AerialLens
Does (can) this use the same ESC's that we have on previous P3's? Is it worth changing out the motors if yours are operating okay? Buy 4 for spares? 18 USD x 4 won't break the bank, but it is very important not to booger-up or confuse the onboard programming. It is apparently a component of a new "tuned propultion system" including motors, ESC's, and propellers. What is the word to the wise on this motor by itself as an upgrade?
Here is a quote from the DJI site (http://www.dji.com/product/e305):
Built with improved manufacturing techniques, the brand new 2312E motor represents a significant
upgrade over the previous 2312 model. The optimized electro-magnetic system boosts efficiency
by nearly 7% and lowers cogging torque, which provides noticeably smoother performance at low RPMs.
A newly designed motor base not only provides better heat dissipation, but also a more advanced, hi-tech look.
**EDIT**
Well, this is confusing...the DJI Store has the 2312E motor available in BOTH 800KV and 960KV versions; KV indicating unloaded RPM's per volt. What do we have on the P3 now?
See http://store.dji.com//tuned-propulsion-system/e305.
