DJI OSMO 2 (development of a new version of the device)
9387 15 2015-12-29
ROSTOVisualFX
Flight distance : 123104 ft
Russia
Collect suggestions for the new version.
What to change or add in the new version of DJI OSMO:
1. To make the centering of the lens to the nodal point of the lens in any direction the camera was always at the same point. This is necessary to avoid the Parallax effect when shooting panoramas.
2. To make the possibility of connection of external power, including external battery, for example, to shoot timelapse with clouds. And then half an hour and the battery is low — is not serious for Timelaps shooting.
3. The mount for the phone to place based on the centre of the balance handle, and taking into account the wide angle camera rotate 360 degrees.
(But now even a thin and light phone like the SGS 4, very tilt the handle to the left, creating discomfort for the hands.
Secondly when you rotate the camera - in a frame falls is Phone Holder.)
4. Shooting 4k video 50/60p 150 Mbps.
5. LARGER cooling fan in the camera, and we had the impression that in the first version of OSMO find the smallest fan from available.
6. It is better not to put the microphone than to put such as in OSMO I. Save on cost and save the reputation. Leave only connector for external microphone.
7. Add protection from splashing water, protection from raindrops, protection from snowflakes. (Protection against immersion in water is not required.)
Please convey to the developers the proposals for improvement of the DJI Osmo.
Offer all forum users will join and support our ideas or suggest your ideas.
2015-12-29
mikegil
Flight distance : 32730 ft
They need to get the current one upto standard before people start to discuss what should be on the Osmo 2
2015-12-29
R&L Aerial phot
Flight distance : 298100 ft
mikegil Posted at 2015-12-29 14:02
They need to get the current one upto standard before people start to discuss what should be on the  ...
I agree, if they are working on the osmo 2 take that team and make them work on the osmo 1 until that actually works as advertised.
2015-12-29
sdchew
Singapore
Yeah I'm in favor they work more on the current system too. Spitting out an Osmo 2 so soon after the current version will only cause us early adopters of the current Osmo to loose faith with DJI.
2015-12-29
setiawan3d
Flight distance : 7861 ft
Indonesia
Better camera lens with focus changing capability.
Agree totally with #2. external battery or higher-capacity battery.
#5: Instead of fan-cooling system, combining a heat-sink capability can also work.
2015-12-29
kgarrison
Flight distance : 11736709 ft
setiawan3d Posted at 2015-12-30 07:19
Agree totally with #2. external battery or highe ...
That is coming with the X5
2015-12-29
setiawan3d
Indonesia
Correct. X5 has interchangeable lens capability & larger sensor, but that's not cheap to me.
So, what I'm thinking here, fix lens with focusing ability. Not interested with having bokeh (also, X3's 1/2.3" is still a smaller sensor), but at least we can do more closeup shots with Osmo.
Like what I did previously in this clip: http://forum.dji.com/thread-35949-1-1.html
Osmo is already 'small enough' compared to other camera+gimbal, so why not having this capability.
2015-12-29
ke-now
Oh dear. I forgot about the nodal point. So the Osmo will not be suitable for 360 panoramas, even if they add this in future firmware. Nice catch.
All of your suggestions are good ones. Watch out for Osmo 2 in 12 to 24 months!
I actually use the Osmo without my phone attached. I just guess the framing, or sometimes I hold the phone in my other hand, frame the shot, then put my phone in my pocket! It's more discrete without phone attached, and better balanced and nicer to hold. Wide angle lens means guessing the correct framing is possible with some practice.
2015-12-30
LMahesa
Flight distance : 3520 ft
Indonesia
ke-now Posted at 2015-12-30 19:24
Oh dear. I forgot about the nodal point. So the Osmo will not be suitable for 360 panoramas, even if ...
I'm the same, set up with the phone then proceed without it. I always render my finals in 1080p, and 4K gives me a LOT of leeway for cropping without sacrificing quality.
2015-12-30
LMahesa
Indonesia
Can someone ELI5 what the nodal point is and how it affects panoramas? Does it affect other shooting modes and/or video, and does the GoPro 3/4 have the same issue?
2015-12-30
job.genders
I can say: i want a bad microphone in a Osmo because when you are recording video and audio, it's easy to synch it later (especially with Pluraleyes) and the complete lacking of audio in the initial recording will make everything much more complicated. So leaving it completly out will NOT be an option. But i wont buy anything from DJI soon. Maybe never.
2015-12-31
ROSTOVisualFX
Russia
R&L Aerial phot Posted at 2015-12-29 23:24
I agree, if they are working on the osmo 2 take that team and make them work on the osmo 1 until t ...
Dear mikegil and R&L Aerial phot - If You think that the first version of the DJI OSMO still have something to Refine - then see this thread: Improving the first version of the DJI OSMO, where I made a small collection of just over 20 enhancements for DJI Osmo 1.We will be glad, if You'll find that I forgot to mention and leave Your suggestion what else can be modified in DJI OSMO 1.
sdchew, right now I would have bought a new DJI Osmo 2 if it were implemented at least 3, 4 and 7 points from my list of innovations.
job.genders, I meant to leave only a connector to connect an external microphone, because the integrated is not even fit for the guide, believe me.
2015-12-31
fansbf038726
Russia
2 Item was unexpectedly implemented for OSMO 1
4 Item is obvious will be also made in OSMO 2 as a new camera to Inspire 2 shoots as requested.
But, please increase the bitrate! 100 Mbps for 4K 60p is too small! Make at least 150 Mbps.
Don't confuse megabits with megabytes. 1 megabyte = 8 megabits. Here 150/8=18.7 megabyte per second and the speed to handle any modern UHS-I U3 card.
2017-4-25
dessimondboris
I would like to see a dual camera like on the iphone. For wide and close shots (macros?)
Since it's not an interchangeable lenses system..
An integraded ND filter or the possibility to mount ND?
... A better DR!
To me it's much important than 4K or anything else.
2017-8-8
felipereis50
Brazil
Filming in 180 degree with 3D effect
2017-8-9
fansbf038726
Russia
You here posts nonsense up? Camera for DJI OSMO 2 for a long time — there is a camera for the Inspire 2. It remains to adapt to it the handle.
2017-8-16
