Osmo cant live screen and take video
1233 13 2015-12-27
shandy_jtf
Indonesia
I wonder is there anyone had this kind problem too? How should i fix this?
I can still control the gimbal with joystick and device but the image didnt show up, and event cant take video nor photo
Its like the camera didnt connect, because i cant change camera setting
Indicator light both were solid green
I already try to turn off and on the osmo few times but nothing happen.
Firmware still stock from dji
Sorry for bad english
Why ist so hard to post image from dji app?
2015-12-27
shandy_jtf
Indonesia
[/URL[/img]
[/URL[/img]
2015-12-27
shandy_jtf
Indonesia
[/URL[/img]
.html][/URL
2015-12-27
shandy_jtf
Indonesia
[/URL[/img]
.html][/URL
2015-12-27
shandy_jtf
Indonesia
[/URL[/img]
2015-12-27
teamnest1
Flight distance : 18484 ft
Did you connect it with Wifi, and what type of device are you using.
2015-12-27
setiawan3d
Flight distance : 7861 ft
Indonesia
Try also restart your phone.
I had this too sometimes ago, and just by restarting the phone, I can finally connect.
btw, what is your phone's model?
2015-12-27
shandy_jtf
Indonesia
setiawan3d Posted at 2015-12-27 21:46
I had this too sometimes ago, and just by restarting the phone, I can  ...
Already try it, but still didn't show the image.
Actually i got this kind issue few times ago,  with just restart osmo and device it will normal again,
But this this time I guess didn't work
My device that i try is, iphone 5s, iphone 6 and ipad mini 3
2015-12-27
setiawan3d
Indonesia
Your Osmo firmware version?
2015-12-27
shandy_jtf
Indonesia
Its still same from base osmo
1.0.1.19+ i try to update with placing update file on root but its like the osmo didn't do anything
2015-12-27
DJI-Amy
Hi, what micro SD card did you use?Left LED light becomes solid yellow means : Micro SD card error.
1) Please format the SD card in the app. Check if the SD card is full in the PC. 2)Please try to take out the SD card see if the camera feed recovered.
3) Please try to use the original SD card and test different SD cards. The SD card needs to be class 10 or UHS-1 above and maximum capacity is 64GB.
2015-12-27
shandy_jtf
Indonesia
DJI-Amy Posted at 2015-12-28 14:37
Hi, what micro SD card did you use?Left LED light becomes solid yellow means : Micro SD card error.  ...
I'm using lexar 16gb micro sd that comes with osmo,
I already try to format micro SD via App but it's say "memory time out"
I see , i will try with another micro SD today
Thanks
2015-12-28
DJI-Amy
shandy_jtf Posted at 2015-12-29 10:18
I already try to format micro SD via App but i ...
Please provide a screenshot of your app , setting->general->about->firmware versions.
2015-12-28
shandy_jtf
Indonesia
DJI-Amy Posted at 2015-12-29 13:32
I already returned the Osmo to retail yesterday,
The firmware version is 1.0.1.19+
2015-12-29
