DJI-Amy
Hi,
1)Have you tried to charge your battery using your friend's charger? It's possible that the charger is damaged. Please try to charge it using another charger and see if the LED light turns to red. And make sure that Pin is well connected.
Fully charge the battery until the led light on the charger turns into green.
2)Reboot and upgrade the OSMO: Copy the upgrade bin file into the SD card. Hold the trigger and record button, and pull down the power button at the same time. Hold it until the right led blinks red and green. Then try to upgrade the OSMO into v. 1.2.1.60. (The OSMO will update automatically with the bin file in the SD card, please wait about 20 minutes for the uprade, the left led becomes solid green means the upgrade is successful)
