ateneu
Flight distance : 1348 ft
Romania
As an introduction, i'm a DOP and i'm fet up with the drone rentals that can't do "this" and "that" and when they do it they don't understand composition and timming the shots. Maybe i was unlucky. All my drone shots are done with luck and they last for 1.5 seconds at most. I'm a very happy owner of the Ronin and using it with big productions and even on small budgets music videos.
So, i want to build fast a SpreadingWing S1000+ system with A2 + Ronin M with Sony A7s low light camera. I'm not using Zenmuse Z15-A7 because as i sad before i'm fed up with limitations of the drone rentals. In this case they have just small lenses (pancake type) with short focal lenght (wide). I want to shot maybe with a 50mm, 85mm, and why not 135mm. For this focal lenghts you will need a REMOTE FOCUS and especially if you want to get out of the limitation of the Aperture setting and going wide open for nice bokeh background. On the Zenmuse it will be a problem balancing the gimbal with longer lenses and Remote Focus motors.
As a conclusion lets say to shot in the city at night and pull focus, i think this is the best configuration: SpreadingWing S1000+ system with A2 + Ronin M with Sony A7s and a Remote Focus.
After profound documentation for a month on all devices, the LightBridge 2 comes in play and it has a remote integrating everything I realy like the SDI integrated and the new features.
Because it's a new product nobody had testet yet or do any combinations.
My Questions are as follow:
1. Does the LightBridge2 works with the Ronin M and SpreadingWings with A2? on the website says it's working only with 3models of Zenmuse
2. Does the Remote that comes with LB2 works just as a slave for gimbal control and for the master can i use a futaba with more channels.
3. If you can buy the second remote, can you make a system of 2remotes like in the Inspire 1Case (1for aircraft, 1 for gimbal)? It's this working just with Zenmuse?
4. How customizable are the buttons? on the master and slave remote, for example how do you retract the landing Gear?
5. I read somewhere that the remote can change the shutter and apperture settings on a GH4 zenmuse gimbal system. It's the same with the Zenmuse z15-A7. What settings can you actually change on a Sony camera?
6. Can you change the same settings (aperture, shutter and so on) on a Ronin M combination with LB 2?
7. Can i use it with my Ronin also? (to buy 2of them)
8. It's ready for purschase? i want to have the system ready by 5oct
Thanks for all the answers
