tbuining
@DJI Tim,
Not that i am fully unhappy with the new Waypoits from DJI.
But if you after flying (filming) are not happy with the results, it is not possible to move the waypoits a little bit, not much, say 20 meters max. (i believe it cannot - or am i wrong)
I understand that flying befor, makes sure that its much better (saver) than making a plan on a map.
But i should like that it would be possible to move the waypoints (after flying, a bit)
If the waypoint was on the wright place, but you want it not on 20, but on 40 meter high. It is not possible (i believe - or am i wrong)
What is very nice, is that you after recording can change the direction of the Inpire 's camera.
That was not possible with the groundstation. I had this before. But there you could move the waypoints.
I think, the groundstation will not work with the Inspire 1. Or is the receiver (as good as) the same as the A2.
