.
[00004793]Done.
[00004836]Version checking[1]...
[00004880][01 00][00] v1.19.3422 -> v1.8.2729
[00004923][01 01][00] v1.19.3422 -> v1.8.2729
[00005026][03 05][00] v34.1.0.5 -> v34.1.0.5
[00005126][03 06][00] v2.2.6.33 -> v2.0.5.14
[00005194][04 00][00] v1.26.0.3 -> v1.16.0.76
[00005285][05 00][00] v3.0.6.1 -> v2.5.6.1
[00015333][08 00][00] v1.14.0.25 -> v1.12.0.21
[00015384][09 00][00] v1.8.0.0 -> v1.7.0.3
[00015466][11 00][00] v3.7.15.9 -> v3.7.1.0
[00015564][12 00][00] v1.8.0.0 -> v1.3.0.60
[00015665][12 01][00] v1.8.0.0 -> v1.3.0.60
[00015765][12 02][00] v1.8.0.0 -> v1.3.0.60
[00015945][12 03][00] v1.8.0.0 -> v1.3.0.60
[00024594][15 00][00] device not detected.
[00024664][17 00][00] v1.1.0.4 -> v1.1.0.1
[00024763][17 01][00] v2.0.0.8 -> v2.0.0.1
[00024814][19 00][00] v1.0.8.96 -> v1.0.8.96
[00026855]Packet upgrade failed at version checking.
[00004799]========== remo-con disconnect. boot(15) ============
[00004838]Packet [C:\WM610_FW_V01.03.00.00.bin] detected, card sn [0x60ce191d].
[00004878]Packet upgrade start...
[00004921]Packet checking...
[00004967]Packet vlink 01.03.0000 <-> 01.02.0000.
[00005038]Done.
[00005078]Version checking[1]...
[00005117][01 00][00] v1.19.3422 -> v1.19.3422
[00005157][01 01][00] v1.19.3422 -> v1.19.3422
[00005246][03 05][00] v34.1.0.5 -> v34.1.0.5
[00005346][03 06][00] v2.2.6.33 -> v2.2.6.33
[00005415][04 00][00] v1.26.0.3 -> v1.26.0.3
[00005506][05 00][00] v3.0.6.1 -> v3.0.6.1
[00005577][08 00][00] v1.14.0.25 -> v1.14.0.25
[00005626][09 00][00] v1.8.0.0 -> v1.8.0.0
[00005706][11 00][00] v3.7.15.9 -> v3.7.15.9
[00005826][12 00][00] v1.8.0.0 -> v1.8.0.0
[00005946][12 01][00] v1.8.0.0 -> v1.8.0.0
[00006046][12 02][00] v1.8.0.0 -> v1.8.0.0
[00006146][12 03][00] v1.8.0.0 -> v1.8.0.0
[00014763][15 00][00] device not detected.
[00014826][17 00][00] v1.1.0.4 -> v1.1.0.4
[00014926][17 01][00] v2.0.0.8 -> v2.0.0.8
[00014976][19 00][00] v1.0.8.96 -> v1.0.8.96
[00017014]Packet upgrade failed at version checking.
[00005647]========== 2015.08.20 18:54:25. boot(15) ============
[00005688]Packet [C:\WM610_FW_V01.03.00.00.bin] detected, card sn [0x60ce191d].
[00005733]Packet upgrade start...
[00005778]Packet checking...
[00005823]Packet vlink 01.03.0000 <-> 01.02.0000.
[00005899]Done.
[00005945]Version checking[1]...
[00005987][01 00][00] v1.19.3422 -> v1.19.3422
[00006037][01 01][00] v1.19.3422 -> v1.19.3422
[00006125][03 05][00] v34.1.0.5 -> v34.1.0.5
[00006225][03 06][00] v2.2.6.33 -> v2.2.6.33
[00006293][04 00][00] v1.26.0.3 -> v1.26.0.3
[00006405][05 00][00] v3.0.6.1 -> v3.0.6.1
[00014107][08 00][00] v1.14.0.25 -> v1.14.0.25
[00014165][09 00][00] v1.8.0.0 -> v1.8.0.0
[00014245][11 00][00] v3.7.15.9 -> v3.7.15.9
[00014346][12 00][00] v1.8.0.0 -> v1.8.0.0
[00014445][12 01][00] v1.8.0.0 -> v1.8.0.0
[00014545][12 02][00] v1.8.0.0 -> v1.8.0.0
[00014646][12 03][00] v1.8.0.0 -> v1.8.0.0
[00017533][15 00][00] device not detected.
[00017605][17 00][00] v1.1.0.4 -> v1.1.0.4
[00017705][17 01][00] v2.0.0.8 -> v2.0.0.8
[00017765][19 00][00] v1.0.8.96 -> v1.0.8.96
[00019808]Packet upgrade failed at version checking.
[00005865]========== 2015.08.20 19:07:18. boot(15) ============
[00005906]Packet [C:\WM610_FW_V01.02.01.06.bin] detected, card sn [0x60ce191d].
[00005950]Packet upgrade start...
[00005994]Packet checking...
[00006039]Packet vlink 01.02.0000 <-> 01.02.0000.
[00006115]Done.
[00006160]Version checking[1]...
[00006201][01 00][00] v1.19.3422 -> v1.8.2729
[00006250][01 01][00] v1.19.3422 -> v1.8.2729
[00006333][03 05][00] v34.1.0.5 -> v34.1.0.5
[00006433][03 06][00] v2.2.6.33 -> v2.0.5.14
[00006506][04 00][00] v1.26.0.3 -> v1.16.0.76
[00006614][05 00][00] v3.0.6.1 -> v2.5.6.1
[00014169][08 00][00] v1.14.0.25 -> v1.12.0.21
[00014223][09 00][00] v1.8.0.0 -> v1.7.0.3
[00014293][11 00][00] v3.7.15.9 -> v3.7.1.0
[00014373][12 00][00] v1.8.0.0 -> v1.3.0.60
[00014474][12 01][00] v1.8.0.0 -> v1.3.0.60
[00014553][12 02][00] v1.8.0.0 -> v1.3.0.60
[00014633][12 03][00] v1.8.0.0 -> v1.3.0.60
[00017469][15 00][00] device not detected.
[00017533][17 00][00] v1.1.0.4 -> v1.1.0.1
[00017633][17 01][00] v2.0.0.8 -> v2.0.0.1
[00017682][19 00][00] v1.0.8.96 -> v1.0.8.96
[00019721]Packet upgrade failed at version checking.
[00005672]========== 2015.08.20 19:15:24. boot(15) ============
[00005710]Packet [C:\WM610_FW_V01.02.01.06.bin] detected, card sn [0x60ce191d].
[00005759]Packet upgrade start...
[00005804]Packet checking...
[00005852]Packet vlink 01.02.0000 <-> 01.02.0000.
[00005923]Done.
[00006064]Version checking[1]...
[00006128][01 00][00] v1.19.3422 -> v1.8.2729
[00006196][01 01][00] v1.19.3422 -> v1.8.2729
[00006292][03 05][00] v34.1.0.5 -> v34.1.0.5
[00006412][03 06][00] v2.2.6.33 -> v2.0.5.14
[00006473][04 00][00] v1.26.0.3 -> v1.16.0.76
[00006532][05 00][00] v3.0.6.1 -> v2.5.6.1
[00014095][08 00][00] v1.14.0.25 -> v1.12.0.21
[00014152][09 00][00] v1.8.0.0 -> v1.7.0.3
[00014212][11 00][00] v3.7.15.9 -> v3.7.1.0
[00014292][12 00][00] v1.8.0.0 -> v1.3.0.60
[00014392][12 01][00] v1.8.0.0 -> v1.3.0.60
[00014472][12 02][00] v1.8.0.0 -> v1.3.0.60
[00014572][12 03][00] v1.8.0.0 -> v1.3.0.60
[00017490][15 00][00] device not detected.
[00017572][17 00][00] v1.1.0.4 -> v1.1.0.1
[00017672][17 01][00] v2.0.0.8 -> v2.0.0.1
[00017726][19 00][00] v1.0.8.96 -> v1.0.8.96
[00019766]Packet upgrade failed at version checking.
[00004612]========== 2015.08.27 22:37:49. boot(15) ============
[00004654]Packet [C:\WM610_FW_V01.03.00.00.bin] detected, card sn [0x60ce191d].
[00004701]Packet upgrade start...
[00004750]Packet checking...
[00004873]Done.
[00004920]Version checking[1]...
[00004962][01 00][00] v1.19.3422 -> v1.19.3422
[00005017][01 01][00] v1.19.3422 -> v1.19.3422
[00005129][03 05][00] v34.1.0.5 -> v34.1.0.5
[00005229][03 06][00] v2.2.6.33 -> v2.2.6.33
[00005304][04 00][00] v1.26.0.3 -> v1.26.0.3
[00005389][05 00][00] v3.0.6.1 -> v3.0.6.1
[00005444][08 00][00] v1.14.0.25 -> v1.14.0.25
[00005514][09 00][00] v1.8.0.0 -> v1.8.0.0
[00005589][11 00][00] v3.7.15.9 -> v3.7.15.9
[00005689][12 00][00] v1.8.0.0 -> v1.8.0.0
[00005809][12 01][00] v1.8.0.0 -> v1.8.0.0
[00005911][12 02][00] v1.8.0.0 -> v1.8.0.0
[00006009][12 03][00] v1.8.0.0 -> v1.8.0.0
[00014615][15 00][00] device not detected.
[00014689][17 00][00] v1.1.0.4 -> v1.1.0.4
[00014789][17 01][00] v2.0.0.8 -> v2.0.0.8
[00014855][19 00][00] v1.0.8.96 -> v1.0.8.96
[00016897]Packet upgrade failed at version checking.
[00004633]========== 2015.08.27 22:39:11. boot(15) ============
[00004681]Packet [C:\WM610_FW_V01.03.00.00.bin] detected, card sn [0x60ce191d].
[00004724]Packet upgrade start...
[00004770]Packet checking...
[00004823]Packet vlink 01.03.0000 <-> 01.02.0000.
[00004902]Done.
[00004946]Version checking[1]...
[00004994][01 00][00] v1.19.3422 -> v1.19.3422
[00005059][01 01][00] v1.19.3422 -> v1.19.3422
[00005168][03 05][00] v34.1.0.5 -> v34.1.0.5
[00005288][03 06][00] v2.2.6.33 -> v2.2.6.33
[00005352][04 00][00] v1.26.0.3 -> v1.26.0.3
[00005429][05 00][00] v3.0.6.1 -> v3.0.6.1
[00005502][08 00][00] v1.14.0.25 -> v1.14.0.25
[00005569][09 00][00] v1.8.0.0 -> v1.8.0.0
[00005650][11 00][00] v3.7.15.9 -> v3.7.15.9
[00005769][12 00][00] v1.8.0.0 -> v1.8.0.0
[00005889][12 01][00] v1.8.0.0 -> v1.8.0.0
[00005969][12 02][00] v1.8.0.0 -> v1.8.0.0
[00006068][12 03][00] v1.8.0.0 -> v1.8.0.0
[00014701][15 00][00] device not detected.
[00014767][17 00][00] v1.1.0.4 -> v1.1.0.4
[00014868][17 01][00] v2.0.0.8 -> v2.0.0.8
[00014922][19 00][00] v1.0.8.96 -> v1.0.8.96
[00016967]Packet upgrade failed at version checking.
2015-8-27
Tahoe_Ed
The firmware is upgraded but it is not recognizing the Air End USB transmitter.  Your camera may be damaged.
2015-8-27
teamnest1
Tahoe_Ed Posted at 2015-8-28 02:53
The firmware is upgraded but it is not recognizing the Air End USB transmitter.  Your camera may be  ...
What may have caused this?
Is there any specific wires I can check?
Everything was working correctly before the upgrade.
I did notice the camera going a bit crazy during my first aircraft upgrade attempt.
Edit: I do not have a camera feed on the DJI GO app, and the DJI GO app keeps saying that the Aircraft needs to be upgraded.
2015-8-28
Tahoe_Ed
teamnest1 Posted at 2015-8-28 12:40
Check the ribbon cables and make sure that they are firmly seated.  Format the SD card, load the bin file alone and try to upgrade again.
2015-8-29
teamnest1
I ended up sending it in. I tried it all. (its under warranty)
I tried a new sd card, format, new update, checked wired, unplugged and replugged, pushed in, cleaned the contacts, and more.
I paid to send the inspire1 back to DJI California via FedEx, waitied, and got the package with a RETURN TO SENDER label.
Fedex claims DJI denied my package =[
I called DJI and they got me a prepaid shipping label. Now I have to wait AGAIN but at least they paid for shipping this time.
It gets to them on Wednesday (tomorrow) I will keep you all updated.
2015-9-15
fjarvis
Flight distance : 30223 ft
I too have exactly the same issue - I've been trying to get help on the RCG forum but no luck, so thought I'd head over here.
I tried updating many times, always resulting in the long DDDDDD beep.  My dealer even tried the update several times and no luck there either, using his PC, SD cards, downloaded BIN file and even tried his camera.
No idea what to do next.
2015-9-15
teamnest1
fjarvis@gmail.c Posted at 2015-9-15 14:39
I too have exactly the same issue - I've been trying to get help on the RCG forum but no luck, so th ...
Fjarvis, is it under warranty? I would call DJI. I would stay away from the online chat. I would do a search on it to. Start here at this link - [url]http://forum.dji.com/thread-7186-1-1.html[/url]
. Try EVERYTHING before you send it in.
2015-9-15
briandash
Same thing happened to me... at the end the Inspire just had a flashing red light and wouldn't turn on. I know i did it right, I was being walked through the process but their chat support. The firmware package must have been messed up. DJI has now had my Inspire1 for 3 months and doesn't respond to emails or tweets. Every time I call i wait on hold for 15 minutes then get disconnected. I haven't been able to reach a human at this company in a month.
So, good luck!
I didn't even want to update my firmware, but my two remote drone only shipped with one remote. When I got the second remote, it had newer firmware, so i had to update the drone. Then it never worked again.
Worst customer support I have ever experienced. Oh, and if you try to contact them on Facebook, they'll just block you instead of dealing with it.
2015-9-15
briandash
teamnest1 Posted at 2015-9-15 06:03
I tried a new sd card, format, new up ...
Say goodbye to that drone... you probably won't see it again until 2016.
2015-9-15
fjarvis
I called support and they asked me to send in the hidden log file, I took a quick look, and relevant part posted below - anyone got any ideas what it is that isn't updating?
Thanks,
Fraser
[00619260]Version checking[6]...
[00619310][01 00][00] v1.19.3422 -> v1.19.3422
[00619363][01 01][00] v1.19.3422 -> v1.19.3422
[00619443][03 05][00] v34.1.0.5 -> v34.1.0.5
[00619523][03 06][00] v2.3.0.13 -> v2.3.0.13
[00619587][04 00][00] v1.26.0.21 -> v1.26.0.21
[00619683][05 00][00] v3.0.6.1 -> v3.0.6.1
[00619757][08 00][00] v1.14.0.25 -> v1.14.0.25
[00619818][09 00][00] v1.8.0.0 -> v1.8.0.0
[00619903][11 00][00] v3.7.15.10 -> v3.7.15.10
[00620002][12 00][00] v1.8.0.0 -> v1.8.0.0
[00620102][12 01][00] v1.8.0.0 -> v1.8.0.0
[00620202][12 02][00] v1.8.0.0 -> v1.8.0.0
[00620302][12 03][00] v1.8.0.0 -> v1.8.0.0
[00620460][15 00][00] v1.1.2.0 -> v1.1.2.0
[00620543][17 00][00] v0.0.0.0 -> v1.1.0.4 need upgrade.
[00620622][17 01][00] v0.0.0.0 -> v2.0.0.8 need upgrade.
[00620687][19 00][00] v1.0.8.96 -> v1.0.8.96
[00620738]Packet upgrade failed at firmware upgrade.
2015-9-16
teamnest1
fjarvis@gmail.c Posted at 2015-9-16 04:03
I called support and they asked me to send in the hidden log file, I took a quick look, and relevant ...
^whatever those two are, its the problem.
Its not detecting a version at all, which means whatever part it is, is not responding and/or disconnected.
My unit arrived to DJI California Carson yesterday.
Keeping my fingers crossed.
2015-9-16
fjarvis
Yeah, just wish I knew what components they were so I could check them out!
Good luck with yours.
2015-9-16
teamnest1
fjarvis@gmail.c Posted at 2015-9-16 13:58
Thanks brother, I received an email saying the process for repair has started. I know they have recently moved to a new facility to its good to know it didn't get lost in that process.
2015-9-21
teamnest1
I just got my Inspire back Today. I am currently charging the batteries. It seems like they replaced my X3 Camera.  That may have been the culprit this whole time? I will take it on a flight later today and update.
2015-10-1
Kefflkb3xjKY
India
I m having  BAD POOL HEADER problem in my Pc.
2016-9-7
DJI-Jamie
Flight distance : 112405 ft
Kefflkb3xjKY Posted at 2016-9-7 20:39
I'm sorry, I have not seen that before, can you please elaborate as to what issue your having with your unit?
2016-9-7
Kefflkb3xjKY
India
I does as this website said
http://www.deskdecode.com/bad-pool-header/
and now my system wont able to start
what to do now does anybody knows something
2016-9-8
komsls
India
How to seeks gives you all about the Latest Tech. News like Errors, How to Fix & Solve, Guides and much more knowledgeable things from all around the world.
Check out more about windows 10 how to seeks will provide you.
2017-5-13
djiuser_vhQEjus
India
here is Geeks Wizard to solve your question.
2017-7-10
djiuser_L7hvalh
India
You Can Find a Solution Regarding 5g phone firmware here
2017-11-4
Håkan K
Flight distance : 262946 ft
Sweden
fjarvis@gmail.c Posted at 2015-9-16 00:03
Thanks,
is the visioning position module. Had the very same issue and purchased one on Ebay and replaced myself.
Can be confirmed by having it all start up. Then lift it in the air 3 feet. The height should change in the app. If not the VPS is not working as it should. You will probably not be able to get it into travel mode either.
2017-11-4
Lucas775
Flight distance : 50642090 ft
For such an expensive drone sure is a lot of problem for a FW.
2017-11-4
Highasakite
Flight distance : 1423930 ft
This thread is like 90 yrs old. But I get 1 point, why not? Happy Thanksgiving  to ALL!  Safety First! Ken.
2017-11-20
Ryanrichter
India
here is resrc to solve your question
2017-11-29
chiru_andy
India
Here is Andytips to get latest apps, reviews, games and other for android users.
2017-12-13
manoj121
India
here is https://tech2ray.com/to solve your question
2017-12-14
12Next >
