DJI X5 Lens Test Olympus 14-42mm
9816 15 2015-12-2
s-bruhn
Flight distance : 1232677 ft
Yesterday was cold and foggy, but i wanted to test the Olypus 14-42mm with the Inspire Pro and X5.
Works quite well, zooming while filming does not.
All Firmware latest. 4K 25fps iso 200 f5.6 100sec shutter
2015-12-2
capalvch
Flight distance : 71125 ft
Venezuela
Wich one of the zuiko 14-42 is the aproved? As i know they have the ED 14-42mm f/3.5-5.6 EZ and the ED 14-42mm f/3.5-5.6 II R
2015-12-3
Phantom Paul
Philippines
Is the one you're using?
Olympus 14-42mm f3.5-5.6 EZ
http://www.amazon.com/gp/product/B00HWMOZEG?psc=1&redirect=true&ref_=ox_sc_sfl_title_1&smid=ATVPDKIKX0DER
2015-12-14
gybo102
Flight distance : 2426230 ft
any input on the above post?
2015-12-21
ge0se
Flight distance : 3184721 ft
Phantom Paul Posted at 2015-12-14 21:33
http://www.amazon.com/gp/product/B00HWMOZEG?p ...
This one is the officially confirmed version (pancake lens) and the one I bought and tested. Currently I use a metal ring taped to the lens to balance it on X5 gimbal - cheesy but works as a temporary solution. Seen a few people found a screw-on lens hood + UV filter solution for balancing it but still don't know exact details, hopefully will figure it out soon.
2015-12-29
rmoura
Flight distance : 4017802 ft
Brazil
I received my pancake last Friday but I cannot test it yet due the rain. Anyway, I have balanced the X5 with the pancake using 3x 37mm filter rings (w/o lens). The problem is that the balance is a little unstable because the gravity center change when you apply the zoom. I believe we can balance in the middle to have an average.  The lens is exactly that above (electronic focus and zoom).
I found little problems / improvement opportunities:
1. After the first use the pancake do not return to the closed position using the X5. I see a post that say you will need a micro 4/3 camera to do that. Will be a must if DJI introduce a command in the App, for instance.
2. The zoom movement is not so smooth  nor precise as you would like, may be because of the on screen control in the App. I believe that if the App could be programmed to use a stick in the second (Slave) RC for that and/or the left wheel in the Master will be great.
2 .
2016-1-11
rjs21989
Flight distance : 2858701 ft
this video show them zooming with the 14mm/42mm @ the 1:23 mark
2016-2-2
pixeldiversity
Flight distance : 979137 ft
rjs21989 Posted at 2016-2-2 16:39
https://youtu.be/bIT8qdSn9sY
well done !!
Thank you !
2016-2-2
freddy.4.u
Flight distance : 2792621 ft
rmoura@uol.com. Posted at 2016-1-11 07:07
I received my pancake last Friday but I cannot test it yet due the rain. Anyway, I have balanced the ...
Did any software or firmware upgrades fix this problem yet? want to have a zoom lens but not buying something that will not work for the DJI X5 and I do not need to buy a camera just to reset this zoom lens?
2016-6-8
Tahoe_Ed
Flight distance : 2605 ft
I have used the 14-42 lens and find it to be a good single lens alternative to having a 12mm and a 45mm.  It is subject to micro bounces if everything, props and gimbal are not balanced well.  I use a ND9 filter to keep the ISO between 100 and 200.
2016-6-8
leoamartinez
Flight distance : 1602986 ft
Dominican Republic
Tahoe_Ed Posted at 2016-6-8 10:26
I have used the 14-42 lens and find it to be a good signal lens alternative to having a 12mm and a 4 ...
Olympus lens are excellent for X5, 14-42mm ez, 12mm, 25mm, 44mm, i have them all, great shots!!
2016-6-8
Tahoe_Ed
leoamartinez@gm Posted at 2016-6-9 10:33
I fully agree with your statement.
2016-6-9
patrickfox10289
Tahoe_Ed Posted at 2016-6-9 07:25
Tahoe_Ed, I have an X5, and the 14-42 zoom lens. The lens does not close when i power down the inspire. is there a solution to this? or will this be fixed in an upcoming firmware update? Thank you very much.
Pat
2016-6-23
mgv1vl13SFxq
Argentina
hi!!!
i have a situation, i have a matrice 600,  but i can´t make it work the lens
I have no idea what I'm doing wrong
Help!!!
The lens just go and living, and doesn´t remain fixed
Thanks!!!
app: version 2.8.7aircraft:        1.0.0.39
remote controller 1.1.50
camera: 1.0.0.30+
LB2 air 1.1.40
2016-9-21
mgv1vl13SFxq
Argentina
zenmuse not get update x5 in my matrice 600 HELP!!!
2016-9-27
fans55dd4de5
here is another test with the 14-42
two man Operation, alone you have Chance to get any decent footage, the movements are zu fast.
the lens never moves to closing Position, you have to attach it to a regular camera to do this.
2016-11-13
