ROSTOVisualFX
Flight distance : 123104 ft
Russia
Inspire 1 (Something to work on)
1. QR-Mat increases the accuracy of the landing. Design a special Mat, which Inspire the positional camera can recognize at a distance, and to position landing focusing on this Mat. This will significantly increase the accuracy of the landing, in conditions of poor GPS reception at low altitude.
2. The ability to set limits the maximum speed depending on the height above the ground Inspire. (For example when the height is below 1 meter, I would set the limit at 0.5 m/s, up to 3M 0.7 m/s to 5m 1m/s.)
3. To design a system to prevent midair collisions with other quadcopters own production (Phantom and Inspire are supposed to broadcast in the open to receive other quadrocopters, (but also the brand DJI) information about your quadrocopter location, and copters should share this information directly and to take action to avoid collision (it is necessary to solve, who to whom should concede if the routes intersect Inspire-Phantom, Phantom there clearly has to give, and if you intersect two Phantom Inspire one or two versions, then who must yield to whom?))
4. To do the advanced calculation of the battery to return home. that is to mark the points at which the route will pass to the right was the calculation of the remaining charge, for a given route. (Explain, by default, the battery calculates the return from a straight the shortest way, but there are situations like flying over the river and back, over the river blows a very strong wind, and keep in mind that the route will be on the triangle.)
Please convey to the developers the proposals for improvement of the DJI Osmo.
Offer all forum users will join and support our ideas or suggest your ideas.
