Siambuddhas Gro
Flight distance : 116926 ft
Singapore
endotherm Posted at 2017-7-22 10:13
This flight does look strange in that there is nothing indicating a fault. After you took off your stick inputs forward and up were no more than a third to half deflection. That corresponds to the rise and forward moves as indicated on the flight track, as well as the ~10° negative pitch. At the apex the aircraft tumbles and falls to the ground. During the tumble you came very close to performing a CSC with both sticks down and out, but it wouldn't have added to your troubles. It is likely due to the location that it was hit by a strong gust of wind coming in from the water (very common at beaches) causing it to tumble, or perhaps was involved in a birdstrike. The freefall shows the track being pushed back inland, which supports the case of the wind blowing it backwards -- normally an out of control fall would be more vertical.
I would suggest extracting the DAT file from inside the aircraft and sharing a link to it back here, so we can rule out motor failure/prop loss. The file is a lot bigger than the flight log you have already shared, but it shouldn't be very big due to the short flight. You will need to share it on a file sharing site like Dropbox or similar. You can extract it by connecting the aircraft to a computer via the front USB port next to the name plate, and putting the aircraft into flight data mode from the Go app.
Thanks , there were a few flying at the same area ..wind speed more like breeze..didnt feel wind.btw its way back to shengzheng HQ.. |
