OSMO New Firmware Version: v1.4.1.80
12Next >
11282 61 2015-12-25
DJI-Tim
China
OSMO Release Notes
1.           Firmware Version: v1.4.1.80
2.           DJI GO App iOS Version: v2.4.3
3.           DJI GO App Android Version: v2.4.3
MajorUpdates
1.           Fixed the issue of the camera restartingunexpectedly when recording in 4096 x 2160.
2.           Improved horizon level accuracy for the roll axis.
3.           Reduced gimbal drifting in timelapse mode,improving stabilized image capture.
4.           Optimized handle movement control.
5.           Optimized control for Selfie Mode.
6.           Fixed a display issue when attempting to connectmultiple mobile devices to the Osmo at the same time.
7.           In panorama modes, the gimbal automatically adjuststhe roll axis to the horizon level.
8.           Optimized 4K video playback performance.
9.           Added support for firmware updates through the DJIGO app.
10.       Added audible prompts for the firmware updateprocess. The Osmo will sound “D—DD......” when the update is
completeand sound “D-D-D-D......” if the update has failed.
Features supported by thelatest DJI GO app v2.4.3:
1.           Added volume display and volume gain adjustments.
2.           Added options to power off and enter Sleep Modefrom the DJI GO app.
3.           Added settings for Selfie Mode in the DJI GO app.
4.           Optimized touchscreen gimbal remote control.
5.           Added a new 180 degree panorama mode.
6.           Added the option to customize white balance.
7.           Added style settings to adjust sharpness,saturation and contrast.
8.           Exposure parameters can now be adjusted whilerecording video.
9.           Added a shortcut for camera settings.
Notes
1.           The Inspire 1 Zenmuse X3 gimbal and camera must beupdated to firmware v1.5.0.30 on the Inspire 1 aircraft before using thisfirmware update on the Osmo handle.
2.           If the Inspire 1 Zenmuse X3 gimbal and cameraenters protection mode, you will need to power cycle the Osmo to reactivate it.
3.           The Inspire 1 Zenmuse X3 gimbal and camera does notsupport Sleep Mode.
4.           Gimbal drift can be minimized using the autocalibration function.
5.           If the firmware upgrade fails, restart the Osmo andDJI GO app to and re-attempt the upgrade.
6.           After performing the firmware update, it isrecommended to perform an auto calibration for the gimbal.
2015-12-25
martin94b
No way - a real christmas miracle...
Let´s hope the fixes work as described - one big step for Osmo finally!
Thx Thx Thx Thx
- Ok, first update attempt did not work (loaded the file to the µSD card root and started the Osmo, blinked and after a few minutes ended with D - D - D beeps)
- After restarting Osmo and connecting the App the App told be about the new download. Then all over sudden the Osmo replied with D - DD - D - DD beeps and everything was fine
- Lost the LiveView image which never happened before?! After restart of Osmo and App worked fine again.
- Setting Mic Loudness works
- Recording 4K in 4096 x 2160 resolution now seems to work fine
- Locking the Gimbal in TimeLapse seems to work fine. I will perform more outdoor tests soon
- Even though not mentined in the release note I found the WiFi connection of Osmo to be much more reliable than before?! Before I had to switch on / off Osmo for about three times before I was able to connect, now it works with the first attempt.
=> Looks good so far. More testing required - let´s go Osmo community...
2015-12-25
zane_isaac
Flight distance : 8712549 ft
Update said successful now I can no longer connect to my osmo.
2015-12-25
ahr69
Flight distance : 83612 ft
zane_isaac@yaho Posted at 2015-12-25 13:56
my update notice came through the DJI GO app when I started up the OSMO. I clicked on it and it started the download then the update process. I didn't have any problems. I didn't have to load anything onto a chip either. The update was automatic which I'm thankful for and checked the about on the app and all looks good. Can anyone else confirm the same results:
firmware versions:      1.4.80
APP:02                           2.4.3(2396)
Wifi: 07                          01.00.09.40
Gimbal: 04                    01.29.00.63
Camera: 01                   02.47.44.92
aircraftEncoder:08       02.14.09.37
AirOFDM:09                  00.00.00.73
2015-12-25
andreib
Russia
After unsuccessful (about 6 tries )update I can not connect to my osmo! please help.
2015-12-25
wordsaremything
Mine updated find through wifi but now it won't stay connected to the Osmo for more than a second.
2015-12-25
wordsaremything
I tried to go back to the old firmware and that failed as well. Now the OSMOS doesn't work at all. I don't see an osmo wifi anymore either. If I try and redo the new firmware, it ends in one red light and a continuous beep.
2015-12-25
krskyeyedrone
I HAVE EXACTLY THE SAME PROBLEM LIKE YOU WORDSAREMYTHING
2015-12-25
zane_isaac
Same here
2015-12-25
FabricioE
Venezuela
Same here. Won't connect through WiFi
2015-12-25
mmccurdy
Flight distance : 34931 ft
Brand new out of the box Christmas present. Fire it up, says to upgrade so I perform the upgrade. No longer seeing video on my phone and wifi for the osmo turns off and on it seems.  (Sad face)
2015-12-25
zane_isaac
I have been told, If resetting the wifi does not fix it, then right now there is not work around
reset the OSMO and try again.  Key combination: Hold down the Trigger and Shutter Button at the same time. Then, pull the power switch down until the System Status Indicator blinks green. Release the power button before releasing the Trigger.
2015-12-25
zane_isaac
Here is the recommendation.  Remove your SD card and format it in Fat32.  Do a clean download of the bin file and copy it to the root drive of the SD card.  Power cycle the OSMO without the card.  Then with the OSMO off, insert the card and turn on the power.  See if the installation completes.  If not try and roll back the firmware to the prior version.  If that works then you can try the upgrade again.
*********Didn't work for me******
2015-12-25
FabricioE
Venezuela
andreib@me.com Posted at 2015-12-25 16:02
Did you fix it?
2015-12-25
zane_isaac
Nope....... fml
2015-12-25
setiawan3d
Flight distance : 7861 ft
Indonesia
Alright... excited and glad to hear the new firmware release..., but somehow, I need assurance and workaround if the upgrade failed, before I upgrade my Osmo...
My current versions:
DJI Go App: 2.4.3(94)
Osmo Firmware: 1.0.1.19 (I didn't go to 1.0.1.19+)
Camera: 02.29.41.49
Gimbal: 01.29.00.00
Encoder: 02.14.09.26
OFDM: 00.00.00.62
Wi-Fi: 01.00.09.22
2015-12-25
richiegl25
Upgraded and WiFi won't stay connected for 1 second, and sometimes wifi connection won't even come up... just got my Osmo yesterday and was having fun until this update. Now I can't use it til DJI fix this issue... smh
2015-12-25
DJI Candice
China
hi all , please try combinations trigger+recording button+power switch
2015-12-25
mmccurdy
DJI Candice Posted at 2015-12-25 22:08
I did trigger+recording button+power and did not fix the issue.
2015-12-25
richiegl25
Hi Candice, should I do combination while osmo on or off.? Also, do I hold the combination for a period of time.?
2015-12-25
mako
Japan
Help !
http://forum.dji.com/forum.php?mod=redirect&goto=findpost&ptid=35948&pid=275235&fromuid=145013
2015-12-25
petevandra
Flight distance : 6939 ft
RE Update to 1.4.1.80
Update worked fine for me.
Updated from 1.0.1.19 and did it via the DJI GO app. (2.4.3) and IOS 9.2.
Biggest plus for me is the improvement in the microphone volume. I still need to experiment more but the internal mic is marginally better but with my Olympus ME52W external microphone attached to my lapel, it is a great improvement. Sometimes there is a crackling noise which I need to investigate further.
I only purchased my OSMO a week ago so I'm still learning about all the other  improvements
2015-12-25
teemu.puolitaiv
Finland
Hi, I have exactly the same problem - Updated via DJI Go Application - successful.  After that no wifi-connection. OSMO connects and disconnects repeatedly. Tried to do manual upgrade downloading the firmware file but no luck, update failed. Tried also older firmware but not working..
========= 2015.12.26 11:48:05 =====================
Packet: OSMO_FW_V99.99.99.99.bin
Upgrading ...
Result: Success.
========== 2014.01.01 00:00:09 remo-con disconnect======
Packet: OSMO_FW_V01.04.01.80.bin
Upgrading ...
Result: Failed.
Reboot the aircraft and try to upgrade the firmware again.
========== 2014.01.01 00:00:08 remo-con disconnect======
Packet: OSMO_FW_V01.02.01.60.bin
Upgrading ...
Result: Failed.
Now Osmo works as stand-alone - I can't even see the wifi on mobile phone.. Tried to reset the WIFI-settings.. No difference.. Has anyone found any workaround for this problem?
2015-12-26
Seachief
Flight distance : 123301 ft
teemu.puolitaiv Posted at 2015-12-26 06:18
Hi, I have exactly the same problem - Updated via DJI Go Application - successful.  After that no wi ...
So is this where this stands still...? The update rendered a lot of people's Osmos unusable? I'm thinking of buying one here post-Christmas, but guess I ought not for now.
2015-12-26
nialldoherty55
Flight distance : 2075600 ft
wordsaremything Posted at 2015-12-25 21:55
I tried to go back to the old firmware and that failed as well. Now the OSMOS doesn't work at all. I ...
me too no wifi can't go back to old f/w
2015-12-26
nialldoherty55
AAAAAAAAAAAHHHHHHHHHHHHHHHHHH anyone found a fix yet my osmo now a brick
2015-12-26
sdhp
Whew - That was really annoying...
My upgrade said on the smartphone that it's stuck at 96% and therefore no connection to the camera possible.
Solution for me was to
a) Do the reset with "trigger+recording button+power switch"
b) not only get out of DJI-Go-App but really close it << important!
c) switch off the Osmo
d) start the regular logon-process as it used to be
And then finally I regained control.
I have to say that the bad feeling of losing such an expensive toy to a firmware-upgrade
is something the company DJI should take much more serious when firmware-updates are rolled out.
That rollercoaster of feelings ranging from fear, sadness and pure anger are not good for DJIs reputation - at all.
It would be a clever step to test those updates very well, with at least the tipical setups the customers use.
2015-12-26
andreib
Russia
No i didn't !
2015-12-26
krskyeyedrone
this is fucking joke !!!!!!!!!!!!!!
2015-12-26
wordsaremything
I have tried everything listed above multiple times and still get nothing.  The OSMO was already lackluster and now it doesn't work at all. Don't you test these updates on multiple products before releasing? What a catastrophe or are you playing some cruel joke on all your loyal customers who bought into this piece of useless camera equipment?
2015-12-26
R&L Aerial
Flight distance : 298100 ft
mmccurdy Posted at 2015-12-25 23:29
There's a new post that say all your osmos  are now broken and send them in for repair. Are they #>€£**€! Serious????? Dji has got to hire some new, better help.
2015-12-26
R&L Aerial
2015-12-26
jennings93
Flight distance : 820102 ft
R&amp;L  Aerial Posted at 2015-12-27 07:13
There's a new post that say all your osmos  are now broken and send them in for repair. Are they # ...
I did the firware update and have all the same problems. I have tried everything including roll back but nothing fixes the wi fi module disaster.
The Osmo actually still works ie it records video and stills and does the usual gimble stuff but no connection to the phone so yu cannot see what you are taking, also no access to settings.
I live in Australia and I suppose this means shipping it to China????####
2015-12-26
Skyrider
Banned
2015-12-26
R&L Aerial
jennings93@gmai Posted at 2015-12-26 16:00
I did the firware update and have all the same problems. I have tried everything including roll ba ...
Yup, and the will fix it and send it back, will take about 6 weeks
2015-12-26
Skyrider
Banned
2015-12-26
setiawan3d
Indonesia
Ok, I renamed the old 'wifi-problematic' firmware, and download the new one,and I noticed the newer fixed one is smaller size.
The older one is 33.8 MB zipped, 73.0 MB .bin uncompressed, dated Dec. 25th 2015 6:56 PM
while the NEW one is 32.77 MB zipped, 72.9 MB .bin uncompressed, dated Dec. 26th 2015 5:33 PM
Hope my post can help noticing the differences.
Set
(sorry for a bit -spamming-like, but I guess I better do this in order to spot the difference of firmware!)
Still, need assurance before proceed on updating.
2015-12-26
DJI-Tim
Dear users,  If you having  wifi connection issue, please check this thread http://forum.dji.com/thread-38018-1-1.html
Thank you!
2015-12-26
LenMiddx
DJI-Tim Posted at 2015-12-27 03:28
Dear users,  If you having  wifi connection issue, please check this thread http://forum.dji.com/thr ...
Maybe future models of the OSMO should have a 'reset' button to reset the device back to a basic and well-tested 'factory fresh' version of the firmware? That would get around the problem of people having to return their device and lose a couple of weeks of use.
2015-12-27
alansworld
Flight distance : 27434 ft
LenMiddx Posted at 2015-12-27 13:52
Maybe future models of the OSMO should have a 'reset' button to reset the device back to a basic a ...
Yes, a good idea.  But clearly in DJI the words 'well tested' have unfortunately been omitted from the company dictionary.
2015-12-27
12Next >
