Use a Micro SD card for firmware upgrade.
Major Updates:
1.Updated list of compatible lenses: Olympus 25mm/f1.8, 45mm/f1.8 and 14-42/f3.5-5.6.
2.Increased the output bit-width of the sensor from 10bit to 12bit for 4kP30/25/24, 2.7KP30/25/24 and 1080P30/25/24.
3.Improved the AF zooming function (new AF auxiliary focus button in the menu).
4. Improved the image quality by fine tuning the sharpness and contrast.
5.Increased the shutter speed upper limit from 1/2 s to 2 s when shooting in ‘A’ mode.
6.Fixed issue of the white balance tending to be warm in the daylight.
7.The DNG format now supports the noise profile and sharpness profile.
8.Fixed issue of occasional flickering exposure changes in Auto Exposure mode.
9.Fixed issue of corrupted DNG due to missing lens profile.
10. Optimized system stability.
11.Optimized the gimbal control parameters for better performance.
12. Optimized the Waypoints feature.
Note:
The firmware can be downgraded to v1.0.0.30 or later only.
