List of lenses supported by Zenmuse X5
49719 22 2015-11-30
DJI-Tim
Dear DJI Users:
Here is a list of lenses supported by ZenmuseX5. If you have any questions, please contact your local DJI service center
Prime lens
OLYMPUS M.ZUIKO DIGITAL ED 12mm f/2.0 Lens
OLYMPUS M.ZUIKO 17mm f/1.8 requires an additional weight ring
DJI MFT 15mm f/1.7 ASPH Prime Lens requires an additional weight ring
Panasonic Lumix 15mm G Leica DGSummiluxf/1.7 ASPH Lens
Olympus 25mm/f1.8
Olympus45mm/f1.8
Zoom lens
Olympus14-42/f3.5——opticalzoom can be adjusted by a sliding block in DJI GO app requires an additional weight ring
2015-11-30
Xahhax
Poland
This is great for the 45 1.8 - thanks!
2015-12-1
gybo102
Flight distance : 2426230 ft
The weight ring, im assuming is different lens to lens? if so, where can we buy these?
Thank you.
2015-12-1
Devincard
Flight distance : 506421 ft
Would love to see who has gotten results with the Olympus zoom lens! Any more info on weight rings?
2015-12-6
gybo102
Any more info on the rings? Thank you. And is it the thin "pancake" looking lens? (14-42)
2015-12-7
Minimanian
gybo102 Posted at 2015-12-7 21:00
Can dji confirm this and what fw version do I need on the inspire pro to  make sure the zoom works?
2015-12-8
drone vision
Hi DJI   it would be good to get some more information on the lens specifics for the 14-42 lens e.g. is it the pancake version???   and is there any info on the balance rings.  there seems to be a lack of enthusiasm to specify.  !!!
2015-12-10
njabinc
The following link will bring you to a thread which is the result of a little intuition, thousands of dollars, and unbeleivable amounts of time. In the end what is revealed is that as of now I have identified 14 lenses that are able to be utilized on the X5. Now before revealing the link I must warn that many of these lenses REQUIRE BALANCING SO THE DON'T DO HARM TO THE GIMBLE MOTORS. Please spend the time and money necessary to balance them so you don't damage your gimble. Go here to find out about all the enhanced uses of your X5 ...
http://www.inspirepilots.com/threads/the-latest-list-of-compatible-lenses-for-the-x5.8112/
2015-12-11
gybo102
Thanks for that, really appreciate the time put into the research.
2015-12-11
drone vision
njabinc Posted at 2015-12-11 17:35
The following link will bring you to a thread which is the result of a little intuition, thousands o ...
This is a great link and provides a really good review for individual selection.   When it comes to balancing is it just matter of getting a total weight for the lens e.g 113 +5-10 grams or more to do with ensuring it is all smooth and vibration free.
I have tried the Olympus 14-42mm lens but find that it is a very tight fit in the gimbal and the knurled zoom ring just binds slightly agains the gimbal body. Anyone else experiencing this?   I expect that I could sand the ring down a bit to increase clearance!!!    Also without any balancing rings there is a harmonic vibration that obviously affects focus. Even replacing the lens cap seems to cure that.
2015-12-14
Cata
Flight distance : 1045220 ft
Romania
Just finish a test with 3 different lenses on the Zenmuse X5
DJI / Panasonic MFT 15mm f1.7
Olympus M.ZUIKO 12mm f2.0
Olympus M.ZUIKO 45mm f1.8
2015-12-15
Heliflo
Flight distance : 8885013 ft
Switzerland
my Version of the 45mm m.zuiko lens test...:
http://youtu.be/AV-sD6ox--s
2015-12-16
Yogi123
Flight distance : 3194669 ft
Cata Posted at 2015-12-15 21:11
Nice work.  Thanks for that.
2015-12-19
gybo102
DJI, any info on the Rings?
2015-12-21
Nick119
Flight distance : 3764045 ft
Hi does anybody know if a lens hood is added to the OLYMPUS M.ZUIKO DIGITAL ED 12mm f/2.0 Lens, will it affect the balance ?
2016-1-24
Nes
So, Tim...
If reading this correctly, the Olympus 12MM and the Olympus 45MM will not need any balancing ring?
(Inspire 1 Pro Turned Off) What about if when using the 12MM the unit tilts back  (back heavy) or when using an ND it falls forward (front heavy). Does the gimbal with the lens on it need to sit centered with no tilt?
The above would apply to the 45MM as well.....?
2016-3-6
monte007
Cata Posted at 2015-12-16 05:11
So which lense do you recommend?
2016-8-10
fans76f284be
Flight distance : 578871 ft
I was under the impression by this post that the Olympus 45mm/f1.8 did not need accessories to balance as the other lenses that needed accessories were marked as such in the list. Be warned, it is very unbalanced. I bought the "Fotasy H37B Screw-In Metal Lens Hood Shade for Olympus M.ZUIKO DIGITAL 45 mm 1:1.8 Lens (Black)" from Amazon.com and noticed it perfectly balances this lens.
Update:
I also swapped out the Panasonic 15mm for the Olympus 12mm on the list above and found again that the latter is completely unbalanced. It quickly points straight up when the gimbal is not turned on which is the definition of not balanced.  I added the 10g DJI weight ring from the Panasonic as it shares the same filter size and found it gets the lens a lot closer to balanced. Instead of pointing straight up it points at 45 degrees if you try to tilt to fully horizontal with motor off. Since there is no DJI weight ring for the 12mm i'm just going to settle for that.
A partial balance must be better then completely unbalanced? Is there an official word on why DJI does not recommend balancing the very unbalanced 12mm Olympus lens?
2017-1-5
fansf873f649
Flight distance : 460404 ft
I found that the zoom lens is not as sharp as the fixed lenses.  I also find the 12mm Olympus to be the sharpest and it is my "go to Lens"
2017-10-2
ReppocMike
Flight distance : 1627667 ft
Finland
fansf873f649 Posted at 2017-10-2 07:32
Can I use Olympus 45/1.8 X5S balansing ring with X5?
2018-1-21
BIGDZ
Flight distance : 10255860 ft
ReppocMike Posted at 2018-1-21 16:14
That is what i used (as well as...) works well...take a look
2018-1-21
Fortnight
Flight distance : 5403383 ft
Olympus 9-18mm
2019-3-20
djiuser_aGRP7PSRtzyJ
Does the very unpopular focus wheel help me hook up to the app without using wifi?
2021-7-15
