HOWTO: Reinstall a Phantom 3 firmware.
12
38197 79 2015-9-18
Chadian
yes the same one that came with it 16gb lexar 633x hc1 I also formatted it to fat 32 before I started Do you think it can be the card? what is the log saying? it is my understanding that it finished but my gimbal light did not green up? I can try another one yes but it will be a 64gb should be the same class card i think and yes its brand new I will format that one too
2015-9-25
Chadian
this is what i seen when i first put in the card
2015-9-25
sploodge
Flight distance : 809350 ft
The presence calibrationdata.bin and userdata.bin files really looks like it just never finishes updating.
If you can, give another SD card a go. Also how are you transferring the firmware to the card? If it a card converter, usb converter or maybe a built in slot in a laptop? Also make sure to "eject" the card properly before removing it from Windows computers ( same with mac )..
2015-9-25
Chadian
yes the one that came with it I am About to try another one same class but bigger
2015-9-26
Chadian
yes i always eject properly even though you can set your external hard drive jump drives to not lose data by using the yank method lol I am sort of techy my self lol
2015-9-26
Chadian
47 mins so far gimble is flashing green light sounds like its doing its thing I think but who knows until you get you log file? I'm Hopping I don't have to send it back I would much rather fly then get my money back.
2015-9-26
Chadian
Here's my new log It says its done but  it just kept on going again just like last time.
I stopped it before the battery was done going to put in a fresh battery and try your method
[00012238][01 00] Firmware upgrade finished successfully.
[00012350]Done.
[00012450]Packet [C:\P3X_FW_V01.02.0006.bin] resumed, card sn [0x60ce1d4b].
[00012593]Version checking[2]...
[00012747][03 05][00] v34.2.0.8 -> v34.2.0.9 need upgrade.
[00012912][03 06][00] v2.1.6.18 -> v2.2.6.8 need upgrade.
[00013023][04 00][00] v1.36.0.0 -> v1.38.0.0 need upgrade.
[00013186][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013287][11 00][00] v1.6.0.0 -> v1.6.0.0
[00013381][12 00][00] v1.8.0.0 -> v1.8.0.0
[00013461][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013540][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013615][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013741][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013815][17 00][00] v1.1.1.2 -> v1.1.1.6 need upgrade.
[00013935][17 01][00] v1.0.2.4 -> v1.0.2.5 need upgrade.
[00013986][19 00][00] v1.0.8.59 -> v1.0.8.96 need upgrade.
[00014021][01 00][05] v1.15.3056 -> v1.15.3056
[00014054][01 01][00] v1.5.2735 -> v1.15.3056 need upgrade
[00014096][08 00][00] v0.11.0.4 -> v0.11.0.4
[00014128]Done.
[00014160]Firmware upgrading[2]...
[00014302][01 01] Firmware upgrade start...
[00012528]========== remo-con disconnect. boot(15) ============
[00012564]Packet [C:\P3X_FW_V01.02.0006.bin] detected, card sn [0x60ce1d4b].
[00012598]Packet upgrade start...
[00012636]Packet checking...
[00012676]Done.
[00012709]Version checking[1]...
[00012769][03 05][00] v34.2.0.8 -> v34.2.0.9 need upgrade.
[00012829][03 06][00] v2.1.6.18 -> v2.2.6.8 need upgrade.
[00012875][04 00][00] v1.36.0.0 -> v1.38.0.0 need upgrade.
[00012934][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013049][11 00][00] v1.6.0.0 -> v1.6.0.0
[00013125][12 00][00] v1.8.0.0 -> v1.8.0.0
[00013225][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013299][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013378][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013505][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013574][17 00][00] v1.1.1.2 -> v1.1.1.6 need upgrade.
[00013700][17 01][00] v1.0.2.4 -> v1.0.2.5 need upgrade.
[00013754][19 00][00] v1.0.8.59 -> v1.0.8.96 need upgrade.
[00013878][01 00][00] v1.15.3056 -> v1.15.3056
[00013914][01 01][00] v1.15.3056 -> v1.15.3056
[00013961][08 00][00] v0.11.0.4 -> v0.11.0.4
[00013996]Done.
[00016035]Waiting for user confirm...
[00012447]========== remo-con disconnect. boot(15) ============
[00012482]Packet [C:\P3X_FW_V01.02.0006.bin] detected, card sn [0x60ce1d4b].
[00012521]Packet upgrade start...
[00012560]Packet checking...
[00012595]Done.
[00012633]Version checking[1]...
[00012752][03 05][00] v34.2.0.8 -> v34.2.0.9 need upgrade.
[00012866][03 06][00] v2.1.6.18 -> v2.2.6.8 need upgrade.
[00012907][04 00][00] v1.36.0.0 -> v1.38.0.0 need upgrade.
[00012957][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013107][11 00][00] v1.6.0.0 -> v1.6.0.0
[00013226][12 00][00] v1.8.0.0 -> v1.8.0.0
[00013345][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013485][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013620][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013766][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013875][17 00][00] v1.1.1.2 -> v1.1.1.6 need upgrade.
[00014036][17 01][00] v1.0.2.4 -> v1.0.2.5 need upgrade.
[00014090][19 00][00] v1.0.8.59 -> v1.0.8.96 need upgrade.
[00014124][01 00][00] v1.15.3056 -> v1.15.3056
[00014157][01 01][00] v1.15.3056 -> v1.15.3056
[00014208][08 00][00] v0.11.0.4 -> v0.11.0.4
[00014241]Done.
[00016277]Waiting for user confirm...
[00026310]Timeout, start upgrade automatically.
[00026384]Firmware upgrading[1]...
[00026442][17 00] Firmware upgrade start...
[00012442]========== 2015.06.28 18:11:33. boot(15) ============
[00012475]Packet [C:\P3X_FW_V01.02.0006.bin] detected, card sn [0x60ce1d4b].
[00012513]Packet upgrade start...
[00012553]Packet checking...
[00012588]Done.
[00012623]Version checking[1]...
[00012694][03 05][00] v34.2.0.8 -> v34.2.0.9 need upgrade.
[00012749][03 06][00] v2.1.6.18 -> v2.2.6.8 need upgrade.
[00012792][04 00][00] v1.36.0.0 -> v1.38.0.0 need upgrade.
[00012858][09 00][00] v1.7.0.3 -> v1.7.0.3
[00012993][11 00][00] v1.6.0.0 -> v1.6.0.0
[00013169][12 00][00] v1.8.0.0 -> v1.8.0.0
[00013259][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013348][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013423][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013572][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013643][17 00][00] v0.0.0.0 -> v1.1.1.6 need upgrade.
[00013724][17 01][00] v0.0.0.0 -> v1.0.2.5 need upgrade.
[00013778][19 00][00] v1.0.8.59 -> v1.0.8.96 need upgrade.
[00013815][01 00][00] v1.15.3056 -> v1.15.3056
[00013857][01 01][00] v1.15.3056 -> v1.15.3056
[00013902][08 00][00] v0.11.0.4 -> v0.11.0.4
[00013939]Done.
[00015974]Waiting for user confirm...
[00016495]User confirmed.
[00016569]Firmware upgrading[1]...
[00016628][17 00] Firmware upgrade start...
[00093237][17 00] Firmware upgrade finished successfully.
[00093312][17 01] Firmware upgrade start...
[00012480]========== 2015.06.28 18:14:13. boot(15) ============
[00012513]Packet [C:\P3X_FW_V01.02.0006.bin] detected, card sn [0x60ce1d4b].
[00012553]Packet upgrade start...
[00012594]Packet checking...
[00012633]Done.
[00012667]Version checking[1]...
[00012827][03 06][00] v2.1.6.18 -> v2.2.6.8 need upgrade.
[00012871][04 00][00] v1.36.0.0 -> v1.38.0.0 need upgrade.
[00012918][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013048][11 00][00] v1.6.0.0 -> v1.6.0.0
[00013116][12 00][00] v1.8.0.0 -> v1.8.0.0
[00013204][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013306][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013402][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013538][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013617][17 00][00] v1.1.1.6 -> v1.1.1.6
[00013736][17 01][00] v1.0.2.5 -> v1.0.2.5
[00013779][19 00][00] v1.0.8.59 -> v1.0.8.96 need upgrade.
[00013850][01 01][00] v1.15.3056 -> v1.15.3056
[00013904][08 00][00] v0.11.0.4 -> v0.11.0.4
[00013941]Done.
[00015977]Waiting for user confirm...
[00026013]Timeout, start upgrade automatically.
[00026090]Firmware upgrading[1]...
[00026146][03 05] Firmware upgrade start...
[00012471]========== 2015.06.28 18:15:10. boot(4) ============
[00012509]Packet [C:\P3X_FW_V01.02.0006.bin] detected, card sn [0x60ce1d4b].
[00012545]Packet upgrade start...
[00012589]Packet checking...
[00012629]Done.
[00012665]Version checking[1]...
[00012724][03 05][00] v33.2.0.8 -> v34.2.0.9 need upgrade.
[00012799][03 06][00] v1.0.0.0 -> v2.2.6.8 need upgrade.
[00012844][04 00][00] v1.36.0.0 -> v1.38.0.0 need upgrade.
[00012889][09 00][00] v1.7.0.3 -> v1.7.0.3
[00025427][11 00][00] device not detected.
[00037966][12 00][00] device not detected.
[00050503][12 01][00] device not detected.
[00063038][12 02][00] device not detected.
[00075575][12 03][00] device not detected.
[00075723][15 00][00] v1.1.2.0 -> v1.1.2.0
[00088260][17 00][00] device not detected.
[00100810][17 01][00] device not detected.
[00100865][19 00][00] v1.0.8.59 -> v1.0.8.96 need upgrade.
[00100901][01 00][00] v1.15.3056 -> v1.15.3056
[00100936][01 01][00] v1.15.3056 -> v1.15.3056
[00100989][08 00][00] v0.11.0.4 -> v0.11.0.4
[00101027]Done.
[00012450]========== remo-con disconnect. boot(15) ============
[00012487]Packet [C:\P3X_FW_V01.01.0009.bin] detected, card sn [0x60ce1d4b].
[00012525]Packet upgrade start...
[00012566]Packet checking...
[00012604]Done.
[00012641]Version checking[1]...
[00012709][03 05][00] v33.2.0.8 -> v34.2.0.8 need upgrade.
[00012769][03 06][00] v1.0.0.0 -> v2.1.6.18 need upgrade.
[00012811][04 00][00] v1.36.0.0 -> v1.36.0.0
[00012879][09 00][00] v1.7.0.3 -> v1.7.0.3
[00025418][11 00][00] device not detected.
[00037953][12 00][00] device not detected.
[00050492][12 01][00] device not detected.
[00063035][12 02][00] device not detected.
[00075588][12 03][00] device not detected.
[00075730][15 00][00] v1.1.2.0 -> v1.1.2.0
[00088271][17 00][00] device not detected.
[00100806][17 01][00] device not detected.
[00100864][19 00][00] v1.0.8.59 -> v1.0.8.59
[00100900][01 00][00] v1.15.3056 -> v1.6.2736
[00101028][01 01][00] v1.15.3056 -> v1.5.2735
[00101086][08 00][00] v0.11.0.4 -> v0.11.0.4
[00101128]Done.
[00103166]Waiting for user confirm...
[00113204]Timeout, start upgrade automatically.
[00113278]Firmware upgrading[1]...
[00113337][03 05] Firmware upgrade start...
[00177443][03 05] Firmware upgrade finished successfully.
[00177647][03 06] Firmware upgrade start...
[00013577]========== remo-con disconnect. boot(15) ============
[00013612]Packet [C:\P3X_FW_V01.02.0006.bin] detected, card sn [0x60ce1d4b].
[00013651]Packet upgrade start...
[00013691]Packet checking...
[00013732]Done.
[00013766]Version checking[1]...
[00013839][03 05][00] v34.2.0.8 -> v34.2.0.9 need upgrade.
[00013899][03 06][00] v1.0.0.0 -> v2.2.6.8 need upgrade.
[00013955][04 00][00] v1.36.0.0 -> v1.38.0.0 need upgrade.
[00014009][09 00][00] v1.7.0.3 -> v1.7.0.3
[00026552][11 00][00] device not detected.
[00039089][12 00][00] device not detected.
[00051626][12 01][00] device not detected.
[00064164][12 02][00] device not detected.
[00076716][12 03][00] device not detected.
[00076866][15 00][00] v1.1.2.0 -> v1.1.2.0
[00089404][17 00][00] device not detected.
[00101944][17 01][00] device not detected.
[00102013][19 00][00] v1.0.8.59 -> v1.0.8.96 need upgrade.
[00102054][01 00][00] v1.15.3056 -> v1.15.3056
[00102093][01 01][00] v1.15.3056 -> v1.15.3056
[00102151][08 00][00] v0.11.0.4 -> v0.11.0.4
[00102188]Done.
[00104225]Waiting for user confirm...
[00114267]Timeout, start upgrade automatically.
[00114344]Firmware upgrading[1]...
[00114401][03 05] Firmware upgrade start...
[00185952][03 05] Firmware upgrade finished successfully.
[00186160][03 06] Firmware upgrade start...
[00506722][03 06] Firmware upgrade finished successfully.
[00509284][19 00] Firmware upgrade start...
[00595468][19 00] Firmware upgrade finish failed (step = 4, err = 0xaa, idx = 1490, los = 1, ng = 0, usb = 1).
[00625538][04 00] Firmware upgrade start...
[00682811][04 00] Firmware upgrade finished successfully.
[00682929]Done.
[00682967]Version checking[2]...
[00683045][03 05][05] v34.2.0.9 -> v34.2.0.9
[00683125][03 06][05] v2.2.6.8 -> v2.2.6.8
[00683173][04 00][05] v1.38.0.0 -> v1.38.0.0
[00683240][09 00][00] v1.7.0.3 -> v1.7.0.3
[00683365][11 00][00] v1.6.0.0 -> v1.6.0.0
[00683454][12 00][00] v1.8.0.0 -> v1.8.0.0
[00683554][12 01][00] v1.8.0.0 -> v1.8.0.0
[00683657][12 02][00] v1.8.0.0 -> v1.8.0.0
[00683755][12 03][00] v1.8.0.0 -> v1.8.0.0
[00684586][15 00][00] v1.1.2.0 -> v1.1.2.0
[00684670][17 00][00] v1.1.1.6 -> v1.1.1.6
[00684789][17 01][00] v1.0.2.5 -> v1.0.2.5
[00684860][19 00][00] v1.0.8.59 -> v1.0.8.96 need upgrade.
[00684898][01 00][00] v1.15.3056 -> v1.15.3056
[00684937][01 01][00] v1.15.3056 -> v1.15.3056
[00684983][08 00][00] v0.11.0.4 -> v0.11.0.4
[00685023]Done.
[00685062]Firmware upgrading[2]...
[00687550][19 00] Firmware upgrade start...
[00699006][19 00] Firmware upgrade finish failed (step = 4, err = 0xaa, idx = 0, los = 1, ng = 0, usb = 1).
[00729046]Done.
[00729082]Version checking[3]...
[00729167][03 05][05] v34.2.0.9 -> v34.2.0.9
[00729247][03 06][05] v2.2.6.8 -> v2.2.6.8
[00729290][04 00][05] v1.38.0.0 -> v1.38.0.0
[00729369][09 00][00] v1.7.0.3 -> v1.7.0.3
[00729487][11 00][00] v1.6.0.0 -> v1.6.0.0
[00729612][12 00][00] v1.8.0.0 -> v1.8.0.0
[00729717][12 01][00] v1.8.0.0 -> v1.8.0.0
[00729816][12 02][00] v1.8.0.0 -> v1.8.0.0
[00729916][12 03][00] v1.8.0.0 -> v1.8.0.0
[00730744][15 00][00] v1.1.2.0 -> v1.1.2.0
[00730833][17 00][00] v1.1.1.6 -> v1.1.1.6
[00730957][17 01][00] v1.0.2.5 -> v1.0.2.5
[00731043][19 00][00] v1.0.8.59 -> v1.0.8.96 need upgrade.
[00731091][01 00][00] v1.15.3056 -> v1.15.3056
[00731130][01 01][00] v1.15.3056 -> v1.15.3056
[00731182][08 00][00] v0.11.0.4 -> v0.11.0.4
[00731220]Done.
[00731259]Firmware upgrading[3]...
[00733759][19 00] Firmware upgrade start...
[00745225][19 00] Firmware upgrade finish failed (step = 4, err = 0xaa, idx = 0, los = 1, ng = 0, usb = 1).
[00775358]Done.
[00775398]Version checking[4]...
[00775489][03 05][05] v34.2.0.9 -> v34.2.0.9
[00775569][03 06][05] v2.2.6.8 -> v2.2.6.8
[00775613][04 00][05] v1.38.0.0 -> v1.38.0.0
[00775665][09 00][00] v1.7.0.3 -> v1.7.0.3
[00775769][11 00][00] v1.6.0.0 -> v1.6.0.0
[00775858][12 00][00] v1.8.0.0 -> v1.8.0.0
[00775958][12 01][00] v1.8.0.0 -> v1.8.0.0
[00776048][12 02][00] v1.8.0.0 -> v1.8.0.0
[00776139][12 03][00] v1.8.0.0 -> v1.8.0.0
[00776942][15 00][00] v1.1.2.0 -> v1.1.2.0
[00777014][17 00][00] v1.1.1.6 -> v1.1.1.6
[00777134][17 01][00] v1.0.2.5 -> v1.0.2.5
[00777184][19 00][00] v1.0.8.59 -> v1.0.8.96 need upgrade.
[00777225][01 00][00] v1.15.3056 -> v1.15.3056
[00777261][01 01][00] v1.15.3056 -> v1.15.3056
[00777316][08 00][00] v0.11.0.4 -> v0.11.0.4
[00777359]Done.
[00777397]Firmware upgrading[4]...
[00779899][19 00] Firmware upgrade start...
[00791366][19 00] Firmware upgrade finish failed (step = 4, err = 0xaa, idx = 0, los = 1, ng = 0, usb = 1).
[00821405]Done.
[00821443]Version checking[5]...
[00821517][03 05][05] v34.2.0.9 -> v34.2.0.9
[00821617][03 06][05] v2.2.6.8 -> v2.2.6.8
[00821661][04 00][05] v1.38.0.0 -> v1.38.0.0
[00821727][09 00][00] v1.7.0.3 -> v1.7.0.3
[00821853][11 00][00] v1.6.0.0 -> v1.6.0.0
[00821943][12 00][00] v1.8.0.0 -> v1.8.0.0
[00822042][12 01][00] v1.8.0.0 -> v1.8.0.0
[00822132][12 02][00] v1.8.0.0 -> v1.8.0.0
[00822207][12 03][00] v1.8.0.0 -> v1.8.0.0
[00823009][15 00][00] v1.1.2.0 -> v1.1.2.0
[00823086][17 00][00] v1.1.1.6 -> v1.1.1.6
[00823242][17 01][00] v1.0.2.5 -> v1.0.2.5
[00823287][19 00][00] v1.0.8.59 -> v1.0.8.96 need upgrade.
[00823329][01 00][00] v1.15.3056 -> v1.15.3056
[00823367][01 01][00] v1.15.3056 -> v1.15.3056
[00823416][08 00][00] v0.11.0.4 -> v0.11.0.4
[00823454]Done.
[00823496]Firmware upgrading[5]...
[00825988][19 00] Firmware upgrade start...
[00837448][19 00] Firmware upgrade finish failed (step = 4, err = 0xaa, idx = 0, los = 1, ng = 0, usb = 1).
[00867575]Done.
[00867614]Version checking[6]...
[00867675][03 05][05] v34.2.0.9 -> v34.2.0.9
[00867740][03 06][05] v2.2.6.8 -> v2.2.6.8
[00867786][04 00][05] v1.38.0.0 -> v1.38.0.0
[00867851][09 00][00] v1.7.0.3 -> v1.7.0.3
[00867976][11 00][00] v1.6.0.0 -> v1.6.0.0
[00868074][12 00][00] v1.8.0.0 -> v1.8.0.0
[00868174][12 01][00] v1.8.0.0 -> v1.8.0.0
[00868271][12 02][00] v1.8.0.0 -> v1.8.0.0
[00868370][12 03][00] v1.8.0.0 -> v1.8.0.0
[00869179][15 00][00] v1.1.2.0 -> v1.1.2.0
[00869264][17 00][00] v1.1.1.6 -> v1.1.1.6
[00869391][17 01][00] v1.0.2.5 -> v1.0.2.5
[00869451][19 00][00] v1.0.8.59 -> v1.0.8.96 need upgrade.
[00869490][01 00][00] v1.15.3056 -> v1.15.3056
[00869529][01 01][00] v1.15.3056 -> v1.15.3056
[00869582][08 00][00] v0.11.0.4 -> v0.11.0.4
[00869620]Packet upgrade failed at firmware upgrade.
[00012509]========== remo-con disconnect. boot(4) ============
[00012553]Packet [C:\P3X_FW_V01.02.0006.bin] detected, card sn [0x60ce1d4b].
[00012594]Packet upgrade start...
[00012637]Packet checking...
[00012687]Done.
[00012726]Version checking[1]...
[00012801][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012902][03 06][00] v2.2.6.8 -> v2.2.6.8
[00012950][04 00][00] v1.38.0.0 -> v1.38.0.0
[00013007][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013122][11 00][00] v1.6.0.0 -> v1.6.0.0
[00013237][12 00][00] v1.8.0.0 -> v1.8.0.0
[00013337][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013437][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013537][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013688][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013792][17 00][00] v1.1.1.6 -> v1.1.1.6
[00013936][17 01][00] v1.0.2.5 -> v1.0.2.5
[00013986][19 00][00] v0.0.0.0 -> v1.0.8.96 need upgrade.
[00014030][01 00][00] v1.15.3056 -> v1.15.3056
[00014070][01 01][00] v1.15.3056 -> v1.15.3056
[00014123][08 00][00] v0.11.0.4 -> v0.11.0.4
[00014164]Done.
[00016204]Waiting for user confirm...
[00026247]Timeout, start upgrade automatically.
[00026330]Firmware upgrading[1]...
[00029254][19 00] Firmware upgrade start...
[00012519]========== remo-con disconnect. boot(15) ============
[00012560]Packet [C:\P3X_FW_V01.02.0006.bin] detected, card sn [0x60ce1d4b].
[00012600]Packet upgrade start...
[00012648]Packet checking...
[00012694]Done.
[00012733]Version checking[1]...
[00012815][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012908][03 06][00] v2.2.6.8 -> v2.2.6.8
[00012954][04 00][00] v1.38.0.0 -> v1.38.0.0
[00013019][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013153][11 00][00] v1.6.0.0 -> v1.6.0.0
[00013243][12 00][00] v1.8.0.0 -> v1.8.0.0
[00013323][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013423][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013508][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013643][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013738][17 00][00] v1.1.1.6 -> v1.1.1.6
[00013858][17 01][00] v1.0.2.5 -> v1.0.2.5
[00013916][19 00][00] v0.0.0.0 -> v1.0.8.96 need upgrade.
[00013958][01 00][00] v1.15.3056 -> v1.15.3056
[00014000][01 01][00] v1.15.3056 -> v1.15.3056
[00014066][08 00][00] v0.11.0.4 -> v0.11.0.4
[00014107]Done.
[00016149]Waiting for user confirm...
[00026199]Timeout, start upgrade automatically.
[00026279]Firmware upgrading[1]...
[00028799][19 00] Firmware upgrade start...
[00012538]========== remo-con disconnect. boot(15) ============
[00012578]Packet [C:\P3X_FW_V01.02.0006.bin] detected, card sn [0x60ce1d4b].
[00012620]Packet upgrade start...
[00012671]Packet checking...
[00012713]Done.
[00012756]Version checking[1]...
[00012821][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012901][03 06][00] v2.2.6.8 -> v2.2.6.8
[00012949][04 00][00] v1.38.0.0 -> v1.38.0.0
[00013015][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013121][11 00][00] v1.6.0.0 -> v1.6.0.0
[00013215][12 00][00] v1.8.0.0 -> v1.8.0.0
[00013316][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013405][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013490][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013658][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013730][17 00][00] v1.1.1.6 -> v1.1.1.6
[00013850][17 01][00] v1.0.2.5 -> v1.0.2.5
[00013975][19 00][00] v0.0.0.0 -> v1.0.8.96 need upgrade.
[00014018][01 00][00] v1.15.3056 -> v1.15.3056
[00014063][01 01][00] v1.15.3056 -> v1.15.3056
[00014125][08 00][00] v0.11.0.4 -> v0.11.0.4
[00014171]Done.
[00016212]Waiting for user confirm...
[00026253]Timeout, start upgrade automatically.
[00026336]Firmware upgrading[1]...
[00012527]========== remo-con disconnect. boot(15) ============
[00012567]Packet [C:\P3X_FW_V01.02.0006.bin] detected, card sn [0x60ce1d4b].
[00012609]Packet upgrade start...
[00012656]Packet checking...
[00012704]Done.
[00012749]Version checking[1]...
[00012835][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012916][03 06][00] v2.2.6.8 -> v2.2.6.8
[00012965][04 00][00] v1.38.0.0 -> v1.38.0.0
[00013030][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013135][11 00][00] v1.6.0.0 -> v1.6.0.0
[00013224][12 00][00] v1.8.0.0 -> v1.8.0.0
[00013325][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013417][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013522][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013746][17 00][00] v1.1.1.6 -> v1.1.1.6
[00013865][17 01][00] v1.0.2.5 -> v1.0.2.5
[00013931][19 00][00] v0.0.0.0 -> v1.0.8.96 need upgrade.
[00013970][01 00][00] v1.15.3056 -> v1.15.3056
[00014012][01 01][00] v1.15.3056 -> v1.15.3056
[00014081][08 00][00] v0.11.0.4 -> v0.11.0.4
[00014124]Done.
[00016166]Waiting for user confirm...
[00026208]Timeout, start upgrade automatically.
[00026291]Firmware upgrading[1]...
[00028801][19 00] Firmware upgrade start...
[00120976][19 00] Firmware upgrade finish failed (step = 4, err = 0xaa, idx = 2200, los = 1, ng = 0, usb = 1).
[00012534]========== remo-con disconnect. boot(15) ============
[00012580]Packet [C:\P3X_FW_V01.02.0006.bin] detected, card sn [0x60ce1d4b].
[00012623]Packet upgrade start...
[00012673]Packet checking...
[00012720]Done.
[00012760]Version checking[1]...
[00012834][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012915][03 06][00] v2.2.6.8 -> v2.2.6.8
[00013062][04 00][00] v1.38.0.0 -> v1.38.0.0
[00013134][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013255][11 00][00] v1.6.0.0 -> v1.6.0.0
[00013354][12 00][00] v1.8.0.0 -> v1.8.0.0
[00013453][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013553][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013655][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013803][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013903][17 00][00] v1.1.1.6 -> v1.1.1.6
[00014046][17 01][00] v1.0.2.5 -> v1.0.2.5
[00014113][19 00][00] v0.0.0.0 -> v1.0.8.96 need upgrade.
[00014156][01 00][00] v1.15.3056 -> v1.15.3056
[00014199][01 01][00] v1.15.3056 -> v1.15.3056
[00014276][08 00][00] v0.11.0.4 -> v0.11.0.4
[00014320]Done.
[00016359]Waiting for user confirm...
[00026405]Timeout, start upgrade automatically.
[00026495]Firmware upgrading[1]...
[00029004][19 00] Firmware upgrade start...
[00012581]Packet [C:\P3X_FW_V01.02.0006.bin] detected, card sn [0x60ce1d4b].
[00012626]Packet upgrade start...
[00012672]Packet checking...
[00012721]Done.
[00012763]Version checking[1]...
[00012849][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012919][03 06][00] v2.2.6.8 -> v2.2.6.8
[00012968][04 00][00] v1.38.0.0 -> v1.38.0.0
[00013048][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013162][11 00][00] v1.6.0.0 -> v1.6.0.0
[00013252][12 00][00] v1.8.0.0 -> v1.8.0.0
[00013332][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013432][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013518][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013667][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013767][17 00][00] v1.1.1.6 -> v1.1.1.6
[00013888][17 01][00] v1.0.2.5 -> v1.0.2.5
[00013948][19 00][00] v0.0.0.0 -> v1.0.8.96 need upgrade.
[00013990][01 00][00] v1.15.3056 -> v1.15.3056
[00014037][01 01][00] v1.15.3056 -> v1.15.3056
[00014139]Done.
[00016188]Waiting for user confirm...
[00026233]Timeout, start upgrade automatically.
[00026318]Firmware upgrading[1]...
[00028828][19 00] Firmware upgrade start...
[00012541]========== remo-con disconnect. boot(4) ============
[00012585]Packet [C:\P3X_FW_V01.02.0006.bin] detected, card sn [0x60ce1d4b].
[00012629]Packet upgrade start...
[00012678]Packet checking...
[00012726]Done.
[00012769]Version checking[1]...
[00012841][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012921][03 06][00] v2.2.6.8 -> v2.2.6.8
[00012972][04 00][00] v1.38.0.0 -> v1.38.0.0
[00013045][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013155][11 00][00] v1.6.0.0 -> v1.6.0.0
[00013260][12 00][00] v1.8.0.0 -> v1.8.0.0
[00013434][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013534][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013679][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013764][17 00][00] v1.1.1.6 -> v1.1.1.6
[00013890][17 01][00] v1.0.2.5 -> v1.0.2.5
[00013964][19 00][00] v0.0.0.0 -> v1.0.8.96 need upgrade.
[00014007][01 00][00] v1.15.3056 -> v1.15.3056
[00014060][01 01][00] v1.15.3056 -> v1.15.3056
[00014110][08 00][00] v0.11.0.4 -> v0.11.0.4
[00014153]Done.
[00016200]Waiting for user confirm...
[00012585]========== remo-con disconnect. boot(15) ============
[00012627]Packet [C:\P3X_FW_V01.02.0006.bin] detected, card sn [0x60ce1d4b].
[00012678]Packet upgrade start...
[00012726]Packet checking...
[00012771]Done.
[00012815]Version checking[1]...
[00012901][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012981][03 06][00] v2.2.6.8 -> v2.2.6.8
[00013032][04 00][00] v1.38.0.0 -> v1.38.0.0
[00013086][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013201][11 00][00] v1.6.0.0 -> v1.6.0.0
[00013286][12 00][00] v1.8.0.0 -> v1.8.0.0
[00013376][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013476][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013576][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013729][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013816][17 00][00] v1.1.1.6 -> v1.1.1.6
[00013945][17 01][00] v1.0.2.5 -> v1.0.2.5
[00014010][19 00][00] v0.0.0.0 -> v1.0.8.96 need upgrade.
[00014054][01 00][00] v1.15.3056 -> v1.15.3056
[00014098][01 01][00] v1.15.3056 -> v1.15.3056
[00014235][08 00][00] v0.11.0.4 -> v0.11.0.4
[00014283]Done.
[00016325]Waiting for user confirm...
[00026374]Timeout, start upgrade automatically.
[00026465]Firmware upgrading[1]...
[00028979][19 00] Firmware upgrade start...
[00041271][19 00] Firmware upgrade finish failed (step = 4, err = 0xaa, idx = 0, los = 1, ng = 0, usb = 1).
[00071316]Done.
[00071362]Version checking[2]...
[00071444][03 05][00] v34.2.0.9 -> v34.2.0.9
[00071524][03 06][00] v2.2.6.8 -> v2.2.6.8
[00071576][04 00][00] v1.38.0.0 -> v1.38.0.0
[00071629][09 00][00] v1.7.0.3 -> v1.7.0.3
[00071744][11 00][00] v1.6.0.0 -> v1.6.0.0
[00071839][12 00][00] v1.8.0.0 -> v1.8.0.0
[00071938][12 01][00] v1.8.0.0 -> v1.8.0.0
[00072018][12 02][00] v1.8.0.0 -> v1.8.0.0
[00072118][12 03][00] v1.8.0.0 -> v1.8.0.0
[00072931][15 00][00] v1.1.2.0 -> v1.1.2.0
[00073014][17 00][00] v1.1.1.6 -> v1.1.1.6
[00073150][17 01][00] v1.0.2.5 -> v1.0.2.5
[00073209][19 00][00] v0.0.0.0 -> v1.0.8.96 need upgrade.
[00073258][01 00][00] v1.15.3056 -> v1.15.3056
[00073301][01 01][00] v1.15.3056 -> v1.15.3056
[00073357][08 00][00] v0.11.0.4 -> v0.11.0.4
[00073406]Done.
[00073451]Firmware upgrading[2]...
[00075976][19 00] Firmware upgrade start...
[00147892][19 00] Firmware upgrade finish failed (step = 4, err = 0xaa, idx = 1, los = 1, ng = 0, usb = 1).
[00177939]Done.
[00177984]Version checking[3]...
[00178094][03 05][00] v34.2.0.9 -> v34.2.0.9
[00178173][03 06][00] v2.2.6.8 -> v2.2.6.8
[00178225][04 00][00] v1.38.0.0 -> v1.38.0.0
[00178314][09 00][00] v1.7.0.3 -> v1.7.0.3
[00178429][11 00][00] v1.6.0.0 -> v1.6.0.0
[00178524][12 00][00] v1.8.0.0 -> v1.8.0.0
[00178624][12 01][00] v1.8.0.0 -> v1.8.0.0
[00178724][12 02][00] v1.8.0.0 -> v1.8.0.0
[00178824][12 03][00] v1.8.0.0 -> v1.8.0.0
[00179637][15 00][00] v1.1.2.0 -> v1.1.2.0
[00179739][17 00][00] v1.1.1.6 -> v1.1.1.6
[00179864][17 01][00] v1.0.2.5 -> v1.0.2.5
[00179934][19 00][00] v0.0.0.0 -> v1.0.8.96 need upgrade.
[00180057][01 00][00] v1.15.3056 -> v1.15.3056
[00180104][01 01][00] v1.15.3056 -> v1.15.3056
[00180167][08 00][00] v0.11.0.4 -> v0.11.0.4
[00180218]Done.
[00180264]Firmware upgrading[3]...
[00182757][19 00] Firmware upgrade start...
[00194236][19 00] Firmware upgrade finish failed (step = 4, err = 0xaa, idx = 0, los = 1, ng = 0, usb = 1).
[00012560]========== remo-con disconnect. boot(15) ============
[00012605]Packet [C:\P3X_FW_V01.02.0006.bin] detected, card sn [0x60ce1d4b].
[00012652]Packet upgrade start...
[00012706]Packet checking...
[00012756]Done.
[00012802]Version checking[1]...
[00025348][03 05][00] device not detected.
[00037892][03 06][00] device not detected.
[00037948][04 00][00] v1.38.0.0 -> v1.38.0.0
[00038008][09 00][00] v0.0.0.0 -> v1.7.0.3 need upgrade.
[00050555][11 00][00] device not detected.
[00063101][12 00][00] device not detected.
[00075647][12 01][00] device not detected.
[00088202][12 02][00] device not detected.
[00100749][12 03][00] device not detected.
[00100894][15 00][00] v1.1.2.0 -> v1.1.2.0
[00113441][17 00][00] device not detected.
[00125992][17 01][00] device not detected.
[00138543][19 00][00] device not detected.
[00138590][01 00][00] v1.15.3056 -> v1.15.3056
[00138635][01 01][00] v1.15.3056 -> v1.15.3056
[00138695][08 00][00] v0.11.0.4 -> v0.11.0.4
[00138740]Done.
[00140791]Waiting for user confirm...
[00150837]Timeout, start upgrade automatically.
[00150932]Firmware upgrading[1]...
[00151001][09 00] Firmware upgrade start...
[00201405][09 00] Firmware upgrade finished successfully.
[00201451]Done.
[00201499]Version checking[2]...
[00201569][03 05][00] v34.2.0.9 -> v34.2.0.9
[00201649][03 06][00] v2.2.6.8 -> v2.2.6.8
[00201700][04 00][00] v1.38.0.0 -> v1.38.0.0
[00201779][09 00][05] v1.7.0.3 -> v1.7.0.3
[00201909][11 00][00] v1.6.0.0 -> v1.6.0.0
[00202004][12 00][00] v1.8.0.0 -> v1.8.0.0
[00202109][12 01][00] v1.8.0.0 -> v1.8.0.0
[00202203][12 02][00] v1.8.0.0 -> v1.8.0.0
[00202398][12 03][00] v1.8.0.0 -> v1.8.0.0
[00202537][15 00][00] v1.1.2.0 -> v1.1.2.0
[00202613][17 00][00] v1.1.1.6 -> v1.1.1.6
[00202734][17 01][00] v1.0.2.5 -> v1.0.2.5
[00202799][19 00][00] v0.0.0.0 -> v1.0.8.96 need upgrade.
[00202853][01 00][00] v1.15.3056 -> v1.15.3056
[00202898][01 01][00] v1.15.3056 -> v1.15.3056
[00202959][08 00][00] v0.11.0.4 -> v0.11.0.4
[00203013]Done.
[00203060]Firmware upgrading[2]...
[00205549][19 00] Firmware upgrade start...
[00212796][19 00] Firmware upgrade finish failed (step = 0, err = 0x19, usb = 0x00).
[00242846]Done.
[00242897]Version checking[3]...
[00242975][03 05][00] v34.2.0.9 -> v34.2.0.9
[00243075][03 06][00] v2.2.6.8 -> v2.2.6.8
[00243133][04 00][00] v1.38.0.0 -> v1.38.0.0
[00243200][09 00][05] v1.7.0.3 -> v1.7.0.3
[00243331][11 00][00] v1.6.0.0 -> v1.6.0.0
[00243421][12 00][00] v1.8.0.0 -> v1.8.0.0
[00243511][12 01][00] v1.8.0.0 -> v1.8.0.0
[00243605][12 02][00] v1.8.0.0 -> v1.8.0.0
[00243711][12 03][00] v1.8.0.0 -> v1.8.0.0
[00243858][15 00][00] v1.1.2.0 -> v1.1.2.0
[00243941][17 00][00] v1.1.1.6 -> v1.1.1.6
[00244061][17 01][00] v1.0.2.5 -> v1.0.2.5
[00244121][19 00][00] v0.0.0.0 -> v1.0.8.96 need upgrade.
[00244168][01 00][00] v1.15.3056 -> v1.15.3056
[00244222][01 01][00] v1.15.3056 -> v1.15.3056
[00244281][08 00][00] v0.11.0.4 -> v0.11.0.4
[00244328]Done.
[00244378]Firmware upgrading[3]...
[00246865][19 00] Firmware upgrade start...
[00254110][19 00] Firmware upgrade finish failed (step = 0, err = 0x19, usb = 0x00).
[00284156]Done.
[00284203]Version checking[4]...
[00284313][03 05][00] v34.2.0.9 -> v34.2.0.9
[00284398][03 06][00] v2.2.6.8 -> v2.2.6.8
[00284455][04 00][00] v1.38.0.0 -> v1.38.0.0
[00284522][09 00][05] v1.7.0.3 -> v1.7.0.3
[00284633][11 00][00] v1.6.0.0 -> v1.6.0.0
[00284732][12 00][00] v1.8.0.0 -> v1.8.0.0
[00284828][12 01][00] v1.8.0.0 -> v1.8.0.0
[00284928][12 02][00] v1.8.0.0 -> v1.8.0.0
[00285008][12 03][00] v1.8.0.0 -> v1.8.0.0
[00285235][15 00][00] v1.1.2.0 -> v1.1.2.0
[00285323][17 00][00] v1.1.1.6 -> v1.1.1.6
[00285457][17 01][00] v1.0.2.5 -> v1.0.2.5
[00285523][19 00][00] v0.0.0.0 -> v1.0.8.96 need upgrade.
[00285573][01 00][00] v1.15.3056 -> v1.15.3056
[00285618][01 01][00] v1.15.3056 -> v1.15.3056
[00285682][08 00][00] v0.11.0.4 -> v0.11.0.4
[00285733]Done.
[00285779]Firmware upgrading[4]...
[00288275][19 00] Firmware upgrade start...
[00295523][19 00] Firmware upgrade finish failed (step = 0, err = 0x19, usb = 0x00).
[00325576]Done.
[00325626]Version checking[5]...
[00325698][03 05][00] v34.2.0.9 -> v34.2.0.9
[00325778][03 06][00] v2.2.6.8 -> v2.2.6.8
[00325842][04 00][00] v1.38.0.0 -> v1.38.0.0
[00325904][09 00][05] v1.7.0.3 -> v1.7.0.3
[00326016][11 00][00] v1.6.0.0 -> v1.6.0.0
[00326109][12 00][00] v1.8.0.0 -> v1.8.0.0
[00326209][12 01][00] v1.8.0.0 -> v1.8.0.0
[00326329][12 02][00] v1.8.0.0 -> v1.8.0.0
[00326429][12 03][00] v1.8.0.0 -> v1.8.0.0
[00326571][15 00][00] v1.1.2.0 -> v1.1.2.0
[00326664][17 00][00] v1.1.1.6 -> v1.1.1.6
[00326789][17 01][00] v1.0.2.5 -> v1.0.2.5
[00326865][19 00][00] v0.0.0.0 -> v1.0.8.96 need upgrade.
[00326914][01 00][00] v1.15.3056 -> v1.15.3056
[00326962][01 01][00] v1.15.3056 -> v1.15.3056
[00327016][08 00][00] v0.11.0.4 -> v0.11.0.4
[00327061]Done.
[00327116]Firmware upgrading[5]...
[00329594][19 00] Firmware upgrade start...
[00336849][19 00] Firmware upgrade finish failed (step = 0, err = 0x19, usb = 0x00).
[00366895]Done.
[00366943]Version checking[6]...
[00367017][03 05][00] v34.2.0.9 -> v34.2.0.9
[00367097][03 06][00] v2.2.6.8 -> v2.2.6.8
[00367154][04 00][00] v1.38.0.0 -> v1.38.0.0
[00367226][09 00][05] v1.7.0.3 -> v1.7.0.3
[00367357][11 00][00] v1.6.0.0 -> v1.6.0.0
[00367448][12 00][00] v1.8.0.0 -> v1.8.0.0
[00367546][12 01][00] v1.8.0.0 -> v1.8.0.0
[00367626][12 02][00] v1.8.0.0 -> v1.8.0.0
[00367736][12 03][00] v1.8.0.0 -> v1.8.0.0
[00367869][15 00][00] v1.1.2.0 -> v1.1.2.0
[00367986][17 00][00] v1.1.1.6 -> v1.1.1.6
[00368206][17 01][00] v1.0.2.5 -> v1.0.2.5
[00368306][19 00][00] v0.0.0.0 -> v1.0.8.96 need upgrade.
[00368359][01 00][00] v1.15.3056 -> v1.15.3056
[00368406][01 01][00] v1.15.3056 -> v1.15.3056
[00368472][08 00][00] v0.11.0.4 -> v0.11.0.4
[00368523]Packet upgrade failed at firmware upgrade.
[00012574]========== remo-con disconnect. boot(4) ============
[00012620]Packet [C:\P3X_FW_V01.02.0006.bin] detected, card sn [0x60ce1d4b].
[00012670]Packet upgrade start...
[00012728]Packet checking...
[00012779]Done.
[00012825]Version checking[1]...
[00012909][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012989][03 06][00] v2.2.6.8 -> v2.2.6.8
[00013054][04 00][00] v1.38.0.0 -> v1.38.0.0
[00013114][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013226][11 00][00] v1.6.0.0 -> v1.6.0.0
[00013329][12 00][00] v1.8.0.0 -> v1.8.0.0
[00013414][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013530][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013630][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013771][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013865][17 00][00] v1.1.1.6 -> v1.1.1.6
[00014000][17 01][00] v1.0.2.5 -> v1.0.2.5
[00014075][19 00][00] v0.0.0.0 -> v1.0.8.96 need upgrade.
[00014123][01 00][00] v1.15.3056 -> v1.15.3056
[00014172][01 01][00] v1.15.3056 -> v1.15.3056
[00014262][08 00][00] v0.11.0.4 -> v0.11.0.4
[00014312]Done.
[00026411]Timeout, start upgrade automatically.
[00026505]Firmware upgrading[1]...
[00012694]========== remo-con disconnect. boot(15) ============
[00012743]Packet [C:\P3X_FW_V01.02.0006.bin] detected, card sn [0x60ce1d4b].
[00012791]Packet upgrade start...
[00012851]Packet checking...
[00012902]Done.
[00012951]Version checking[1]...
[00013020][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013100][03 06][00] v2.2.6.8 -> v2.2.6.8
[00013158][04 00][00] v1.38.0.0 -> v1.38.0.0
[00013230][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013355][11 00][00] v1.6.0.0 -> v1.6.0.0
[00013460][12 00][00] v1.8.0.0 -> v1.8.0.0
[00013637][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013724][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013814][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013964][15 00][00] v1.1.2.0 -> v1.1.2.0
[00014045][17 00][00] v1.1.1.6 -> v1.1.1.6
[00014170][17 01][00] v1.0.2.5 -> v1.0.2.5
[00014250][19 00][00] v0.0.0.0 -> v1.0.8.96 need upgrade.
[00014297][01 00][00] v1.15.3056 -> v1.15.3056
[00014355][01 01][00] v1.15.3056 -> v1.15.3056
[00014422][08 00][00] v0.11.0.4 -> v0.11.0.4
[00014475]Done.
[00016528]Waiting for user confirm...
[00026581]Timeout, start upgrade automatically.
[00026678]Firmware upgrading[1]...
[00029206][19 00] Firmware upgrade start...
[00012609]========== remo-con disconnect. boot(15) ============
[00012660]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x60ce1d4b].
[00012716]Packet upgrade start...
[00012771]Packet checking...
[00012824]Done.
[00012880]Version checking[1]...
[00012950][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013030][03 06][00] v2.2.6.8 -> v2.2.6.19 need upgrade.
[00013086][04 00][00] v1.38.0.0 -> v1.40.0.0 need upgrade.
[00013161][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013310][11 00][00] v1.6.0.0 -> v1.7.0.0 need upgrade.
[00013400][12 00][00] v1.8.0.0 -> v1.8.0.0
[00013504][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013604][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013704][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013855][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013934][17 00][00] v1.1.1.6 -> v1.1.1.7 need upgrade.
[00014055][17 01][00] v1.0.2.5 -> v1.0.2.7 need upgrade.
[00014120][19 00][00] v0.0.0.0 -> v1.0.8.96 need upgrade.
[00014171][01 00][00] v1.15.3056 -> v1.23.3419 need upgrade
[00014229][01 01][00] v1.15.3056 -> v1.23.3419 need upgrade
[00014297][08 00][00] v0.11.0.4 -> v0.12.0.4 need upgrade.
[00014353]Done.
[00016403]Waiting for user confirm...
[00026456]Timeout, start upgrade automatically.
[00026563]Firmware upgrading[1]...
[00038776][01 00] Firmware upgrade start...
[00012612]========== remo-con disconnect. boot(4) ============
[00012741]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x60ce1d4b].
[00012796]Packet upgrade start...
[00012853]Packet checking...
[00012910]Done.
[00012961]Version checking[1]...
[00013035][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013110][03 06][00] v2.2.6.8 -> v2.2.6.19 need upgrade.
[00013170][04 00][00] v1.38.0.0 -> v1.40.0.0 need upgrade.
[00013246][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013375][11 00][00] v1.6.0.0 -> v1.7.0.0 need upgrade.
[00013466][12 00][00] v1.8.0.0 -> v1.8.0.0
[00013565][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013640][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013730][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013877][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013981][17 00][00] v1.1.1.6 -> v1.1.1.7 need upgrade.
[00014101][17 01][00] v1.0.2.5 -> v1.0.2.7 need upgrade.
[00014166][19 00][00] v0.0.0.0 -> v1.0.8.96 need upgrade.
[00014216][01 00][00] v1.15.3056 -> v1.23.3419 need upgrade
[00014276][01 01][00] v1.15.3056 -> v1.23.3419 need upgrade
[00014342][08 00][00] v0.11.0.4 -> v0.12.0.4 need upgrade.
[00014401]Done.
[00016455]Waiting for user confirm...
[00026507]Timeout, start upgrade automatically.
[00026612]Firmware upgrading[1]...
[00040178][01 00] Firmware upgrade start...
[00018998]========== remo-con disconnect. boot(15) ============
[00019051]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x60ce1d4b].
[00019104]Packet upgrade start...
[00019159]Packet checking...
[00019214]Done.
[00019267]Version checking[1]...
[00019356][03 05][00] v34.2.0.9 -> v34.2.0.9
[00019436][03 06][00] v2.2.6.8 -> v2.2.6.19 need upgrade.
[00019496][04 00][00] v1.38.0.0 -> v1.40.0.0 need upgrade.
[00019572][09 00][00] v1.7.0.3 -> v1.7.0.3
[00019717][11 00][00] v1.6.0.0 -> v1.7.0.0 need upgrade.
[00019832][12 00][00] v1.8.0.0 -> v1.8.0.0
[00019957][12 01][00] v1.8.0.0 -> v1.8.0.0
[00020042][12 02][00] v1.8.0.0 -> v1.8.0.0
[00020156][12 03][00] v1.8.0.0 -> v1.8.0.0
[00020291][15 00][00] v1.1.2.0 -> v1.1.2.0
[00020382][17 00][00] v1.1.1.6 -> v1.1.1.7 need upgrade.
[00020622][17 01][00] v1.0.2.5 -> v1.0.2.7 need upgrade.
[00020692][19 00][00] v0.0.0.0 -> v1.0.8.96 need upgrade.
[00020742][01 00][00] v1.15.3056 -> v1.23.3419 need upgrade
[00020798][01 01][00] v1.15.3056 -> v1.23.3419 need upgrade
[00020868][08 00][00] v0.11.0.4 -> v0.12.0.4 need upgrade.
[00020927]Done.
[00022976]Waiting for user confirm...
[00033029]Timeout, start upgrade automatically.
[00033136]Firmware upgrading[1]...
[00012616]========== remo-con disconnect. boot(4) ============
[00012666]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x60ce1d4b].
[00012722]Packet upgrade start...
[00012774]Packet checking...
[00012828]Done.
[00012883]Version checking[1]...
[00012965][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013086][03 06][00] v2.2.6.8 -> v2.2.6.19 need upgrade.
[00013141][04 00][00] v1.38.0.0 -> v1.40.0.0 need upgrade.
[00013221][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013346][11 00][00] v1.6.0.0 -> v1.7.0.0 need upgrade.
[00013462][12 00][00] v1.8.0.0 -> v1.8.0.0
[00013562][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013661][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013786][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013944][15 00][00] v1.1.2.0 -> v1.1.2.0
[00014056][17 00][00] v1.1.1.6 -> v1.1.1.7 need upgrade.
[00014206][17 01][00] v1.0.2.5 -> v1.0.2.7 need upgrade.
[00014301][19 00][00] v0.0.0.0 -> v1.0.8.96 need upgrade.
[00014356][01 00][00] v1.15.3056 -> v1.23.3419 need upgrade
[00014404][01 01][00] v1.15.3056 -> v1.23.3419 need upgrade
[00014485][08 00][00] v0.11.0.4 -> v0.12.0.4 need upgrade.
[00014539]Done.
[00016591]Waiting for user confirm...
[00026641]Timeout, start upgrade automatically.
[00026747]Firmware upgrading[1]...
[00040300][01 00] Firmware upgrade start...
[00012230][01 00] Firmware upgrade finished successfully.
[00012278]Done.
[00012337]Packet [C:\P3X_FW_V01.03.0020.bin] resumed, card sn [0x60ce1d4b].
[00012391]Packet vlink 01.03.0020 <-> 01.01.0009.
[00012472]Version checking[2]...
[00012630][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012710][03 06][00] v2.2.6.8 -> v2.2.6.19 need upgrade.
[00012769][04 00][00] v1.38.0.0 -> v1.40.0.0 need upgrade.
[00012845][09 00][00] v1.7.0.3 -> v1.7.0.3
[00012991][11 00][00] v1.6.0.0 -> v1.7.0.0 need upgrade.
[00013129][12 00][00] v1.8.0.0 -> v1.8.0.0
[00013325][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013425][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013585][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013699][17 00][00] v1.1.1.6 -> v1.1.1.7 need upgrade.
[00013819][17 01][00] v1.0.2.5 -> v1.0.2.7 need upgrade.
[00013885][19 00][00] v0.0.0.0 -> v1.0.8.96 need upgrade.
[00013935][01 00][05] v1.23.3419 -> v1.23.3419
[00013993][01 01][00] v1.15.3056 -> v1.23.3419 need upgrade
[00014059][08 00][00] v0.11.0.4 -> v0.12.0.4 need upgrade.
[00014109]Done.
[00014165]Firmware upgrading[2]...
[00014335][01 01] Firmware upgrade start...
[00044610][01 01] Firmware upgrade finished successfully.
[00045483][08 00] Firmware upgrade start...
[00014908]========== remo-con disconnect. boot(5) ============
[00014960]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x60ce1d4b].
[00015010]Packet upgrade start...
[00015064]Packet checking...
[00015124]Packet vlink 01.03.0020 <-> 01.01.0009.
[00015206]Done.
[00015253]Version checking[1]...
[00015356][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015439][03 06][00] v2.2.6.8 -> v2.2.6.19 need upgrade.
[00015493][04 00][00] v1.38.0.0 -> v1.40.0.0 need upgrade.
[00015580][09 00][00] v1.7.0.3 -> v1.7.0.3
[00015795][11 00][00] v1.6.0.0 -> v1.7.0.0 need upgrade.
[00015901][12 00][00] v1.8.0.0 -> v1.8.0.0
[00016010][12 01][00] v1.8.0.0 -> v1.8.0.0
[00016110][12 02][00] v1.8.0.0 -> v1.8.0.0
[00016210][12 03][00] v1.8.0.0 -> v1.8.0.0
[00016347][15 00][00] v1.1.2.0 -> v1.1.2.0
[00016444][17 00][00] v1.1.1.6 -> v1.1.1.7 need upgrade.
[00016590][17 01][00] v1.0.2.5 -> v1.0.2.7 need upgrade.
[00016661][19 00][00] v0.0.0.0 -> v1.0.8.96 need upgrade.
[00016796][01 00][00] v1.23.3419 -> v1.23.3419
[00016847][01 01][00] v1.23.3419 -> v1.23.3419
[00016914][08 00][00] v0.11.0.4 -> v0.12.0.4 need upgrade.
[00016970]Done.
[00019021]Waiting for user confirm...
[00018947]========== remo-con disconnect. boot(5) ============
[00018996]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x60ce1d4b].
[00019050]Packet upgrade start...
[00019109]Packet checking...
[00019162]Packet vlink 01.03.0020 <-> 01.01.0009.
[00019245]Done.
[00019301]Version checking[1]...
[00019396][03 05][00] v34.2.0.9 -> v34.2.0.9
[00019496][03 06][00] v2.2.6.8 -> v2.2.6.19 need upgrade.
[00019566][04 00][00] v1.38.0.0 -> v1.40.0.0 need upgrade.
[00019636][09 00][00] v1.7.0.3 -> v1.7.0.3
[00019776][11 00][00] v1.6.0.0 -> v1.7.0.0 need upgrade.
[00019875][12 00][00] v1.8.0.0 -> v1.8.0.0
[00019985][12 01][00] v1.8.0.0 -> v1.8.0.0
[00020087][12 02][00] v1.8.0.0 -> v1.8.0.0
[00020195][12 03][00] v1.8.0.0 -> v1.8.0.0
[00020343][15 00][00] v1.1.2.0 -> v1.1.2.0
[00020446][17 00][00] v1.1.1.6 -> v1.1.1.7 need upgrade.
[00020591][17 01][00] v1.0.2.5 -> v1.0.2.7 need upgrade.
[00020656][19 00][00] v0.0.0.0 -> v1.0.8.96 need upgrade.
[00020703][01 00][00] v1.23.3419 -> v1.23.3419
[00020752][01 01][00] v1.23.3419 -> v1.23.3419
[00020812][08 00][00] v0.11.0.4 -> v0.12.0.4 need upgrade.
[00020860]Done.
[00022907]Waiting for user confirm...
[00032955]Timeout, start upgrade automatically.
[00033065]Firmware upgrading[1]...
[00033952][08 00] Firmware upgrade start...
[00012728]========== remo-con disconnect. boot(5) ============
[00012786]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x60ce1d4b].
[00012837]Packet upgrade start...
[00012893]Packet checking...
[00012955]Packet vlink 01.03.0020 <-> 01.01.0009.
[00013037]Done.
[00013093]Version checking[1]...
[00013180][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013260][03 06][00] v2.2.6.8 -> v2.2.6.19 need upgrade.
[00013317][04 00][00] v1.38.0.0 -> v1.40.0.0 need upgrade.
[00013471][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013601][11 00][00] v1.6.0.0 -> v1.7.0.0 need upgrade.
[00013696][12 00][00] v1.8.0.0 -> v1.8.0.0
[00013820][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013913][12 02][00] v1.8.0.0 -> v1.8.0.0
[00014010][12 03][00] v1.8.0.0 -> v1.8.0.0
[00014147][15 00][00] v1.1.2.0 -> v1.1.2.0
[00014226][17 00][00] v1.1.1.6 -> v1.1.1.7 need upgrade.
[00014370][17 01][00] v1.0.2.5 -> v1.0.2.7 need upgrade.
[00014450][19 00][00] v0.0.0.0 -> v1.0.8.96 need upgrade.
[00014501][01 00][00] v1.23.3419 -> v1.23.3419
[00014554][01 01][00] v1.23.3419 -> v1.23.3419
[00014624][08 00][00] v0.11.0.4 -> v0.12.0.4 need upgrade.
[00014676]Done.
[00016727]Waiting for user confirm...
[00012896]========== remo-con disconnect. boot(5) ============
[00012944]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x60ce1d4b].
[00012993]Packet upgrade start...
[00013045]Packet checking...
[00013096]Packet vlink 01.03.0020 <-> 01.01.0009.
[00013175]Done.
[00013223]Version checking[1]...
[00013323][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013420][03 06][00] v2.2.6.8 -> v2.2.6.19 need upgrade.
[00013474][04 00][00] v1.38.0.0 -> v1.40.0.0 need upgrade.
[00013558][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013679][11 00][00] v1.6.0.0 -> v1.7.0.0 need upgrade.
[00013793][12 00][00] v1.8.0.0 -> v1.8.0.0
[00013893][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013993][12 02][00] v1.8.0.0 -> v1.8.0.0
[00014093][12 03][00] v1.8.0.0 -> v1.8.0.0
[00014247][15 00][00] v1.1.2.0 -> v1.1.2.0
[00014343][17 00][00] v1.1.1.6 -> v1.1.1.7 need upgrade.
[00014483][17 01][00] v1.0.2.5 -> v1.0.2.7 need upgrade.
[00014579][19 00][00] v0.0.0.0 -> v1.0.8.96 need upgrade.
[00014637][01 00][00] v1.23.3419 -> v1.23.3419
[00014687][01 01][00] v1.23.3419 -> v1.23.3419
[00014767][08 00][00] v0.11.0.4 -> v0.12.0.4 need upgrade.
[00014820]Done.
[00016879]Waiting for user confirm...
[00026928]Timeout, start upgrade automatically.
[00027038]Firmware upgrading[1]...
[00027995][08 00] Firmware upgrade start...
[00012932]========== remo-con disconnect. boot(15) ============
[00012981]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x60ce1d4b].
[00013031]Packet upgrade start...
[00013083]Packet checking...
[00013136]Packet vlink 01.03.0020 <-> 01.01.0009.
[00013215]Done.
[00013265]Version checking[1]...
[00013361][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013461][03 06][00] v2.2.6.8 -> v2.2.6.19 need upgrade.
[00013516][04 00][00] v1.38.0.0 -> v1.40.0.0 need upgrade.
[00013576][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013701][11 00][00] v1.6.0.0 -> v1.7.0.0 need upgrade.
[00013815][12 00][00] v1.8.0.0 -> v1.8.0.0
[00013916][12 01][00] v1.8.0.0 -> v1.8.0.0
[00014035][12 02][00] v1.8.0.0 -> v1.8.0.0
[00014170][12 03][00] v1.8.0.0 -> v1.8.0.0
[00014310][15 00][00] v1.1.2.0 -> v1.1.2.0
[00014410][17 00][00] v1.1.1.6 -> v1.1.1.7 need upgrade.
[00014550][17 01][00] v1.0.2.5 -> v1.0.2.7 need upgrade.
[00014615][19 00][00] v0.0.0.0 -> v1.0.8.96 need upgrade.
[00014666][01 00][00] v1.23.3419 -> v1.23.3419
[00014715][01 01][00] v1.23.3419 -> v1.23.3419
[00014776][08 00][00] v0.11.0.4 -> v0.12.0.4 need upgrade.
[00014824]Done.
[00016874]Waiting for user confirm...
[00000824][01 00] Firmware upgrade finished failed (step = 3, err = 0xffffffff).
[00013065]========== remo-con disconnect. boot(15) ============
[00013115]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0x60ce1d4b].
[00013171]Packet upgrade start...
[00013234]Packet checking...
[00013286]Packet vlink 01.04.0010 <-> 01.03.0020.
[00013377]Done.
[00013506]Version checking[1]...
[00013589][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013689][03 06][00] v2.2.6.8 -> v2.3.0.13 need upgrade.
[00013756][04 00][00] v1.38.0.0 -> v1.41.0.0 need upgrade.
[00013818][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013955][11 00][00] v1.6.1.0 -> v1.7.0.0 need upgrade.
[00014058][12 00][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
[00014159][12 01][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
[00014258][12 02][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
[00014333][12 03][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
[00014482][15 00][00] v1.1.2.0 -> v1.1.2.0
[00014573][17 00][00] v1.1.1.6 -> v1.1.1.7 need upgrade.
[00014742][17 01][00] v1.0.2.5 -> v1.0.2.7 need upgrade.
[00014818][19 00][00] v0.0.0.0 -> v1.0.8.96 need upgrade.
[00014881][01 00][00] v1.23.3419 -> v1.23.3419
[00014937][01 01][00] v1.23.3419 -> v1.23.3419
[00015002][08 00][00] v0.11.0.4 -> v0.12.0.4 need upgrade.
[00015057]Done.
[00017112]Waiting for user confirm...
[00027167]Timeout, start upgrade automatically.
[00027270]Firmware upgrading[1]...
[00027985][08 00] Firmware upgrade start...
[00012666]========== remo-con disconnect. boot(15) ============
[00012718]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0x0109824e].
[00012771]Packet upgrade start...
[00012828]Packet checking...
[00012879]Packet vlink 01.04.0010 <-> 01.03.0020.
[00012962]Done.
[00013014]Version checking[1]...
[00013104][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013184][03 06][00] v2.2.6.8 -> v2.3.0.13 need upgrade.
[00013253][04 00][00] v1.38.0.0 -> v1.41.0.0 need upgrade.
[00013334][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013464][11 00][00] v1.6.1.0 -> v1.7.0.0 need upgrade.
[00013554][12 00][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
[00013655][12 01][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
[00013753][12 02][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
[00013855][12 03][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
[00014000][15 00][00] v1.1.2.0 -> v1.1.2.0
[00014095][17 00][00] v1.1.1.6 -> v1.1.1.7 need upgrade.
[00014329][17 01][00] v1.0.2.5 -> v1.0.2.7 need upgrade.
[00014394][19 00][00] v0.0.0.0 -> v1.0.8.96 need upgrade.
[00014448][01 00][00] v1.23.3419 -> v1.23.3419
[00014502][01 01][00] v1.23.3419 -> v1.23.3419
[00014567][08 00][00] v0.11.0.4 -> v0.12.0.4 need upgrade.
[00014621]Done.
[00016675]Waiting for user confirm...
So what can you make of this one?
2015-9-26
Chadian
one question what is [00016675]Waiting for user confirm...   also this is my non-hidden log
========== 2014.01.01 00:00:12 remo-con disconnect======
Packet: P3X_FW_V01.02.0006.bin
Upgrading ...
========== 2015.06.28 18:11:33 =====================
Upgrading ...
========== 2015.06.28 18:14:13 =====================
Upgrading ...
========== 2015.06.28 18:15:09 =====================
Packet: P3X_FW_V01.01.0009.bin
Upgrading ...
Upgrading ...
Result: Failed.
Reboot the aircraft and try to upgrade the firmware again.
Upgrading ...
Upgrading ...
Upgrading ...
Upgrading ...
Upgrading ...
Upgrading ...
2015-9-26
karel
Flight distance : 1333740 ft
Brazil
Hello Sploodge
Thanks for all the help
Can you tell me whats is each DEVICE number on dji logs ?
I'm having problem with DEVICE 11
  1. [00011733][01 00] Firmware upgrade finished successfully.
  2. [00011858]Done.
  3. [00011892]Packet [C:\P3S_FW_V01.02.0008.bin] resumed, card sn [0x00ce11ab].
  4. [00011932]Version checking[2]...
  5. [00011998][03 05][00] v34.2.0.8 -> v34.2.0.9 need upgrade.
  6. [00012077][03 06][00] v2.1.6.18 -> v2.2.6.8 need upgrade.
  7. [00012117][04 00][00] v1.36.0.0 -> v1.38.0.0 need upgrade.
  8. [00012178][09 00][00] v1.7.0.3 -> v1.7.0.3
  9. [00012297][11 00][00] v1.6.1.0 -> v1.6.0.0
  10. [00012386][12 00][00] v1.8.0.0 -> v1.8.0.0
  11. [00012467][12 01][00] v1.8.0.0 -> v1.8.0.0
  12. [00012543][12 02][00] v1.8.0.0 -> v1.8.0.0
  13. [00012632][12 03][00] v1.8.0.0 -> v1.8.0.0
  14. [00012665][15 00][00] v1.1.2.0 -> v1.1.2.0
  15. [00012749][17 00][00] v1.1.1.2 -> v1.1.1.6 need upgrade.
  16. [00012867][17 01][00] v1.0.2.4 -> v1.0.2.5 need upgrade.
  17. [00012917][19 00][00] v1.0.8.96 -> v1.0.8.96
  18. [00012950][01 00][05] v1.14.3090 -> v1.14.3090
  19. [00012985][01 01][00] v1.7.2735 -> v1.14.3090 need upgrade
  20. [00013022]Done.
  21. [00013054]Firmware upgrading[2]...
  22. [00013207][01 01] Firmware upgrade start...
  23. [00043483][01 01] Firmware upgrade finished successfully.
  24. [00043548][17 00] Firmware upgrade start...
  25. [00148069][17 00] Firmware upgrade finished successfully.
  26. [00148115][17 01] Firmware upgrade start...
  27. [00219513][17 01] Firmware upgrade finished successfully.
  28. [00219567][03 05] Firmware upgrade start...
  29. [00288907][03 05] Firmware upgrade finished successfully.
  30. [00289145][03 06] Firmware upgrade start...
  31. [00589837][03 06] Firmware upgrade finished successfully.
  32. [00589900][04 00] Firmware upgrade start...
  33. [00647717][04 00] Firmware upgrade finished successfully.
  34. [00647755]Done.
  35. [00647784]Version checking[3]...
  36. [00647876][03 05][05] v34.2.0.9 -> v34.2.0.9
  37. [00647955][03 06][05] v2.2.6.8 -> v2.2.6.8
  38. [00647998][04 00][05] v1.38.0.0 -> v1.38.0.0
  39. [00648052][09 00][00] v1.7.0.3 -> v1.7.0.3
  40. [00648175][11 00][00] v1.6.1.0 -> v1.6.0.0
  41. [00648271][12 00][00] v1.8.0.0 -> v1.8.0.0
  42. [00648371][12 01][00] v1.8.0.0 -> v1.8.0.0
  43. [00648471][12 02][00] v1.8.0.0 -> v1.8.0.0
  44. [00648675][12 03][00] v1.8.0.0 -> v1.8.0.0
  45. [00648709][15 00][00] v1.1.2.0 -> v1.1.2.0
  46. [00648825][17 00][05] v1.1.1.6 -> v1.1.1.6
  47. [00648942][17 01][05] v1.0.2.5 -> v1.0.2.5
  48. [00649011][19 00][00] v1.0.8.96 -> v1.0.8.96
  49. [00649045][01 00][05] v1.14.3090 -> v1.14.3090
  50. [00649078][01 01][05] v1.14.3090 -> v1.14.3090
  51. [00649110]Packet upgrade finish successfully.
  52. [00011941]========== remo-con disconnect. boot(15) ============
  53. [00011988]Packet [C:\P3S_FW_V01.03.0020.bin] detected, card sn [0x40700ba3].
  54. [00012030]Packet upgrade start...
  55. [00012074]Packet checking...
  56. [00012112]Done.
  57. [00012162]Version checking[1]...
  58. [00012216][03 05][00] v34.2.0.9 -> v34.2.0.9
  59. [00012287][03 06][00] v2.2.6.8 -> v2.2.6.19 need upgrade.
  60. [00012341][04 00][00] v1.38.0.0 -> v1.40.0.0 need upgrade.
  61. [00012409][09 00][00] v1.7.0.3 -> v1.7.0.3
  62. [00012595][11 00][00] v1.6.0.0 -> v1.7.0.0 need upgrade.
  63. [00012675][12 00][00] v1.8.0.0 -> v1.8.0.0
  64. [00012751][12 01][00] v1.8.0.0 -> v1.8.0.0
  65. [00012825][12 02][00] v1.8.0.0 -> v1.8.0.0
  66. [00012916][12 03][00] v1.8.0.0 -> v1.8.0.0
  67. [00012967][15 00][00] v1.1.2.0 -> v1.1.2.0
  68. [00013045][17 00][00] v1.1.1.6 -> v1.1.1.7 need upgrade.
  69. [00013165][17 01][00] v1.0.2.5 -> v1.0.2.7 need upgrade.
  70. [00013230][19 00][00] v1.0.8.96 -> v1.0.8.96
  71. [00013268][01 00][00] v1.14.3090 -> v1.20.3419 need upgrade
  72. [00013317][01 01][00] v1.14.3090 -> v1.20.3419 need upgrade
  73. [00013359]Done.
  74. [00015408]Waiting for user confirm...
  75. [00025447]Timeout, start upgrade automatically.
  76. [00025529]Firmware upgrading[1]...
  77. [00041787][01 00] Firmware upgrade start...
  78. [00011733][01 00] Firmware upgrade finished successfully.
  79. [00011785]Done.
  80. [00011826]Packet [C:\P3S_FW_V01.03.0020.bin] resumed, card sn [0x40700ba3].
  81. [00011870]Packet vlink 01.03.0020 <-> 01.01.0009.
  82. [00011953]Version checking[2]...
  83. [00012014][03 05][00] v34.2.0.9 -> v34.2.0.9
  84. [00012092][03 06][00] v2.2.6.8 -> v2.2.6.19 need upgrade.
  85. [00012147][04 00][00] v1.38.0.0 -> v1.40.0.0 need upgrade.
  86. [00012302][09 00][00] v1.7.0.3 -> v1.7.0.3
  87. [00012414][11 00][00] v1.6.0.0 -> v1.7.0.0 need upgrade.
  88. [00012508][12 00][00] v1.8.0.0 -> v1.8.0.0
  89. [00012588][12 01][00] v1.8.0.0 -> v1.8.0.0
  90. [00012664][12 02][00] v1.8.0.0 -> v1.8.0.0
  91. [00012764][12 03][00] v1.8.0.0 -> v1.8.0.0
  92. [00012815][15 00][00] v1.1.2.0 -> v1.1.2.0
  93. [00012898][17 00][00] v1.1.1.6 -> v1.1.1.7 need upgrade.
  94. [00013018][17 01][00] v1.0.2.5 -> v1.0.2.7 need upgrade.
  95. [00013084][19 00][00] v1.0.8.96 -> v1.0.8.96
  96. [00013131][01 00][05] v1.20.3419 -> v1.20.3419
  97. [00013172][01 01][00] v1.14.3090 -> v1.20.3419 need upgrade
  98. [00013218]Done.
  99. [00013260]Firmware upgrading[2]...
  100. [00013426][01 01] Firmware upgrade start...
  101. [00043731][01 01] Firmware upgrade finished successfully.
  102. [00043799][17 00] Firmware upgrade start...
  103. [00144625][17 00] Firmware upgrade finished successfully.
  104. [00144675][17 01] Firmware upgrade start...
  105. [00231051][17 01] Firmware upgrade finished successfully.
  106. [00231106][11 00] Firmware upgrade start...
  107. [00281283][11 00] Firmware upgrade finished successfully.
  108. [00281533][03 06] Firmware upgrade start...
  109. [00588703][03 06] Firmware upgrade finished successfully.
  110. [00588772][04 00] Firmware upgrade start...
  111. [00647399][04 00] Firmware upgrade finished successfully.
  112. [00647456]Done.
  113. [00647524]Version checking[3]...
  114. [00647598][03 05][00] v34.2.0.9 -> v34.2.0.9
  115. [00647677][03 06][05] v2.2.6.19 -> v2.2.6.19
  116. [00647784][04 00][05] v1.40.0.0 -> v1.40.0.0
  117. [00647836][09 00][00] v1.7.0.3 -> v1.7.0.3
  118. [00647957][11 00][05] v1.7.0.0 -> v1.7.0.0
  119. [00648051][12 00][00] v1.8.0.0 -> v1.8.0.0
  120. [00648151][12 01][00] v1.8.0.0 -> v1.8.0.0
  121. [00648255][12 02][00] v1.8.0.0 -> v1.8.0.0
  122. [00648351][12 03][00] v1.8.0.0 -> v1.8.0.0
  123. [00648395][15 00][00] v1.1.2.0 -> v1.1.2.0
  124. [00648487][17 00][05] v1.1.1.7 -> v1.1.1.7
  125. [00648627][17 01][05] v1.0.2.7 -> v1.0.2.7
  126. [00648677][19 00][00] v1.0.8.96 -> v1.0.8.96
  127. [00648718][01 00][05] v1.20.3419 -> v1.20.3419
  128. [00648765][01 01][05] v1.20.3419 -> v1.20.3419
  129. [00648888]Packet upgrade finish successfully.
  130. [00012108]========== remo-con disconnect. boot(15) ============
  131. [00012173]Packet [C:\P3S_FW_V01.03.0020.bin] detected, card sn [0x40700ba3].
  132. [00012230]Packet upgrade start...
  133. [00012303]Packet checking...
  134. [00012353]Packet vlink 01.03.0020 <-> 01.01.0009.
  135. [00012403]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
  136. [00012463]Done.
  137. [00012511]Version checking[1]...
  138. [00012603][03 05][00] v34.2.0.9 -> v34.2.0.9
  139. [00012702][03 06][00] v2.2.6.19 -> v2.2.6.19
  140. [00012763][04 00][00] v1.40.0.0 -> v1.40.0.0
  141. [00012826][09 00][00] v1.7.0.3 -> v1.7.0.3
  142. [00012967][11 00][00] v1.7.0.0 -> v1.7.0.0
  143. [00013071][12 00][00] v1.8.0.0 -> v1.8.0.0
  144. [00013196][12 01][00] v1.8.0.0 -> v1.8.0.0
  145. [00013296][12 02][00] v1.8.0.0 -> v1.8.0.0
  146. [00013397][12 03][00] v1.8.0.0 -> v1.8.0.0
  147. [00013458][15 00][00] v1.1.2.0 -> v1.1.2.0
  148. [00013553][17 00][00] v1.1.1.7 -> v1.1.1.7
  149. [00013692][17 01][00] v1.0.2.7 -> v1.0.2.7
  150. [00013792][19 00][00] v1.0.8.96 -> v1.0.8.96
  151. [00013844][01 00][00] v1.20.3419 -> v1.20.3419
  152. [00013899][01 01][00] v1.20.3419 -> v1.20.3419
  153. [00013948]Packet upgrade cancelled at version checking.
  154. [00012104]========== remo-con disconnect. boot(15) ============
  155. [00012166]Packet [C:\P3S_FW_V01.03.0020.bin] detected, card sn [0x40700ba3].
  156. [00012220]Packet upgrade start...
  157. [00012281]Packet checking...
  158. [00012335]Packet vlink 01.03.0020 <-> 01.01.0009.
  159. [00012385]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
  160. [00012432]Done.
  161. [00012479]Version checking[1]...
  162. [00012572][03 05][00] v34.2.0.9 -> v34.2.0.9
  163. [00012668][03 06][00] v2.2.6.19 -> v2.2.6.19
  164. [00012724][04 00][00] v1.40.0.0 -> v1.40.0.0
  165. [00012792][09 00][00] v1.7.0.3 -> v1.7.0.3
  166. [00012911][11 00][00] v1.7.0.0 -> v1.7.0.0
  167. [00013027][12 00][00] v1.8.0.0 -> v1.8.0.0
  168. [00013127][12 01][00] v1.8.0.0 -> v1.8.0.0
  169. [00013226][12 02][00] v1.8.0.0 -> v1.8.0.0
  170. [00013326][12 03][00] v1.8.0.0 -> v1.8.0.0
  171. [00013377][15 00][00] v1.1.2.0 -> v1.1.2.0
  172. [00013578][17 00][00] v1.1.1.7 -> v1.1.1.7
  173. [00013720][17 01][00] v1.0.2.7 -> v1.0.2.7
  174. [00013792][19 00][00] v1.0.8.96 -> v1.0.8.96
  175. [00013845][01 00][00] v1.20.3419 -> v1.20.3419
  176. [00013898][01 01][00] v1.20.3419 -> v1.20.3419
  177. [00013944]Packet upgrade cancelled at version checking.
  178. [00012130]========== remo-con disconnect. boot(15) ============
  179. [00012185]Packet [C:\P3S_FW_V01.03.0020.bin] detected, card sn [0x40700ba3].
  180. [00012242]Packet upgrade start...
  181. [00012318]Packet checking...
  182. [00012370]Packet vlink 01.03.0020 <-> 01.01.0009.
  183. [00012425]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
  184. [00012481]Done.
  185. [00012535]Version checking[1]...
  186. [00012625][03 05][00] v34.2.0.9 -> v34.2.0.9
  187. [00012714][03 06][00] v2.2.6.19 -> v2.2.6.19
  188. [00012778][04 00][00] v1.40.0.0 -> v1.40.0.0
  189. [00012858][09 00][00] v1.7.0.3 -> v1.7.0.3
  190. [00012974][11 00][00] v1.7.0.0 -> v1.7.0.0
  191. [00013088][12 00][00] v1.8.0.0 -> v1.8.0.0
  192. [00013187][12 01][00] v1.8.0.0 -> v1.8.0.0
  193. [00013291][12 02][00] v1.8.0.0 -> v1.8.0.0
  194. [00013387][12 03][00] v1.8.0.0 -> v1.8.0.0
  195. [00013444][15 00][00] v1.1.2.0 -> v1.1.2.0
  196. [00013544][17 00][00] v1.1.1.7 -> v1.1.1.7
  197. [00013683][17 01][00] v1.0.2.7 -> v1.0.2.7
  198. [00013779][19 00][00] v1.0.8.96 -> v1.0.8.96
  199. [00013832][01 00][00] v1.20.3419 -> v1.20.3419
  200. [00013886][01 01][00] v1.20.3419 -> v1.20.3419
  201. [00013940]Packet upgrade cancelled at version checking.
  202. [00012353]========== remo-con disconnect. boot(15) ============
  203. [00012402]Packet [C:\P3S_FW_V01.04.0010.bin] detected, card sn [0x40700ba3].
  204. [00012458]Packet upgrade start...
  205. [00012515]Packet checking...
  206. [00012564]Packet vlink 01.04.0010 <-> 01.03.0020.
  207. [00012608]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
  208. [00012665]Done.
  209. [00012707]Version checking[1]...
  210. [00012806][03 05][00] v34.2.0.9 -> v34.2.0.9
  211. [00012906][03 06][00] v2.2.6.19 -> v2.3.0.13 need upgrade.
  212. [00012967][04 00][00] v1.40.0.0 -> v1.41.0.0 need upgrade.
  213. [00013059][09 00][00] v1.7.0.3 -> v1.7.0.3
  214. [00013190][11 00][00] v1.7.0.0 -> v1.7.0.0
  215. [00013399][12 00][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
  216. [00013501][12 01][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
  217. [00013600][12 02][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
  218. [00013701][12 03][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
  219. [00013772][15 00][00] v1.1.2.0 -> v1.1.2.0
  220. [00013876][17 00][00] v1.1.1.7 -> v1.1.1.7
  221. [00014015][17 01][00] v1.0.2.7 -> v1.0.2.7
  222. [00014140][19 00][00] v1.0.8.96 -> v1.0.8.96
  223. [00014189][01 00][00] v1.20.3419 -> v1.21.3647 need upgrade
  224. [00014238][01 01][00] v1.20.3419 -> v1.21.3647 need upgrade
  225. [00014293]Done.
  226. [00016343]Waiting for user confirm...
  227. [00026393]Timeout, start upgrade automatically.
  228. [00026493]Firmware upgrading[1]...
  229. [00043352][01 00] Firmware upgrade start...
  230. [00011745][01 00] Firmware upgrade finished successfully.
  231. [00011792]Done.
  232. [00011847]Packet [C:\P3S_FW_V01.04.0010.bin] resumed, card sn [0x40700ba3].
  233. [00011899]Packet vlink 01.04.0010 <-> 01.03.0020.
  234. [00011941]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
  235. [00011985]Version checking[2]...
  236. [00012068][03 05][00] v34.2.0.9 -> v34.2.0.9
  237. [00012149][03 06][00] v2.2.6.19 -> v2.3.0.13 need upgrade.
  238. [00012198][04 00][00] v1.40.0.0 -> v1.41.0.0 need upgrade.
  239. [00012259][09 00][00] v1.7.0.3 -> v1.7.0.3
  240. [00012389][11 00][00] v1.7.0.0 -> v1.7.0.0
  241. [00012473][12 00][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
  242. [00012564][12 01][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
  243. [00012644][12 02][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
  244. [00012718][12 03][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
  245. [00012767][15 00][00] v1.1.2.0 -> v1.1.2.0
  246. [00012855][17 00][00] v1.1.1.7 -> v1.1.1.7
  247. [00012973][17 01][00] v1.0.2.7 -> v1.0.2.7
  248. [00013038][19 00][00] v1.0.8.96 -> v1.0.8.96
  249. [00013080][01 00][05] v1.21.3647 -> v1.21.3647
  250. [00013123][01 01][00] v1.20.3419 -> v1.21.3647 need upgrade
  251. [00013172]Done.
  252. [00013214]Firmware upgrading[2]...
  253. [00013383][01 01] Firmware upgrade start...
  254. [00043690][01 01] Firmware upgrade finished successfully.
  255. [00043749][12 00] Firmware upgrade start...
  256. [00110188][12 00] Firmware upgrade finished successfully.
  257. [00110250][12 01] Firmware upgrade start...
  258. [00180757][12 01] Firmware upgrade finished successfully.
  259. [00180821][12 02] Firmware upgrade start...
  260. [00246816][12 02] Firmware upgrade finished successfully.
  261. [00246884][12 03] Firmware upgrade start...
  262. [00315819][12 03] Firmware upgrade finished successfully.
  263. [00316109][03 06] Firmware upgrade start...
  264. [00681628][03 06] Firmware upgrade finished successfully.
  265. [00681711][04 00] Firmware upgrade start...
  266. [00740717][04 00] Firmware upgrade finished successfully.
  267. [00740762]Done.
  268. [00740804]Version checking[3]...
  269. [00740878][03 05][00] v34.2.0.9 -> v34.2.0.9
  270. [00740953][03 06][05] v2.3.0.13 -> v2.3.0.13
  271. [00741003][04 00][05] v1.41.0.0 -> v1.41.0.0
  272. [00741058][09 00][00] v1.7.0.3 -> v1.7.0.3
  273. [00741178][11 00][00] v1.7.0.0 -> v1.7.0.0
  274. [00741286][12 00][05] v1.10.0.0 -> v1.10.0.0
  275. [00741386][12 01][05] v1.10.0.0 -> v1.10.0.0
  276. [00741486][12 02][05] v1.10.0.0 -> v1.10.0.0
  277. [00741586][12 03][05] v1.10.0.0 -> v1.10.0.0
  278. [00741633][15 00][00] v1.1.2.0 -> v1.1.2.0
  279. [00741721][17 00][00] v1.1.1.7 -> v1.1.1.7
  280. [00741887][17 01][00] v1.0.2.7 -> v1.0.2.7
  281. [00741959][19 00][00] v1.0.8.96 -> v1.0.8.96
  282. [00742002][01 00][05] v1.21.3647 -> v1.21.3647
  283. [00742049][01 01][05] v1.21.3647 -> v1.21.3647
  284. [00742094]Packet upgrade finish successfully.
  285. [00012057]========== 2015.09.12 13:10:39. boot(15) ============
  286. [00012102]Packet [C:\P3S_FW_V01.04.0010.bin] detected, card sn [0x40700ba3].
  287. [00012151]Packet upgrade start...
  288. [00012202]Packet checking...
  289. [00012245]Packet vlink 01.04.0010 <-> 01.03.0020.
  290. [00012284]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
  291. [00012337]Done.
  292. [00012380]Version checking[1]...
  293. [00012459][03 05][00] v34.2.0.9 -> v34.2.0.9
  294. [00012539][03 06][00] v2.3.0.13 -> v2.3.0.13
  295. [00012588][04 00][00] v1.41.0.0 -> v1.41.0.0
  296. [00012662][09 00][00] v1.7.0.3 -> v1.7.0.3
  297. [00012775][11 00][00] v1.7.0.0 -> v1.7.0.0
  298. [00012961][12 00][00] v1.10.0.0 -> v1.10.0.0
  299. [00013074][12 01][00] v1.10.0.0 -> v1.10.0.0
  300. [00013175][12 02][00] v1.10.0.0 -> v1.10.0.0
  301. [00013260][12 03][00] v1.10.0.0 -> v1.10.0.0
  302. [00013312][15 00][00] v1.1.2.0 -> v1.1.2.0
  303. [00013396][17 00][00] v1.1.1.7 -> v1.1.1.7
  304. [00013543][17 01][00] v1.0.2.7 -> v1.0.2.7
  305. [00013595][19 00][00] v1.0.8.96 -> v1.0.8.96
  306. [00013648][01 00][00] v1.21.3647 -> v1.21.3647
  307. [00013693][01 01][00] v1.21.3647 -> v1.21.3647
  308. [00013740]Packet upgrade cancelled at version checking.
  309. [00012092]========== remo-con disconnect. boot(15) ============
  310. [00012148]Packet [C:\P3S_FW_V01.04.0010.bin] detected, card sn [0x40700ba3].
  311. [00012194]Packet upgrade start...
  312. [00012248]Packet checking...
  313. [00012292]Packet vlink 01.04.0010 <-> 01.03.0020.
  314. [00012349]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
  315. [00012395]Done.
  316. [00012443]Version checking[1]...
  317. [00012539][03 05][00] v34.2.0.9 -> v34.2.0.9
  318. [00012619][03 06][00] v2.3.0.13 -> v2.3.0.13
  319. [00012680][04 00][00] v1.41.0.0 -> v1.41.0.0
  320. [00012736][09 00][00] v1.7.0.3 -> v1.7.0.3
  321. [00013003][11 00][00] v1.7.0.0 -> v1.7.0.0
  322. [00013114][12 00][00] v1.10.0.0 -> v1.10.0.0
  323. [00013219][12 01][00] v1.10.0.0 -> v1.10.0.0
  324. [00013319][12 02][00] v1.10.0.0 -> v1.10.0.0
  325. [00013428][12 03][00] v1.10.0.0 -> v1.10.0.0
  326. [00013485][15 00][00] v1.1.2.0 -> v1.1.2.0
  327. [00013588][17 00][00] v1.1.1.7 -> v1.1.1.7
  328. [00013740][17 01][00] v1.0.2.7 -> v1.0.2.7
  329. [00013793][19 00][00] v1.0.8.96 -> v1.0.8.96
  330. [00013851][01 00][00] v1.21.3647 -> v1.21.3647
  331. [00013899][01 01][00] v1.21.3647 -> v1.21.3647
  332. [00013950]Packet upgrade cancelled at version checking.
  333. [00012074]========== 2015.09.12 14:16:04. boot(15) ============
  334. [00012118]Packet [C:\P3S_FW_V01.04.0010.bin] detected, card sn [0x40700ba3].
  335. [00012171]Packet upgrade start...
  336. [00012221]Packet checking...
  337. [00012264]Packet vlink 01.04.0010 <-> 01.03.0020.
  338. [00012317]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
  339. [00012362]Done.
  340. [00012407]Version checking[1]...
  341. [00012609][03 05][00] v34.2.0.9 -> v34.2.0.9
  342. [00012690][03 06][00] v2.3.0.13 -> v2.3.0.13
  343. [00012755][04 00][00] v1.41.0.0 -> v1.41.0.0
  344. [00012831][09 00][00] v1.7.0.3 -> v1.7.0.3
  345. [00012951][11 00][00] v1.7.0.0 -> v1.7.0.0
  346. [00013071][12 00][00] v1.10.0.0 -> v1.10.0.0
  347. [00013171][12 01][00] v1.10.0.0 -> v1.10.0.0
  348. [00013254][12 02][00] v1.10.0.0 -> v1.10.0.0
  349. [00013354][12 03][00] v1.10.0.0 -> v1.10.0.0
  350. [00013406][15 00][00] v1.1.2.0 -> v1.1.2.0
  351. [00013494][17 00][00] v1.1.1.7 -> v1.1.1.7
  352. [00013642][17 01][00] v1.0.2.7 -> v1.0.2.7
  353. [00013708][19 00][00] v1.0.8.96 -> v1.0.8.96
  354. [00013755][01 00][00] v1.21.3647 -> v1.21.3647
  355. [00013809][01 01][00] v1.21.3647 -> v1.21.3647
  356. [00013856]Packet upgrade cancelled at version checking.
  357. [00012078]========== 2015.09.19 15:25:31. boot(15) ============
  358. [00012124]Packet [C:\P3S_FW_V01.04.0010.bin] detected, card sn [0x40700ba3].
  359. [00012177]Packet upgrade start...
  360. [00012224]Packet checking...
  361. [00012271]Packet vlink 01.04.0010 <-> 01.03.0020.
  362. [00012321]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
  363. [00012372]Done.
  364. [00012418]Version checking[1]...
  365. [00012524][03 05][00] v34.2.0.9 -> v34.2.0.9
  366. [00012624][03 06][00] v2.3.0.13 -> v2.3.0.13
  367. [00012684][04 00][00] v1.41.0.0 -> v1.41.0.0
  368. [00012759][09 00][00] v1.7.0.3 -> v1.7.0.3
  369. [00012904][11 00][00] v1.7.0.0 -> v1.7.0.0
  370. [00013018][12 00][00] v1.10.0.0 -> v1.10.0.0
  371. [00013118][12 01][00] v1.10.0.0 -> v1.10.0.0
  372. [00013239][12 02][00] v1.10.0.0 -> v1.10.0.0
  373. [00013338][12 03][00] v1.10.0.0 -> v1.10.0.0
  374. [00013385][15 00][00] v1.1.2.0 -> v1.1.2.0
  375. [00013487][17 00][00] v1.1.1.7 -> v1.1.1.7
  376. [00013627][17 01][00] v1.0.2.7 -> v1.0.2.7
  377. [00013700][19 00][00] v1.0.8.96 -> v1.0.8.96
  378. [00013747][01 00][00] v1.21.3647 -> v1.21.3647
  379. [00013792][01 01][00] v1.21.3647 -> v1.21.3647
  380. [00013845]Packet upgrade cancelled at version checking.
  381. [00012144]========== 2015.09.24 15:56:32. boot(15) ============
  382. [00012186]Packet [C:\P3S_FW_V01.04.0010.bin] detected, card sn [0x40700ba3].
  383. [00012321]Packet upgrade start...
  384. [00012376]Packet checking...
  385. [00012419]Packet vlink 01.04.0010 <-> 01.03.0020.
  386. [00012475]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
  387. [00012521]Done.
  388. [00012570]Version checking[1]...
  389. [00012641][03 05][00] v34.2.0.9 -> v34.2.0.9
  390. [00012720][03 06][00] v2.3.0.13 -> v2.3.0.13
  391. [00012787][04 00][00] v1.41.0.0 -> v1.41.0.0
  392. [00012869][09 00][00] v1.7.0.3 -> v1.7.0.3
  393. [00012979][11 00][00] v1.6.1.0 -> v1.7.0.0 need upgrade.
  394. [00013078][12 00][00] v1.10.0.0 -> v1.10.0.0
  395. [00013173][12 01][00] v1.10.0.0 -> v1.10.0.0
  396. [00013250][12 02][00] v1.10.0.0 -> v1.10.0.0
  397. [00013329][12 03][00] v1.10.0.0 -> v1.10.0.0
  398. [00013379][15 00][00] v1.1.2.0 -> v1.1.2.0
  399. [00013475][17 00][00] v1.1.1.7 -> v1.1.1.7
  400. [00013613][17 01][00] v1.0.2.7 -> v1.0.2.7
  401. [00013687][19 00][00] v1.0.8.96 -> v1.0.8.96
  402. [00013740][01 00][00] v1.21.3647 -> v1.21.3647
  403. [00013786][01 01][00] v1.21.3647 -> v1.21.3647
  404. [00013844]Done.
  405. [00015899]Waiting for user confirm...
  406. [00025949]Timeout, start upgrade automatically.
  407. [00026044]Firmware upgrading[1]...
  408. [00026098][11 00] Firmware upgrade start...
  409. [00078076][11 00] Firmware upgrade finished successfully.
  410. [00078119]Done.
  411. [00078169]Version checking[2]...
  412. [00078268][03 05][00] v34.2.0.9 -> v34.2.0.9
  413. [00078348][03 06][00] v2.3.0.13 -> v2.3.0.13
  414. [00078408][04 00][00] v1.41.0.0 -> v1.41.0.0
  415. [00078480][09 00][00] v1.7.0.3 -> v1.7.0.3
  416. [00078628][11 00][05] v1.7.0.0 -> v1.7.0.0
  417. [00078740][12 00][00] v1.10.0.0 -> v1.10.0.0
  418. [00078836][12 01][00] v1.10.0.0 -> v1.10.0.0
  419. [00078939][12 02][00] v1.10.0.0 -> v1.10.0.0
  420. [00079040][12 03][00] v1.10.0.0 -> v1.10.0.0
  421. [00079089][15 00][00] v1.1.2.0 -> v1.1.2.0
  422. [00079191][17 00][00] v1.1.1.7 -> v1.1.1.7
  423. [00079353][17 01][00] v1.0.2.7 -> v1.0.2.7
  424. [00079428][19 00][00] v1.0.8.96 -> v1.0.8.96
  425. [00079476][01 00][00] v1.21.3647 -> v1.21.3647
  426. [00079521][01 01][00] v1.21.3647 -> v1.21.3647
  427. [00079577]Packet upgrade finish successfully.
  428. [00022178]========== remo-con disconnect. boot(15) ============
  429. [00022336]Packet [C:\P3S_FW_V01.04.0010.bin] detected, card sn [0x40700ba3].
  430. [00022389]Packet upgrade start...
  431. [00022450]Packet checking...
  432. [00022507]Packet vlink 01.04.0010 <-> 01.03.0020.
  433. [00022558]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
  434. [00022612]Done.
  435. [00022670]Version checking[1]...
  436. [00035225][03 05][00] device not detected.
  437. [00047775][03 06][00] device not detected.
  438. [00047842][04 00][00] v1.41.0.0 -> v1.41.0.0
  439. [00060393][09 00][00] device not detected.
  440. [00072940][11 00][00] device not detected.
  441. [00085487][12 00][00] device not detected.
  442. [00098036][12 01][00] device not detected.
  443. [00110600][12 02][00] device not detected.
  444. [00123151][12 03][00] device not detected.
  445. [00145701][15 00][00] device not detected.
  446. [00158253][17 00][00] device not detected.
  447. [00170808][17 01][00] device not detected.
  448. [00183373][19 00][00] device not detected.
  449. [00183430][01 00][00] v1.21.3647 -> v1.21.3647
  450. [00183485][01 01][00] v1.21.3647 -> v1.21.3647
  451. [00183547]Packet upgrade failed at version checking.
  452. [00022324]========== remo-con disconnect. boot(15) ============
  453. [00022379]Packet [C:\P3S_FW_V01.04.0010.bin] detected, card sn [0x40700ba3].
  454. [00022433]Packet upgrade start...
  455. [00022504]Packet checking...
  456. [00022557]Packet vlink 01.04.0010 <-> 01.03.0020.
  457. [00022612]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
  458. [00022672]Done.
  459. [00022724]Version checking[1]...
  460. [00035291][03 05][00] device not detected.
  461. [00047850][03 06][00] device not detected.
  462. [00047912][04 00][00] v1.41.0.0 -> v1.41.0.0
  463. [00060463][09 00][00] device not detected.
  464. [00073035][11 00][00] device not detected.
  465. [00085584][12 00][00] device not detected.
  466. [00098132][12 01][00] device not detected.
  467. [00110683][12 02][00] device not detected.
  468. [00123251][12 03][00] device not detected.
  469. [00145802][15 00][00] device not detected.
  470. [00158354][17 00][00] device not detected.
  471. [00170902][17 01][00] device not detected.
  472. [00183552][19 00][00] device not detected.
  473. [00183615][01 00][00] v1.21.3647 -> v1.21.3647
  474. [00183666][01 01][00] v1.21.3647 -> v1.21.3647
  475. [00183722]Packet upgrade failed at version checking.
  476. [00022239]========== remo-con disconnect. boot(15) ============
  477. [00022298]Packet [C:\P3S_FW_V01.04.0010.bin] detected, card sn [0x40700ba3].
  478. [00022361]Packet upgrade start...
  479. [00022424]Packet checking...
  480. [00022486]Packet vlink 01.04.0010 <-> 01.03.0020.
  481. [00022540]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
  482. [00022594]Done.
  483. [00022659]Version checking[1]...
  484. [00035225][03 05][00] device not detected.
  485. [00047776][03 06][00] device not detected.
  486. [00047843][04 00][00] v1.41.0.0 -> v1.41.0.0
  487. [00060397][09 00][00] device not detected.
  488. [00072963][11 00][00] device not detected.
  489. [00085515][12 00][00] device not detected.
  490. [00098067][12 01][00] device not detected.
  491. [00110634][12 02][00] device not detected.
  492. [00123186][12 03][00] device not detected.
  493. [00022279]========== remo-con disconnect. boot(15) ============
  494. [00022339]Packet [C:\P3S_FW_V01.04.0010.bin] detected, card sn [0x40700ba3].
  495. [00022395]Packet upgrade start...
  496. [00022467]Packet checking...
  497. [00022531]Packet vlink 01.04.0010 <-> 01.03.0020.
  498. [00022590]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
  499. [00022653]Done.
  500. [00022707]Version checking[1]...
  501. [00035263][03 05][00] device not detected.
  502. [00047816][03 06][00] device not detected.
  503. [00047887][04 00][00] v1.41.0.0 -> v1.41.0.0
  504. [00060450][09 00][00] device not detected.
  505. [00073004][11 00][00] device not detected.
  506. [00085575][12 00][00] device not detected.
  507. [00098127][12 01][00] device not detected.
  508. [00110680][12 02][00] device not detected.
  509. [00123246][12 03][00] device not detected.
  510. [00145806][15 00][00] device not detected.
  511. [00158360][17 00][00] device not detected.
  512. [00170928][17 01][00] device not detected.
  513. [00183480][19 00][00] device not detected.
  514. [00183547][01 00][00] v1.21.3647 -> v1.21.3647
  515. [00183602][01 01][00] v1.21.3647 -> v1.21.3647
  516. [00183756]Packet upgrade failed at version checking.
  517. [00022224]========== remo-con disconnect. boot(15) ============
  518. [00022282]Packet [C:\P3S_FW_V01.04.0010.bin] detected, card sn [0x40700ba3].
  519. [00022341]Packet upgrade start...
  520. [00022408]Packet checking...
  521. [00022466]Packet vlink 01.04.0010 <-> 01.03.0020.
  522. [00022529]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
  523. [00022588]Done.
  524. [00022641]Version checking[1]...
  525. [00035203][03 05][00] device not detected.
  526. [00047771][03 06][00] device not detected.
  527. [00047843][04 00][00] v1.41.0.0 -> v1.41.0.0
  528. [00060396][09 00][00] device not detected.
  529. [00072963][11 00][00] device not detected.
  530. [00085517][12 00][00] device not detected.
  531. [00022238]========== remo-con disconnect. boot(15) ============
  532. [00022298]Packet [C:\P3S_FW_V01.04.0010.bin] detected, card sn [0x40700ba3].
  533. [00022351]Packet upgrade start...
  534. [00022420]Packet checking...
  535. [00022476]Packet vlink 01.04.0010 <-> 01.03.0020.
  536. [00022540]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
  537. [00022601]Done.
  538. [00022659]Version checking[1]...
  539. [00035218][03 05][00] device not detected.
  540. [00047783][03 06][00] device not detected.
  541. [00047859][04 00][00] v1.41.0.0 -> v1.41.0.0
  542. [00060410][09 00][00] device not detected.
  543. [00072975][11 00][00] device not detected.
  544. [00085530][12 00][00] device not detected.
  545. [00098079][12 01][00] device not detected.
  546. [00110650][12 02][00] device not detected.
  547. [00123204][12 03][00] device not detected.
  548. [00145768][15 00][00] device not detected.
  549. [00158332][17 00][00] device not detected.
  550. [00022307]========== remo-con disconnect. boot(15) ============
  551. [00022373]Packet [C:\P3S_FW_V01.04.0010.bin] detected, card sn [0x40700ba3].
  552. [00022435]Packet upgrade start...
  553. [00022513]Packet checking...
  554. [00022574]Packet vlink 01.04.0010 <-> 01.03.0020.
  555. [00022635]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
  556. [00022701]Done.
  557. [00022829]Version checking[1]...
  558. [00035384][03 05][00] device not detected.
  559. [00047947][03 06][00] device not detected.
  560. [00048115][04 00][00] v1.41.0.0 -> v1.41.0.0
  561. [00060668][09 00][00] device not detected.
  562. [00073219][11 00][00] device not detected.
  563. [00085785][12 00][00] device not detected.
  564. [00098342][12 01][00] device not detected.
  565. [00110893][12 02][00] device not detected.
  566. [00123456][12 03][00] device not detected.
  567. [00022136]========== remo-con disconnect. boot(15) ============
  568. [00022195]Packet [C:\P3S_FW_V01.04.0010.bin] detected, card sn [0x40700ba3].
  569. [00022242]Packet upgrade start...
  570. [00022301]Packet checking...
  571. [00022360]Packet vlink 01.04.0010 <-> 01.03.0020.
  572. [00022409]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
  573. [00022465]Done.
  574. [00022526]Version checking[1]...
  575. [00035076][03 05][00] device not detected.
  576. [00047621][03 06][00] device not detected.
  577. [00047685][04 00][00] v1.41.0.0 -> v1.41.0.0
  578. [00060234][09 00][00] device not detected.
  579. [00072779][11 00][00] device not detected.
  580. [00085325][12 00][00] device not detected.
  581. [00097871][12 01][00] device not detected.
  582. [00022160]========== remo-con disconnect. boot(15) ============
  583. [00022211]Packet [C:\P3S_FW_V01.04.0010.bin] detected, card sn [0x40700ba3].
  584. [00022263]Packet upgrade start...
  585. [00022328]Packet checking...
  586. [00022378]Packet vlink 01.04.0010 <-> 01.03.0020.
  587. [00022433]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
  588. [00022493]Done.
  589. [00022544]Version checking[1]...
  590. [00035096][03 05][00] device not detected.
  591. [00047646][03 06][00] device not detected.
  592. [00047713][04 00][00] v1.41.0.0 -> v1.41.0.0
  593. [00060263][09 00][00] device not detected.
  594. [00022180]========== remo-con disconnect. boot(15) ============
  595. [00022232]Packet [C:\P3S_FW_V01.04.0010.bin] detected, card sn [0x40700ba3].
  596. [00022289]Packet upgrade start...
  597. [00022358]Packet checking...
  598. [00022413]Packet vlink 01.04.0010 <-> 01.03.0020.
  599. [00022467]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
  600. [00022528]Done.
  601. [00022584]Version checking[1]...
  602. [00022122]========== remo-con disconnect. boot(15) ============
  603. [00022262]Packet [C:\P3S_FW_V01.04.0010.bin] detected, card sn [0x40700ba3].
  604. [00022320]Packet upgrade start...
  605. [00022373]Packet checking...
  606. [00022424]Packet vlink 01.04.0010 <-> 01.03.0020.
  607. [00022475]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
  608. [00022530]Done.
  609. [00022585]Version checking[1]...
  610. [00035135][03 05][00] device not detected.
  611. [00047685][03 06][00] device not detected.
  612. [00047760][04 00][00] v1.41.0.0 -> v1.41.0.0
  613. [00060318][09 00][00] device not detected.
  614. [00072874][11 00][00] device not detected.
  615. [00085424][12 00][00] device not detected.
  616. [00097989][12 01][00] device not detected.
  617. [00110540][12 02][00] device not detected.
  618. [00123093][12 03][00] device not detected.
  619. [00145644][15 00][00] device not detected.
  620. [00158216][17 00][00] device not detected.
  621. [00170766][17 01][00] device not detected.
  622. [00183320][19 00][00] device not detected.
  623. [00183371][01 00][00] v1.21.3647 -> v1.21.3647
  624. [00183425][01 01][00] v1.21.3647 -> v1.21.3647
  625. [00183485]Packet upgrade failed at version checking.
  626. [00023941]========== remo-con disconnect. boot(15) ============
  627. [00023996]Packet [C:\P3S_FW_V01.04.0010.bin] detected, card sn [0xbc13e9df].
  628. [00024050]Packet upgrade start...
  629. [00024104]Packet checking...
  630. [00024165]Packet vlink 01.04.0010 <-> 01.03.0020.
  631. [00024217]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
  632. [00024267]Done.
  633. [00024326]Version checking[1]...
  634. [00036893][03 05][00] device not detected.
  635. [00049444][03 06][00] device not detected.
  636. [00049511][04 00][00] v1.41.0.0 -> v1.41.0.0
  637. [00062061][09 00][00] device not detected.
  638. [00074608][11 00][00] device not detected.
  639. [00087158][12 00][00] device not detected.
  640. [00099728][12 01][00] device not detected.
  641. [00112277][12 02][00] device not detected.
  642. [00124825][12 03][00] device not detected.
  643. [00147375][15 00][00] device not detected.
  644. [00159923][17 00][00] device not detected.
  645. [00172476][17 01][00] device not detected.
  646. [00185041][19 00][00] device not detected.
  647. [00185194][01 00][00] v1.21.3647 -> v1.21.3647
  648. [00185249][01 01][00] v1.21.3647 -> v1.21.3647
  649. [00185297]Packet upgrade failed at version checking.
  650. [00013069]========== remo-con disconnect. boot(15) ============
  651. [00013121]Packet [C:\P3S_FW_V01.04.0010.bin] detected, card sn [0xbc13e9df].
  652. [00013177]Packet upgrade start...
  653. [00013240]Packet checking...
  654. [00013290]Packet vlink 01.04.0010 <-> 01.03.0020.
  655. [00013347]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
  656. [00013408]Done.
  657. [00013457]Version checking[1]...
  658. [00013556][03 05][00] v34.2.0.9 -> v34.2.0.9
  659. [00013641][03 06][00] v2.3.0.13 -> v2.3.0.13
  660. [00013696][04 00][00] v1.41.0.0 -> v1.41.0.0
  661. [00013770][09 00][00] v1.7.0.3 -> v1.7.0.3
  662. [00026322][11 00][00] device not detected.
  663. [00026425][12 00][00] v1.10.0.0 -> v1.10.0.0
  664. [00026517][12 01][00] v1.10.0.0 -> v1.10.0.0
  665. [00026616][12 02][00] v1.10.0.0 -> v1.10.0.0
  666. [00026725][12 03][00] v1.10.0.0 -> v1.10.0.0
  667. [00026783][15 00][00] v1.1.2.0 -> v1.1.2.0
  668. [00026885][17 00][00] v1.1.1.7 -> v1.1.1.7
  669. [00027006][17 01][00] v1.0.2.7 -> v1.0.2.7
  670. [00027090][19 00][00] v1.0.8.96 -> v1.0.8.96
  671. [00027147][01 00][00] v1.21.3647 -> v1.21.3647
  672. [00027200][01 01][00] v1.21.3647 -> v1.21.3647
  673. [00027261]Packet upgrade failed at version checking.
  674. [00022971]========== remo-con disconnect. boot(15) ============
  675. [00023025]Packet [C:\P3S_FW_V01.04.0010.bin] detected, card sn [0xbc13e9df].
  676. [00023079]Packet upgrade start...
  677. [00023146]Packet checking...
  678. [00023201]Packet vlink 01.04.0010 <-> 01.03.0020.
  679. [00023257]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
  680. [00023316]Done.
  681. [00023371]Version checking[1]...
  682. [00035928][03 05][00] device not detected.
  683. [00048485][03 06][00] device not detected.
  684. [00048560][04 00][00] v1.41.0.0 -> v1.41.0.0
  685. [00048633][09 00][00] v0.0.0.0 -> v1.7.0.3 need upgrade.
  686. [00061192][11 00][00] device not detected.
  687. [00073741][12 00][00] device not detected.
  688. [00086293][12 01][00] device not detected.
  689. [00098860][12 02][00] device not detected.
  690. [00111509][12 03][00] device not detected.
  691. [00111574][15 00][00] v1.1.2.0 -> v1.1.2.0
  692. [00124125][17 00][00] device not detected.
  693. [00136693][17 01][00] device not detected.
  694. [00149253][19 00][00] device not detected.
  695. [00149306][01 00][00] v1.21.3647 -> v1.21.3647
  696. [00149361][01 01][00] v1.21.3647 -> v1.21.3647
  697. [00149425]Done.
  698. [00151482]Waiting for user confirm...
  699. [00161532]Timeout, start upgrade automatically.
  700. [00161651]Firmware upgrading[1]...
  701. [00161736][09 00] Firmware upgrade start...
  702. [00212906][09 00] Firmware upgrade finished successfully.
  703. [00212961]Done.
  704. [00213022]Version checking[2]...
  705. [00213115][03 05][00] v34.2.0.9 -> v34.2.0.9
  706. [00213216][03 06][00] v2.3.0.13 -> v2.3.0.13
  707. [00213279][04 00][00] v1.41.0.0 -> v1.41.0.0
  708. [00213354][09 00][05] v1.7.0.3 -> v1.7.0.3
  709. [00225915][11 00][00] device not detected.
  710. [00226024][12 00][00] v1.10.0.0 -> v1.10.0.0
  711. [00226124][12 01][00] v1.10.0.0 -> v1.10.0.0
  712. [00226249][12 02][00] v1.10.0.0 -> v1.10.0.0
  713. [00226349][12 03][00] v1.10.0.0 -> v1.10.0.0
  714. [00226405][15 00][00] v1.1.2.0 -> v1.1.2.0
  715. [00226504][17 00][00] v1.1.1.7 -> v1.1.1.7
  716. [00226688][17 01][00] v1.0.2.7 -> v1.0.2.7
  717. [00226754][19 00][00] v1.0.8.96 -> v1.0.8.96
  718. [00226805][01 00][00] v1.21.3647 -> v1.21.3647
  719. [00226868][01 01][00] v1.21.3647 -> v1.21.3647
  720. [00226926]Packet upgrade failed at version checking.
Copy the code
Thanks
2015-10-23
sploodge
Flight distance : 809350 ft
karel@bond101.n Posted at 2015-10-23 15:39
Hello Sploodge
11 is battery..
2015-10-23
karel
Brazil
Thanks
My ESC BOARD has problem and do not show BATTERY status on gji go
And show BATTERY ERROR PROBLEM
Invalid battery
I changed the main board and all fine now.
2015-10-23
Michael Stoute
Flight distance : 3495003 ft
And all other device numbers?
2015-10-23
karel
Brazil
Michael Stoute Posted at 2015-10-24 05:28
This is a good quesstion
If sploodge can tell us
2015-10-23
karel
Brazil
Do you know all the other devices numbers my friend ?
I yes... Can you share with us this informaion ?
About what is each device ?
Thanks
2015-11-8
jesolins
Flight distance : 2169 ft
Hi Gents,
  I have a recently bought used P3P that will not load the new firmware by the camera micro SD slot.  No text files get written about the firmware load, just gets the P3P folders re-written to it.  The camera and SD card slot seem to work fine otherwise.  Videos and photos are saved normally to the SD card. The SD card is a new 32GB c10(I have tried several other SD cards with the same results) that is formatted (tried both FAT32 and extfat on the PC and used the Go app to format too) before I put on the 1.1.9, 2.6.0, 1.3.2, or 1.4001(tried them all) P3P firmware which I have re-downloaded several time to try to get it to update.  The file is unzipped on the SD card  It just goes into normal flight mode when the firmware SD card is in the P3P and then the model powered on. Also I noticed that if the camera cables are connected, the Go app About firmware states firmware unknown/N/A for the aircraft.  If the camera cable are removed it will show the aircraft firmware as 1.8+  The Go app is version 2.41 and the RC controller was updated to 1.4.3 normally.  I have also tried to use the service.bin to correct this issue but no joy with that either...and a success file is written when I run that service.bin file.  It flies and works fine except for not being able to get updated firmware on-board.
Does anyone know of an alternate way to load the aircraft firmware?  Has anyone tried to load it via the micro USB on the Phantom or the micro SD on the bottom of the centerboard?
Any thoughts or suggestions welcomed.
Cheers,
Jim
2015-11-18
evgeny381
Kazakhstan
and how to roll back the firmware for Phantom 3 Standard?
2015-12-5
rodger
Flight distance : 20145135 ft
Great job as always.
2015-12-5
howieal
At the start of your video, I saw you removed the SD card and I did not see where you put it back in.
My P3 Go app will not connect if I don't have the SD card installed.
I can't help much with the other stuff but I know mine will not show "Connected" unless I have the  SD card in the P3.
Good Luck,
Howard
2016-1-20
RichJ53
Flight distance : 1837356 ft
sploodge Posted at 2015-9-22 07:35
Contact DJI, get an RMA and send it back..
did you try to uninstall the DJI Go App and start over?  The only other thing I can think of is to relink the aircraft (bind procedure) following the manual.
Rich
2016-1-23
Steelman
Just for the record, I had the identical problem updating to 1.6 from 1.4
long steady beep, tried and tried then read through SPLOODGE's posts.
After removing the card and doing a full FORMAT, not the quick format.
Then putting 1.6 on the card and tried the update again....success!
I just need to take it outdoors and fly it yet to confirm everything is working properly.
2016-1-24
JbDrone
I tried to update my phantom 3 advanced as I received it for Christmas as a gift. After a first update fail my paper weight only beeped. After days of trying to troubleshoot the problem and several emails to the service I finally had to return it to get fixed. I got so frustrated I wanted a refund to buy a different one, but read that you can only get a refund within a week of purchase. So I asked for a new drone as this has never been on except to try to update the paper weight. Well their exchange policy is as bad as their refund. My parents bought this in November to make sure I got in time for Christmas. I'm sure it took 5 days to deliver to my parents and then wait till Christmas to open it, so it went past all the policy exchange and refund time. I sent it two weeks ago and 2 days ago they just checked it in. If it comes back still not working and asking me for a update I'm going to my roof and tossing it off to pretend like it works.
2016-1-25
afiend69
Flight distance : 626647 ft
may have updated my battery as well as I was shutting down... if the battery only takes like 15 seconds to update.
If there was a magic button like this for the RC I would probably be flying right now
2016-1-25
paggaru
Indonesia
I have Phantom 3 Standard remote no signal after up date DJI GO
2016-2-5
snakemb
Brazil
And for the Phantom 3 4k? reinstalling the firmware? He gets two consecutive beeps at two-second intervals
2016-2-6
snakemb
Brazil
2016-2-6
noaches232
Thanks! this will undoubtedly save many phantoms. as usual great advice.
2016-2-8
rhandry
Madagascar
sploodge Posted at 2015-9-21 09:11
Does the log show issue with module 8 and/or 19?
Hi Sploodge,
I got these errors
[00110365][15 00][00] device not detected.
[00123440][08 00][00] device not detected.
Can you help me what device are them and how to fix the failed in upgrading the firmware?
Thanks
Andry
2016-2-9
sploodge
rhandry Posted at 2016-2-9 15:30
Hi Sploodge,
I got these errors
The devices are as follows:
15 - Air End USB transmit
8 - Air encoder
To be honest with you, this issue is rarely fixable yourself.. I suggest you contact DJI Support and go from there..
2016-2-9
rhandry
Madagascar
sploodge Posted at 2016-2-9 22:39
Thank you sploodge, as I understand I have to send back, they said only the gambles with camera but can you show me how to disassemble it from the aircraft?
2016-2-9
StefanW
South Africa
I have also been struggling. I crashed my drone and snapped the yaw arm and ribbon cable. I have replaced both but when I boot, the gimbal remains limp. The DJI app said that I need to upgrade the firmware on the battery and the quad. I tried to update the firmware but it doesn't seem to work. I get the red/green flashing like I am meant to (no sounds from the gimbal though). After a few minutes, I get a red light for about 2 seconds and then it seems to reboot the gimbal (quick green flashing and then goes to red/green flashing).
The only line I get in the log is "[00000663][01 00] Firmware upgrade finished failed (step = 3, err = 0xffffffff)"
Any ideas?
2016-2-24
Jairo
Brazil
Hi rhandry,
I have exactly the same problem as you. Unfortunately after lot of tries I couldn't solve this problem. My P3P flight well and record videos and shot photos ok. The only problem is that I dont't see anything in my smartphone or tablet.
Do you contact DJI form a RMA? What did you sent to them? only the Gimbal? How ths cost to fix?
Thanks in advance.
2016-4-29
jannischrenko
sploodge can you tell me if device 8 and 15 are on the same board ?, so u can just buy a new board and problem is fixed ?
2016-5-1
NeilP3
Hi, came across this thread while looking for solutions. I had been using my P3P fine but it was grounded for a few weeks due to weather and not having the time to go flying. Now I got it back out I have the 'No Signal' problem with no live feed but everything else still works fine. The only changes since last time must have been the app update. So I tried installing an older version with no luck, still same problem. The app wanted to update the controller to 1.60 so I let it do that, still no change.
I thought I would try updating the firmware to see if that fixed it and following the same procedure as the last 2 firmware updates, for the first time ever, my bird fails to update after a few minutes with the red light and constant beep. I've tried different memory cards, formatting each one both in the app and on PC, I've tried downloading the file several times to make sure it wasn't corrupted somehow, tried different batteries, with controller on, controller off, everything I can think of and everything I can find online and still no luck.
I get the following in the log files (I'm guessing this part relates to the most recent update attempts):
[00260190]Version checking[2]...
[00260309][03 05][00] v34.2.0.9 -> v34.2.0.9
[00260430][03 06][00] v2.4.20.18 -> v2.4.20.18
[00260514][04 00][00] v1.44.0.0 -> v1.44.0.0
[00260670][11 00][00] v1.8.0.0 -> v1.8.0.0
[00260810][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00260888][11 01][00] v1.8.0.0 -> v2.0.0.33
[00261024][12 00][00] v1.10.0.0 -> v1.10.0.0
[00261150][12 01][00] v1.10.0.0 -> v1.10.0.0
[00261286][12 02][00] v1.10.0.0 -> v1.10.0.0
[00261410][12 03][00] v1.10.0.0 -> v1.10.0.0
[00273990][15 00][00] device not detected.
[00274094][17 00][00] v1.1.1.7 -> v1.1.1.7
[00274234][17 01][00] v1.0.2.7 -> v1.0.2.7
[00274319][19 00][00] v1.0.8.96 -> v1.0.8.96
[00274396][01 00][00] v1.30.5036 -> v1.30.5036
[00274477][01 01][00] v1.30.5036 -> v1.30.5036
[00287060][08 00][00] device not detected.
[00287160][09 00][05] v3.0.0.10 -> v3.0.0.10
[00287245]Packet upgrade failed at version checking.
When I power the drone back on without the .bin file it starts up and works fine except the no signal problem just like before the update attempt and in the app it says the drone has the lastest firmware (1.9.60) despite beeping like its failed. Has it updated everything except the components its mentioned and that somehow isn't enough to flag in the app?
I can see I have the 08  00 and 15 00 issue. Does this mean it has to go to DJI? Problem I have is that my P3P is now out of warranty. Any fix may well be uneconomical. Can anyone confirm which physical part this refers to? Would a new gimbal or main board solve the problem? I'm quite handy and could probably switch out the part myself but want to make sure it would actually fix the issue.
Also...is it worth contacting DJI since the problem is clearly firmware/software related. Is it worth waiting for another firmware update?
Thanks
2016-7-17
Dompie
NeilP3 Posted at 2016-7-18 01:09
Hi, came across this thread while looking for solutions. I had been using my P3P fine but it was gro ...
I have exactly the same issue, they say, in my trade '' SS DD ..  same s..t...,different day!!
2016-10-17
Dompie
Dompie Posted at 2016-10-18 06:09
WHY so much secrecy about this issue, like a War secret
2016-10-17
jdavcfy
NeilP3 Posted at 2016-7-17 13:09
Same problem here as well... Really disheartening that so many others are having it. Sounds like a design flaw of some kind to me. I wish we could get some answers.
2016-10-17
Vladimir4
Russia
Please can you sent me the file for the Phantom 3 pro. I have a mistake with my last update.
2016-10-31
Aardvark
Flight distance : 384432 ft
Vladimir4 Posted at 2016-10-31 14:18
Hi robrogkr!
Please can you sent me the file for the Phantom 3 pro. I have a mistake with my last up ...
You could try one of These
2016-10-31
saarela
Sweden
what am i doing wrong?
[00014143][01 00] Firmware upgrade finished successfully.
[00014255]Done.
[00014289]Packet [C:\P3X_FW_V01.10.0090.bin] resumed, card sn [0xa0ce6885].
[00014330]Packet vlink 01.10.0090 <-> 01.10.0090.
[00014396]Version checking[2]...
[00014441][03 05][00] v34.2.0.8 -> v34.2.0.9 need upgrade.
[00014501][03 06][00] v2.1.6.18 -> v2.4.20.28 need upgrade.
[00014553][04 00][00] v1.36.0.0 -> v1.48.0.0 need upgrade.
[00014640][11 00][00] v1.6.1.0 -> v1.8.0.0 need upgrade.
[00014744][11 01][00] v1.6.1.0 -> v2.0.0.33, firmware v1.6.1.0 not support.
[00014780][11 01][00] v1.6.1.0 -> v2.0.0.33
[00014859][12 00][00] v1.8.0.0 -> v1.11.0.0 need upgrade.
[00014955][12 01][00] v1.8.0.0 -> v1.11.0.0 need upgrade.
[00015034][12 02][00] v1.8.0.0 -> v1.11.0.0 need upgrade.
[00015115][12 03][00] v1.8.0.0 -> v1.11.0.0 need upgrade.
[00027664][15 00][00] device not detected.
[00027730][17 00][00] v1.1.1.2 -> v1.1.1.7 need upgrade.
[00027851][17 01][00] v1.0.2.4 -> v1.0.2.7 need upgrade.
[00027896][19 00][00] v1.0.8.96 -> v1.0.8.96
[00027927][01 00][05] v1.32.5432 -> v1.32.5432
[00027962][01 01][00] v1.6.2736 -> v1.32.5432 need upgrade
[00040510][08 00][00] device not detected.
[00040576][09 00][00] v1.7.0.3 -> v3.0.0.10 need upgrade.
[00040606]Done.
[00040640]Firmware upgrading[2]...
[00040783][01 01] Firmware upgrade start...
[00071048][01 01] Firmware upgrade finished successfully.
[00071112][12 00] Firmware upgrade start...
[00137017][12 00] Firmware upgrade finished successfully.
[00137065][12 01] Firmware upgrade start...
[00204296][12 01] Firmware upgrade finished successfully.
[00204353][12 02] Firmware upgrade start...
[00268790][12 02] Firmware upgrade finished successfully.
[00268843][12 03] Firmware upgrade start...
[00337448][12 03] Firmware upgrade finished successfully.
[00337512][17 00] Firmware upgrade start...
[00437489][17 00] Firmware upgrade finished successfully.
[00437539][17 01] Firmware upgrade start...
[00502053][17 01] Firmware upgrade finished successfully.
[00502191][11 00] Firmware upgrade start...
[00555453][11 00] Firmware upgrade finished successfully.
[00555500][03 05] Firmware upgrade start...
[00628787][03 05] Firmware upgrade finished successfully.
[00629046][03 06] Firmware upgrade start...
[00992127][03 06] Firmware upgrade finished successfully.
[00992192][09 00] Firmware upgrade start...
[01044275][09 00] Firmware upgrade finished successfully.
[01044347][04 00] Firmware upgrade start...
[01102859][04 00] Firmware upgrade finished successfully.
[01102901]Done.
[01102936]Version checking[3]...
[01103023][03 05][05] v34.2.0.9 -> v34.2.0.9
[01103103][03 06][05] v2.4.20.28 -> v2.4.20.28
[01103189][04 00][05] v1.48.0.0 -> v1.48.0.0
[01103322][11 00][05] v1.8.0.0 -> v1.8.0.0
[01103443][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[01103479][11 01][00] v1.8.0.0 -> v2.0.0.33
[01103568][12 00][05] v1.11.0.0 -> v1.11.0.0
[01103662][12 01][05] v1.11.0.0 -> v1.11.0.0
[01103749][12 02][05] v1.11.0.0 -> v1.11.0.0
[01103842][12 03][05] v1.11.0.0 -> v1.11.0.0
[01116385][15 00][00] device not detected.
[01116467][17 00][05] v1.1.1.7 -> v1.1.1.7
[01116608][17 01][05] v1.0.2.7 -> v1.0.2.7
[01116659][19 00][00] v1.0.8.96 -> v1.0.8.96
[01116694][01 00][05] v1.32.5432 -> v1.32.5432
[01116737][01 01][05] v1.32.5432 -> v1.32.5432
[01129271][08 00][00] device not detected.
[01129319][09 00][05] v3.0.0.10 -> v3.0.0.10
[01129354]Packet upgrade failed at version checking.
[00014452]========== remo-con disconnect. boot(15) ============
[00014486]Packet [C:\P3X_FW_V01.10.0090.bin] detected, card sn [0xa0ce6885].
[00014521]Packet upgrade start...
[00014559]Packet checking...
[00014600]Packet vlink 01.10.0090 <-> 01.10.0090.
[00014670]Done.
[00014705]Version checking[1]...
[00014774][03 05][00] v34.2.0.9 -> v34.2.0.9
[00014835][03 06][00] v2.4.20.28 -> v2.4.20.28
[00014877][04 00][00] v1.48.0.0 -> v1.48.0.0
[00014994][11 00][00] v1.8.0.0 -> v1.8.0.0
[00015195][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00015232][11 01][00] v1.8.0.0 -> v2.0.0.33
[00015319][12 00][00] v1.11.0.0 -> v1.11.0.0
[00015399][12 01][00] v1.11.0.0 -> v1.11.0.0
[00015494][12 02][00] v1.11.0.0 -> v1.11.0.0
[00015568][12 03][00] v1.11.0.0 -> v1.11.0.0
[00028111][15 00][00] device not detected.
[00028199][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028340][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028399][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028445][01 00][00] v1.32.5432 -> v1.32.5432
[00028482][01 01][00] v1.32.5432 -> v1.32.5432
[00041020][08 00][00] device not detected.
[00041081][09 00][00] v3.0.0.10 -> v3.0.0.10
[00041124]Packet upgrade failed at version checking.
[00012643]========== remo-con disconnect. boot(15) ============
[00012678]Packet [C:\P3X_FW_V01.10.0090.bin] detected, card sn [0xa0ce6885].
[00012715]Packet upgrade start...
[00012756]Packet checking...
[00012797]Packet vlink 01.10.0090 <-> 01.10.0090.
[00012867]Done.
[00012903]Version checking[1]...
[00012984][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013060][03 06][00] v2.4.20.28 -> v2.4.20.28
[00013101][04 00][00] v1.48.0.0 -> v1.48.0.0
[00013226][11 00][00] v1.8.0.0 -> v1.8.0.0
[00013345][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00013381][11 01][00] v1.8.0.0 -> v2.0.0.33
[00013472][12 00][00] v1.11.0.0 -> v1.11.0.0
[00013564][12 01][00] v1.11.0.0 -> v1.11.0.0
[00013652][12 02][00] v1.11.0.0 -> v1.11.0.0
[00013743][12 03][00] v1.11.0.0 -> v1.11.0.0
[00026280][15 00][00] device not detected.
[00026371][17 00][00] v1.1.1.7 -> v1.1.1.7
[00026487][17 01][00] v1.0.2.7 -> v1.0.2.7
[00026537][19 00][00] v1.0.8.96 -> v1.0.8.96
[00026572][01 00][00] v1.32.5432 -> v1.32.5432
[00026607][01 01][00] v1.32.5432 -> v1.32.5432
[00039154][08 00][00] device not detected.
[00039218][09 00][00] v3.0.0.10 -> v3.0.0.10
[00039257]Packet upgrade failed at version checking.
[00012481]========== remo-con disconnect. boot(15) ============
[00012590]Packet [C:\P3X_FW_V01.10.0090.bin] detected, card sn [0xa0ce6885].
[00012636]Packet upgrade start...
[00012678]Packet checking...
[00012715]Packet vlink 01.10.0090 <-> 01.10.0090.
[00012786]Done.
[00012822]Version checking[1]...
[00012895][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012975][03 06][00] v2.4.20.28 -> v2.4.20.28
[00013018][04 00][00] v1.48.0.0 -> v1.48.0.0
[00013135][11 00][00] v1.8.0.0 -> v1.8.0.0
[00013235][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00013276][11 01][00] v1.8.0.0 -> v2.0.0.33
[00013349][12 00][00] v1.11.0.0 -> v1.11.0.0
[00013434][12 01][00] v1.11.0.0 -> v1.11.0.0
[00013504][12 02][00] v1.11.0.0 -> v1.11.0.0
[00013599][12 03][00] v1.11.0.0 -> v1.11.0.0
[00026141][15 00][00] device not detected.
[00026227][17 00][00] v1.1.1.7 -> v1.1.1.7
[00026349][17 01][00] v1.0.2.7 -> v1.0.2.7
[00026403][19 00][00] v1.0.8.96 -> v1.0.8.96
[00026450][01 00][00] v1.32.5432 -> v1.32.5432
[00026486][01 01][00] v1.32.5432 -> v1.32.5432
[00039024][08 00][00] device not detected.
[00039087][09 00][00] v3.0.0.10 -> v3.0.0.10
[00039129]Packet upgrade failed at version checking.
[00014490]========== 2017.03.24 23:16:10. boot(15) ============
[00014526]Packet [C:\P3X_FW_V01.10.0090.bin] detected, card sn [0xa0ce6885].
[00014563]Packet upgrade start...
[00014607]Packet checking...
[00014648]Packet vlink 01.10.0090 <-> 01.10.0090.
[00014716]Done.
[00014755]Version checking[1]...
[00014832][03 05][00] v34.2.0.9 -> v34.2.0.9
[00014914][03 06][00] v2.4.20.28 -> v2.4.20.28
[00014963][04 00][00] v1.48.0.0 -> v1.48.0.0
[00015072][11 00][00] v1.8.0.0 -> v1.8.0.0
[00015192][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00015315][12 00][00] v1.11.0.0 -> v1.11.0.0
[00015401][12 01][00] v1.11.0.0 -> v1.11.0.0
[00015497][12 02][00] v1.11.0.0 -> v1.11.0.0
[00015576][12 03][00] v1.11.0.0 -> v1.11.0.0
[00028116][15 00][00] device not detected.
[00028296][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028421][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028495][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028535][01 00][00] v1.32.5432 -> v1.32.5432
[00028573][01 01][00] v1.32.5432 -> v1.32.5432
[00041128][08 00][00] device not detected.
[00041196][09 00][00] v3.0.0.10 -> v3.0.0.10
[00041237]Packet upgrade failed at version checking.
[00052494]========== 2017.03.24 23:18:58. boot(15) ============
[00052531]Packet [C:\P3X_FW_V01.10.0090.bin] detected, card sn [0xa0ce6885].
[00052570]Packet upgrade start...
[00052611]Packet checking...
[00052657]Packet vlink 01.10.0090 <-> 01.10.0090.
[00052725]Done.
[00052764]Version checking[1]...
[00052837][03 05][00] v34.2.0.9 -> v34.2.0.9
[00052917][03 06][00] v2.4.20.28 -> v2.4.20.28
[00052967][04 00][00] v1.48.0.0 -> v1.48.0.0
[00053077][11 00][00] v1.8.0.0 -> v1.8.0.0
[00053197][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00053235][11 01][00] v1.8.0.0 -> v2.0.0.33
[00053329][12 00][00] v1.11.0.0 -> v1.11.0.0
[00053406][12 01][00] v1.11.0.0 -> v1.11.0.0
[00053486][12 02][00] v1.11.0.0 -> v1.11.0.0
[00053577][12 03][00] v1.11.0.0 -> v1.11.0.0
[00066114][15 00][00] device not detected.
[00066202][17 00][00] v1.1.1.7 -> v1.1.1.7
[00066343][17 01][00] v1.0.2.7 -> v1.0.2.7
[00066402][19 00][00] v1.0.8.96 -> v1.0.8.96
[00066442][01 00][00] v1.32.5432 -> v1.32.5432
[00066483][01 01][00] v1.32.5432 -> v1.32.5432
[00079021][08 00][00] device not detected.
[00079083][09 00][00] v3.0.0.10 -> v3.0.0.10
[00079121]Packet upgrade failed at version checking.
[00012597]========== remo-con disconnect. boot(15) ============
[00012638]Packet [C:\P3X_FW_V01.10.0090.bin] detected, card sn [0xa0ce6885].
[00012678]Packet upgrade start...
[00012734]Packet checking...
[00012773]Packet vlink 01.10.0090 <-> 01.10.0090.
[00012842]Done.
[00012882]Version checking[1]...
[00012960][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013039][03 06][00] v2.4.20.28 -> v2.4.20.28
[00013166][04 00][00] v1.48.0.0 -> v1.48.0.0
[00013279][11 00][00] v1.8.0.0 -> v1.8.0.0
[00013419][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00013467][11 01][00] v1.8.0.0 -> v2.0.0.33
[00013542][12 00][00] v1.11.0.0 -> v1.11.0.0
[00013638][12 01][00] v1.11.0.0 -> v1.11.0.0
[00013712][12 02][00] v1.11.0.0 -> v1.11.0.0
[00013818][12 03][00] v1.11.0.0 -> v1.11.0.0
[00026363][15 00][00] device not detected.
[00026444][17 00][00] v1.1.1.7 -> v1.1.1.7
[00026564][17 01][00] v1.0.2.7 -> v1.0.2.7
[00026629][19 00][00] v1.0.8.96 -> v1.0.8.96
[00026679][01 00][00] v1.32.5432 -> v1.32.5432
[00026721][01 01][00] v1.32.5432 -> v1.32.5432
[00039262][08 00][00] device not detected.
[00039329][09 00][00] v3.0.0.10 -> v3.0.0.10
[00039371]Packet upgrade failed at version checking.
[00012581]========== remo-con disconnect. boot(15) ============
[00012623]Packet [C:\P3X_FW_V01.09.0060.bin] detected, card sn [0xda7063b0].
[00012666]Packet upgrade start...
[00012720]Packet checking...
[00012765]Packet vlink 01.09.0060 <-> 01.08.0080.
[00012837]Done.
[00012880]Version checking[1]...
[00013083][03 06][00] v2.4.20.28 -> v2.4.20.18
[00013142][04 00][00] v1.48.0.0 -> v1.44.0.0
[00013264][11 00][00] v1.8.0.0 -> v1.8.0.0
[00013383][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00013427][11 01][00] v1.8.0.0 -> v2.0.0.33
[00013512][12 00][00] v1.11.0.0 -> v1.10.0.0
[00013612][12 01][00] v1.11.0.0 -> v1.10.0.0
[00013711][12 02][00] v1.11.0.0 -> v1.10.0.0
[00013816][12 03][00] v1.11.0.0 -> v1.10.0.0
[00026375][15 00][00] device not detected.
[00026468][17 00][00] v1.1.1.7 -> v1.1.1.7
[00026592][17 01][00] v1.0.2.7 -> v1.0.2.7
[00026664][19 00][00] v1.0.8.96 -> v1.0.8.96
[00026709][01 00][00] v1.32.5432 -> v1.30.5036
[00026753][01 01][00] v1.32.5432 -> v1.30.5036
[00039296][08 00][00] device not detected.
[00039373][09 00][00] v3.0.0.10 -> v3.0.0.10
[00039512]Packet upgrade failed at version checking.
[00012539]========== remo-con disconnect. boot(15) ============
[00012580]Packet [C:\P3X_FW_V01.09.0060.bin] detected, card sn [0xda7063b0].
[00012629]Packet upgrade start...
[00012676]Packet checking...
[00012717]Packet vlink 01.09.0060 <-> 01.08.0080.
[00012797]Done.
[00012841]Version checking[1]...
[00012909][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012989][03 06][00] v2.4.20.28 -> v2.4.20.18
[00013043][04 00][00] v1.48.0.0 -> v1.44.0.0
[00013169][11 00][00] v1.8.0.0 -> v1.8.0.0
[00013269][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00013309][11 01][00] v1.8.0.0 -> v2.0.0.33
[00013402][12 00][00] v1.11.0.0 -> v1.10.0.0
[00013478][12 01][00] v1.11.0.0 -> v1.10.0.0
[00013559][12 02][00] v1.11.0.0 -> v1.10.0.0
[00013649][12 03][00] v1.11.0.0 -> v1.10.0.0
[00026195][15 00][00] device not detected.
[00026301][17 00][00] v1.1.1.7 -> v1.1.1.7
[00026419][17 01][00] v1.0.2.7 -> v1.0.2.7
[00026501][19 00][00] v1.0.8.96 -> v1.0.8.96
[00026543][01 00][00] v1.32.5432 -> v1.30.5036
[00026586][01 01][00] v1.32.5432 -> v1.30.5036
[00039139][08 00][00] device not detected.
[00039198][09 00][00] v3.0.0.10 -> v3.0.0.10
[00039243]Packet upgrade failed at version checking.
[00012540]========== 2017.03.25 00:17:10. boot(15) ============
[00012586]Packet [C:\P3X_FW_V01.09.0060.bin] detected, card sn [0xda7063b0].
[00012632]Packet upgrade start...
[00012679]Packet checking...
[00012721]Packet vlink 01.09.0060 <-> 01.08.0080.
[00012800]Done.
[00012844]Version checking[1]...
[00012933][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013013][03 06][00] v2.4.20.28 -> v2.4.20.18
[00013069][04 00][00] v1.48.0.0 -> v1.44.0.0
[00013193][11 00][00] v1.8.0.0 -> v1.8.0.0
[00013339][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00013502][12 00][00] v1.11.0.0 -> v1.10.0.0
[00013613][12 01][00] v1.11.0.0 -> v1.10.0.0
[00013799][12 02][00] v1.11.0.0 -> v1.10.0.0
[00013903][12 03][00] v1.11.0.0 -> v1.10.0.0
[00026447][15 00][00] device not detected.
[00026537][17 00][00] v1.1.1.7 -> v1.1.1.7
[00026679][17 01][00] v1.0.2.7 -> v1.0.2.7
[00026750][19 00][00] v1.0.8.96 -> v1.0.8.96
[00026794][01 00][00] v1.32.5432 -> v1.30.5036
[00026841][01 01][00] v1.32.5432 -> v1.30.5036
[00039388][08 00][00] device not detected.
[00039470][09 00][00] v3.0.0.10 -> v3.0.0.10
[00012607]========== remo-con disconnect. boot(15) ============
[00012645]Packet [C:\P3X_FW_V01.10.0090.bin] detected, card sn [0xa0ce6885].
[00012693]Packet upgrade start...
[00012740]Packet checking...
[00012779]Packet vlink 01.10.0090 <-> 01.10.0090.
[00012852]Done.
[00012893]Version checking[1]...
[00012980][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013107][04 00][00] v1.48.0.0 -> v1.48.0.0
[00013220][11 00][00] v1.8.0.0 -> v1.8.0.0
[00013388][11 01][00] v1.8.0.0 -> v2.0.0.33
[00013468][12 00][00] v1.11.0.0 -> v1.11.0.0
[00013548][12 01][00] v1.11.0.0 -> v1.11.0.0
[00013640][12 02][00] v1.11.0.0 -> v1.11.0.0
[00013729][12 03][00] v1.11.0.0 -> v1.11.0.0
[00026274][15 00][00] device not detected.
[00026368][17 00][00] v1.1.1.7 -> v1.1.1.7
[00026485][17 01][00] v1.0.2.7 -> v1.0.2.7
[00026564][19 00][00] v1.0.8.96 -> v1.0.8.96
[00026608][01 00][00] v1.32.5432 -> v1.32.5432
[00026650][01 01][00] v1.32.5432 -> v1.32.5432
[00039196][08 00][00] device not detected.
[00039265][09 00][00] v3.0.0.10 -> v3.0.0.10
[00039303]Packet upgrade failed at version checking.
[00015078]========== 2017.03.25 00:50:17. boot(15) ============
[00015123]Packet [C:\P3X_FW_V01.10.0090.bin] detected, card sn [0xa0ce6885].
[00015164]Packet upgrade start...
[00015213]Packet checking...
[00015265]Packet vlink 01.10.0090 <-> 01.10.0090.
[00015430]Done.
[00015472]Version checking[1]...
[00015567][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015667][03 06][00] v2.4.20.28 -> v2.4.20.28
[00015714][04 00][00] v1.48.0.0 -> v1.48.0.0
[00015867][11 00][00] v1.8.0.0 -> v1.8.0.0
[00015987][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00016032][11 01][00] v1.8.0.0 -> v2.0.0.33
[00016130][12 00][00] v1.11.0.0 -> v1.11.0.0
[00016238][12 01][00] v1.11.0.0 -> v1.11.0.0
[00016337][12 02][00] v1.11.0.0 -> v1.11.0.0
[00016436][12 03][00] v1.11.0.0 -> v1.11.0.0
[00028976][15 00][00] device not detected.
[00029070][17 00][00] v1.1.1.7 -> v1.1.1.7
[00029212][17 01][00] v1.0.2.7 -> v1.0.2.7
[00029278][19 00][00] v1.0.8.96 -> v1.0.8.96
[00029320][01 00][00] v1.32.5432 -> v1.32.5432
[00029363][01 01][00] v1.32.5432 -> v1.32.5432
[00041908][08 00][00] device not detected.
[00041969][09 00][00] v3.0.0.10 -> v3.0.0.10
[00042011]Packet upgrade failed at version checking.
[00012609]========== remo-con disconnect. boot(15) ============
[00012651]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0xa0ce6885].
[00012698]Packet upgrade start...
[00012745]Packet checking...
[00012787]Packet vlink 01.03.0020 <-> 01.01.0009.
[00012866]Done.
[00012908]Version checking[1]...
[00013001][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013079][03 06][00] v2.4.20.28 -> v2.2.6.19
[00013129][04 00][00] v1.48.0.0 -> v1.40.0.0
[00013203][09 00][00] v3.0.0.10 -> v1.7.0.3
[00013335][11 00][00] v1.8.0.0 -> v1.7.0.0
[00013439][12 00][00] v1.11.0.0 -> v1.8.0.0
[00013529][12 01][00] v1.11.0.0 -> v1.8.0.0
[00013619][12 02][00] v1.11.0.0 -> v1.8.0.0
[00013707][12 03][00] v1.11.0.0 -> v1.8.0.0
[00026248][15 00][00] device not detected.
[00026345][17 00][00] v1.1.1.7 -> v1.1.1.7
[00026464][17 01][00] v1.0.2.7 -> v1.0.2.7
[00026523][19 00][00] v1.0.8.96 -> v1.0.8.96
[00026568][01 00][00] v1.32.5432 -> v1.23.3419
[00026611][01 01][00] v1.32.5432 -> v1.23.3419
[00039272]Packet upgrade failed at version checking.
[00014724]========== remo-con disconnect. boot(15) ============
[00014764]Packet [C:\P3X_FW_V01.10.0090.bin] detected, card sn [0xa0ce6885].
[00014811]Packet upgrade start...
[00014860]Packet checking...
[00014902]Packet vlink 01.10.0090 <-> 01.10.0090.
[00014971]Done.
[00015013]Version checking[1]...
[00015101][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015183][03 06][00] v2.4.20.28 -> v2.4.20.28
[00015242][04 00][00] v1.48.0.0 -> v1.48.0.0
[00015361][11 00][00] v1.8.0.0 -> v1.8.0.0
[00015482][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00015523][11 01][00] v1.8.0.0 -> v2.0.0.33
[00015612][12 00][00] v1.11.0.0 -> v1.11.0.0
[00015711][12 01][00] v1.11.0.0 -> v1.11.0.0
[00015795][12 02][00] v1.11.0.0 -> v1.11.0.0
[00015891][12 03][00] v1.11.0.0 -> v1.11.0.0
[00028436][15 00][00] device not detected.
[00028528][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028647][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028707][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028749][01 00][00] v1.32.5432 -> v1.32.5432
[00028789][01 01][00] v1.32.5432 -> v1.32.5432
[00041341][08 00][00] device not detected.
[00041407][09 00][00] v3.0.0.10 -> v3.0.0.10
[00041454]Packet upgrade failed at version checking.
[00012550]========== remo-con disconnect. boot(15) ============
[00012598]Packet [C:\P3X_FW_V01.10.0090.bin] detected, card sn [0xa0ce6885].
[00012642]Packet upgrade start...
[00012693]Packet checking...
[00012737]Packet vlink 01.10.0090 <-> 01.10.0090.
[00012813]Done.
[00012860]Version checking[1]...
[00025405][03 05][00] device not detected.
[00037956][03 06][00] device not detected.
[00038011][04 00][00] v1.48.0.0 -> v1.48.0.0
[00050559][11 00][00] device not detected.
[00063102][11 01][00] device not detected.
[00075660][12 00][00] device not detected.
[00088203][12 01][00] device not detected.
[00100749][12 02][00] device not detected.
[00113293][12 03][00] device not detected.
[00125939][15 00][00] device not detected.
[00138485][17 00][00] device not detected.
[00151032][17 01][00] device not detected.
[00163582][19 00][00] device not detected.
[00163627][01 00][00] v1.32.5432 -> v1.32.5432
[00163671][01 01][00] v1.32.5432 -> v1.32.5432
[00176215][08 00][00] device not detected.
[00176311][09 00][00] v0.0.0.0 -> v3.0.0.10 need upgrade.
[00176357]Done.
[00178400]Waiting for user confirm...
[00188452]Timeout, start upgrade automatically.
[00188541]Firmware upgrading[1]...
[00188615][09 00] Firmware upgrade start...
[00240454][09 00] Firmware upgrade finished successfully.
[00240504]Done.
[00240549]Version checking[2]...
[00240633][03 05][00] v34.2.0.9 -> v34.2.0.9
[00240713][03 06][00] v2.4.20.28 -> v2.4.20.28
[00240768][04 00][00] v1.48.0.0 -> v1.48.0.0
[00240894][11 00][00] v1.8.0.0 -> v1.8.0.0
[00241011][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00241057][11 01][00] v1.8.0.0 -> v2.0.0.33
[00241140][12 00][00] v1.11.0.0 -> v1.11.0.0
[00241245][12 01][00] v1.11.0.0 -> v1.11.0.0
[00241345][12 02][00] v1.11.0.0 -> v1.11.0.0
[00241445][12 03][00] v1.11.0.0 -> v1.11.0.0
[00254005][15 00][00] device not detected.
[00254102][17 00][00] v1.1.1.7 -> v1.1.1.7
[00254240][17 01][00] v1.0.2.7 -> v1.0.2.7
[00254312][19 00][00] v1.0.8.96 -> v1.0.8.96
[00254358][01 00][00] v1.32.5432 -> v1.32.5432
[00254404][01 01][00] v1.32.5432 -> v1.32.5432
[00266952][08 00][00] device not detected.
[00267020][09 00][05] v3.0.0.10 -> v3.0.0.10
[00267064]Packet upgrade failed at version checking.
[00014846]========== remo-con disconnect. boot(15) ============
[00014890]Packet [C:\P3X_FW_V01.10.0090.bin] detected, card sn [0xa0ce6885].
[00014939]Packet upgrade start...
[00014988]Packet checking...
[00015038]Packet vlink 01.10.0090 <-> 01.10.0090.
[00015112]Done.
[00015159]Version checking[1]...
[00015240][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015320][03 06][00] v2.4.20.28 -> v2.4.20.28
[00015472][04 00][00] v1.48.0.0 -> v1.48.0.0
[00015582][11 00][00] v1.8.0.0 -> v1.8.0.0
[00015700][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00015745][11 01][00] v1.8.0.0 -> v2.0.0.33
[00015834][12 00][00] v1.11.0.0 -> v1.11.0.0
[00015936][12 01][00] v1.11.0.0 -> v1.11.0.0
[00016034][12 02][00] v1.11.0.0 -> v1.11.0.0
[00016110][12 03][00] v1.11.0.0 -> v1.11.0.0
[00028655][15 00][00] device not detected.
[00028752][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028877][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028930][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028980][01 00][00] v1.32.5432 -> v1.32.5432
[00029030][01 01][00] v1.32.5432 -> v1.32.5432
[00041579][08 00][00] device not detected.
[00041671][09 00][00] v3.0.0.10 -> v3.0.0.10
[00041715]Packet upgrade failed at version checking.
[00012729]========== remo-con disconnect. boot(15) ============
[00012777]Packet [C:\P3X_FW_V01.10.0090.bin] detected, card sn [0xda7063b0].
[00012821]Packet upgrade start...
[00012873]Packet checking...
[00012918]Packet vlink 01.10.0090 <-> 01.10.0090.
[00013000]Done.
[00013046]Version checking[1]...
[00025589][03 05][00] device not detected.
[00038144][03 06][00] device not detected.
[00038199][04 00][00] v1.48.0.0 -> v1.48.0.0
[00050745][11 00][00] device not detected.
[00063288][11 01][00] device not detected.
[00075835][12 00][00] device not detected.
[00088376][12 01][00] device not detected.
[00100919][12 02][00] device not detected.
[00113463][12 03][00] device not detected.
[00126010][15 00][00] device not detected.
[00138560][17 00][00] device not detected.
[00151103][17 01][00] device not detected.
[00163646][19 00][00] device not detected.
[00163689][01 00][00] v1.32.5432 -> v1.32.5432
[00163734][01 01][00] v1.32.5432 -> v1.32.5432
[00176287][08 00][00] device not detected.
[00176364][09 00][00] v0.0.0.0 -> v3.0.0.10 need upgrade.
[00176407]Done.
[00178462]Waiting for user confirm...
[00188505]Timeout, start upgrade automatically.
[00188680]Firmware upgrading[1]...
[00188751][09 00] Firmware upgrade start...
[00240610][09 00] Firmware upgrade finished successfully.
[00240663]Done.
[00240706]Version checking[2]...
[00240788][03 05][00] v34.2.0.9 -> v34.2.0.9
[00240888][03 06][00] v2.4.20.28 -> v2.4.20.28
[00240945][04 00][00] v1.48.0.0 -> v1.48.0.0
[00241088][11 00][00] v1.8.0.0 -> v1.8.0.0
[00241227][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00241271][11 01][00] v1.8.0.0 -> v2.0.0.33
[00241376][12 00][00] v1.11.0.0 -> v1.11.0.0
[00241476][12 01][00] v1.11.0.0 -> v1.11.0.0
[00241607][12 02][00] v1.11.0.0 -> v1.11.0.0
[00241716][12 03][00] v1.11.0.0 -> v1.11.0.0
[00254268][15 00][00] device not detected.
[00254356][17 00][00] v1.1.1.7 -> v1.1.1.7
[00254491][17 01][00] v1.0.2.7 -> v1.0.2.7
[00254562][19 00][00] v1.0.8.96 -> v1.0.8.96
[00254607][01 00][00] v1.32.5432 -> v1.32.5432
[00254653][01 01][00] v1.32.5432 -> v1.32.5432
[00267214][08 00][00] device not detected.
[00267282][09 00][05] v3.0.0.10 -> v3.0.0.10
[00267327]Packet upgrade failed at version checking.
2017-3-25
Pgregory
Help???  [00014998]Delete history success.  [00015202]========== remo-con disconnect. boot(15) ============  [00015241]Packet [C:\P3X_FW_V01.02.0006.bin] detected, card sn [0x90ce1efb].  [00015282]Packet upgrade start...  [00015337]Packet checking...  [00015377]Packet vlink 01.01.0000 <-> 01.01.0000.  [00015415]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 6).  [00015456]Packet upgrade failed at packet checking.  [00015000]========== remo-con disconnect. boot(15) ============  [00015040]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x90ce1efb].  [00015079]Packet upgrade start...  [00015126]Packet checking...  [00015166]Packet vlink 01.03.0020 <-> 01.01.0009.  [00015205]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 1).  [00015254]Done.  [00015292]Version checking[1]...  [00015373][03 05][00] v34.2.0.9 -> v34.2.0.9  [00015455][03 06][00] v2.4.20.28 -> v2.2.6.19 need upgrade.  [00015496][04 00][00] v1.48.0.0 -> v1.40.0.0  [00015547][09 00][00] v3.0.0.10 -> v1.7.0.3  [00015674][11 00][00] v1.8.0.0 -> v1.7.0.0  [00015761][12 00][00] v1.11.0.0 -> v1.8.0.0  [00015868][12 01][00] v1.11.0.0 -> v1.8.0.0  [00015968][12 02][00] v1.11.0.0 -> v1.8.0.0  [00016067][12 03][00] v1.11.0.0 -> v1.8.0.0  [00028612][15 00][00] device not detected.  [00028720][17 00][00] v1.1.1.7 -> v1.1.1.7  [00028863][17 01][00] v1.0.2.7 -> v1.0.2.7  [00028929][19 00][00] v1.0.8.96 -> v1.0.8.96  [00028968][01 00][00] v1.32.5432 -> v1.23.3419 need upgrade  [00029004][01 01][00] v1.32.5432 -> v1.23.3419 need upgrade  [00041548][08 00][00] device not detected.  [00041584]Done.  [00043628]Waiting for user confirm...  [00053665]Timeout, start upgrade automatically.  [00053743]Firmware upgrading[1]...  [00053900][01 01] Firmware upgrade start...  [00014479]========== remo-con disconnect. boot(15) ============  [00014520]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x90ce1efb].  [00014559]Packet upgrade start...  [00014602]Packet checking...  [00014645]Packet vlink 01.03.0020 <-> 01.01.0009.  [00014770]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 1).  [00014808]Done.  [00014851]Version checking[1]...  [00014920][03 05][00] v34.2.0.9 -> v34.2.0.9  [00014999][03 06][00] v2.4.20.28 -> v2.2.6.19 need upgrade.  [00015052][04 00][00] v1.48.0.0 -> v1.40.0.0  [00015108][09 00][00] v3.0.0.10 -> v1.7.0.3  [00015224][11 00][00] v1.8.0.0 -> v1.7.0.0  [00015313][12 00][00] v1.11.0.0 -> v1.8.0.0  [00015393][12 01][00] v1.11.0.0 -> v1.8.0.0  [00015469][12 02][00] v1.11.0.0 -> v1.8.0.0  [00015549][12 03][00] v1.11.0.0 -> v1.8.0.0  [00028090][15 00][00] device not detected.  [00028165][17 00][00] v1.1.1.7 -> v1.1.1.7  [00028294][17 01][00] v1.0.2.7 -> v1.0.2.7  [00028350][19 00][00] v1.0.8.96 -> v1.0.8.96  [00028391][01 00][00] v1.32.5432 -> v1.23.3419 need upgrade  [00028430][01 01][00] v1.23.3419 -> v1.23.3419  [00040971][08 00][00] device not detected.  [00041007]Done.  [00043050]Waiting for user confirm...  [00053089]Timeout, start upgrade automatically.  [00053169]Firmware upgrading[1]...  [00053412][03 06] Firmware upgrade start...  [00370595][03 06] Firmware upgrade finished successfully.  [00370636]Done.  [00370676]Version checking[2]...  [00370741][03 05][00] v34.2.0.9 -> v34.2.0.9  [00370806][03 06][05] v2.2.6.19 -> v2.2.6.19  [00370859][04 00][00] v1.48.0.0 -> v1.40.0.0  [00370931][09 00][00] v3.0.0.10 -> v1.7.0.3  [00371041][11 00][00] v1.8.0.0 -> v1.7.0.0  [00371115][12 00][00] v1.11.0.0 -> v1.8.0.0  [00371191][12 01][00] v1.11.0.0 -> v1.8.0.0  [00371290][12 02][00] v1.11.0.0 -> v1.8.0.0  [00371380][12 03][00] v1.11.0.0 -> v1.8.0.0  [00383933][15 00][00] device not detected.  [00384006][17 00][00] v1.1.1.7 -> v1.1.1.7  [00384126][17 01][00] v1.0.2.7 -> v1.0.2.7  [00384191][19 00][00] v1.0.8.96 -> v1.0.8.96  [00384237][01 00][00] v1.32.5432 -> v1.23.3419 need upgrade  [00384277][01 01][00] v1.23.3419 -> v1.23.3419  [00396818][08 00][00] device not detected.  [00396859]Packet upgrade failed at version checking.  [00150594]========== 2017.04.08 14:09:27. boot(15) ============  [00150739]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x90ce1efb].  [00150782]Packet upgrade start...  [00150827]Packet checking...  [00150868]Packet vlink 01.03.0020 <-> 01.01.0009.  [00150909]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 1).  [00150949]Done.  [00150990]Version checking[1]...  [00151068][03 05][00] v34.2.0.9 -> v34.2.0.9  [00151148][03 06][00] v2.2.6.19 -> v2.2.6.19  [00151192][04 00][00] v1.48.0.0 -> v1.40.0.0  [00151258][09 00][00] v3.0.0.10 -> v1.7.0.3  [00014592]========== remo-con disconnect. boot(15) ============  [00014633]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x90ce1efb].  [00014671]Packet upgrade start...  [00014713]Packet checking...  [00014757]Packet vlink 01.03.0020 <-> 01.01.0009.  [00014797]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 1).  [00014838]Done.  [00014882]Version checking[1]...  [00014952][03 05][00] v34.2.0.9 -> v34.2.0.9  [00015032][03 06][00] v2.2.6.19 -> v2.2.6.19  [00015078][04 00][00] v1.48.0.0 -> v1.40.0.0  [00015139][09 00][00] v3.0.0.10 -> v1.7.0.3  [00015252][11 00][00] v1.8.0.0 -> v1.7.0.0  [00015342][12 00][00] v1.11.0.0 -> v1.8.0.0  [00015432][12 01][00] v1.11.0.0 -> v1.8.0.0  [00015532][12 02][00] v1.11.0.0 -> v1.8.0.0  [00015618][12 03][00] v1.11.0.0 -> v1.8.0.0  [00028155][15 00][00] device not detected.  [00028243][17 00][00] v1.1.1.7 -> v1.1.1.7  [00028359][17 01][00] v1.0.2.7 -> v1.0.2.7  [00028419][19 00][00] v1.0.8.96 -> v1.0.8.96  [00028459][01 00][00] v1.32.5432 -> v1.23.3419 need upgrade  [00028500][01 01][00] v1.23.3419 -> v1.23.3419  [00041039][08 00][00] device not detected.  [00041078]Packet upgrade failed at version checking.  [00014492]========== remo-con disconnect. boot(15) ============  [00014532]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x90ce1efb].  [00014571]Packet upgrade start...  [00014614]Packet checking...  [00014658]Packet vlink 01.03.0020 <-> 01.01.0009.  [00014696]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 1).  [00014820]Done.  [00014858]Version checking[1]...  [00014918][03 05][00] v34.2.0.9 -> v34.2.0.9  [00014977][03 06][00] v2.2.6.19 -> v2.2.6.19  [00015022][04 00][00] v1.48.0.0 -> v1.40.0.0  [00015087][09 00][00] v3.0.0.10 -> v1.7.0.3  [00015220][11 00][00] v1.8.0.0 -> v1.7.0.0  [00015317][12 00][00] v1.11.0.0 -> v1.8.0.0  [00015420][12 01][00] v1.11.0.0 -> v1.8.0.0  [00015518][12 02][00] v1.11.0.0 -> v1.8.0.0  [00015593][12 03][00] v1.11.0.0 -> v1.8.0.0  [00028142][15 00][00] device not detected.  [00028225][17 00][00] v1.1.1.7 -> v1.1.1.7  [00028343][17 01][00] v1.0.2.7 -> v1.0.2.7  [00028408][19 00][00] v1.0.8.96 -> v1.0.8.96  [00028452][01 00][00] v1.32.5432 -> v1.23.3419 need upgrade  [00028488][01 01][00] v1.23.3419 -> v1.23.3419  [00041030][08 00][00] device not detected.  [00041067]Packet upgrade failed at version checking.  [00014629]========== 2017.04.08 14:14:31. boot(15) ============  [00014670]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x90ce1efb].  [00014709]Packet upgrade start...  [00014757]Packet checking...  [00014797]Packet vlink 01.03.0020 <-> 01.01.0009.  [00014837]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 1).  [00014882]Done.  [00014919]Version checking[1]...  [00014996][03 05][00] v34.2.0.9 -> v34.2.0.9  [00015076][03 06][00] v2.2.6.19 -> v2.2.6.19  [00015123][04 00][00] v1.48.0.0 -> v1.40.0.0  [00015187][09 00][00] v3.0.0.10 -> v1.7.0.3  [00015297][11 00][00] v1.8.0.0 -> v1.7.0.0  [00015412][12 00][00] v1.11.0.0 -> v1.8.0.0  [00015486][12 01][00] v1.11.0.0 -> v1.8.0.0  [00015577][12 02][00] v1.11.0.0 -> v1.8.0.0  [00015652][12 03][00] v1.11.0.0 -> v1.8.0.0  [00028188][15 00][00] device not detected.  [00028263][17 00][00] v1.1.1.7 -> v1.1.1.7  [00028389][17 01][00] v1.0.2.7 -> v1.0.2.7  [00028450][19 00][00] v1.0.8.96 -> v1.0.8.96  [00028487][01 00][00] v1.32.5432 -> v1.23.3419 need upgrade  [00028527][01 01][00] v1.23.3419 -> v1.23.3419  [00041069][08 00][00] device not detected.  [00041109]Packet upgrade failed at version checking.  [00015010]========== remo-con disconnect. boot(15) ============  [00015054]Packet [C:\P3X_FW_V01.10.0090.bin] detected, card sn [0x90ce1efb].  [00015095]Packet upgrade start...  [00015141]Packet checking...  [00015182]Packet vlink 01.10.0090 <-> 01.10.0090.  [00015232]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).  [00015273]Done.  [00015309]Version checking[1]...  [00015392][03 05][00] v34.2.0.9 -> v34.2.0.9  [00015465][03 06][00] v2.2.6.19 -> v2.4.20.28 need upgrade.  [00015512][04 00][00] v1.48.0.0 -> v1.48.0.0  [00015627][11 00][00] v1.8.0.0 -> v1.8.0.0  [00015746][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.  [00015785][11 01][00] v1.8.0.0 -> v2.0.0.33  [00015900][12 00][00] v1.11.0.0 -> v1.11.0.0  [00016000][12 01][00] v1.11.0.0 -> v1.11.0.0  [00016100][12 02][00] v1.11.0.0 -> v1.11.0.0  [00016200][12 03][00] v1.11.0.0 -> v1.11.0.0  [00028744][15 00][00] device not detected.  [00028836][17 00][00] v1.1.1.7 -> v1.1.1.7  [00028955][17 01][00] v1.0.2.7 -> v1.0.2.7  [00029006][19 00][00] v1.0.8.96 -> v1.0.8.96  [00029048][01 00][00] v1.32.5432 -> v1.32.5432  [00029088][01 01][00] v1.23.3419 -> v1.32.5432 need upgrade  [00041635][08 00][00] device not detected.  [00041706][09 00][00] v3.0.0.10 -> v3.0.0.10  [00041747]Done.  [00043788]Waiting for user confirm...  [00053836]Timeout, start upgrade automatically.  [00053914]Firmware upgrading[1]...  [00054067][01 01] Firmware upgrade start...  [00084327][01 01] Firmware upgrade finished successfully.  [00084599][03 06] Firmware upgrade start...  [00465716][03 06] Firmware upgrade finished successfully.  [00465759]Done.  [00465797]Version checking[2]...  [00465881][03 05][00] v34.2.0.9 -> v34.2.0.9  [00465980][03 06][05] v2.4.20.28 -> v2.4.20.28  [00466039][04 00][00] v1.48.0.0 -> v1.48.0.0  [00466159][11 00][00] v1.8.0.0 -> v1.8.0.0  [00466283][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.  [00466322][11 01][00] v1.8.0.0 -> v2.0.0.33  [00466628][12 00][00] v1.11.0.0 -> v1.11.0.0  [00466759][12 01][00] v1.11.0.0 -> v1.11.0.0  [00466888][12 02][00] v1.11.0.0 -> v1.11.0.0  [00467021][12 03][00] v1.11.0.0 -> v1.11.0.0  [00479589][15 00][00] device not detected.  [00479704][17 00][00] v1.1.1.7 -> v1.1.1.7  [00479864][17 01][00] v1.0.2.7 -> v1.0.2.7  [00479956][19 00][00] v1.0.8.96 -> v1.0.8.96  [00480017][01 00][00] v1.32.5432 -> v1.32.5432  [00480077][01 01][05] v1.32.5432 -> v1.32.5432  [00492641][08 00][00] device not detected.  [00492716][09 00][00] v3.0.0.10 -> v3.0.0.10  [00492774]Packet upgrade failed at version checking.  [00015527]========== remo-con disconnect. boot(15) ============  [00015589]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x90ce1efb].  [00015658]Packet upgrade start...  [00015726]Packet checking...  [00015789]Packet vlink 01.03.0020 <-> 01.01.0009.  [00015855]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 1).  [00015915]Done.  [00015976]Version checking[1]...  [00016092][03 05][00] v34.2.0.9 -> v34.2.0.9  [00016191][03 06][00] v2.4.20.28 -> v2.2.6.19 need upgrade.  [00016275][04 00][00] v1.48.0.0 -> v1.40.0.0  [00016350][09 00][00] v3.0.0.10 -> v1.7.0.3  [00016491][11 00][00] v1.8.0.0 -> v1.7.0.0  [00016599][12 00][00] v1.11.0.0 -> v1.8.0.0  [00016723][12 01][00] v1.11.0.0 -> v1.8.0.0  [00016840][12 02][00] v1.11.0.0 -> v1.8.0.0  [00016946][12 03][00] v1.11.0.0 -> v1.8.0.0 [00029525][15 00][00] device not detected. [00029634][17 00][00] v1.1.1.7 -> v1.1.1.7 [00029779][17 01][00] v1.0.2.7 -> v1.0.2.7 [00029870][19 00][00] v1.0.8.96 -> v1.0.8.96 [00029935][01 00][00] v1.32.5432 -> v1.23.3419 need upgrade [00030001][01 01][00] v1.32.5432 -> v1.23.3419 need upgrade [00042565][08 00][00] device not detected. [00042626]Done. [00044687]Waiting for user confirm... [00054754]Timeout, start upgrade automatically. [00054859]Firmware upgrading[1]... [00055045][01 01] Firmware upgrade start... [00085327][01 01] Firmware upgrade finished successfully. [00085587][03 06] Firmware upgrade start... [00402817][03 06] Firmware upgrade finished successfully. [00402881]Done. [00402943]Version checking[2]... [00403043][03 05][00] v34.2.0.9 -> v34.2.0.9 [00403138][03 06][05] v2.2.6.19 -> v2.2.6.19 [00403201][04 00][00] v1.48.0.0 -> v1.40.0.0 [00403293][09 00][00] v3.0.0.10 -> v1.7.0.3 [00403433][11 00][00] v1.8.0.0 -> v1.7.0.0 [00403538][12 00][00] v1.11.0.0 -> v1.8.0.0 [00403629][12 01][00] v1.11.0.0 -> v1.8.0.0 [00403739][12 02][00] v1.11.0.0 -> v1.8.0.0 [00403839][12 03][00] v1.11.0.0 -> v1.8.0.0 [00416408][15 00][00] device not detected. [00416529][17 00][00] v1.1.1.7 -> v1.1.1.7 [00416669][17 01][00] v1.0.2.7 -> v1.0.2.7 [00416754][19 00][00] v1.0.8.96 -> v1.0.8.96 [00416814][01 00][00] v1.32.5432 -> v1.23.3419 need upgrade [00416882][01 01][05] v1.23.3419 -> v1.23.3419 [00429457][08 00][00] device not detected. [00429519]Packet upgrade failed at version checking.
2017-4-8
12
