dgmultimedia
Flight distance : 216526 ft
Re SD card Format - suggest you put it in the Camera and use the App function FORMAT... rather than formatting it on your PC - you might be using the wrong FAT config.
Re GPS - put it OUTSIDE with a clear view of the Sky - first time it might take a while to find the Orbit data.
DO NOT put any stickers of any sort on the top of the WHITE canopy... there is an icon just to the left of the Status Bar (Button) at the top of the screen - it should show how many Sats are available...
Putting it into Travel mode - you MUST place it on a flat smooth surface (Not a glass tabletop) preferably with a pattern of some sort - THEN trigger the Travel Mode from either the Landing gear switch on the TX ( up, down, up , down or from the APP ) and you MUST have taken the camera OFF first... Do not hold it in the air - it uses the Ultrasonic sensors to confirm that it has moved the arms so that they are level. |
