bornish
Flight distance : 91447 ft
United Arab Emirates
Hi Alan!
I like the way you think.
I have tried recording a timelapse with a 3rd party car-camera mount the first day owning the OSMO.
The results were not great but was pretty impressed with the results. I do not think that using the bike mount in between a car mount and the OSMO to benefit from the shock absorber would really bring much in off-road conditions and on a normal road I did not feel is required as the camera movement is quite smooth.
I had no time yet since purchasing the OSMO but planning to build a few custom mounts of myself:
- car / bike mount with magnetic shocks
- shoulder / chest mount for tracking / hiking
- quick release mounts (magnetic / clip microphone-type) for tripod stands... already found a mic-type stand which can be adapted to clip the OSMO to a tripod
Also, custom mounts can be built for attaching peripherals to the OSMO, like video light and external microphone. Others have already attached such peripherals in so many ways (ex: phone sunshade with mic) and I am already using an O-ring with a light metallic arm to attach an external light or mic directly between the phone mount and the OSMO.
I do plan to customize a BOYA stereo self powered mic by changing its plastic enclosure, in order to attach it directly to the 3.5mm port and secure it to the handle, thus not requiring an additional mount and extension rod attached, having a rather bulky setup as per DJI's design. This is how DJI should've implement the audio solution anyway, by providing an optional external mic to the OSMO, since the internal mic is completely useless. What I love about this BOYA mic when compared to other suggested recommended units to be used with OSMO is that has 2 output ports (one for camera and another for headphones or additional sound recorder), while also providing a volume gain dial, -10db sound attenuation toggle and 2-step high pass filter toggle... all in a very small sized board with 2 adjustable sensors allowing 90/120 degrees of stereo recording.
Best regards,
Bogdan |
