Flight Raptor
Flight distance : 3014675 ft
Good luck! IF, they won't repair it, an option is to open up the transmitter, and use hot glue to 're-make' the pillars that the screws go into. Once the hot-glue is dried, take and drill a small hold in the center of the glue so you have a starting point for the screw.
Re-assemble the contoller and then screw into the hot glue and you'll me amazed at how strong the hold is. I had to do this on pillars that hold my gimbal wheel. Assemblers must have used too much torque and the screw pillars completely cracked/disintegrated. |
