Inspire 1 Pro New Firmware V1.2.0.50
12Next >
6624 72 2015-12-9
DJI-Tim
The latest Inspire 1 Pro firmware has been released. Download the firmware update package from the product page on the official DJI website http://www.dji.com/product/inspire-1-pro-and-raw/download
Overview:
1.      Upgrade the firmware to v1.2.0.50.
2.      Upgrade the DJI GO app iOS to v2.4.2.
3.      Upgrade the DJI GO app Android to v2.4.2.
MajorUpdates
1.      Fixed issue of battery level fluctuation.
2.      Fixed issue of flicking lines in night scenes.
3.      Fixed issue of flicking dots in dark areas.
4.      Reduced noise for photos and video.
5.      Decreased the sharpness settings for D-LOG and D-Cinelike.
6.      Fine-tuned the tone curve for photos and video.
7.      Tuned down 3D denoising for night scenes.
Note:
1.      This release includes a battery firmware upgrade. Be sure to upgrade all your batteries.
2.      The firmware is intended for the Zenmuse X5 camera only. DO NOT mount the ZenmuseX3 for this upgrade.
3.      The firmware can be downgraded to v1.0.0.30 or later only.
12/10/2015
For  the issue with 'Version 1.4.00.10+' is fixed. Please download the firmware again and upgrade.
2015-12-9
gboivin
Flight distance : 1544416 ft
DJI-Tim Thanks for the clarification!
2015-12-9
drone vision
gboivin@msn.com Posted at 2015-12-9 11:56
Hi DJI Tim, thanks for the update information.   I realise my next question may seem basic to some, but when I do the update do I just do it once?. Then remove the .bin file if its been successful.   or do I have to keep doing a restart with the FW .bin file on the SD card for each battery  - or - do the batteries automatically update when I put them in prior to flight/
2015-12-9
airymok
Flight distance : 2623652 ft
drone vision Posted at 2015-12-9 20:12
Hi DJI Tim, thanks for the update information.   I realise my next question may seem basic to some ...
keep the firmware in SD card to upgrade all your batteries.
2015-12-9
avia.arm
Armenia
After Upgrade in go App  write the aircraft need update   and show version 1.4.00.10+
2015-12-9
drone vision
airymok Posted at 2015-12-9 12:28
Hi DJI Tim   some advice please.
I have just carried out the new update on my Inspire Pro.  everything went well. I carried it out three times with a different battery to ensure they were updated.   All went well and the .txt message in each case was success.
Then am quick test with the RC to ensure all was well and connected.
I m, now getting a message Aircraft State  to tell me  'Update Required.'
the Message in About confirms:
App:         Version 2.4.2
Aircraft    Version 1.4.00.10+
RC            Version  1.5.70
Camera   Version1.2.0.50
Is the message telling me I need further FW update??   or that I need to calibrate  compass etc??
2015-12-9
Linolens
Flight distance : 501250 ft
Macao
drone vision Posted at 2015-12-9 21:54
I have just carried out the new update on my Inspire Pro.  every ...
same here.........
Spent the last hour trying to figure it out.
2015-12-9
drone vision
drone vision Posted at 2015-12-9 13:54
Is it relevant that updating to V1.2.0.50 has also changed my Aircraft version from V1.2.1.06+  to 1.4.00.10+
Despite original advice should I now be updating to the Verson 1.5   that We were advised was only for Inspire 1 with X3 camera
2015-12-9
Linolens
Macao
drone vision Posted at 2015-12-9 22:27
Is it relevant that updating to V1.2.0.50 has also changed my Aircraft version from V1.2.1.06+  to ...
i think the issue is the App telling you that the aircraft needs an update, after the update has been successfully done. Or so I assume...
2015-12-9
Dragonflyin
Flight distance : 16562 ft
So there is no 'follow me' feature or RC upgrade included in this Inspie Pro FW upgrade?
2015-12-9
Linolens
Macao
Dragonflyin Posted at 2015-12-9 22:35
camera FW upgrade only
2015-12-9
DJI-Ken
Flight distance : 1515312 ft
if you have an Inspire1 then the latest update is 1.5.0.3 that was released on Dec 7th.
If you have an Inspire Pro then the latest release is 1.2.0.50 that was released this morning.
Users with the Pro were seeing the "Upgrade Required" but they should have only seen it with the Inspire1. So this mornings update for the Pro will fix that.
2015-12-9
marc.aries-serv
Ken, have updated the firmware for my Inspire Pro with this mornings release but still have the message "aircraft requires upgrade"
Firmware info as follows on my Inspire Pro
App =     Version    2.4.2
Aircraft  =  Version 1.5.00.30
RC =            Version 1.5.70
Camera =   Version 1.2.0.50
2015-12-9
marc.aries-serv
Follow up from my previous post, formatted my sd card for the X5 and when checking firmware info on the DJI Go app, my aircraft now says  Version 1.1.4.00.10+ !!!!
Whats going on DJI ??
2015-12-9
HEJM
Flight distance : 872362 ft
Same here, getting an "Upgrade Required" warning after the Inspire 1 Pro upgrade V1.2.0.50
I have an Inspire 1 Pro (not Inspire 1 with additional Zenmuse x5)
App        2.4.2
Aircraft  1.4.00.10+
RC          1.5.70
Camera 1.2.0.50
2015-12-9
ardian
Flight distance : 455197 ft
noticing some flaws on firmware update
with inspire 1 pro X5,updating success however now i don't have a signal
app 2.4.2
aircraft 1.4.00.10+ (even though i downloaded 1.2.0.50)
RC 1.5.70
this my dear friends is typical DJI.....
2015-12-9
ardian
ardian Posted at 2015-12-9 10:27
with inspire 1 pro X5,updating success however now i don't h ...
just spoke to customer service and they are waiting for a response from headquarters
apparently I'm not the only one with this issue.With that being said upgrade F/W if you want
HOWEVER consider yourself warned!!!
2015-12-9
DJI-Ken
marc.aries-serv Posted at 2015-12-9 23:59
Ken, have updated the firmware for my Inspire Pro with this mornings release but still have the mess ...
Mi Marc,
It seems some other customers are also having an issue.
They are working on it now and should have a solution soon.
2015-12-9
drone vision
DJI-Ken Posted at 2015-12-9 15:22
If you have  ...
hi Ken   I think you'll see from all of the posts on this thread that people are surprised that they have updated to V1.2.0.50  which has worked and updated the camera but has also changed the FW version of the  Aircraft. in my and other peoples case this has been to 1.40.00.10+.
Annoyingly now being told update required even though the.txt file shows it a success.   This mornings update didn't cure anything but caused a new problem!!!
Any response on action to take??
2015-12-9
drone vision
If you have  ...
2015-12-9
emulsiondown
Tim - the link you provided brings up this page...
404
SORRY,THAT PAGE DOESN’T EXIST
OR IS UNAVAILABLE.
GO BACK TO DJI.COM
OR CONTACT US ABOUT A PROBLEM.
2015-12-9
DJI-Ken
X5 Pro users, for now please downgrade the firmware back to 1.1.0.40 then you should be working as before.
A solution will be found soon. It seems there's a glitch in the 1.2.0.50 firmware.
2015-12-9
Ryan Gordon
Flight distance : 2186250 ft
Do we have to downgrade each of our batteries as well that were updated this morning?
2015-12-9
DJI-Ken
Ryan Gordon Posted at 2015-12-10 01:57
The updates for the battery are fine so there is no reason to downgrade each battery. But downgrading will remove the battery fixes on 1.2.0.50, so when you downgrade to 1.0.40 the battery used will also downgrade.
That one battery will just act as it did before the downgrade. And if you absolutely have to the the battery fluctuation issue fixed, then i suggest not using that battery until there's a solution to the 1.2.0.50 update.
2015-12-9
coyut.riot
Flight distance : 2559222 ft
Switzerland
DJI-Ken Posted at 2015-12-9 19:17
The updates for the battery are fine so there is no reason to downgrade each battery. But downgrad ...
The 1.2.0.50 firmware is still up at the DJI site.  It's available for download.
Is it already fixed? If not why is it still up?
I updated just about an hour ago or so but also get the "Aircraft requires upgrade" Information. (Aircraft 1.4.00.10+)
Will the next fixed update run over the 1.2.0.50?
I don't want to downgrade, as .40 was just a mess and not usable for customer work!
DJI should really better test their upgrades prior publishing them !
2015-12-9
Rob W
Flight distance : 94390 ft
Sweden
@ DJI:
While fixing this firmware, please incorporate the increased bitrate for PAL. Somehow that slipped, and only NTSC got the update. See the thread "Increased bitrates in new firmware, WTH?!" here on the forum.
2015-12-9
Ryan Gordon
Does this update make the drone unsafe to use? Has the update made the drone unusable or is it just that the app tells you to upgrade?
2015-12-9
ianw79
Flight distance : 275856 ft
I think DJI's Firmware Programmers went out for a particularly hardcore xmas party at the weekend!
2015-12-9
ianw79
My inspire 1 PRO aircraft firmware was already on V1.4.00.10+. This firmware needs to upgrade the aircrafts firmware to V1.5.0.30. The aircraft firmware on the I1Pro and the I1 should be the same as they are the same craft. It's only the camera firmware that should be different. DJI just put the wrong aircraft firmware in the update.
2015-12-9
ianw79
DJI-Ken Posted at 2015-12-9 17:55
X5 Pro users, for now please downgrade the firmware back to 1.1.0.40 then you should be working as b ...
Working as before but it will still tell us an upgrade is required because you need to include the aircraft firmware V1.5.0.30 in the package.
2015-12-9
DJI-Ken
ianw79@mac.com Posted at 2015-12-10 05:44
Working as before but it will still tell us an upgrade is required because you need to include the ...
Yes, they will get that solved hopefully by tomorrow.
2015-12-9
DJI.Terry
emulsiondown Posted at 2015-12-10 01:38
404
Fixed. Thanks.
2015-12-9
flightstick
South Africa
when is this new update going to be released
2015-12-9
DJI-Tim
avia.arm@gmail. Posted at 2015-12-9 21:33
For the first time you have to have the internet connection so see a  new FW version
2015-12-9
airymok
flightstick Posted at 2015-12-10 14:05
Download the firmware again, it should fix. I can see a new update in dji website, v1.2.0.50. The release date is the today.
2015-12-9
DJI-Tim
Linolens Posted at 2015-12-9 22:29
i think the issue is the App telling you that the aircraft needs an update, after the update has b ...
Right, if your update sucseed , it's just an application that shows the old version
2015-12-9
DJI-Tim
Rob W Posted at 2015-12-10 02:59
@ DJI:
While fixing this firmware, please incorporate the increased bitrate for PAL. Somehow that s ...
Thanks for your solution again! it's been  already reported to our engineers
2015-12-9
DJI-Terry
Hi, All
2015-12-9
Linolens
Macao
DJI-Tim Posted at 2015-12-10 14:24
Another bit of info:
Only the Android app is accusing the need for update.
iOS is fine
tks Tim
2015-12-9
oncan.ozgur
Turkey
Hi All,
I have a inspire 1 ( normal ) but additional X5
I think that I just follow inspire Pro updates but my motors is not 3510h. That is why, should i change any gain settings ? or do anything ? after install inspire pro filmware
thanks
ozgur
2015-12-9
12Next >
