Kneepuck
Flight distance : 275105 ft
You need to delete the dji-go app completely from your device. The update is first downloaded automatically to your device from the dji site. It is stored on your device. If the Dji-Go app see's the file on your device, it will assume it is already downloaded and will not download again. So totally delete the entire dji directory from your device. Now re-install the Dji-Go app. Now turn on the controller, then the phantom. Now connect your device to the internet. and select to download firmware. After download is finished, connect your device to the Phantom3 wifi. Select to begin upgrade. There will be a bunch of beeps, then 4 beeps in a row for a while. All the lights on the arms will turn red for a while. Just walk away from the thing and come back in half an hour. Restart everything, do an imu and compass recalibration and you will be good to go. If you have more than one battery, you will have to do this for every battery, but that takes only a few minutes per battery.
