dji phantom 2 voltage
2080 6 2014-12-27
dekelkabeli
Israel
Hey my name is Dekel and when I fly the phantom the voltage come to 10.8 what a to do? I know that the recommend voltage is 11.1...
2014-12-27
Tahoe_Ed
Flight distance : 2605 ft
One make sure that the battery is properly charged.  Calibrate the battery under the voltage tab in the Phantom Assistant.
2014-12-27
dekelkabeli
Israel
Tahoe_Ed Posted at 2014-12-28 00:13
One make sure that the battery is properly charged.  Calibrate the battery under the voltage tab in  ...
where is the voltage tab in the phantom assistant? i cant find it
2014-12-28
Tahoe_Ed
dekelkabeli Posted at 2014-12-29 05:44
Advanced, Battery.
2014-12-29
dekelkabeli
Israel
I was there. How can I calibrate the battery ?
2015-1-7
momochi
Not sure what you mean by "calibrate". The only thing you can do is set the "Go-Home" option. You can see all the battery information. Check each cell voltage and you will also be able to see the number of cycles.
2015-1-7
Johnnythaboy
New Zealand
Tahoe_Ed Posted at 2014-12-27 08:13
hi, my battery level using a multimeter is 10.5 volts. however, on the phantom 2 vision assistant software, it reads 12.4 volts and thinks it is at full power. how can i calibrate so the battery reads the true voltage?
2017-5-6
