Kneepuck
Flight distance : 275105 ft
This system works. The Dominator V3 has a nice display, switchable between HDMI and A/V inputs and both inputs can be either 2D or 3D input. I was a little surprised at the screen size. A 30 degree field of view sounds ok until you realize that it is 30 degrees from top left corner to bottom right corner. In effect, you are looking at a 40 inch screen from a distance of 7 feet. Not too bad really. Maybe I am spoiled. I use a 48 inch diag. monitor on my computer and I am about 4 feet from it. In any case, it is certainly usable. Somehow I had visualized an enormous virtual screen, like sitting 2 feet from an 80 inch display. Oh well, noob mistake.
The main issue is, because the P3 Standard does not have any option for the HDMI module like its bigger brothers, you have to use a bit of extra hardware. I forgot to mention, the Fatshark Dominator V3 HDMI input requires a maximum resolution of 720p. My Samsung Galaxy S5 has higher resolution than that, and no way to change it. So, you have to still get the usb to HDMI adaptor for the S5 Galaxy as well as an HDMI to Composite adaptor to go between that and the FatShark, using the supplied A/V cable from the composite output RCA connectors to the A/V input on the Fatshark. That connector is located next to the power connector on the Fatshark. I had hoped to reduce or eliminate most of the extra hardware, but no such luck.
In summary, to get an FPV goggle view from a P3S, you have to have, in my case, an S5 Galaxy( or I suppose any device or tablet that supports HDMI output), a USB to HDMI adaptor, an HDMI to Composite adaptor, the necessary cables, which includes usb cables to power both adaptors in addition to the signal cables. If your device can output 720p HD, you can eliminate the HDMI to Composite adaptor. No matter what, you will have an electronic spaghetti mess to deal with.
My next try will be to install the 2.4 ghz receiver in the FatShark and try to receive the video stream directly from the controller via wireless. I feel like this will not work because, if for no other reason, no way to enter the wifi password to the FatShark display.
If anyone has had any luck with another setup, please let me know. I have not yet tried the Google cardboard setup. I will be very sad if that turns out to be the best option for the P3 Standard. I will also be a good deal poorer. Ah well. Easy come, easy go.
