DJI-Jamie
Flight distance : 112405 ft
PILOTDK Posted at 2017-6-2 07:03
I will just add, that the first year the system had no problems. It came - as other users are writing - with some of the firmware updates (I think). So I would say, that the Ipad actually can handle the data - unless DJI has changed soemthing radically in the firmware/app/dataflow in the new updates.
As more functions and devices got added to the Go app, it required more processing power to run it all. Eventually, older models aren't able to cut it anymore. Just for the sake of troubleshooting, you can try the following button combinations to make sure that the RC and aircraft are communicating properly:
Reset the RC:
* Turn on the controller, and the aircraft should be off.
* Press C1, C2, and shutter on the controller then turn the controller off.
* While holding the buttons, turn on the RC, then the aircraft and relink the remote.
Relink the RC to the aircraft manually:
* Turn on both the aircraft and the controller.
* Press C1, C2, and the record button on the controller, then the controller will make a "D-DD" audio queue. This may take a few seconds of holding it.
*While holding the buttons, press the wheel on the right side of the controller (ISO) and then the LED indicator on the controller will become blue and it will constantly beep "DDDD".
* Use a pen to click the linking button on the aircraft in and hold for 3-5 seconds, and then take the pen off the aircraft and wait, it will be linked soon.
Give that a try and see if there's any difference. It may be cumbersome, you may want to look into manually selecting the channels to see if that's more stable. |
