Madebyvadim
Flight distance : 2023002 ft
Russia
Hey Bryan,
Thanks for reply. You should definitely check the camera if it's like you describe. BTW check it in P mode , because for some bizarre reason only P mode had a focus when you tap on screen. If its still blurry then it must be the camera. Also you talked about smear on the lens I do had it one time also but I believe its because of the accidental touch to the filter cap before the take off, never appeared again. but I almost always have a very distinctive bright white dots especially on the top 2/3 of the image, like a hundred of them or so, always at random and I had to clean up it from almost all pictures. Did you get that as well?
If you teaching Lightroom and Photography I believe my method of post-processign will not be new to you
Vadim. |
