Gain and expo tunning problem
1279 8 2015-9-6
adam.hube
Poland
Dear All,
I have a problem with adjusting the gain and expo.
I try to change the parameter of rudder response from default 0,40 to minumum 0,30 to get a smoother camera recording.
But the change of this parameter is NOT SAVED in the app.
I change it from 0,40 to 0,30, go the screen back, and when I go again the parameter in not changed...
What i do wrong?
Please advise.
Adam
2015-9-6
dopeytree
Flight distance : 6716467 ft
Have you got the phantom & controller turned on?
2015-9-6
adam.hube
Poland
dopeytree Posted at 2015-9-7 01:33
Yes. The Phantom and controller is on. I will try to contact the dji chat help. Ada
2015-9-6
andreneradil
Brazil
Dear Adam,
I have the same problem. Have you already the solution?
Andre
2015-10-11
EditorPO
Slovakia
i have the same problem, solved?
2015-12-1
DJI-Amy
Hi, what is your aircraft type and APP version?  We've added this function for a long time.  All of the settings are saved in the flight control of aircraft, you need to conect the APP with the aircraft and RC to check if the values returned to your previous settings. What's more, a firmware update will reset all the settings to default, so please check the settings after every firmware update.If the problem persist even if you've connected the aircraft with APP, please provide your aircraft type, mobile device type, android system version , and aircraft firmware version.  Thanks.
2015-12-3
DJI-Patrick
EditorPO Posted at 2015-12-2 06:23
Hi ,
  I've tested that using an  Ipad mini 4 , Phantom3 standard with the latest version firmware And the Phantom3 Pro/Adv are also tested , still no problem .
The data will return to the default everytime after the upgrade . So you'll have to set the data by yourself . And even if you've changed the settings your app will also show the default values when it's not connected to a working aircraft .
2015-12-3
EditorPO
Slovakia
DJI-Patrick Posted at 2015-12-4 04:40
Hi ,
  I've tested that using an  Ipad mini 4 , Phantom3 standard with the latest version firmware  ...
After updating Phantom, RC and app is problem solved. Thanks
2015-12-7
DJI-Patrick
EditorPO Posted at 2015-12-8 03:22
Glad to hear that !
2015-12-8
