Phantom 3 Firmware 1.4.0010 - App Support Thread
43222 250 2015-9-7
radius
Indonesia
sploodge Posted at 2015-9-8 14:58
You can go direct to 1.4 but nothing stops you doing an increment  If I was to increment, I would ...
thank you sploodge.
so 1.3.20 then 1.4.0 will be for me.
2015-9-8
no1caresme
Error for update the firmware! Need Help
HELP! HELP! I got the error for updating the firmware. I need to present my work but there is no signal.
1: Phantom 3 Version :
Pro
2: App Platform  Android  and  the latest version.
3: Mobile Device type
Samsung Note2
4: Update log TXT files
I tried different bin files, all Failed.
========== 2014.01.01 00:00:13 remo-con disconnect======
Packet: P3X_FW_V01.04.0010.bin
Upgrading ...
Result: Failed.
Reboot the aircraft and try to upgrade the firmware again.
Upgrading ...
Result: Failed.
========== 2015.09.08 17:03:26 =====================
Result: Failed.
Result: Failed.
Result: Failed.
Packet: P3X_FW_V01.03.0020.bin
Result: Failed.
Result: Failed.
========== 2015.09.08 17:44:53 =====================
Result: Failed.
========== 2015.09.08 17:48:04 =====================
Result: Failed.
========== 2014.01.01 00:00:14 remo-con disconnect======
Packet: P3X_FW_V01.04.0005.bin
Result: Failed.
Result: Failed.
Result: Failed.
Result: Failed.
========== 2015.09.08 18:39:54 =====================
Result: Failed.
========== 2015.09.08 19:13:29 =====================
Result: Failed.
Result: Failed.
========== 2014.01.01 00:00:15 remo-con disconnect======
Result: Failed.
========== 2015.09.08 19:41:04 =====================
Result: Failed.
========== 2015.09.08 19:42:43 =====================
Result: Failed.
Packet: P3X_FW_V01.01.0009.bin
Result: Failed.
[00012239][01 00] Firmware upgrade finished successfully.
[00012348]Done.
[00012448]Packet [C:\P3X_FW_V01.04.0010.bin] resumed, card sn [0x70ce1c3a].
[00012587]Packet vlink 01.04.0010 <-> 01.03.0020.
[00012723]Version checking[2]...
[00012874][03 05][00] v34.2.0.8 -> v34.2.0.9 need upgrade.
[00013009][03 06][00] v2.1.9.1 -> v2.3.0.13 need upgrade.
[00013118][04 00][00] v1.36.0.0 -> v1.41.0.0 need upgrade.
[00013224][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013395][11 00][00] v1.6.0.0 -> v1.7.0.0 need upgrade.
[00013470][12 00][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
[00013549][12 01][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
[00013626][12 02][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
[00013705][12 03][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
[00013845][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013919][17 00][00] v1.1.1.2 -> v1.1.1.7 need upgrade.
[00014020][17 01][00] v1.0.2.4 -> v1.0.2.7 need upgrade.
[00014064][19 00][00] v1.0.8.59 -> v1.0.8.96 need upgrade.
[00014104][01 00][05] v1.23.3419 -> v1.23.3419
[00014137][01 01][00] v1.5.2735 -> v1.23.3419 need upgrade
[00014178][08 00][00] v0.11.0.4 -> v0.12.0.4 need upgrade.
[00014211]Done.
[00014260]Firmware upgrading[2]...
[00014406][01 01] Firmware upgrade start...
[00044664][01 01] Firmware upgrade finished successfully.
[00045522][08 00] Firmware upgrade start...
[00014502]========== remo-con disconnect. boot(15) ============
[00014537]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0x70ce1c3a].
[00014571]Packet upgrade start...
[00014616]Packet checking...
[00014650]Packet vlink 01.04.0010 <-> 01.03.0020.
[00014713]Done.
[00014746]Version checking[1]...
[00014802][03 05][00] v34.2.0.8 -> v34.2.0.9 need upgrade.
[00014862][03 06][00] v2.1.9.1 -> v2.3.0.13 need upgrade.
[00014901][04 00][00] v1.36.0.0 -> v1.41.0.0 need upgrade.
[00014952][09 00][00] v1.7.0.3 -> v1.7.0.3
[00015042][11 00][00] v1.6.0.0 -> v1.7.0.0 need upgrade.
[00015113][12 00][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
[00015202][12 01][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
[00015377][12 02][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
[00015453][12 03][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
[00027991][15 00][00] device not detected.
[00028067][17 00][00] v1.1.1.2 -> v1.1.1.7 need upgrade.
[00028187][17 01][00] v1.0.2.4 -> v1.0.2.7 need upgrade.
[00028272][19 00][00] v1.0.8.59 -> v1.0.8.96 need upgrade.
[00028309][01 00][00] v1.23.3419 -> v1.23.3419
[00028343][01 01][00] v1.23.3419 -> v1.23.3419
[00040878][08 00][00] device not detected.
[00040909]Done.
[00042949]Waiting for user confirm...
[00052981]Timeout, start upgrade automatically.
[00053048]Firmware upgrading[1]...
[00053100][12 00] Firmware upgrade start...
[00122113][12 00] Firmware upgrade finished successfully.
[00122166][12 01] Firmware upgrade start...
[00184601][12 01] Firmware upgrade finished successfully.
[00184650][12 02] Firmware upgrade start...
[00250329][12 02] Firmware upgrade finished successfully.
[00250379][12 03] Firmware upgrade start...
[00315923][12 03] Firmware upgrade finished successfully.
[00315979][17 00] Firmware upgrade start...
[00417189][17 00] Firmware upgrade finished successfully.
[00417236][17 01] Firmware upgrade start...
[00488513][17 01] Firmware upgrade finished successfully.
[00488565][11 00] Firmware upgrade start...
[00537706][11 00] Firmware upgrade finished successfully.
[00537754][03 05] Firmware upgrade start...
[00608080][03 05] Firmware upgrade finished successfully.
[00608320][03 06] Firmware upgrade start...
[00949463][03 06] Firmware upgrade finished successfully.
[00952090][19 00] Firmware upgrade start...
[00962430][19 00] stop streaming timeout, continue upgrade.
[01106807][19 00] start streaming timeout, continue upgrade.
[01136849][19 00] Firmware upgrade finished successfully.
[01136915][04 00] Firmware upgrade start...
[01195405][04 00] Firmware upgrade finished successfully.
[01195446]Done.
[01195478]Version checking[2]...
[01195558][03 05][05] v34.2.0.9 -> v34.2.0.9
[01195718][03 06][05] v2.3.0.13 -> v2.3.0.13
[01195760][04 00][05] v1.41.0.0 -> v1.41.0.0
[01195826][09 00][00] v1.7.0.3 -> v1.7.0.3
[01195939][11 00][05] v1.7.0.0 -> v1.7.0.0
[01196007][12 00][05] v1.10.0.0 -> v1.10.0.0
[01196092][12 01][05] v1.10.0.0 -> v1.10.0.0
[01196171][12 02][05] v1.10.0.0 -> v1.10.0.0
[01196249][12 03][05] v1.10.0.0 -> v1.10.0.0
[01208791][15 00][00] device not detected.
[01208862][17 00][05] v1.1.1.7 -> v1.1.1.7
[01208986][17 01][05] v1.0.2.7 -> v1.0.2.7
[01209047][19 00][05] v1.0.8.96 -> v1.0.8.96
[01209082][01 00][00] v1.23.3419 -> v1.23.3419
[01209121][01 01][00] v1.23.3419 -> v1.23.3419
[01221658][08 00][00] device not detected.
[01221692]Packet upgrade failed at version checking.
[00014446]========== remo-con disconnect. boot(15) ============
[00014483]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0x70ce1c3a].
[00014517]Packet upgrade start...
[00014555]Packet checking...
[00014596]Packet vlink 01.04.0010 <-> 01.03.0020.
[00014662]Done.
[00014697]Version checking[1]...
[00014757][03 05][00] v34.2.0.9 -> v34.2.0.9
[00014817][03 06][00] v2.3.0.13 -> v2.3.0.13
[00014856][04 00][00] v1.41.0.0 -> v1.41.0.0
[00014906][09 00][00] v1.7.0.3 -> v1.7.0.3
[00015036][11 00][00] v1.6.0.0 -> v1.7.0.0 need upgrade.
[00015110][12 00][00] v1.10.0.0 -> v1.10.0.0
[00015186][12 01][00] v1.10.0.0 -> v1.10.0.0
[00015277][12 02][00] v1.10.0.0 -> v1.10.0.0
[00015356][12 03][00] v1.10.0.0 -> v1.10.0.0
[00027896][15 00][00] device not detected.
[00027986][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028106][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028166][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028201][01 00][00] v1.23.3419 -> v1.23.3419
[00028250][01 01][00] v1.23.3419 -> v1.23.3419
[00040790][08 00][00] device not detected.
[00040824]Done.
[00042858]Waiting for user confirm...
[00052892]Timeout, start upgrade automatically.
[00052969]Firmware upgrading[1]...
[00053015][11 00] Firmware upgrade start...
[00103736][11 00] Firmware upgrade finished successfully.
[00103775]Done.
[00103812]Version checking[2]...
[00103882][03 05][00] v34.2.0.9 -> v34.2.0.9
[00103942][03 06][00] v2.3.0.13 -> v2.3.0.13
[00103981][04 00][00] v1.41.0.0 -> v1.41.0.0
[00104051][09 00][00] v1.7.0.3 -> v1.7.0.3
[00104161][11 00][05] v1.7.0.0 -> v1.7.0.0
[00104257][12 00][00] v1.10.0.0 -> v1.10.0.0
[00104335][12 01][00] v1.10.0.0 -> v1.10.0.0
[00104412][12 02][00] v1.10.0.0 -> v1.10.0.0
[00104486][12 03][00] v1.10.0.0 -> v1.10.0.0
[00117027][15 00][00] device not detected.
[00117091][17 00][00] v1.1.1.7 -> v1.1.1.7
[00117206][17 01][00] v1.0.2.7 -> v1.0.2.7
[00117291][19 00][00] v1.0.8.96 -> v1.0.8.96
[00117327][01 00][00] v1.23.3419 -> v1.23.3419
[00117368][01 01][00] v1.23.3419 -> v1.23.3419
[00129903][08 00][00] device not detected.
[00129938]Packet upgrade failed at version checking.
[00014630]========== 2015.09.08 17:03:27. boot(15) ============
[00014667]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0x70ce1c3a].
[00014704]Packet upgrade start...
[00014749]Packet checking...
[00014788]Packet vlink 01.04.0010 <-> 01.03.0020.
[00014854]Done.
[00014891]Version checking[1]...
[00014964][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015049][03 06][00] v2.3.0.13 -> v2.3.0.13
[00015095][04 00][00] v1.41.0.0 -> v1.41.0.0
[00015148][09 00][00] v1.7.0.3 -> v1.7.0.3
[00015265][11 00][00] v1.7.0.0 -> v1.7.0.0
[00015358][12 00][00] v1.10.0.0 -> v1.10.0.0
[00015439][12 01][00] v1.10.0.0 -> v1.10.0.0
[00015512][12 02][00] v1.10.0.0 -> v1.10.0.0
[00015592][12 03][00] v1.10.0.0 -> v1.10.0.0
[00028129][15 00][00] device not detected.
[00028212][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028356][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028413][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028457][01 00][00] v1.23.3419 -> v1.23.3419
[00028493][01 01][00] v1.23.3419 -> v1.23.3419
[00041035][08 00][00] device not detected.
[00041069]Packet upgrade failed at version checking.
[00014629]========== remo-con disconnect. boot(15) ============
[00014666]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0x70ce1c3a].
[00014705]Packet upgrade start...
[00014752]Packet checking...
[00014791]Packet vlink 01.04.0010 <-> 01.03.0020.
[00014858]Done.
[00014893]Version checking[1]...
[00015024][03 06][00] v2.3.0.13 -> v2.3.0.13
[00015066][04 00][00] v1.41.0.0 -> v1.41.0.0
[00015133][09 00][00] v1.7.0.3 -> v1.7.0.3
[00015248][11 00][00] v1.7.0.0 -> v1.7.0.0
[00015337][12 00][00] v1.10.0.0 -> v1.10.0.0
[00015417][12 01][00] v1.10.0.0 -> v1.10.0.0
[00015504][12 02][00] v1.10.0.0 -> v1.10.0.0
[00015583][12 03][00] v1.10.0.0 -> v1.10.0.0
[00028122][15 00][00] device not detected.
[00028193][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028333][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028393][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028436][01 00][00] v1.23.3419 -> v1.23.3419
[00028472][01 01][00] v1.23.3419 -> v1.23.3419
[00041008][08 00][00] device not detected.
[00041046]Packet upgrade failed at version checking.
[00014633]========== remo-con disconnect. boot(15) ============
[00014670]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0x70ce1c3a].
[00014709]Packet upgrade start...
[00014754]Packet checking...
[00014793]Packet vlink 01.04.0010 <-> 01.03.0020.
[00014862]Done.
[00014899]Version checking[1]...
[00014984][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015065][03 06][00] v2.3.0.13 -> v2.3.0.13
[00015110][04 00][00] v1.41.0.0 -> v1.41.0.0
[00015163][09 00][00] v1.7.0.3 -> v1.7.0.3
[00015284][11 00][00] v1.7.0.0 -> v1.7.0.0
[00015388][12 00][00] v1.10.0.0 -> v1.10.0.0
[00015492][12 01][00] v1.10.0.0 -> v1.10.0.0
[00015589][12 02][00] v1.10.0.0 -> v1.10.0.0
[00015684][12 03][00] v1.10.0.0 -> v1.10.0.0
[00028227][15 00][00] device not detected.
[00028309][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028435][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028484][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028594][01 00][00] v1.23.3419 -> v1.23.3419
[00028641][01 01][00] v1.23.3419 -> v1.23.3419
[00041179][08 00][00] device not detected.
[00041218]Packet upgrade failed at version checking.
[00014639]========== remo-con disconnect. boot(15) ============
[00014678]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x70ce1c3a].
[00014717]Packet upgrade start...
[00014764]Packet checking...
[00014800]Packet vlink 01.03.0020 <-> 01.01.0009.
[00014870]Done.
[00014907]Version checking[1]...
[00014980][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015061][03 06][00] v2.3.0.13 -> v2.2.6.19
[00015112][04 00][00] v1.41.0.0 -> v1.40.0.0
[00015165][09 00][00] v1.7.0.3 -> v1.7.0.3
[00015281][11 00][00] v1.7.0.0 -> v1.7.0.0
[00015381][12 00][00] v1.10.0.0 -> v1.8.0.0
[00015474][12 01][00] v1.10.0.0 -> v1.8.0.0
[00015581][12 02][00] v1.10.0.0 -> v1.8.0.0
[00015675][12 03][00] v1.10.0.0 -> v1.8.0.0
[00028311][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028436][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028486][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028524][01 00][00] v1.23.3419 -> v1.23.3419
[00028564][01 01][00] v1.23.3419 -> v1.23.3419
[00041114][08 00][00] device not detected.
[00041155]Packet upgrade failed at version checking.
[00014650]========== remo-con disconnect. boot(15) ============
[00014686]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x70ce1c3a].
[00014725]Packet upgrade start...
[00014772]Packet checking...
[00014814]Packet vlink 01.03.0020 <-> 01.01.0009.
[00014883]Done.
[00014925]Version checking[1]...
[00014987][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015067][03 06][00] v2.3.0.13 -> v2.2.6.19
[00015117][04 00][00] v1.41.0.0 -> v1.40.0.0
[00015176][09 00][00] v1.7.0.3 -> v1.7.0.3
[00015307][11 00][00] v1.7.0.0 -> v1.7.0.0
[00015406][12 00][00] v1.10.0.0 -> v1.8.0.0
[00015506][12 01][00] v1.10.0.0 -> v1.8.0.0
[00015681][12 03][00] v1.10.0.0 -> v1.8.0.0
[00028311][15 00][00] device not detected.
[00028402][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028542][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028602][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028642][01 00][00] v1.23.3419 -> v1.23.3419
[00028681][01 01][00] v1.23.3419 -> v1.23.3419
[00041221][08 00][00] device not detected.
[00041260]Packet upgrade failed at version checking.
[00014661]========== 2015.09.08 17:44:54. boot(15) ============
[00014700]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x70ce1c3a].
[00014739]Packet upgrade start...
[00014789]Packet checking...
[00014829]Packet vlink 01.03.0020 <-> 01.01.0009.
[00014898]Done.
[00014947]Version checking[1]...
[00015009][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015069][03 06][00] v2.3.0.13 -> v2.2.6.19
[00015119][04 00][00] v1.41.0.0 -> v1.40.0.0
[00015178][09 00][00] v1.7.0.3 -> v1.7.0.3
[00015289][11 00][00] v1.7.0.0 -> v1.7.0.0
[00015363][12 00][00] v1.10.0.0 -> v1.8.0.0
[00015463][12 01][00] v1.10.0.0 -> v1.8.0.0
[00015543][12 02][00] v1.10.0.0 -> v1.8.0.0
[00015618][12 03][00] v1.10.0.0 -> v1.8.0.0
[00028159][15 00][00] device not detected.
[00028238][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028403][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028446][01 00][00] v1.23.3419 -> v1.23.3419
[00028484][01 01][00] v1.23.3419 -> v1.23.3419
[00041025][08 00][00] device not detected.
[00041063]Packet upgrade failed at version checking.
[00015190]========== 2015.09.08 17:48:05. boot(15) ============
[00015228]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x70ce1c3a].
[00015272]Packet upgrade start...
[00015315]Packet checking...
[00015355]Packet vlink 01.03.0020 <-> 01.01.0009.
[00015424]Done.
[00015460]Version checking[1]...
[00015553][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015630][03 06][00] v2.3.0.13 -> v2.2.6.19
[00015677][04 00][00] v1.41.0.0 -> v1.40.0.0
[00015728][09 00][00] v1.7.0.3 -> v1.7.0.3
[00015853][11 00][00] v1.7.0.0 -> v1.7.0.0
[00016017][12 00][00] v1.10.0.0 -> v1.8.0.0
[00016117][12 01][00] v1.10.0.0 -> v1.8.0.0
[00016197][12 02][00] v1.10.0.0 -> v1.8.0.0
[00016317][12 03][00] v1.10.0.0 -> v1.8.0.0
[00028857][15 00][00] device not detected.
[00028957][17 00][00] v1.1.1.7 -> v1.1.1.7
[00029077][17 01][00] v1.0.2.7 -> v1.0.2.7
[00029148][19 00][00] v1.0.8.96 -> v1.0.8.96
[00029187][01 00][00] v1.23.3419 -> v1.23.3419
[00029233][01 01][00] v1.23.3419 -> v1.23.3419
[00041776][08 00][00] device not detected.
[00041817]Packet upgrade failed at version checking.
[00014667]========== remo-con disconnect. boot(15) ============
[00014709]Packet [C:\P3X_FW_V01.04.0005.bin] detected, card sn [0x70ce1c3a].
[00014751]Packet upgrade start...
[00014796]Packet checking...
[00014839]Packet vlink 01.04.0005 <-> 01.03.0020.
[00014910]Done.
[00014952]Version checking[1]...
[00015018][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015097][03 06][00] v2.3.0.13 -> v2.3.0.10
[00015144][04 00][00] v1.41.0.0 -> v1.40.0.0
[00015201][09 00][00] v1.7.0.3 -> v1.7.0.3
[00015338][11 00][00] v1.7.0.0 -> v1.7.0.0
[00015431][12 00][00] v1.10.0.0 -> v1.8.0.0
[00015586][12 02][00] v1.10.0.0 -> v1.8.0.0
[00015671][12 03][00] v1.10.0.0 -> v1.8.0.0
[00028211][15 00][00] device not detected.
[00028327][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028446][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028501][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028542][01 00][00] v1.23.3419 -> v1.23.3419
[00028580][01 01][00] v1.23.3419 -> v1.23.3419
[00041132][08 00][00] device not detected.
[00041173]Packet upgrade failed at version checking.
[00014665]========== remo-con disconnect. boot(15) ============
[00014705]Packet [C:\P3X_FW_V01.04.0005.bin] detected, card sn [0x70ce1c3a].
[00014747]Packet upgrade start...
[00014791]Packet checking...
[00014835]Packet vlink 01.04.0005 <-> 01.03.0020.
[00014906]Done.
[00014955]Version checking[1]...
[00015118][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015198][03 06][00] v2.3.0.13 -> v2.3.0.10
[00015261][04 00][00] v1.41.0.0 -> v1.40.0.0
[00015322][09 00][00] v1.7.0.3 -> v1.7.0.3
[00015440][11 00][00] v1.7.0.0 -> v1.7.0.0
[00015532][12 00][00] v1.10.0.0 -> v1.8.0.0
[00015612][12 01][00] v1.10.0.0 -> v1.8.0.0
[00015712][12 02][00] v1.10.0.0 -> v1.8.0.0
[00015812][12 03][00] v1.10.0.0 -> v1.8.0.0
[00028356][15 00][00] device not detected.
[00028447][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028578][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028663][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028706][01 00][00] v1.23.3419 -> v1.23.3419
[00028748][01 01][00] v1.23.3419 -> v1.23.3419
[00041297][08 00][00] device not detected.
[00041337]Packet upgrade failed at version checking.
[00014770]========== remo-con disconnect. boot(15) ============
[00014804]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x92ac838d].
[00014839]Packet upgrade start...
[00014875]Packet checking...
[00014908]Packet vlink 01.03.0020 <-> 01.01.0009.
[00014977]Done.
[00015008]Version checking[1]...
[00015068][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015129][03 06][00] v2.3.0.13 -> v2.2.6.19
[00015167][04 00][00] v1.41.0.0 -> v1.40.0.0
[00015217][09 00][00] v1.7.0.3 -> v1.7.0.3
[00015328][11 00][00] v1.7.0.0 -> v1.7.0.0
[00015408][12 00][00] v1.10.0.0 -> v1.8.0.0
[00015487][12 01][00] v1.10.0.0 -> v1.8.0.0
[00015562][12 02][00] v1.10.0.0 -> v1.8.0.0
[00015641][12 03][00] v1.10.0.0 -> v1.8.0.0
[00028175][15 00][00] device not detected.
[00028258][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028379][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028437][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028471][01 00][00] v1.23.3419 -> v1.23.3419
[00028505][01 01][00] v1.23.3419 -> v1.23.3419
[00041042][08 00][00] device not detected.
[00041076]Packet upgrade failed at version checking.
[00015300]========== remo-con disconnect. boot(15) ============
[00015385]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0x70ce1c3a].
[00015517]Packet upgrade start...
[00015566]Packet checking...
[00015616]Packet vlink 01.04.0010 <-> 01.03.0020.
[00015688]Done.
[00015730]Version checking[1]...
[00015815][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015894][03 06][00] v2.3.0.13 -> v2.3.0.13
[00015943][04 00][00] v1.41.0.0 -> v1.41.0.0
[00016003][09 00][00] v1.7.0.3 -> v1.7.0.3
[00016115][11 00][00] v1.7.0.0 -> v1.7.0.0
[00016208][12 00][00] v1.10.0.0 -> v1.10.0.0
[00016343][12 01][00] v1.10.0.0 -> v1.10.0.0
[00016423][12 02][00] v1.10.0.0 -> v1.10.0.0
[00016508][12 03][00] v1.10.0.0 -> v1.10.0.0
[00029053][15 00][00] device not detected.
[00029144][17 00][00] v1.1.1.7 -> v1.1.1.7
[00029266][17 01][00] v1.0.2.7 -> v1.0.2.7
[00029323][19 00][00] v1.0.8.96 -> v1.0.8.96
[00029366][01 00][00] v1.23.3419 -> v1.23.3419
[00029408][01 01][00] v1.23.3419 -> v1.23.3419
[00041950][08 00][00] device not detected.
[00041994]Packet upgrade failed at version checking.
[00015801]========== 2015.09.08 18:39:54. boot(15) ============
[00015840]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0x70ce1c3a].
[00015889]Packet upgrade start...
[00015932]Packet checking...
[00015974]Packet vlink 01.04.0010 <-> 01.03.0020.
[00016048]Done.
[00016089]Version checking[1]...
[00016161][03 05][00] v34.2.0.9 -> v34.2.0.9
[00016220][03 06][00] v2.3.0.13 -> v2.3.0.13
[00016266][04 00][00] v1.41.0.0 -> v1.41.0.0
[00016329][09 00][00] v1.7.0.3 -> v1.7.0.3
[00016441][11 00][00] v1.7.0.0 -> v1.7.0.0
[00016529][12 00][00] v1.10.0.0 -> v1.10.0.0
[00016605][12 01][00] v1.10.0.0 -> v1.10.0.0
[00016694][12 02][00] v1.10.0.0 -> v1.10.0.0
[00016794][12 03][00] v1.10.0.0 -> v1.10.0.0
[00029334][15 00][00] device not detected.
[00029407][17 00][00] v1.1.1.7 -> v1.1.1.7
[00029538][17 01][00] v1.0.2.7 -> v1.0.2.7
[00029594][19 00][00] v1.0.8.96 -> v1.0.8.96
[00029633][01 00][00] v1.23.3419 -> v1.23.3419
[00029673][01 01][00] v1.23.3419 -> v1.23.3419
[00042215][08 00][00] device not detected.
[00042334]Packet upgrade failed at version checking.
[00201319]========== 2015.09.08 19:13:30. boot(15) ============
[00201368]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0x70ce1c3a].
[00201414]Packet upgrade start...
[00201464]Packet checking...
[00201516]Packet vlink 01.04.0010 <-> 01.03.0020.
[00201592]Done.
[00201639]Version checking[1]...
[00201741][03 05][00] v34.2.0.9 -> v34.2.0.9
[00201839][03 06][00] v2.3.0.13 -> v2.3.0.13
[00201890][04 00][00] v1.41.0.0 -> v1.41.0.0
[00201953][09 00][00] v1.7.0.3 -> v1.7.0.3
[00202079][11 00][00] v1.7.0.0 -> v1.7.0.0
[00202208][12 00][00] v1.10.0.0 -> v1.10.0.0
[00202307][12 01][00] v1.10.0.0 -> v1.10.0.0
[00202407][12 02][00] v1.10.0.0 -> v1.10.0.0
[00202507][12 03][00] v1.10.0.0 -> v1.10.0.0
[00215051][15 00][00] device not detected.
[00215131][17 00][00] v1.1.1.7 -> v1.1.1.7
[00215233][17 01][00] v1.0.2.7 -> v1.0.2.7
[00215303][19 00][00] v1.0.8.96 -> v1.0.8.96
[00215353][01 00][00] v1.23.3419 -> v1.23.3419
[00215397][01 01][00] v1.23.3419 -> v1.23.3419
[00227942][08 00][00] device not detected.
[00227985]Packet upgrade failed at version checking.
[00014549]========== remo-con disconnect. boot(15) ============
[00014597]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0x70ce1c3a].
[00014641]Packet upgrade start...
[00014687]Packet checking...
[00014731]Packet vlink 01.04.0010 <-> 01.03.0020.
[00014810]Done.
[00014855]Version checking[1]...
[00014933][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015006][03 06][00] v2.3.0.13 -> v2.3.0.13
[00015062][04 00][00] v1.41.0.0 -> v1.41.0.0
[00015120][09 00][00] v1.7.0.3 -> v1.7.0.3
[00015226][11 00][00] v1.7.0.0 -> v1.7.0.0
[00015295][12 00][00] v1.10.0.0 -> v1.10.0.0
[00015385][12 01][00] v1.10.0.0 -> v1.10.0.0
[00015485][12 02][00] v1.10.0.0 -> v1.10.0.0
[00015560][12 03][00] v1.10.0.0 -> v1.10.0.0
[00028103][15 00][00] device not detected.
[00028195][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028337][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028500][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028544][01 00][00] v1.23.3419 -> v1.23.3419
[00028589][01 01][00] v1.23.3419 -> v1.23.3419
[00041140][08 00][00] device not detected.
[00041184]Packet upgrade failed at version checking.
[00014546]========== remo-con disconnect. boot(15) ============
[00014592]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x70ce1c3a].
[00014633]Packet upgrade start...
[00014679]Packet checking...
[00014722]Packet vlink 01.03.0020 <-> 01.01.0009.
[00014798]Done.
[00014843]Version checking[1]...
[00014932][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015009][03 06][00] v2.3.0.13 -> v2.2.6.19
[00015065][04 00][00] v1.41.0.0 -> v1.40.0.0
[00015121][09 00][00] v1.7.0.3 -> v1.7.0.3
[00015231][11 00][00] v1.7.0.0 -> v1.7.0.0
[00015343][12 00][00] v1.10.0.0 -> v1.8.0.0
[00015415][12 01][00] v1.10.0.0 -> v1.8.0.0
[00015515][12 02][00] v1.10.0.0 -> v1.8.0.0
[00015607][12 03][00] v1.10.0.0 -> v1.8.0.0
[00028153][15 00][00] device not detected.
[00028261][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028381][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028462][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028504][01 00][00] v1.23.3419 -> v1.23.3419
[00028547][01 01][00] v1.23.3419 -> v1.23.3419
[00041106][08 00][00] device not detected.
[00041148]Packet upgrade failed at version checking.
[00015117]========== 2015.09.08 19:41:04. boot(15) ============
[00015158]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x70ce1c3a].
[00015200]Packet upgrade start...
[00015253]Packet checking...
[00015293]Packet vlink 01.03.0020 <-> 01.01.0009.
[00015366]Done.
[00015407]Version checking[1]...
[00015490][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015569][03 06][00] v2.3.0.13 -> v2.2.6.19
[00015623][04 00][00] v1.41.0.0 -> v1.40.0.0
[00015673][09 00][00] v1.7.0.3 -> v1.7.0.3
[00015789][11 00][00] v1.7.0.0 -> v1.7.0.0
[00015878][12 00][00] v1.10.0.0 -> v1.8.0.0
[00015979][12 01][00] v1.10.0.0 -> v1.8.0.0
[00016158][12 02][00] v1.10.0.0 -> v1.8.0.0
[00016238][12 03][00] v1.10.0.0 -> v1.8.0.0
[00028787][15 00][00] device not detected.
[00028878][17 00][00] v1.1.1.7 -> v1.1.1.7
[00029019][17 01][00] v1.0.2.7 -> v1.0.2.7
[00029073][19 00][00] v1.0.8.96 -> v1.0.8.96
[00029120][01 00][00] v1.23.3419 -> v1.23.3419
[00029165][01 01][00] v1.23.3419 -> v1.23.3419
[00041708][08 00][00] device not detected.
[00041750]Packet upgrade failed at version checking.
[00014568]========== 2015.09.08 19:42:43. boot(15) ============
[00014607]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x70ce1c3a].
[00014651]Packet upgrade start...
[00014696]Packet checking...
[00014744]Packet vlink 01.03.0020 <-> 01.01.0009.
[00014816]Done.
[00014859]Version checking[1]...
[00014938][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015018][03 06][00] v2.3.0.13 -> v2.2.6.19
[00015071][04 00][00] v1.41.0.0 -> v1.40.0.0
[00015142][09 00][00] v1.7.0.3 -> v1.7.0.3
[00015258][11 00][00] v1.7.0.0 -> v1.7.0.0
[00015352][12 00][00] v1.10.0.0 -> v1.8.0.0
[00015457][12 01][00] v1.10.0.0 -> v1.8.0.0
[00015552][12 02][00] v1.10.0.0 -> v1.8.0.0
[00015652][12 03][00] v1.10.0.0 -> v1.8.0.0
[00028195][15 00][00] device not detected.
[00028328][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028447][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028503][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028546][01 00][00] v1.23.3419 -> v1.23.3419
[00028590][01 01][00] v1.23.3419 -> v1.23.3419
[00041134][08 00][00] device not detected.
[00041177]Packet upgrade failed at version checking.
[00014590]========== remo-con disconnect. boot(15) ============
[00014632]Packet [C:\P3X_FW_V01.01.0009.bin] detected, card sn [0x70ce1c3a].
[00014680]Packet upgrade start...
[00014730]Packet checking...
[00014780]Packet vlink 01.01.0000 <-> 01.01.0000.
[00014857]Done.
[00014900]Version checking[1]...
[00014987][03 05][00] v34.2.0.9 -> v34.2.0.8
[00015067][03 06][00] v2.3.0.13 -> v2.1.6.18
[00015123][04 00][00] v1.41.0.0 -> v1.36.0.0
[00015277][09 00][00] v1.7.0.3 -> v1.7.0.3
[00015387][11 00][00] v1.7.0.0 -> v1.6.0.0
[00015476][12 00][00] v1.10.0.0 -> v1.8.0.0
[00015567][12 01][00] v1.10.0.0 -> v1.8.0.0
[00015676][12 02][00] v1.10.0.0 -> v1.8.0.0
[00015767][12 03][00] v1.10.0.0 -> v1.8.0.0
[00028314][15 00][00] device not detected.
[00028396][17 00][00] v1.1.1.7 -> v1.1.1.2
[00028537][17 01][00] v1.0.2.7 -> v1.0.2.4
[00028599][19 00][00] v1.0.8.96 -> v1.0.8.59
[00028644][01 00][00] v1.23.3419 -> v1.6.2736
[00028691][01 01][00] v1.23.3419 -> v1.5.2735
[00041241][08 00][00] device not detected.
[00041291]Packet upgrade failed at version checking.
5: Any supporting video you might have for the issue.
[url=http://youtu.be/3liMkO9Bzxg]http://youtu.be/3liMkO9Bzxg[/url]
2015-9-8
sploodge
Flight distance : 809350 ft
no1caresme Posted at 2015-9-8 10:55
HELP! HELP! I got the error for updating the firmware. I need to present my work but there is no si ...
Remove the battery for 15 minutes from then P3 then try firmware again
2015-9-8
Flyhigh7887
Sweden
sploodge Posted at 2015-9-7 23:33
Check the about section of the App. if it says you are on 1.3.20 for the RC verison then you are OK ...
DJI is looking out for you Sploodge. They are afraid all of the repeated questions will scare you away. ;)
From their downloads site:
"The All-in-One firmware v1.4.0010 does not include remote controller update package. However, for the best user experience, it is recommended that the users who are using the firmware that older than v1.3.20 to update the firmware to v1.3.20 before updating the aircraft."
edit: oh sh!t, now i am THAT guy... i missed that you already posted it.  {:3_50:}
2015-9-8
no1caresme
sploodge Posted at 2015-9-8 20:54
Still the same error
2015-9-8
Phantom Menace
Trouble updating my RC. This is a Phantom 3 Pro and the RC already had 1.2.6 on it.
I tried updating when 1.3.2 came out and it wouldn't allow it saying it was already up-to-date. I understand that the RC does not require every new update, but mine keeps saying that it REQUIRES an update now. Then, when I try to give it one, it won't take it. I tried letting the latest Go app (The one released with yesterday's FW update) automatically update the RC's firmware. I followed the instructions and when I clicked on the update button, it just gave me a line of text saying to follow the directions in the manual. I used a USB stick and tried it. No luck there, either. My text file on the USB said what was there was the same or newer than what I was trying to put in. Fine, but it keeps telling me that an UPDATE IS REQUIRED.
How do I solve this?
2015-9-8
sploodge
Phantom Menace Posted at 2015-9-8 12:52
I tried updating when 1.3.2 came out and it wouldn't allow it saying it was ...
Download firmware 1.3.20 and use this to update the RC ONLY. Make sure to remove any other firmware file and logs form the SD card/USB Pen first
2015-9-8
no1caresme
I have already tried to format the SD card and to use different SD card.
I still got the same error whatever using P3X_FW_V01.04.0010.bin or P3X_FW_V01.03.0020.bin
Upgrading ...
Result: Failed.
Upgrading ...
Result: Failed.
Result: Failed.
Result: Failed.
Result: Failed.
Result: Failed.
Result: Failed.
Result: Failed.
Result: Failed.
Result: Failed.
Result: Failed.
Result: Failed.
Result: Failed.
Result: Failed.
Result: Failed.
Result: Failed.
Result: Failed.
Result: Failed.
Result: Failed.
Result: Failed.
========== 2015.09.08 20:17:53 =====================
Result: Failed.
Packet: P3X_FW_V01.01.1003.bin
Result: Corrupted.
Firmware bin file is corrupted, download it again from the DJI offical website.
Result: Corrupted.
Result: Failed.
========== 2015.09.08 21:05:34 =====================
Result: Failed.
Result: Failed.
Result: Failed.
Result: Failed.
[00012348]Done.
[00014211]Done.
[00014713]Done.
[00040909]Done.
[01195446]Done.
[00014662]Done.
[00040824]Done.
[00103775]Done.
[00014854]Done.
[00014858]Done.
[00014862]Done.
[00014870]Done.
[00014883]Done.
[00014898]Done.
[00015424]Done.
[00014910]Done.
[00014906]Done.
[00014977]Done.
[00015688]Done.
[00016048]Done.
[00201592]Done.
[00014810]Done.
[00014798]Done.
[00015366]Done.
[00014816]Done.
[00014857]Done.
[00014603]========== 2015.09.08 20:17:54. boot(15) ============
[00014648]Packet [C:\P3X_FW_V01.01.0009.bin] detected, card sn [0x70ce1c3a].
[00014691]Packet upgrade start...
[00014738]Packet checking...
[00014789]Packet vlink 01.01.0000 <-> 01.01.0000.
[00014862]Done.
[00014905]Version checking[1]...
[00015001][03 05][00] v34.2.0.9 -> v34.2.0.8
[00015085][03 06][00] v2.3.0.13 -> v2.1.6.18
[00015135][04 00][00] v1.41.0.0 -> v1.36.0.0
[00015199][09 00][00] v1.7.0.3 -> v1.7.0.3
[00015347][11 00][00] v1.7.0.0 -> v1.6.0.0
[00015451][12 00][00] v1.10.0.0 -> v1.8.0.0
[00015555][12 01][00] v1.10.0.0 -> v1.8.0.0
[00015656][12 02][00] v1.10.0.0 -> v1.8.0.0
[00015753][12 03][00] v1.10.0.0 -> v1.8.0.0
[00028296][15 00][00] device not detected.
[00028388][17 00][00] v1.1.1.7 -> v1.1.1.2
[00028529][17 01][00] v1.0.2.7 -> v1.0.2.4
[00028687][01 01][00] v1.23.3419 -> v1.5.2735
[00041232][08 00][00] device not detected.
[00041281]Packet upgrade failed at version checking.
[00014594]========== remo-con disconnect. boot(15) ============
[00014639]Packet [C:\P3X_FW_V01.01.1003.bin] detected, card sn [0x70ce1c3a].
[00014687]Packet upgrade start...
[00014736]Packet checking...
[00014788]Packet upgrade failed at packet checking.
[00015117]========== remo-con disconnect. boot(15) ============
[00015164]Packet [C:\P3X_FW_V01.01.1003.bin] detected, card sn [0x70ce1c3a].
[00015214]Packet upgrade start...
[00015269]Packet checking...
[00015320]Packet upgrade failed at packet checking.
[00014632]========== remo-con disconnect. boot(15) ============
[00014677]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x70ce1c3a].
[00014723]Packet upgrade start...
[00014778]Packet checking...
[00014824]Packet vlink 01.03.0020 <-> 01.01.0009.
[00014898]Done.
[00014950]Version checking[1]...
[00015037][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015121][03 06][00] v2.3.0.13 -> v2.2.6.19
[00015169][04 00][00] v1.41.0.0 -> v1.40.0.0
[00015236][09 00][00] v1.7.0.3 -> v1.7.0.3
[00015360][11 00][00] v1.7.0.0 -> v1.7.0.0
[00015445][12 00][00] v1.10.0.0 -> v1.8.0.0
[00015545][12 01][00] v1.10.0.0 -> v1.8.0.0
[00015748][12 03][00] v1.10.0.0 -> v1.8.0.0
[00028293][15 00][00] device not detected.
[00028385][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028531][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028596][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028641][01 00][00] v1.23.3419 -> v1.23.3419
[00028686][01 01][00] v1.23.3419 -> v1.23.3419
[00041233][08 00][00] device not detected.
[00041283]Packet upgrade failed at version checking.
[00225352]========== 2015.09.08 21:05:35. boot(15) ============
[00225398]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x70ce1c3a].
[00225448]Packet upgrade start...
[00225498]Packet checking...
[00225544]Packet vlink 01.03.0020 <-> 01.01.0009.
[00225619]Done.
[00225664]Version checking[1]...
[00225737][03 05][00] v34.2.0.9 -> v34.2.0.9
[00225816][03 06][00] v2.3.0.13 -> v2.2.6.19
[00225874][04 00][00] v1.41.0.0 -> v1.40.0.0
[00225945][09 00][00] v1.7.0.3 -> v1.7.0.3
[00226061][11 00][00] v1.7.0.0 -> v1.7.0.0
[00226150][12 00][00] v1.10.0.0 -> v1.8.0.0
[00226230][12 01][00] v1.10.0.0 -> v1.8.0.0
[00226410][12 02][00] v1.10.0.0 -> v1.8.0.0
[00226510][12 03][00] v1.10.0.0 -> v1.8.0.0
[00239057][15 00][00] device not detected.
[00239165][17 00][00] v1.1.1.7 -> v1.1.1.7
[00239305][17 01][00] v1.0.2.7 -> v1.0.2.7
[00239369][19 00][00] v1.0.8.96 -> v1.0.8.96
[00239418][01 00][00] v1.23.3419 -> v1.23.3419
[00239469][01 01][00] v1.23.3419 -> v1.23.3419
[00252015][08 00][00] device not detected.
[00252064]Packet upgrade failed at version checking.
[00014950]========== remo-con disconnect. boot(15) ============
[00015072]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x92ac838d].
[00015122]Packet upgrade start...
[00015167]Packet checking...
[00015213]Packet vlink 01.03.0020 <-> 01.01.0009.
[00015293]Done.
[00015336]Version checking[1]...
[00015403][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015483][03 06][00] v2.3.0.13 -> v2.2.6.19
[00015533][04 00][00] v1.41.0.0 -> v1.40.0.0
[00015593][09 00][00] v1.7.0.3 -> v1.7.0.3
[00015704][11 00][00] v1.7.0.0 -> v1.7.0.0
[00015804][12 00][00] v1.10.0.0 -> v1.8.0.0
[00015893][12 01][00] v1.10.0.0 -> v1.8.0.0
[00015983][12 02][00] v1.10.0.0 -> v1.8.0.0
[00016083][12 03][00] v1.10.0.0 -> v1.8.0.0
[00028634][15 00][00] device not detected.
[00028714][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028836][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028894][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028944][01 00][00] v1.23.3419 -> v1.23.3419
[00028986][01 01][00] v1.23.3419 -> v1.23.3419
[00041530][08 00][00] device not detected.
[00041574]Packet upgrade failed at version checking.
[00015125]========== remo-con disconnect. boot(15) ============
[00015231]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x92ac838d].
[00015354]Packet upgrade start...
[00015400]Packet checking...
[00015450]Packet vlink 01.03.0020 <-> 01.01.0009.
[00015524]Done.
[00015567]Version checking[1]...
[00015655][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015732][03 06][00] v2.3.0.13 -> v2.2.6.19
[00015794][04 00][00] v1.41.0.0 -> v1.40.0.0
[00015961][09 00][00] v1.7.0.3 -> v1.7.0.3
[00016155][11 00][00] v1.7.0.0 -> v1.7.0.0
[00016248][12 00][00] v1.10.0.0 -> v1.8.0.0
[00016348][12 01][00] v1.10.0.0 -> v1.8.0.0
[00016447][12 02][00] v1.10.0.0 -> v1.8.0.0
[00016547][12 03][00] v1.10.0.0 -> v1.8.0.0
[00029106][15 00][00] device not detected.
[00029198][17 00][00] v1.1.1.7 -> v1.1.1.7
[00029324][17 01][00] v1.0.2.7 -> v1.0.2.7
[00029383][19 00][00] v1.0.8.96 -> v1.0.8.96
[00029431][01 00][00] v1.23.3419 -> v1.23.3419
[00029485][01 01][00] v1.23.3419 -> v1.23.3419
[00042030][08 00][00] device not detected.
[00042075]Packet upgrade failed at version checking.
[00015139]========== remo-con disconnect. boot(15) ============
[00015259]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x92ac838d].
[00015382]Packet upgrade start...
[00015433]Packet checking...
[00015479]Packet vlink 01.03.0020 <-> 01.01.0009.
[00015556]Done.
[00015604]Version checking[1]...
[00015680][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015760][03 06][00] v2.3.0.13 -> v2.2.6.19
[00015811][04 00][00] v1.41.0.0 -> v1.40.0.0
[00015869][09 00][00] v1.7.0.3 -> v1.7.0.3
[00015980][11 00][00] v1.7.0.0 -> v1.7.0.0
[00016074][12 00][00] v1.10.0.0 -> v1.8.0.0
[00016174][12 01][00] v1.10.0.0 -> v1.8.0.0
[00016274][12 02][00] v1.10.0.0 -> v1.8.0.0
[00016349][12 03][00] v1.10.0.0 -> v1.8.0.0
[00028896][15 00][00] device not detected.
[00028990][17 00][00] v1.1.1.7 -> v1.1.1.7
[00029111][17 01][00] v1.0.2.7 -> v1.0.2.7
[00029170][19 00][00] v1.0.8.96 -> v1.0.8.96
[00029216][01 00][00] v1.23.3419 -> v1.23.3419
[00029265][01 01][00] v1.23.3419 -> v1.23.3419
[00041817][08 00][00] device not detected.
[00041861]Packet upgrade failed at version checking.
2015-9-8
Phantom Menace
sploodge Posted at 2015-9-8 07:55
Download firmware 1.3.20 and use this to update the RC ONLY. Make sure to remove any other firmwar ...
That solved the problem. All is good now. After going back and reading the beginning of this thread, I did find those instructions there and put 1.3.2 on the RC.
I am ready to go try everything out now.
2015-9-8
chris
Finland
hi worried abouit my upgrade all seems ok, but !!! it only tiook around 15 minutes till gimbal light solid green and right da da noises, i left it for anothe ten minutes but nothing happend further
this is misc log could you glance over it and verify succes :}
[00012226][01 00] Firmware upgrade finished successfully.
[00012335]Done.
[00012367]Packet [C:\P3X_FW_V01.02.0006.bin] resumed, card sn [0x90ce6786].
[00012401]Version checking[2]...
[00012484][03 05][00] v34.2.0.8 -> v34.2.0.9 need upgrade.
[00012561][03 06][00] v2.1.6.18 -> v2.2.6.8 need upgrade.
[00012600][04 00][00] v1.36.0.0 -> v1.38.0.0 need upgrade.
[00012666][09 00][00] v1.7.0.3 -> v1.7.0.3
[00012761][11 00][00] v1.6.1.0 -> v1.6.0.0
[00012856][12 00][00] v1.8.0.0 -> v1.8.0.0
[00012936][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013011][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013086][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013213][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013306][17 00][00] v1.1.1.2 -> v1.1.1.6 need upgrade.
[00013426][17 01][00] v1.0.2.4 -> v1.0.2.5 need upgrade.
[00013486][19 00][00] v1.0.8.96 -> v1.0.8.96
[00013519][01 00][05] v1.15.3056 -> v1.15.3056
[00013552][01 01][00] v1.6.2736 -> v1.15.3056 need upgrade
[00013593][08 00][00] v0.11.0.4 -> v0.11.0.4
[00013632]Done.
[00013665]Firmware upgrading[2]...
[00013808][01 01] Firmware upgrade start...
[00044067][01 01] Firmware upgrade finished successfully.
[00044125][17 00] Firmware upgrade start...
[00127672][17 00] Firmware upgrade finished successfully.
[00127717][17 01] Firmware upgrade start...
[00198296][17 01] Firmware upgrade finished successfully.
[00198351][03 05] Firmware upgrade start...
[00273215][03 05] Firmware upgrade finished successfully.
[00273434][03 06] Firmware upgrade start...
[00591249][03 06] Firmware upgrade finished successfully.
[00591310][04 00] Firmware upgrade start...
[00649095][04 00] Firmware upgrade finished successfully.
[00649130]Done.
[00649163]Version checking[3]...
[00649242][03 05][05] v34.2.0.9 -> v34.2.0.9
[00649322][03 06][05] v2.2.6.8 -> v2.2.6.8
[00649359][04 00][05] v1.38.0.0 -> v1.38.0.0
[00649423][09 00][00] v1.7.0.3 -> v1.7.0.3
[00649523][11 00][00] v1.6.1.0 -> v1.6.0.0
[00649613][12 00][00] v1.8.0.0 -> v1.8.0.0
[00649703][12 01][00] v1.8.0.0 -> v1.8.0.0
[00649892][12 02][00] v1.8.0.0 -> v1.8.0.0
[00649983][12 03][00] v1.8.0.0 -> v1.8.0.0
[00650102][15 00][00] v1.1.2.0 -> v1.1.2.0
[00650192][17 00][05] v1.1.1.6 -> v1.1.1.6
[00650354][17 01][05] v1.0.2.5 -> v1.0.2.5
[00650402][19 00][00] v1.0.8.96 -> v1.0.8.96
[00650436][01 00][05] v1.15.3056 -> v1.15.3056
[00650469][01 01][05] v1.15.3056 -> v1.15.3056
[00650517][08 00][00] v0.11.0.4 -> v0.11.0.4
[00650549]Packet upgrade finish successfully.
[00013476]========== remo-con disconnect. boot(15) ============
[00013600]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x90ce6786].
[00013677]Packet upgrade start...
[00013819]Packet checking...
[00013924]Done.
[00014030]Version checking[1]...
[00014178][03 05][00] v34.2.0.9 -> v34.2.0.9
[00014318][03 06][00] v2.2.6.8 -> v2.2.6.19 need upgrade.
[00014429][04 00][00] v1.38.0.0 -> v1.40.0.0 need upgrade.
[00014498][09 00][00] v1.7.0.3 -> v1.7.0.3
[00014694][11 00][00] v1.6.1.0 -> v1.7.0.0 need upgrade.
[00014893][12 00][00] v1.8.0.0 -> v1.8.0.0
[00015053][12 01][00] v1.8.0.0 -> v1.8.0.0
[00015233][12 02][00] v1.8.0.0 -> v1.8.0.0
[00015413][12 03][00] v1.8.0.0 -> v1.8.0.0
[00015605][15 00][00] v1.1.2.0 -> v1.1.2.0
[00015742][17 00][00] v1.1.1.6 -> v1.1.1.7 need upgrade.
[00015929][17 01][00] v1.0.2.5 -> v1.0.2.7 need upgrade.
[00016059][19 00][00] v1.0.8.96 -> v1.0.8.96
[00016164][01 00][00] v1.15.3056 -> v1.23.3419 need upgrade
[00016269][01 01][00] v1.15.3056 -> v1.23.3419 need upgrade
[00016440][08 00][00] v0.11.0.4 -> v0.12.0.4 need upgrade.
[00016550]Done.
[00018653]Waiting for user confirm...
[00028714]Timeout, start upgrade automatically.
[00028921]Firmware upgrading[1]...
[00041029][01 00] Firmware upgrade start...
[00012237][01 00] Firmware upgrade finished successfully.
[00012277]Done.
[00012308]Packet [C:\P3X_FW_V01.03.0020.bin] resumed, card sn [0x90ce6786].
[00012346]Packet vlink 01.03.0020 <-> 01.01.0009.
[00012417]Version checking[2]...
[00012574][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012652][03 06][00] v2.2.6.8 -> v2.2.6.19 need upgrade.
[00012691][04 00][00] v1.38.0.0 -> v1.40.0.0 need upgrade.
[00012752][09 00][00] v1.7.0.3 -> v1.7.0.3
[00012852][11 00][00] v1.6.1.0 -> v1.7.0.0 need upgrade.
[00012937][12 00][00] v1.8.0.0 -> v1.8.0.0
[00013027][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013127][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013207][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013342][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013418][17 00][00] v1.1.1.6 -> v1.1.1.7 need upgrade.
[00013538][17 01][00] v1.0.2.5 -> v1.0.2.7 need upgrade.
[00013593][19 00][00] v1.0.8.96 -> v1.0.8.96
[00013628][01 00][05] v1.23.3419 -> v1.23.3419
[00013663][01 01][00] v1.15.3056 -> v1.23.3419 need upgrade
[00013721][08 00][00] v0.11.0.4 -> v0.12.0.4 need upgrade.
[00013755]Done.
[00013789]Firmware upgrading[2]...
[00013932][01 01] Firmware upgrade start...
[00044184][01 01] Firmware upgrade finished successfully.
[00045020][08 00] Firmware upgrade start...
[00600912][08 00] Firmware upgrade finished successfully.
[00600971][17 00] Firmware upgrade start...
[00693615][17 00] Firmware upgrade finished successfully.
[00693660][17 01] Firmware upgrade start...
[00760359][17 01] Firmware upgrade finished successfully.
[00760409][11 00] Firmware upgrade start...
[00809794][11 00] Firmware upgrade finished successfully.
[00810012][03 06] Firmware upgrade start...
[01125126][03 06] Firmware upgrade finished successfully.
[01125188][04 00] Firmware upgrade start...
[01183125][04 00] Firmware upgrade finished successfully.
[01183161]Done.
[01183196]Version checking[3]...
[01183300][03 05][00] v34.2.0.9 -> v34.2.0.9
[01183379][03 06][05] v2.2.6.19 -> v2.2.6.19
[01183419][04 00][05] v1.40.0.0 -> v1.40.0.0
[01183480][09 00][00] v1.7.0.3 -> v1.7.0.3
[01183600][11 00][05] v1.7.0.0 -> v1.7.0.0
[01183699][12 00][00] v1.8.0.0 -> v1.8.0.0
[01183785][12 01][00] v1.8.0.0 -> v1.8.0.0
[01183874][12 02][00] v1.8.0.0 -> v1.8.0.0
[01184034][12 03][00] v1.8.0.0 -> v1.8.0.0
[01184183][15 00][00] v1.1.2.0 -> v1.1.2.0
[01184265][17 00][05] v1.1.1.7 -> v1.1.1.7
[01184385][17 01][05] v1.0.2.7 -> v1.0.2.7
[01184460][19 00][00] v1.0.8.96 -> v1.0.8.96
[01184498][01 00][05] v1.23.3419 -> v1.23.3419
[01184533][01 01][05] v1.23.3419 -> v1.23.3419
[01184592][08 00][05] v0.12.0.4 -> v0.12.0.4
[01184625]Packet upgrade finish successfully.
[00013100]========== remo-con disconnect. boot(15) ============
[00013141]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0x90ce6786].
[00013176]Packet upgrade start...
[00013214]Packet checking...
[00013250]Packet vlink 01.04.0010 <-> 01.03.0020.
[00013286]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00013329]Done.
[00013362]Version checking[1]...
[00013429][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013489][03 06][00] v2.2.6.19 -> v2.3.0.13 need upgrade.
[00013545][04 00][00] v1.40.0.0 -> v1.41.0.0 need upgrade.
[00013599][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013710][11 00][00] v1.7.0.0 -> v1.7.0.0
[00013810][12 00][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
[00013884][12 01][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
[00013965][12 02][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
[00014040][12 03][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
[00014178][15 00][00] v1.1.2.0 -> v1.1.2.0
[00014260][17 00][00] v1.1.1.7 -> v1.1.1.7
[00014379][17 01][00] v1.0.2.7 -> v1.0.2.7
[00014439][19 00][00] v1.0.8.96 -> v1.0.8.96
[00014474][01 00][00] v1.23.3419 -> v1.23.3419
[00014510][01 01][00] v1.23.3419 -> v1.23.3419
[00014562][08 00][00] v0.12.0.4 -> v0.12.0.4
[00014604]Done.
[00016639]Waiting for user confirm...
[00026681]Timeout, start upgrade automatically.
[00026755]Firmware upgrading[1]...
[00026804][12 00] Firmware upgrade start...
[00094058][12 00] Firmware upgrade finished successfully.
[00094110][12 01] Firmware upgrade start...
[00160107][12 01] Firmware upgrade finished successfully.
[00160158][12 02] Firmware upgrade start...
[00224430][12 02] Firmware upgrade finished successfully.
[00224481][12 03] Firmware upgrade start...
[00290200][12 03] Firmware upgrade finished successfully.
[00290424][03 06] Firmware upgrade start...
[00623714][03 06] Firmware upgrade finished successfully.
[00623778][04 00] Firmware upgrade start...
[00681441][04 00] Firmware upgrade finished successfully.
[00681485]Done.
[00681521]Version checking[2]...
[00681593][03 05][00] v34.2.0.9 -> v34.2.0.9
[00681673][03 06][05] v2.3.0.13 -> v2.3.0.13
[00681716][04 00][05] v1.41.0.0 -> v1.41.0.0
[00681778][09 00][00] v1.7.0.3 -> v1.7.0.3
[00681894][11 00][00] v1.7.0.0 -> v1.7.0.0
[00681982][12 00][05] v1.10.0.0 -> v1.10.0.0
[00682067][12 01][05] v1.10.0.0 -> v1.10.0.0
[00682167][12 02][05] v1.10.0.0 -> v1.10.0.0
[00682247][12 03][05] v1.10.0.0 -> v1.10.0.0
[00682380][15 00][00] v1.1.2.0 -> v1.1.2.0
[00682457][17 00][00] v1.1.1.7 -> v1.1.1.7
[00682582][17 01][00] v1.0.2.7 -> v1.0.2.7
[00682636][19 00][00] v1.0.8.96 -> v1.0.8.96
[00682671][01 00][00] v1.23.3419 -> v1.23.3419
[00682709][01 01][00] v1.23.3419 -> v1.23.3419
[00682771][08 00][00] v0.12.0.4 -> v0.12.0.4
[00682808]Packet upgrade finish successfully.
thanks
kiitos
2015-9-8
sploodge
chris@chris-hil Posted at 2015-9-8 13:34
hi worried abouit my upgrade all seems ok, but !!! it only tiook around 15 minutes till gimbal light ...
All good to go .. Check the App's "About " section and verify the remote controller is at 1.3.20.
2015-9-8
nicholascurtis3
sploodge Posted at 2015-9-8 00:56
The log shows its updated OK..
Thank you sploodge, greatly appreciate it!
2015-9-8
hbargine
Been trying to update my RC with the latest -- I have the P3 advanced
I was able to successfully update the bird however the RC refuses to take the update.
RC version of firmware is 1.1.8
It does not allow me to update while being connected to bird.
I tried the current update and put in on a SD card - turn the RC on and nothing happens after 60 secs... no blue light no update.
Pretty sure I've tried every SD card that I have - and even used the card that came with the bird - removed the updated version and went to the 1.3.20 version that was suggested and still no acceptance of the new firmware. Any suggestions...
2015-9-8
sploodge
hbargine Posted at 2015-9-8 14:45
I was able to successfully up ...
Can you post the contents of both logs files when trying to update the RC?
2015-9-8
hbargine
sploodge Posted at 2015-9-8 07:58
When I tried to input the 1.3.20 version I removed the txt files from the card and put them in the trash.
Can't find them in the trash - even though I had not emptied the trash... perplexed.
2015-9-8
adot
no1caresme Posted at 2015-9-8 07:09
I still got the same er ...
I have the same problem.. No signal and it will not take the update. I have tried everything I can think of. No crashes the phantom has been flying fine for months and now this.
2015-9-8
radius
Indonesia
radius Posted at 2015-9-8 17:41
thank you sploodge.
reporting back. the update went nice & smooth.
from 1.1.9 to 1.3.2.0 :
  - update aircraft, RC, and extra battery.
  - took about 22 minutes
from 1.3.2.0 to 1.4.0010 :
  - update aircraft only
  - RC & extra battery don't need to update, apparently...
  - took about 10 minutes
in "about" menu it now shows firmware 1.4.0010 for the aircraft and 1.3.2.0 for RC.
didn't take the P3P to fly yet. it's almost midnight here in my country.
2015-9-8
aburkefl
Flight distance : 78612 ft
Followed your printed guide right to the letter. The only thing I think I did wrong - didn't remove the gimbal holder when I started! Fortunately, didn't appear to hurt anything.
Pleasantly surprised with the update. I was anticipating around half an hour or so - my update took about 12 - 15 minutes. Went out flying (calibrated the snot out of it first!) everything works great.
Haven't really gotten around to the new features yet, just been able to verify the firmware update.
2015-9-8
DarrenDCClark
After flying my P3 Adv yesterday I did the update to 1.4.0010 without issue. Updated my iPad App and updated the quad, however I now cannot calibrate the compass. I get constant Electo Mag Interference whatever I do and wherever I try. Tried it in the middle of nowhere with no metal anywhere around and no joy. Recalibrate the IMU and no success. Downgraded back to previous firmware and it's the same, unable to calibrate the compass. Very, very peeved as it's been working perfectly fine since I got it months ago up to this update. No idea what to do next, i'm now the owner of a very expensive paperweight! Have spent the last six hours this afternoon trying to get it to work without success. Any help or ideas to get me back in the air would be greatly appreciated!
2015-9-8
dmsteen
Anyone know if this is normal? I followed exactly ....update beeping went for what seemed like an unusually long time. This is the text file that was written.
Any thoughts?
Thank you!
Delete history success.
Result: Abort.
The firmware on the SD card is identical to or older than the current firmware on the aircraft.
========== 2014.01.01 00:00:12 remo-con disconnect======
Packet: P3X_FW_V01.02.0006.bin
Result: Abort.
Result: Abort.
========== 2015.07.31 07:52:46 =====================
Result: Abort.
========== 2015.07.31 07:58:53 =====================
Result: Abort.
========== 2015.07.31 08:06:19 =====================
Result: Abort.
========== 2015.07.31 08:10:02 =====================
Result: Abort.
Result: Abort.
========== 2015.07.31 08:23:31 =====================
Result: Abort.
========== 2015.07.31 08:29:20 =====================
Result: Abort.
Result: Abort.
========== 2015.08.02 17:51:38 =====================
Result: Abort.
Result: Abort.
Upgrading ...
Result: Success.
========== 2014.01.01 00:00:11 remo-con disconnect======
Upgrading ...
Result: Success.
Result: Abort.
========== 2015.08.10 00:48:01 =====================
Result: Abort.
Result: Abort.
========== 2015.08.10 16:52:47 =====================
Result: Abort.
========== 2015.08.10 19:16:16 =====================
Result: Abort.
Result: Abort.
========== 2015.08.11 20:12:30 =====================
Result: Abort.
========== 2015.08.12 20:02:47 =====================
Result: Abort.
========== 2015.08.13 15:46:15 =====================
Result: Abort.
Result: Abort.
========== 2015.08.14 18:33:47 =====================
Result: Abort.
========== 2015.08.14 18:41:44 =====================
Result: Abort.
Result: Abort.
Result: Abort.
========== 2015.09.02 17:26:15 =====================
Result: Abort.
Result: Abort.
Upgrading ...
Result: Success.
Result: Abort.
Result: Abort.
========== 2015.09.07 18:46:16 =====================
Result: Abort.
Result: Abort.
2015-9-8
sploodge
dmsteen Posted at 2015-9-8 18:33
Anyone know if this is normal? I followed exactly ....update beeping went for what seemed like an un ...
Looks like it updated OK. Post the contents of the log file in the hidden folder /MISC/LOG on the Sd card to confirm..
Upgrading ...
Result: Success.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
2015-9-8
Alvise
Flight distance : 6237 ft
I (thought) I couldn't update the controller FW.
Then I realised I had to update DJI GO, instead. Something I didn't thought about, since It were only 10-15 hours I had installed that App for the very first time.
Anyway, updating from 2.1.0 to 2.2.0 shows the controller was updated just fine
2015-9-8
hbargine
133#
When I went to put the 1.3.20 version on the card - I erased the current upgrade along with the txt files that were on it. So I don't have those clues to work with. Sure would like to update the firmware to my RC...
2015-9-8
dmsteen
sploodge Posted at 2015-9-9 01:47
Looks like it updated OK. Post the contents of the log file in the hidden folder /MISC/LOG on the  ...
Thanks. Silly question maybe, but where is the hidden folder located?
Using a Mac I can't see it . Tried a terminal entry to show hidden folders/files...still nothing?
Am i missing something?
I also am seeing now that the RC connection jumps back and forth continuously stating poor interference.
even in open areas...areas i had no issues with prior.
Thoughts?
2015-9-8
daxsoft
Flight distance : 484186 ft
Hello:
Recently I put on the Phantom 3 Professional module HDMI output
Today, I loaded with the firmware update and apparently had no problems this "SUCESS".
And I have the latest firmware in the P3P 1.4.0010
  1.3.20 RC
and the latest Android 2.1 app
And nothing will not let me access the IOC, active Enabled Multiple Fligth RC Mode and put the switch to F and the option to "Enabled IOC" is disabled ...
Does anyone know anything?
Logs
Upgrading ...
Result: Success.
[00012683]========== 2015.09.09 00:32:17. boot(15) ============
[00012736]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0xa0ce318f].
[00012789]Packet upgrade start...
[00012853]Packet checking...
[00012988]Packet vlink 01.04.0010 <-> 01.03.0020.
[00013043]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00013098]Done.
[00013151]Version checking[1]...
[00013251][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013351][03 06][00] v2.3.0.13 -> v2.3.0.13
[00013413][04 00][00] v1.41.0.0 -> v1.41.0.0
[00013488][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013625][11 00][00] v1.7.0.0 -> v1.7.0.0
[00013713][12 00][00] v1.10.0.0 -> v1.10.0.0
[00013813][12 01][00] v1.10.0.0 -> v1.10.0.0
[00013925][12 02][00] v1.10.0.0 -> v1.10.0.0
[00014014][12 03][00] v1.10.0.0 -> v1.10.0.0
[00014208][15 00][00] v1.1.2.0 -> v1.1.2.0
[00014333][17 00][00] v1.1.1.7 -> v1.1.1.7
[00014484][17 01][00] v1.0.2.7 -> v1.0.2.7
[00014568][19 00][00] v1.0.8.96 -> v1.0.8.96
[00014622][01 00][00] v1.23.3419 -> v1.23.3419
[00014677][01 01][00] v1.23.3419 -> v1.23.3419
[00014750][08 00][00] v0.12.0.4 -> v0.12.0.4
[00014802]Packet upgrade cancelled at version checking.
I'm sorry for my English
2015-9-8
tongtang878
sploodge Posted at 2015-9-7 22:57
can you downgrade it to 1.3.20 and see if its "OK" again.. Only takes about 5-8 mins to downgrade. ...
I tried that today and the same problem persisted. Any other suggestion before I contact DJI customer support?
2015-9-8
loveailin247
The latest firmware updates the air craft but what about the remote control?
2015-9-8
henry
Flight distance : 52457 ft
sploodge Posted at 2015-9-7 06:31
Seems not on IOS at the moment... Android is out.
My app was automatically updated on iOS, iPad mini 3, yesterday before I updated the firmware.  I tried to update the app first and after no success double checked the version no.  I already had the new app.  The firmware update worked flawlessly.  So far so good, but poi was a little jerky in light wind (<5 mph.).  Still much impressed with the p3.  Cheers.
P.S.  Thank you, Splooge,  for the excellent "how to" post.
2015-9-8
radius
Indonesia
loveailin247@ya Posted at 2015-9-9 10:12
what RC firmware did you have before?
if it was 1.3.2.0, then you don't have to update the RC.
if it was prior 1.3.2.0, then you have to update it using 1.3.2.0 firmware.
2015-9-8
hbargine
Many questions. Few answers.
2015-9-8
Pjames
tried to update with the latest firmware.  When I plugged my SD card back into my computer to check the results, it said "success", but then gave me about 20 lines of "The firmware on the SD card is identical to or older than the current firmware on the aircraft.".  now, I turn on my a aircraft and I have a very loud, constant, beep, which sounds like the same sound that is used when turning on the aircraft and the gimble turns.  I am concerned about this.  Any idea what this is from?  I have tried removing the battery and putting it back in and starting.  I hate these new updates
2015-9-8
sploodge
daxsoft Posted at 2015-9-9 00:07
Hello:
make sure you are flying, and follow this - http://forum.dji.com/thread-29855-1-1.html
2015-9-8
sploodge
hbargine Posted at 2015-9-8 22:29
133#
Post the log files contents..
2015-9-8
fwicks
I have updated the controller to hdmi, and i have used the phantom 3 with the inspire controller with hdmi.  Once you plug in the hdmi, the video to the usb is disabled. On inspire, app settings allow to transmit on both, but that function is disabled for phantom.   Can you update the app and/ or firmware to allow simultaneous video on hdmi and usb? Thanks!
2015-9-9
hbargine
sploodge Posted at 2015-9-8 23:54
If you read the post is says that I erased my notes when I tried to install 1.3.200 update
2015-9-9
sploodge
hbargine Posted at 2015-9-9 14:16
Run it again and new logs will be added ( it will even show older update details ).
2015-9-9
capbat
Flight distance : 54905 ft
sploodge Posted at 2015-9-7 08:31
Is there a difference betwen the ios and android app?
Specificly in the way the data is presenred on the screen?
Thznks
Bat
2015-9-9
capbat
DarrenDCClark Posted at 2015-9-8 13:29
After flying my P3 Adv yesterday I did the update to 1.4.0010 without issue. Updated my iPad App and ...
Have received any answer? Did you fix your problem?
Bat
2015-9-9
DarrenDCClark
capbat Posted at 2015-9-9 15:32
Bat
Hi capbat. No joy, have spent yet another frustrating day fiddling and getting nowhere. DJI have not responded at all so can't say I'm impressed with them.
I have now reverted back to f/w 1.3.2 as that did work fine however I still cannot calibrate the compass and just get a low MOD value of around 700 no matter where I go or what I do. Tried degaussing with a magnet but the values just return to 700 or so.
I will never do any firmware updates again unless seriously forced to do it. I have a very expensive paperweight and doubt I will ever but a DJI product again if they fail to respond.
2015-9-9
L8again
hbargine Posted at 2015-9-9 01:48
Go to top of thread and start reading. All questions have been answered about a dozen time each!
2015-9-9
