PHANTOM DOES NOT HOLD ITS STILL POSITION IT SWING AROUND PLEASE FIX DJI
1958 7 2015-9-10
fvillanueva
hey guys dealing with my phantom swinging around or moving around be cause of new firmware it doesn't hold its POSITION AT ALL ANYMORE LIKE THE OLD FIRMWARE DID PLEASE DJI FIX PROBLEM ASAP OR THERE ARE GONNA BE A LOT OF PHANTOMS CRASHING AND ILL WILL BE BLAMING THIS ON YOU GUYS BECAUSE ITS A BUG THAT NEEDS TO BE SQUASHED ASAP
2015-9-10
ProFly
I´ve got the latest Firmware, the latest App Version and everything works fine. I use iOS devices, both, iPad Air and Iphone 6. May it was gusty outside, or my be you got water, grass or a structureless ground under your drone. I have a Phantom 3 pro. Check this and try again. I believe in App and Firmware !
2015-9-11
fvillanueva
I have phantom 3 proffessional as well I hope it's just the firm ware I have to delete and download again
2015-9-11
rodmael
I love the new firmware.  However I too, experience the wandering increase and outright nutty behaviour in "follow me".  (panic fly aways)  I always recalibrate, have reloaded the firmware several times but still see the "wonky" behaviour.   Having said that,  the course lock and orbit work great, and I will extend my sincere thank you to the DJI folks for sending this out to us.
2015-9-11
Cetaman
Flight distance : 2528264 ft
Aloha fvillanueva,
     Sound like you need to calibrate your IMU - and badly.  Go into sensors and press "Check IMU".  It should tell you if you need to calibrate.  Be sure to use a level to set a calibration platform so the sensors get the best data and then be sure to calibrate your compass when you are done.
     Hope this helps!
Aloha and Drone On!
2015-10-2
fans78de9f6b
Indonesia
Hi friends i have same problem.
My DJI not fix in position.
Compass status ok
IMU status ok
But still flying not fix in position.
May be anyone can help me too.
Thanks.
2017-3-22
DJI-Jamie
Flight distance : 112405 ft
fans78de9f6b Posted at 2017-3-22 18:47
Compass status ok
Can you verify which Phantom model you have? What firmware and Go app version are you running? How many satellites are you getting? Have you tried recalibrating the compass or just doing an IMU calibration to see if it helps?
2017-3-22
sean808080
My new p3p moves around more than I think it should.  I'm coming from a parrot bebop 2 and that bird was rock solid.   This one moves around a few feet to and fro when I'm expecting it to be still.
2017-3-25
