ljhellmich
Run the calibration in DJI RC System Assistant as well, including all switches and the wheel... regardless of what the pop ups or text says. I found that doing a final cal and check in RC Assistant seemed to smooth out the tilt wheel, even after calibrating in P2 Vision Assistant. Try that to see if it helps.
As Gerry stated, the speed is proportional to how far you roll the wheel. Super slow, to fast.
Jamie |
