kirk2579
Flight distance : 37415 ft
eden
I see you posted in a couple threads asking similar stuff about vision and vision plus etc. and that you are a rookie. Wecome to the club. based on a model # you posted DJI confirmed your is a plus.
I strongly think your only choice realistically is a vision plus unit to go on your vision plus phantom.
I am assuming you have the rc and wifi unit that comes with the phantom, if not what?
If you have the RC and WIFI and quad , simply attaching and & plugging it in gives you a working fpv quad.
Other wise you will be searching and trying to match parts etc to things not exactly made to match sometimes with frustration's etc. If you are not tech savvy and handy with soldering iron etc. you may want to shy away from custom build for now.
Should you try to use the vision camera Google will be your friend to help search youtube for how to videos.
also to speed up your process try this search on google " re500 vs re700 " you will get answer far quicker,
good luck
Have fun! |
