I read that you have re-built the P3 after a crash.. Make sure the VPS unit is in place properly. Also try disabling it in the App and see if that makes a difference.
sploodge Posted at 2015-9-10 11:45
I read that you have re-built the P3 after a crash.. Make sure the VPS unit is in place properly. ...
I noticed the a capacitor has fallen off.. when back and found it. Held it in place with my finger and then the done works. Just need to find the glue that they use
You soldered it correct? And you used the glue to connect it to the side of something to keep it from vibrating and breaking off again? I hope you soldered it anyway....
