OSMO Activation Tutorial
31520 15 2015-11-17
DJI-Tim
The next step after unboxing your brand new osmo is device activation.
We will describe the procedure of osmo activation:
1.      Turn on the OSMO
2.      Go to Wi-Fi settings and connect to OSMOxxxxxx Wi-Fi (password 12341234)
3.      Run the DJI GO > OSMO> Enter the camera view
4.      Press “Next”
5.      Enter your DJI ID
6.      Connect to another Wi-Fi with internet access to send your activation data to DJI server
7.      Go back to DJI GO
8.      Press “Activate”
9.      After your data will be sent to server, please connect back to OSMO Wi-Fi and run DJI GO
10.  Activation Successful
2015-11-17
julie
Flight distance : 31480 ft
Thank you!  When I do this, the app immediately asks me to login to my DJI account.  No problem except... the wifi is set to the Osmo so obviously cannot get online!  So then I disconnect, go onto my house wifi (or data) and the app shows that I am already logged in.  Ugh.  Major glitches.  I am on iphone and I just updated to the most recent DJI GO update.
2015-11-22
DJI-Tim
julie@elysiumpr Posted at 2015-11-23 10:30
Thank you!  When I do this, the app immediately asks me to login to my DJI account.  No problem exce ...
Hi, Julie!
What you have to do is disconnect from the osmo WiFi, connect to another WiFi, go back to app so it will notify you to connect back to osmo WiFi to continue the activation process. And.. it's done{:3_52:}
2015-11-22
DJI-Tim
Also, you can login to your DJI account before doing activation
2015-11-22
Skyrider
Banned
2015-11-23
mccarty.video
This does not work on Android OS.
2015-11-28
Chicagophil
How do I get back tho the activation screen again? It didn't work for me the first time and now the screen doesn't show up on my dpi go app.
Any suggestions?
2015-12-3
pveauvy
It doesn't work with Android... could you please tell us how to activate this nice and expensive camera...
2015-12-4
rodger
Flight distance : 20145135 ft
Tim, I followed the OSMO Tutorial on activation. Everything went smooth as silk. No issues at all.
thanks
2015-12-10
frankhoppen
DJI-Tim Posted at 2015-11-22 18:45
Dear DJI-Tim, thank you for helping. Got mine today and trying your steps. Switing from OSMO wifi to Home wifi. Full wifi but when signing in this error
Sign in failed.
OK
comes up on iphone and also ipads used.
Is your server down, or any other step missed.
2015-12-29
beau.holguin
I'm having a similar problem. I follow the steps, but when I get to step 8 I get a message that says "Activation Failed. Contact DJI Support if you cannot activate your aircraft" I reset the wifi, updated the firmware, reset the wifi again and tried to use the web chat support. Their advice was to send an email, which I did. 5 days ago I received a notice that a ticket was created and someone would be contacting me. Nothing. Today I called and spent an hour on hold. When I told the person who answered that my osmo didn't work I was transferred and put on hold again. Charles answered, listened to what was wrong and told me to wait an hour then reset the wifi again. He said he would send me an email which I could reply to if that didn't solve my problem. I never received that email. Now I have to call back and spend another hour on hold just so I can get instructions to return this useless piece of $650 plastic.
2016-1-4
Vliegende Braba
Flight distance : 36591 ft
beau.holguin Posted at 2016-1-5 09:35
I'm having a similar problem. I follow the steps, but when I get to step 8 I get a message that says ...
I have a different problem with the activation. When I follow the activation manual everything goes fine, untill DJI Go finally uploads the data via my home wifi, and then after a few seconds I get the message: activation failed Active Failed(ServerNoAvailableDevices) contact dji support if it persists after restart
I have mounted my I1 X3 (the white one) with updated software (OSMO_FW_V01.06.02.10)
Anybody knows how to fix it? I have three days left for money back guarantee.
Thanks
2016-4-23
wbillib
Vliegende Braba Posted at 2016-4-23 13:58
I have a different problem with the activation. When I follow the activation manual everything goe ...
I had the same problem, it was not possible, with my Samsung Duos smartphone, to upload the registration data to the server,
but by using another smartphone, a Motorola Moto G 2, the activation was successfull,
so, it is only a smartphone issue.
After the activation, later, I could also use my Samsung Duos smartphone, so its only a question, to finish the activation process with a smartphone, that didn`t clear the cache, when changing between 2 wifi stations.
2016-7-17
fans372ef3a6
Been trying for two days to activate OSMO-no luck.  Every attempt is a dead end.  I've tried numerous strategies learned from online posters and help lines.  And I've updated the firmware. Seriously disappointed in this product and activation protocol. Total failure.
I cannot activate the device because I can't get online to the OSMO WIFI network.  My iPhone 6 won't recognize it and then nothing can move forward since the camera isn't activated.  About five minutes away from simply send this thing back and buying from a competitor.
VERY disappointed and frustrated at this entire process.  Again-TOTAL FAILURE.
2017-7-2
fans372ef3a6
rodger Posted at 2015-12-10 07:53
thanks
Sorry.  Don't believe you...
2017-7-2
Rodger8
fans372ef3a6 Posted at 2017-7-2 08:35
Who asked you
2017-7-2
